05-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10205-IP Multicast Command Reference
03-Multicast VLAN Commands
03-Multicast VLAN Commands 34.29 KB
Multicast VLAN configuration commands······································· 1
display multicast-vlan······································································································ 1
multicast-vlan················································································································· 1
port (Multicast VLAN view)······························································································· 2
port multicast-vlan··········································································································· 3
Use display multicast-vlan to display information about the specified multicast VLAN.
display multicast-vlan [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
vlan-id: Specifies a multicast VLAN by its ID, in the range of 1 to 4094. If this argument is not specified, this command displays information about all multicast VLANs.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about all multicast VLANs.
<Sysname> display multicast-vlan
 Total 1 multicast-vlan(s)
 Multicast vlan 100
   subvlan list:
    vlan 2  4-6
   port list:
    WLAN-ESS1
Total number of multicast VLANs.
port list
Port list of the multicast VLAN.
multicast-vlan
Use multicast-vlan to configure the specified VLAN as a multicast VLAN and enter multicast VLAN view.
Use undo multicast-vlan to remove the specified VLAN as a multicast VLAN.
multicast-vlan vlan-id
undo multicast-vlan { all | vlan-id }
No VLAN is configured as a multicast VLAN.
2: System level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
all: Specifies all multicast VLANs.
The specified VLAN to be configured as a multicast VLAN must exist.
The multicast VLAN feature cannot be enabled on a device with IP multicast routing enabled.
For a port-based multicast VLAN, you must enable IGMP snooping in both the multicast VLAN and all the VLANs that contain the multicast data receivers.
# Enable IGMP snooping in VLAN 100. Configure it as a multicast VLAN and enter multicast VLAN view.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] igmp-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan 100
[Sysname-mvlan-100]
Use port to assign the specified ports to the current multicast VLAN.
Use undo port to remove the specified ports from the current multicast VLAN.
port interface-list
undo port { all | interface-list }
A multicast VLAN has no ports.
Multicast VLAN view
2: System level
interface-list: Specifies a space-separated list of interface items. Each item specifies an interface or an interface list in the format of start-interface-type interface-number to end-interface-type interface-number. The interface-type interface-number argument specifies an interface by its type and number.
all: Specifies all the ports in the current multicast VLAN.
A port can belong to only one multicast VLAN.
You can assign Ethernet ports, WLAN-ESS interfaces, and WLAN-MESH interfaces as multicast VLAN ports.
# Assign ports WLAN-ESS 2 through WLAN-ESS 3 to multicast VLAN 100.
[Sysname-mvlan-100] port WLAN-ESS 2 to WLAN-ESS 3
port multicast-vlan
Use port multicast-vlan to assign the current port to the specified multicast VLAN.
Use undo port multicast-vlan to restore the default.
port multicast-vlan vlan-id
A port does not belong to any multicast VLAN.
Ethernet interface view, WLAN-ESS interface view, Layer 2 aggregate interface view, port group view.
2: System level
# Assign WLAN-ESS 1 to multicast VLAN 100.
[Sysname] interface WLAN-ESS 1
[Sysname-WLAN-ESS1] port multicast-vlan 100
