03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7536P05-6W10003-Layer 2 - LAN Switching Configuration Examples
02-H3C_Ethernet_Link_Aggregation_Configuration_Examples
H3C Ethernet Link Aggregation
H3C_彩色.emf
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 2 link aggregation
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
·     VLAN 10 on Device A can communicate with VLAN 10 on Device B.
·     VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Figure 1 Network diagram
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
·     Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
·     Assign the aggregate interface to VLAN 10 and VLAN 20.
Software version used
This configuration example was created and verified on S7500E-CMW710-R7536P05.
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
·     When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.     Use the display this command in interface view to check the following attribute configurations of the port:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
b.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.     Assign the port to the aggregation group.
·     An aggregation group can operate in static or dynamic mode. You can choose one mode as required.
¡     In a static aggregation group, the aggregation states of the member ports are not affected by the peer ports. Static link aggregation is stable.
¡     In a dynamic aggregation group, the local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
·     In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, H3C recommends using dynamic aggregation.
·     You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1.     Configure Device A:
# Create VLAN 10, and assign port Ten-GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port Ten-GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
¡     Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
 Configuring Ten-GigabitEthernet1/0/1 done.
 Configuring Ten-GigabitEthernet1/0/2 done.
 Configuring Ten-GigabitEthernet1/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
·     Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority  Oper-Key
  XGE1/0/1(R)      S       32768     1
  XGE1/0/2         S       32768     1
  XGE1/0/3         S       32768     1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
·     Link aggregation configuration information when the dynamic aggregation mode is used:
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE1/0/1            S        32768    2        1                      {ACDEF}
  XGE1/0/2            S        32768    3        1                      {ACDEF}
  XGE1/0/3            S        32768    4        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE1/0/1(R)         32768    2        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/0/2            32768    3        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/0/3            32768    4        1        0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
·     Device A:
vlan 10
interface Ten-GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet1/0/5
 port access vlan 20
¡     In the static aggregation mode:
interface Bridge-Aggregation1
¡     In the dynamic aggregation mode:
·     Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Example: Configuring Layer 2 link aggregation in an IRF fabric
On the network as shown in Figure 2, perform the following tasks:
·     Set up a two-chassis IRF fabric at the access layer and a two-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure link aggregation to improve the reliability of the links between the access-layer and distribution-layer IRF fabrics and implement load sharing.
·     Run LACP MAD on the two IRF fabrics to detect IRF split.
Figure 2 Network diagram
When you configure Layer 2 link aggregation in an IRF fabric, follow these restrictions and guidelines:
·     IRF physical ports must be set to the bridge mode.
·     When you bind physical ports to an IRF port, you must set all the physical ports to operate in either normal or enhanced mode.
·     The physical ports of two connected IRF ports must operate in the same mode: normal or enhanced. For more information about the binding mode of the IRF physical ports, see Virtual technologies Configuration Guide.
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
Procedures
1.     Configure IRF on Device A:
# Shut down ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4.
# Assign member ID 1 to Device A.
[DeviceA] irf member 1
# Bind Ten-GigabitEthernet 1/0/1 to IRF port 1.
[DeviceA] irf-port 1
[DeviceA-irf-port1] port group interface ten-gigabitethernet 1/0/1
[DeviceA-irf-port1] quit
# Save the configuration
[DeviceA] quit
<DeviceA> save
# Enable IRF mode.
[DeviceA] chassis convert mode irf
The device will switch to IRF mode and reboot.
You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in IRF mode? [Y/N]:y
 Please wait...
 Saving the converted configuration file to the main board succeeded.
Slot 1:
 Saving the converted configuration file succeeded.
 Now rebooting, please wait...
After the reboot, Device A forms a one-chassis IRF fabric. The interface number of Ten-GigabitEthernet 1/0/1 changes to Ten-GigabitEthernet 1/1/0/1.
2.     Configure IRF on Device B:
# Assign member ID 2 to Device B.
[DeviceB] irf member 2
# Bind Ten-Gigabitethernet 1/0/1 to IRF port 2.
[Sysname] irf-port 2
[DeviceB-irf-port2] port group interface ten-gigabitethernet 1/0/1
[DeviceB-irf-port2] quit
# Save the configuration.
[DeviceB] quit
<DeviceB> save
# Connect the Device A and Device B as shown in Figure 2.
# Enable IRF mode.
[DeviceB] chassis convert mode irf
Please wait...
Slot 1:
After the reboot, Device B forms a two-chassis IRF fabric with Device A. The interface number of Ten-GigabitEthernet 1/0/1 changes to Ten-GigabitEthernet 2/1/0/1.
3.     Configure a Layer 2 aggregation group on Device A:
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and configure the link aggregation mode as dynamic.
