- 05-Layer 3-IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 IS-IS configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
| 07-Policy-based routing configuration | 96.58 KB |
Configuring match criteria for a node
Configuring actions for a node
Displaying and maintaining PBR
Configuring PBR
Overview
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify the next hop for packets that match specific criteria such as ACLs.
A device forwards received packets using the following process:
1. The device uses PBR to forward matching packets.
2. If the packets do not match the PBR policy or the PBR-based forwarding fails, the device uses the routing table, excluding the default route, to forward the packets.
3. If the routing table-based forwarding fails, the device uses the default next hop or default output interface defined in PBR to forward packets.
4. If the default next hop or default output interface-based forwarding fails, the device uses the default route to forward packets.
PBR includes local PBR and interface PBR.
· Local PBR guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
· Interface PBR guides the forwarding of packets received on an interface only.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
A policy matches nodes in priority order against packets. If a packet matches the criteria on a node, it is processed by the action on the node. Otherwise, it goes to the next node for a match. If the packet does not match the criteria on any node, it is forwarded according to the routing table.
if-match clause
PBR supports the if-match acl clause to set an ACL match criterion. You can specify only one if-match acl clause for a node.
apply clause
PBR supports the apply next-hop clause to set next hops for packets.
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node? |
Match mode |
Permit |
Deny |
Yes. |
· If the node contains an apply clause, PBR executes the apply clause on the node. It does not match the packet against the next node. · If the node does not contain apply clauses, the packet is forwarded according to the routing table. |
The packet is forwarded according to the routing table. |
No. |
PBR matches the packet against the next node. |
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked next hop.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
PBR configuration task list
Tasks at a glance |
(Required.) Configuring a policy: |
(Required.) Configuring PBR: |
Creating a node
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a node for a policy, and enter policy node view. |
policy-based-route policy-name [ deny | permit ] node node-number |
By default, no policy node is created. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter policy node view. |
N/A |
3. Configure an ACL match criterion. |
if-match acl acl-number { acl-number | name acl-name } |
By default, no ACL match criterion is configured. |
NOTE: An ACL match criterion uses the specified ACL to match packets regardless of the permit or deny action and the time range of the ACL. If the specified ACL does not exist, no packet can match the criterion. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set next hops. |
apply next-hop { ip-address [ direct ] [ track track-entry-number ] }&<1-n> |
By default, no next hop is specified. You can specify multiple next hops for backup by executing this command once or multiple times. You can specify a maximum of two next hops for a node. |
Configuring PBR
Configuring local PBR
Configure PBR by applying a policy locally. PBR uses the policy to guide the forwarding of locally generated packets. The specified policy must already exist. Otherwise, the local PBR configuration fails.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services, such as ping and Telnet. Do not configure local PBR unless doing so is required.
To configure local PBR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Apply a policy locally. |
ip local policy-based-route policy-name |
By default, no policy is locally applied. |
Configuring interface PBR
Configure PBR by applying a policy to an interface. PBR uses the policy to guide the forwarding of packets received on the interface. The specified policy must already exist. Otherwise, the interface PBR configuration fails.
You can apply only one policy to an interface. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
To configure interface PBR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Apply a policy to the interface. |
ip policy-based-route policy-name |
By default, no policy is applied to the interface. |
Task |
Command |
Display PBR policy information. |
display ip policy-based-route [ policy policy-name ] |
Display PBR configuration. |
display ip policy-based-route setup |
Display local PBR configuration and statistics. |
display ip policy-based-route local [ slot slot-number ] |
Display interface PBR configuration and statistics. |
display ip policy-based-route interface interface-type interface-number [ slot slot-number ] |
Clear PBR statistics. |
reset ip policy-based-route statistics [ policy policy-name ] |
PBR configuration examples
Packet type-based local PBR configuration example
Network requirements
As shown in Figure 1, configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2. Switch A forwards other packets according to the routing table.
Configuration procedure
1. Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl number 3101
[SwitchA-acl-adv-3101] rule permit tcp
[SwitchA-acl-adv-3101] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2. Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3. Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
# Telnet to Switch B on Switch A. The operation succeeds.
# Telnet to Switch C on Switch A. The operation fails.
# Ping Switch C from Switch A. The operation succeeds.
Telnet uses TCP and ping uses ICMP. The results show the following:
· All TCP packets sent from Switch A are forwarded to the next hop 1.1.2.2.
· Other packets are forwarded through VLAN-interface 20.
· The local PBR configuration is effective.
Packet type-based interface PBR configuration example
As shown in Figure 2, configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2. Switch A forwards other packets according to the routing table.
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 10.110.0.10 24
[SwitchA-Vlan-interface11] ip policy-based-route aaa
# Create VLAN 10.
[SwitchB] vlan 10
# Configure a static route to subnet 10.110.0.0/24.
[SwitchB] ip route-static 10.110.0.0 24 1.1.2.1
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-Vlan-interface20] quit
[SwitchC] ip route-static 10.110.0.0 24 1.1.3.1
# Configure the IP address 10.110.0.20/24 for Host A, and specify its gateway address as 10.110.0.10.
# On Host A, Telnet to Switch B that is directly connected to Switch A. The operation succeeds.
# On Host A, Telnet to Switch C that is directly connected to Switch A. The operation fails.
# Ping Switch C from Host A. The operation succeeds.
· All TCP packets arriving on VLAN-interface 11 of Switch A are forwarded to next hop 1.1.2.2.
· The interface PBR configuration is effective.
