H3C WX2540E Access Controller Installation Guide-6W102
HomeSupportWirelessH3C WX2500E Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX2540E Access Controller Installation Guide-6W102
00-Preface
00-Preface 56.24 KB
Preface
The H3C WX2540E Access Controller Installation Guide describes preparing for installation, installing the access controller, troubleshooting, and hardware management and maintenance of the WX2540E access controller.
This preface includes:
·           Audience
·           Conventions
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the WX2540E
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
We appreciate your comments.
