00-Preface | 21.34 KB |
Preface
This installation guide describes the procedures for installing and removing the VCF OpenStack plug-ins.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with H3C VCF controllers.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
