H3C WX3024E Wireless Switch Installation Guide-6W106
HomeSupportWirelessWX3000E Series Wireless SwitchesInstall & UpgradeInstallation GuidesH3C WX3024E Wireless Switch Installation Guide-6W106
03-Appendix B Transceiver Module Specifications
03-Appendix B Transceiver Module Specifications 101.20 KB
The WX3024E provides the following transceiver modules:
·           GE SFP transceiver modules
·           XFP-SX-MM850 transceiver module
·           XFP-LX-SM1310 transceiver module
·       Transceiver modules are optional components and are not supplied with the WX3024E. Use H3C-recommended transceiver modules.
·       The WX3024E supports all XFP transceiver modules except those requiring power supplies with negative voltage.
Figure 1 Appearance of a GE SFP transceiver module
图-1副本
Table 1 GE SFP transceiver module specifications
Item
Specifications
SFP-GE-SX-MM850-A
SFP-GE-LX-SM1310-A
Central wavelength
850 nm
1310 nm
Maximum transmission distance
550 m (1804.46 ft)
10 km (6.21 miles)
Data rate
1250 Mbps
1250 Mbps
Connector type
Duplex LC
Duplex LC
Fiber mode
MMF
SMF
Cable specification
50/125 µm
9/125 µm
Output optical power
–9.5 to 0 dBm
–9.5 to –3 dBm
Receiving sensitivity
≤ –17 dBm
≤ –20 dBm
Optical saturation
≤ –3 dBm
≤ –3 dBm
Figure 2 Appearance of XFP transceiver modules
Table 2 XFP transceiver module specifications
Item
Specifications
XFP-SX-MM850
XFP-LX-SM1310
Central wavelength
850 nm
1310 nm
300 m (984.25 ft)
10 km (6.21 miles)
Data rate
10.31 Gbps
10.31 Gbps
Connector type
Duplex LC
Duplex LC
Fiber Mode
MMF
SMF
Cable specification
50/125 µm
9/125 µm
Fiber bandwidth
2000 MHz*km
–7.3 to –1.08 dBm
–8.2 to +0.5 dBm
≤ –11.1 dBm
≤ –12.6 dBm
Pressure sensitivity
≤ –7.5 dBm
≤ –10.3 dBm
Optical saturation
≤ –1 dBm
≤ 0.5 dBm
