05-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10205-IP Multicast Command Reference
02-MLD Snooping Commands
02-MLD Snooping Commands 135.87 KB
MLD snooping configuration commands
display mld-snooping group
Use display mld-snooping group to display MLD snooping group information, including both dynamic and static MLD snooping group entries.
display mld-snooping group [ vlan vlan-id ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
vlan vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094. If you do not specify a VLAN, this command displays MLD snooping group information in all VLANs.
verbose: Displays detailed MLD snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display detailed MLD snooping group information in VLAN 2.
<Sysname> display mld-snooping group vlan 2 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port(s):total 1 port(s).
            GE1/0/2                (D) ( 00:01:30 )
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:FF1E::101
        (::, FF1E::101):
          Attribute:    Host Port
          Host port(s):total 1 port(s).
            GE1/0/1                (D) ( 00:03:23 )
    MAC group(s):
        MAC group address:3333-0000-0101
            GE1/0/1
Total 1 IP Group(s)
Total number of IPv6 multicast groups.
Total number of IPv6 multicast sources.
Total number of MAC multicast groups.
Port flags:
·     D—Dynamic port.
·     S—Static port.
·     C—Port copied from a (*, G) entry to an (S, G) entry.
·     P—Port that IPv6 PIM snooping adds.
Sub-VLAN flags:
·     R—Real egress sub-VLAN under the current entry.
·     C—Sub-VLAN copied from a (*, G) entry to an (S, G) entry.
Router port(s)
Number of router ports.
( 00:01:30 )
Remaining time of the aging timer for the dynamic member port or router port.
IP group address
Address of IPv6 multicast group.
MAC group address
Address of MAC multicast group.
Attribute
Attribute of IPv6 multicast group.
Host port(s)
Number of member ports.
display mld-snooping host
Use display mld-snooping host to display information about the hosts tracked by MLD snooping.
display mld-snooping host vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group ipv6-group-address: Specifies an IPv6 multicast group. The value range for the ipv6-group-address argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where x and y represent any hexadecimal numbers from 0 to F.
source ipv6-source-address: Specifies an IPv6 multicast source.
# Display information about the hosts tracked by MLD snooping in multicast group FF1E::101 in VLAN 2.
<Sysname> display mld-snooping host vlan 2 group ff1e::101
VLAN(ID) : 2
  (::, FF1E::101)
    Port : GE1/0/1
      Host                                    Uptime          Expires
      1::1                                    00:02:20        00:00:40
      2::2                                    00:02:21        00:00:39
    Port : GE1/0/2
      Host                                    Uptime          Expires
      3::3                                    00:02:20        00:00:40
VLAN(ID)
VLAN ID.
(::, FF1E::101)
(S, G) entry, where double colon (::) means all IPv6 multicast sources.
Port
Member port.
Host
Host IPv6 address.
Uptime
Host running duration.
Expires
Host expiration time, where "timeout" means that the host has expired.
display mld-snooping statistics
Use display mld-snooping statistics to display the statistics for MLD messages learned through MLD snooping.
display mld-snooping statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display statistics for all MLD messages learned through MLD snooping.
<Sysname> display mld-snooping statistics
  Received MLD general queries:0.
  Received MLDv1 specific queries:0.
  Received MLDv1 reports:0.
  Received MLD dones:0.
  Sent     MLDv1 specific queries:0.
  Received MLDv2 reports:0.
  Received MLDv2 reports with right and wrong records:0.
  Received MLDv2 specific queries:0.
  Received MLDv2 specific sg queries:0.
  Sent     MLDv2 specific queries:0.
  Sent     MLDv2 specific sg queries:0.
  Received error MLD messages:0.
general queries
General query messages.
specific queries
Multicast-address-specific query messages.
reports
Report messages.
dones
Done messages.
Reports that contain correct and incorrect records.
specific sg queries
Multicast-address-and-source-specific queries.
error MLD messages
Error MLD messages.
dot1p-priority (MLD-snooping view)
Use dot1p-priority to set the 802.1p precedence for MLD messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority-number
undo dot1p-priority
The default 802.1p precedence for MLD messages is 0.
