03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7536P05-6W10003-Layer 2 - LAN Switching Configuration Examples
04-H3C_Spanning_Tree_Configuration_Examples
04-H3C_Spanning_Tree_Configuration_Examples 320.18 KB
H3C Spanning Tree Configuration Examples
H3C_彩色.emf
Introduction
This document provides spanning tree configuration examples.
This document assumes that you have basic knowledge of spanning tree protocols.
Example: Configuring MSTP
As shown in Figure 1, Device A and Device B operate at the core layer, and Device C and Device D operate at the distribution layer. The ports on the devices have the same path cost, and they all permit VLANs 11 through 30.
Configure MSTP to meet the following requirements:
·     Device A, Device B, Device C, and Device D belong to the same MST region.
·     MSTIs are used to share the traffic of VLANs 11 through 20 and of VLANs 21 through 30.
Figure 1 Network diagram
Analysis
To assign the devices to the same MST region, make sure the following MST region parameters are the same on the devices:
·     Spanning tree mode (the default mode MSTP is used).
·     Region name (test in this example).
·     Revision level (the default value 0 is used).
·     VLAN-to-instance mappings (VLANs 11 through 20 to MIST 1, and VLANs 21 through 30 to MIST 2).
To use redundant links to share the traffic of different VLANs (as shown in Figure 2), perform the following tasks:
·     Configure Device A as the root bridge of MSTI 1.
·     Configure Device B as the root bridge of MIST 2.
·     Assign priorities to Device A, Device B, Device C, and Device D in MSTI 0 in descending order for Device A to be the regional root bridge.
Figure 2 MSTIs mapped to different VLANs
Software versions used
This configuration example was created and verified on S7500E-CMW710-R7536P05.
Procedures
Configuring Device A
# Create VLANs 11 through 30.
[DeviceA] vlan 11 to 30
# Configure GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to trunk VLANs 11 through 30.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 11 to 30
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Configure the MST region name as test.
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name test
# Map VLANs 11 through 20 to MSTI 1, and map VLANs 21 through 30 to MSTI 2.
[DeviceA-mst-region] instance 1 vlan 11 to 20
[DeviceA-mst-region] instance 2 vlan 21 to 30
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Configure Device A as the root bridge of MSTI 0 and MSTI 1.
[DeviceA] stp instance 0 to 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp global enable
Configuring Device B
[DeviceB] vlan 11 to 30
[DeviceB] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 11 to 30
[DeviceB-if-range] undo shutdown
[DeviceB-if-range] quit
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name test
[DeviceB-mst-region] instance 1 vlan 11 to 20
[DeviceB-mst-region] instance 2 vlan 21 to 30
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Configure Device B as the root bridge of MSTI 2 and a secondary root bridge of MSTI 0.
[DeviceB] stp instance 2 root primary
[DeviceB] stp instance 0 root secondary
[DeviceB] stp global enable
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 11 to 30
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLANs 11 through 30.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceC-if-range] port link-mode bridge
[DeviceC-if-range] port link-type trunk
[DeviceC-if-range] port trunk permit vlan 11 to 30
[DeviceC-if-range] undo shutdown
[DeviceC-if-range] quit
[DeviceC-mst-region] region-name test
# Map VLANs 11 through 20 through MSTI 1, and map VLANs 21 through 30 to MSTI 2.
[DeviceC-mst-region] instance 1 vlan 11 to 20
[DeviceC-mst-region] instance 2 vlan 21 to 30
[DeviceC-mst-region] quit
[DeviceC] stp global enable
Configuring Device D
<DeviceD> system-view
[DeviceD] vlan 11 to 30
[DeviceD] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceD-if-range] port link-mode bridge
[DeviceD-if-range] port link-type trunk
[DeviceD-if-range] port trunk permit vlan 11 to 30
[DeviceD-if-range] undo shutdown
[DeviceD-if-range] quit
[DeviceD-mst-region] region-name test
[DeviceD-mst-region] instance 1 vlan 11 to 20
[DeviceD-mst-region] instance 2 vlan 21 to 30
[DeviceD-mst-region] quit
# Set the device priority to 36864 in MSTI 0, which is lower than the default priority 32768 of Device C.
[DeviceD] stp instance 0 priority 36864
[DeviceD] stp global enable
1.     Verify that Layer 2 loops have been eliminated in each MSTI:
Use the display stp brief command to display brief spanning tree information on each device.