# Configure Layer 2 aggregation group 1 to load share packets based on source IP addresses.
[DeviceA-Bridge-Aggregation1] link-aggregation load-sharing mode source-ip
# Assign ports Ten-GigabitEthernet 1/1/0/9, Ten-GigabitEthernet 1/1/0/10, Ten-GigabitEthernet 2/1/0/9, and Ten-GigabitEthernet 2/1/0/10 to link aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/1/0/9 to ten-gigabitethernet 1/1/0/10
ten-gigabitethernet 2/1/0/9 to ten-gigabitethernet 2/1/0/10
[DeviceA]
4.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[DeviceA] irf domain 1
# Enable LACP MAD on Bridge-Aggregation 1.
[DeviceA] interface Bridge-Aggregation 1
[DeviceA-Bridge-Aggregation1] mad enable
[Current domain is: 1]:
The assigned domain ID is: 1
MAD LACP only enable on dynamic aggregation interface.
5.     Configure IRF on Device C in the same way IRF is configured on Device A. (Details not shown.)
6.     Configure IRF on Device D in the same way IRF is configured on Device B. (Details not shown.)
Device C and Device D perform master election, and the one that has lost the election reboots to form an IRF fabric with the master. In this example, Device C reboots.
7.     Configure a Layer 2 dynamic aggregation group Bridge-Aggregation 1 on Device C in the same way Bridge-Aggregation 1 is configured on Device A. (Details not shown.)
8.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 2.
<DeviceC> system-view
[DeviceC] irf domain 2
[DeviceC] interface Bridge-Aggregation 1
[DeviceC-Bridge-Aggregation1] mad enable
[Current domain is: 2]:
The assigned domain ID is: 2
# Display the information about the link aggregation groups on Device A.
System ID: 0x8000, 00a0-fc00-5800
Local:
  XGE1/0/9            S        32768    10       1                      {ACG}
  XGE1/0/10           S        32768    11       1                      {ACG}
  XGE2/0/9            S        32768    138      1                      {ACG}
  XGE2/0/10           S        32768    139      1                      {ACG}
Remote:
  XGE1/0/9            32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE1/0/10           32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE2/0/9            32768    0        0        0x8000, 0000-0000-0000 {EF}
  XGE2/0/10           32768    0        0        0x8000, 0000-0000-0000 {EF}
# Display the load sharing mode of Layer 2 aggregation group 1 on Device A.
[DeviceA] display link-aggregation load-sharing mode interface Bridge-Aggregation 1
Bridge-Aggregation1 load-sharing mode:
source-ip address
The output shows that Layer 2 aggregation group 1 load shares packets based on source IP addresses.
# Shut down physical IRF port Ten-GigabitEthernet 2/0/1 on Device B.
A log message appears on Device A.
[DeviceA]%Jul  9 16:52:41:734 2016 H3C STM/3/STM_LINK_DOWN: -MDC=1; IRF port 1 went down.
%Jul  9 16:52:41:800 2016 H3C IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:854 2016 H3C IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet1/0/1 changed to down.
%Jul  9 16:52:41:867 2016 H3C DEV/3/BOARD_REMOVED: -MDC=1; Board was removed from slot 2, type is Simware.
The output shows that IRF split occurs on the distribution layer because Ten-GigabitEthernet 2/1/0/1 that is bound to IRF port 2 is physically down.
Configuration files
·     Device A:
 irf domain 1
 irf mac-address persistent timer
 irf auto-update enable
 irf link-delay 0
 irf member 1 priority 1
 irf member 2 priority 1
irf-port 1/1
 port group interface Ten-GigabitEthernet1/1/0/1 mode enhanced
irf-port 2/2
 port group interface Ten-GigabitEthernet2/1/0/1 mode enhanced
interface Ten-GigabitEthernet1/1/0/9
interface Ten-GigabitEthernet1/1/0/10
interface Ten-GigabitEthernet2/1/0/9
interface Ten-GigabitEthernet2/1/0/10
·     Device C:
The configuration file on Device C is similar as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation
On the network as shown in Figure 3, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 3 Network diagram
·     In a static aggregation group, the aggregation states of the member ports are not affected by the peer ports. Static link aggregation is stable.
·     In a dynamic aggregation group, the local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡     Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
  XGE1/0/2         S       32768    1
  XGE1/0/3         S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
  XGE1/0/1(R)         S        32768    2        1                      {ACDEF}
Remote:
  XGE1/0/1            32768    2        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/0/2            32768    3        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/0/3            32768    4        1        0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
·     Device A:
interface route-aggregation1
·     Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Related documentation
·     H3C S7500E Switch Series Layer 2—LAN Switching Configuration Guide-Release R7536P05
·     H3C S7500E Switch Series Layer 2—LAN Switching Command Reference-Release R7536P05
