| 00-Preface | 113.17 KB |
Preface
This command reference describes IP multicast configuration commands.
The IP Multicast Command Reference describes the configuration commands for IGMP snooping, MLD snooping, multicast VLAN, and IPv6 multicast VLAN.
NOTE: Support of the H3C access controllers for commands might vary by device model. For the command matrixes, see About the H3C Access Controllers Command References. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