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
 MST ID   Port                                Role  STP State   Protection
 0        GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 0        GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 0        GigabitEthernet1/0/3                DESI  FORWARDING  NONE
 1        GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 1        GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 1        GigabitEthernet1/0/3                DESI  FORWARDING  NONE
 2        GigabitEthernet1/0/1                ALTE  DISCARDING  NONE
 2        GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 2        GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
 0        GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
 1        GigabitEthernet1/0/2                ALTE  DISCARDING  NONE
 1        GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
 2        GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 2        GigabitEthernet1/0/3                DESI  FORWARDING  NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
 0        GigabitEthernet1/0/1                ROOT  FORWARDING  NONE
 0        GigabitEthernet1/0/2                ALTE  DISCARDING  NONE
 1        GigabitEthernet1/0/1                ROOT  FORWARDING  NONE
 2        GigabitEthernet1/0/2                ROOT  FORWARDING  NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
 0        GigabitEthernet1/0/1                ALTE  DISCARDING  NONE
 0        GigabitEthernet1/0/2                ROOT  FORWARDING  NONE
 1        GigabitEthernet1/0/1                ALTE  DISCARDING  NONE
 1        GigabitEthernet1/0/2                ROOT  FORWARDING  NONE
 2        GigabitEthernet1/0/1                ROOT  FORWARDING  NONE
 2        GigabitEthernet1/0/2                ALTE  DISCARDING  NONE
Based on the output, the topology for each MSTI is shown in Figure 3.
Figure 3 MSTI topologies
2.     Verify that the network can accommodate topology changes:
# Shut down GigabitEthernet 1/0/1 on Device C. (Details not shown.)
# Display brief spanning tree information on all devices.
Based on the output, the topology for each MSTI is shown in Figure 4.
Figure 4 MSTI topologies
Configuration files
·     Device A:
vlan 1
vlan 11 to 30
 region-name test
 stp global enable
 port trunk permit vlan 1 11 to 30
·     Device B:
vlan 1
vlan 11 to 30
 region-name test
 stp global enable
·     Device C:
vlan 1
vlan 11 to 30
 region-name test
 stp global enable
·     Device D:
vlan 1
vlan 11 to 30
 region-name test
 stp global enable
Example: Configuring PVST
As shown in Figure 5, Device A and Device B operate at the distribution layer, and Device C and Device D operate at the access layer. The ports on the devices have the same path cost.
Configure PVST to meet the following requirements:
·     Redundant links are used for load sharing.
·     Packets of each VLAN are forwarded along its spanning tree.
Figure 5 Network diagram
Analysis
For traffic of different VLANs to be shared along the spanning trees in Figure 6, perform the following tasks:
·     Configure Device A as the root bridge of the spanning trees for VLAN 10 and VLAN 30.
·     Configure Device B as the root bridge of the spanning tree for VLAN 20.