MLD-snooping view
2: System level
priority-number: Specifies an 802.1p precedence for MLD messages, in the range of 0 to 7. A higher value means a higher precedence.
# Set the 802.1p precedence for MLD messages to 3 globally.
[Sysname] mld-snooping
[Sysname-mld-snooping] dot1p-priority 3
drop-unknown (MLD-snooping view)
Use drop-unknown to enable dropping unknown IPv6 multicast data globally.
Use undo drop-unknown to disable dropping unknown IPv6 multicast data globally.
drop-unknown
undo drop-unknown
This function is disabled, and unknown IPv6 multicast data is flooded in the VLAN.
MLD-snooping view
2: System level
# Globally enable the device to drop unknown IPv6 multicast data.
[Sysname-mld-snooping] drop-unknown
mld-snooping drop-unknown
fast-leave (MLD-snooping view)
Use fast-leave to enable fast-leave processing globally. With this function enabled, when the AC receives an MLD done message on a port, it directly removes that port from the forwarding table entry for the specific IPv6 multicast group.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
MLD-snooping view
2: System level
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command takes effect on all VLANs. If you specify multiple VLANs, the command takes effect on only the specified VLANs.
# Enable fast-leave processing globally for VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
mld-snooping fast-leave
group-policy (MLD-snooping view)
Use group-policy to configure a global IPv6 multicast group filter to control the IPv6 multicast groups that the hosts in a VLAN can join.
Use undo group-policy to remove the configured global IPv6 multicast group filter.
group-policy acl6-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
No IPv6 multicast group filter is configured globally, and a host in any VLAN can join a valid IPv6 multicast group.
MLD-snooping view
2: System level
acl6-number: Specifies a basic or advanced IPv6 ACL number, in the range of 2000 to 3999.
If the specified IPv6 ACL does not exist or the ACL rule is null, all IPv6 multicast groups are filtered out.
You can configure different IPv6 ACL rules for each port in different VLANs. For a given VLAN, a newly configured IPv6 ACL rule overrides the existing one.
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts in VLAN 2 can join FF03::101 only.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source ff03::101 16
[Sysname-acl6-basic-2000] quit
[Sysname-mld-snooping] group-policy 2000 vlan 2
mld-snooping group-policy
host-aging-time (MLD-snooping view)
Use host-aging-time to configure the aging timer for the dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time interval
The aging timer of the dynamic member ports is 260 seconds.
MLD-snooping view
2: System level
interval: Specifies an aging timer in seconds for the dynamic member ports, in the range of 200 to 1000.
# Set the aging timer for the dynamic member ports to 300 seconds globally.
[Sysname-mld-snooping] host-aging-time 300
mld-snooping host-aging-time
host-tracking (MLD-snooping view)
Use host-tracking to enable the MLD snooping host tracking function globally.
Use undo host-tracking to disable the MLD snooping host tracking function globally.
host-tracking
undo host-tracking
This function is disabled.
MLD-snooping view
2: System level
# Enable the MLD snooping host tracking function globally.
[Sysname-mld-snooping] host-tracking
mld-snooping host-tracking
last-listener-query-interval (MLD-snooping view)
Use last-listener-query-interval to set the MLD last-listener query interval globally.
Use undo last-listener-query-interval to restore the default.
The MLD last listener query interval is 1 second.
MLD-snooping view
2: System level
interval: Sets the MLD last-listener query interval in seconds, in the range of 1 to 5.
The MLD last-listener query interval determines the interval for sending MLD multicast-address-specific queries and the maximum response delay for MLD multicast-address-specific queries.
# Set the MLD last-listener query interval to 3 seconds globally.
[Sysname-mld-snooping] last-listener-query-interval 3
mld-snooping last-listener-query-interval
max-response-time (MLD-snooping view)
Use max-response-time to configure the maximum response delay for MLD general queries globally.
