H3C WX3024E Wireless Switch Installation Guide-6W106
HomeSupportWirelessWX3000E Series Wireless SwitchesInstall & UpgradeInstallation GuidesH3C WX3024E Wireless Switch Installation Guide-6W106
00-Preface
00-Preface 48.07 KB
Preface
The H3C WX3024E Wireless Switch Installation Guide describes preparing for installation, installing the switch, starting and configuring the switch, troubleshooting, transceiver module specifications, and software maintenance of the WX3024E wireless switch.
This preface includes:
·           Audience
·           Conventions
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the WX3024E
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
We appreciate your comments.