Use undo max-response-time to restore the default.
max-response-time interval
The maximum response delay for MLD general queries is 10 seconds.
MLD-snooping view
2: System level
interval: Specifies the maximum response delay in seconds for MLD general queries, in the range of 1 to 25.
# Set the maximum response delay for MLD general queries to 5 seconds globally.
[Sysname-mld-snooping] max-response-time 5
·     mld-snooping max-response-time
·     mld-snooping query-interval
mld-snooping
Use mld-snooping to enable MLD snooping globally and enter MLD-snooping view.
Use undo mld-snooping to disable MLD snooping globally.
mld-snooping
undo mld-snooping
MLD snooping is disabled.
2: System level
# Enable MLD snooping globally and enter MLD-snooping view.
mld-snooping enable
mld-snooping done source-ip
Use mld-snooping done source-ip to configure the source IPv6 address of the MLD done messages that the MLD snooping proxy sends.
Use undo mld-snooping done source-ip to restore the default.
mld-snooping done source-ip { ipv6-address | current-interface }
The source IPv6 address of the MLD done messages that the MLD snooping proxy sends is FE80::02FF:FFFF:FE00:0001.
VLAN view
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD done messages that the MLD snooping proxy sends, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD done messages that the MLD snooping proxy sends. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
You must enable MLD snooping for a VLAN before you configure this command for the VLAN.
The source IPv6 address configured in the mld-snooping done source-ip command also applies when the simulated host sends MLD done messages.
# In VLAN 2, enable MLD snooping and configure the source IPv6 address of MLD done messages that the MLD snooping proxy sends to FE80:0:0:1::1.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping enable
mld-snooping dot1p-priority
Use mld-snooping dot1p-priority to set the 802.1p precedence for MLD messages in a VLAN.
Use undo mld-snooping dot1p-priority to restore the default.
mld-snooping dot1p-priority priority-number
VLAN view
2: System level
# In VLAN 2, enable MLD snooping and set the 802.1p precedence for MLD messages to 3.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping dot1p-priority 3
mld-snooping enable
Use mld-snooping drop-unknown to enable dropping unknown IPv6 multicast data in the VLAN.
Use undo mld-snooping drop-unknown to disable dropping unknown IPv6 multicast data in the VLAN.
This function is disabled, and unknown IPv6 multicast data is flooded.
VLAN view
2: System level
You must enable MLD snooping for a VLAN before you execute this command for the VLAN.
# Enable MLD snooping and the function for dropping unknown IPv6 multicast data in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
·     drop-unknown
·     mld-snooping enable
mld-snooping enable
Use mld-snooping enable to enable MLD snooping for a VLAN.
Use undo mld-snooping enable to disable MLD snooping for a VLAN.
mld-snooping enable
VLAN view
2: System level
You must enable MLD snooping globally before you enable it for a VLAN.
# Enable MLD snooping for VLAN 2.
[Sysname] vlan 2
mld-snooping
Use mld-snooping fast-leave to enable fast-leave processing on a port. With this function enabled, when the AC receives an MLD done message on the port, it directly removes that port from the forwarding table entry for the specific IPv6 multicast group.
Use undo mld-snooping fast-leave to disable fast-leave processing on a port.
undo mld-snooping fast-leave [ vlan vlan-list ]
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
2: System level
Configuration views for this command vary by device models. For more information, see About the H3C Access Controllers Command References.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect on all VLANs to which the interface belongs. If you specify one or multiple VLANs, the command takes effect on the specified VLANs to which the interface belongs.
If you do not specify any VLAN when using this command in port group view, the command takes effect on all the ports in this group. If you specify one or multiple VLANs, the command takes effect only on those ports in this group that belong to the specified VLANs.
# Enable fast-leave processing on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname] interface Gigabitethernet 1/0/1
[Sysname-GigabitEthernet1/0/1] mld-snooping fast-leave vlan 2
fast-leave
mld-snooping general-query source-ip
Use mld-snooping general-query source-ip to configure the source IPv6 address for MLD general queries.
Use undo mld-snooping general-query source-ip to restore the default.
mld-snooping general-query source-ip { ipv6-address | current-interface }
The source IPv6 address of MLD general queries is FE80::02FF:FFFF:FE00:0001.
VLAN view
2: System level
ipv6-address: Specifies the source IPv6 address of MLD general queries, which can be any legal IPv6 link-local address.
current-interface: Sets the source IPv6 link-local address of MLD general queries to the IPv6 address of the current VLAN interface. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used as the source IPv6 address of MLD general queries.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping enable
mld-snooping group-limit
Use mld-snooping group-limit to set the maximum number of IPv6 multicast groups that a port can join.
Use undo mld-snooping group-limit to restore the default.
undo mld-snooping group-limit [ vlan vlan-list ]
The maximum number of IPv6 multicast groups that a port can join is 256.
2: System level
limit: Specifies the maximum number of IPv6 multicast groups that a port can join, in the range of 1 to 256.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range of a VLAN ID is 1 to 4094. If this argument is not specified, the command separately takes effect on all VLANs to which the port belongs.
# Configure the device to allow GigabitEthernet 1/0/1 in VLAN 2 to join up to 10 IPv6 multicast groups.
[Sysname-GigabitEthernet1/0/1] mld-snooping group-limit 10 vlan 2
mld group-limit
Use mld-snooping group-policy to configure an IPv6 multicast group filter on a port to control the IPv6 multicast groups that the hosts on the port can join.
Use undo mld-snooping group-policy to remove the configured IPv6 multicast group filter.
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
No IPv6 multicast group filter is configured on a port, and the hosts on the port can join any valid IPv6 multicast group.
2: System level
# Apply ACL 2000 as an IPv6 multicast group filter so that hosts on GigabitEthernet 1/0/1 in VLAN 2 can join FF03::101 only.
[Sysname-GigabitEthernet1/0/1] mld-snooping group-policy 2000 vlan 2
group-policy
Use mld-snooping host-aging-time to set the aging timer for the dynamic member ports in the current VLAN.
Use undo mld-snooping host-aging-time to restore the default.
mld-snooping host-aging-time interval
The dynamic member port aging timer is 260 seconds.
VLAN view
2: System level
interval: Specifies an aging timer in seconds for the dynamic member ports. The value range is 200 to 1000.
# Enable MLD snooping and set the aging timer for the dynamic member ports in VLAN 2 to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
·     host-aging-time
mld-snooping host-join
Use mld-snooping host-join to configure a port on the AC as a simulated member host for the specified IPv6 multicast group or the specified IPv6 multicast source and group.
Use undo mld-snooping host-join to remove the simulated member host.
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
2: System level
ipv6-group-address: Specifies an IPv6 multicast group. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where x and y represent any hexadecimal numbers from 0 to F.
The source-ip ipv6-source-address option in the command is meaningful only for MLDv2 snooping. If MLDv1 snooping is running, the source-ip ipv6-source-address option does not take effect although you can include source-ip ipv6-source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this feature takes effect only if the interface belongs to the specified VLAN. In port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 1/0/1 in VLAN 2 as a simulated member host for the IPv6 multicast source and group (2002::22, FF1E::101).
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] mld-snooping host-join ff1e::101 source-ip 2002::22 vlan 2
Use mld-snooping host-tracking to enable the MLD snooping host tracking function for a VLAN.
Use undo mld-snooping host-tracking to disable the MLD snooping host tracking function for a VLAN.
VLAN view
2: System level
# Enable MLD snooping and the MLD snooping host tracking function for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-tracking
·     host-tracking
Use mld-snooping last-listener-query-interval to set the MLD last-listener query interval for a VLAN.
Use undo mld-snooping last-listener-query-interval to restore the default.
The MLD last-listener query interval is 1 second.
VLAN view
2: System level
The MLD last-listener query interval determines the interval for sending MLD multicast-address-specific queries and the maximum response delay for MLD multicast-address-specific queries in a VLAN.
# Enable MLD snooping and set the MLD last-listener query interval to 3 seconds for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
·     last-listener-query-interval
Use mld-snooping max-response-time to set the maximum response delay for MLD general queries in the VLAN.
Use undo mld-snooping max-response-time to restore the default.
mld-snooping max-response-time interval
VLAN view
2: System level
# Enable MLD snooping and set the maximum response delay for MLD general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
·     max-response-time
mld-snooping overflow-replace
Use mld-snooping overflow-replace to enable the IPv6 multicast group replacement function on a port.
Use undo mld-snooping overflow-replace to disable the IPv6 multicast group replacement function on a port.
undo mld-snooping overflow-replace [ vlan vlan-list ]
The IPv6 multicast group replacement function is disabled.
2: System level
# Enable the IPv6 multicast group replacement function on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping overflow-replace vlan 2
overflow-replace
mld-snooping proxying enable
Use mld-snooping proxying enable to enable the MLD snooping proxying function for a VLAN.
Use undo mld-snooping proxying enable to disable the MLD snooping proxying function for a VLAN.
MLD snooping proxying is disabled in all VLANs.
VLAN view
2: System level
# Enable MLD snooping and MLD snooping proxying for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping proxying enable
mld-snooping enable
mld-snooping querier
Use mld-snooping querier to enable the MLD snooping querier function.
Use undo mld-snooping querier to disable the MLD snooping querier function.
The MLD snooping querier function is disabled.
VLAN view
2: System level
This command takes effect only if MLD snooping is enabled in the VLAN.
# Enable MLD snooping and the MLD snooping querier function for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
mld-snooping enable
Use mld-snooping query-interval to set the MLD query interval.
Use undo mld-snooping query-interval to restore the default.
The MLD query interval is 125 seconds.
VLAN view
2: System level
interval: Specifies an MLD query interval in seconds, namely, the interval for sending MLD general queries. The value range for this argument is 2 to 300.
# Enable MLD snooping and set the MLD query interval to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
·     max-response-time
·     mld-snooping querier
mld-snooping report source-ip
Use mld-snooping report source-ip to configure the source IPv6 address for the MLD reports that the MLD snooping proxy sends.
Use undo mld-snooping report source-ip to restore the default.
mld-snooping report source-ip { ipv6-address | current-interface }
The source IPv6 address of the MLD reports that the MLD snooping proxy sends is FE80::02FF:FFFF:FE00:0001.
VLAN view
2: System level
ipv6-address: Specifies a source IPv6 address for the MLD reports that the MLD snooping proxy sends, which can be any legal IPv6 link-local address.
current-interface: Specifies the IPv6 link-local address of the current VLAN interface as the source address of MLD reports that the MLD snooping proxy sends. If no IPv6 address has been assigned to the current interface, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used.
The source IPv6 address configured in the mld-snooping report source-ip command also applies when the simulated host sends MLD reports.
# In VLAN 2, enable MLD snooping and configure the source IPv6 address for the MLD reports that the MLD snooping proxy sends to FE80:0:0:1::1.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping enable
mld-snooping router-aging-time
Use mld-snooping router-aging-time to set the aging timer for the dynamic router ports in the current VLAN.
Use undo mld-snooping router-aging-time to restore the default.
mld-snooping router-aging-time interval
The dynamic router port aging timer is 260 seconds.
VLAN view
2: System level
interval: Specifies an aging timer in seconds for the dynamic router ports, in the range of 1 to 1000.
# Enable MLD snooping and set the aging timer for the dynamic router ports in VLAN 2 to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
·     router-aging-time
mld-snooping router-port-deny
Use mld-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo mld-snooping router-port-deny to restore the default.
undo mld-snooping router-port-deny [ vlan vlan-list ]
A port can become a dynamic router port.
2: System level
# Disable GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet1/0/1] mld-snooping router-port-deny vlan 2
mld-snooping special-query source-ip
Use mld-snooping special-query source-ip to configure the source IPv6 address of MLD multicast-address-specific queries.
Use undo mld-snooping special-query source-ip to restore the default.
mld-snooping special-query source-ip { ipv6-address | current-interface }
The source IPv6 address of MLD multicast-address-specific queries is FE80::02FF:FFFF:FE00:0001.
VLAN view
2: System level
ipv6-address: Specifies an IPv6 link-local address as the source IPv6 address of MLD multicast-address-specific queries.
current-interface: Specifies the source IPv6 link-local address of the VLAN interface of the current VLAN as the source IPv6 address of MLD multicast-address-specific queries. If the current VLAN interface does not have an IPv6 address, the default IPv6 address FE80::02FF:FFFF:FE00:0001 is used as the source IPv6 address of MLD multicast-address-specific queries.
# In VLAN 2, enable MLD snooping and specify FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
mld-snooping enable
mld-snooping static-group
Use mld-snooping static-group to configure a port as a static member port of an IPv6 multicast group or an IPv6 multicast source and group.
Use undo mld-snooping static-group to restore the default.
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
A port is not a static member port.
2: System level
# Configure GigabitEthernet 1/0/1 in VLAN 2 as a static member port for the IPv6 multicast source and group (2002::22, FF1E::101).
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] mld-snooping static-group ff1e::101 source-ip 2002::22 vlan 2
mld-snooping static-router-port
Use mld-snooping static-router-port to configure a port as a static router port.
Use undo mld-snooping static-router-port to restore the default.
undo mld-snooping static-router-port vlan vlan-id
No ports are static router ports.
2: System level
# Configure GigabitEthernet 1/0/1 in VLAN 2 as a static router port.
[Sysname-GigabitEthernet1/0/1] mld-snooping static-router-port vlan 2
Use mld-snooping version to specify the version of MLD snooping.
Use undo mld-snooping version to restore the default.
The MLD snooping version is MLDv1.
VLAN view
2: System level
version-number: Specifies an MLD snooping version, in the range of 1 to 2.
This command can take effect only if MLD snooping is enabled in the VLAN.
# Enable MLD snooping and specify MLDv2 snooping in VLAN 2.
[Sysname] vlan 2
mld-snooping enable
overflow-replace (MLD-snooping view)
Use overflow-replace to enable the IPv6 multicast group replacement function globally.
Use undo overflow-replace to disable the IPv6 multicast group replacement function globally.
undo overflow-replace [ vlan vlan-list ]
The IPv6 multicast group replacement function is disabled globally.
MLD-snooping view
2: System level
# Enable the IPv6 multicast group replacement function globally in VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
report-aggregation (MLD-snooping view)
Use report-aggregation to enable MLD report suppression.
Use undo report-aggregation to disable MLD report suppression.
report-aggregation
MLD report suppression is enabled.
MLD-snooping view
2: System level
# Disable MLD report suppression.
[Sysname-mld-snooping] undo report-aggregation
reset mld-snooping group
Use reset mld-snooping group to remove the dynamic group entries of a specified MLD snooping group.
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
2: System level
all: Specifies all IPv6 multicast groups.
This command cannot remove the static group entries of MLD snooping groups.
# Remove the dynamic group entries of all MLD snooping groups.
<Sysname> reset mld-snooping group all
reset mld-snooping statistics
Use reset mld-snooping statistics to clear statistics for the MLD messages learned through MLD snooping.
2: System level
# Clear the statistics for all MLD messages learned through MLD snooping.
<Sysname> reset mld-snooping statistics
router-aging-time (MLD-snooping view)
Use router-aging-time to set the aging timer for the dynamic router ports globally.
Use undo router-aging-time to restore the default.
MLD-snooping view
2: System level
# Set the aging timer for the dynamic router ports to 100 seconds globally.
[Sysname-mld-snooping] router-aging-time 100