Figure 6 VLAN spanning tree topologies
Procedures
# Create VLAN 10, VLAN 20, and VLAN 30.
[DeviceA] vlan 10
[DeviceA-vlan10] vlan 20
[DeviceA-vlan20] vlan 30
[DeviceA-vlan30] quit
# Configure GigabitEthernet 1/0/1 to trunk VLAN 10 and VLAN 20.
[DeviceA-GigabitEthernet1/0/1] port link-mode bridge
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan 10 20
[DeviceA-GigabitEthernet1/0/1] undo shutdown
# Configure GigabitEthernet 1/0/2 to trunk VLAN 20 and VLAN 30.
[DeviceA-GigabitEthernet1/0/2] port link-mode bridge
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 20 30
[DeviceA-GigabitEthernet1/0/2] undo shutdown
# Configure GigabitEthernet 1/0/3 to trunk VLAN 10, VLAN 20, and VLAN 30.
[DeviceA-GigabitEthernet1/0/3] port link-mode bridge
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 10 20 30
[DeviceA-GigabitEthernet1/0/3] undo shutdown
# Set the spanning tree mode to PVST.
[DeviceA] stp mode pvst
# Configure Device A as the root bridge of VLAN 10 and VLAN 30.
[DeviceA] stp vlan 10 30 root primary
[DeviceB] vlan 10
[DeviceB-vlan10] vlan 20
[DeviceB-vlan20] vlan 30
[DeviceB-vlan30] quit
# Configure GigabitEthernet 1/0/1 to trunk VLAN 20 and VLAN 30.
[DeviceB-GigabitEthernet1/0/1] port link-mode bridge
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 20 30
[DeviceB-GigabitEthernet1/0/1] undo shutdown
# Configure GigabitEthernet 1/0/2 to trunk VLAN 10 and VLAN 20.
[DeviceB-GigabitEthernet1/0/2] port link-mode bridge
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 10 20
[DeviceB-GigabitEthernet1/0/2] undo shutdown
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port link-mode bridge
[DeviceB-GigabitEthernet1/0/3] port link-type trunk
[DeviceB-GigabitEthernet1/0/3] port trunk permit vlan 10 20 30
[DeviceB-GigabitEthernet1/0/3] undo shutdown
[DeviceB] stp mode pvst
# Configure Device B as the root bridge of VLAN 20.
[DeviceB] stp vlan 20 root primary
# Create VLAN 10 and VLAN 20.
[DeviceC] vlan 10
[DeviceC-vlan10] vlan 20
[DeviceC-vlan20] quit
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLAN 10 and VLAN 20.
[DeviceC] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/2
[DeviceC-if-range] port trunk permit vlan 10 20
[DeviceC] stp mode pvst
# Create VLAN 20 and VLAN 30.
[DeviceD] vlan 20
[DeviceD-vlan20] vlan 30
[DeviceD-vlan30] quit
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLAN 20 and VLAN 30.
[DeviceD] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/2
[DeviceD-if-range] port trunk permit vlan 20 30
[DeviceD] stp mode pvst
 VLAN ID  Port                                Role  STP State   Protection
 1        GigabitEthernet1/0/3                ALTE  DISCARDING  NONE
 10       GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 10       GigabitEthernet1/0/3                DESI  FORWARDING  NONE
 20       GigabitEthernet1/0/1                ALTE  DISCARDING  NONE
 20       GigabitEthernet1/0/2                ALTE  DISCARDING  NONE
 20       GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
 30       GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 30       GigabitEthernet1/0/3                DESI  FORWARDING  NONE
 10       GigabitEthernet1/0/2                ALTE  DISCARDING  NONE
 10       GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
 20       GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 20       GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 20       GigabitEthernet1/0/3                DESI  FORWARDING  NONE
 30       GigabitEthernet1/0/1                ALTE  DISCARDING  NONE
 30       GigabitEthernet1/0/3                ROOT  FORWARDING  NONE
 10       GigabitEthernet1/0/1                ROOT  FORWARDING  NONE
 10       GigabitEthernet1/0/2                DESI  FORWARDING  NONE
 20       GigabitEthernet1/0/2                ROOT  FORWARDING  NONE
 20       GigabitEthernet1/0/1                ROOT  FORWARDING  NONE
 30       GigabitEthernet1/0/1                DESI  FORWARDING  NONE
 30       GigabitEthernet1/0/2                ROOT  FORWARDING  NONE
Based on the output, the topology for each VLAN is shown in Figure 7.
Figure 7 VLAN spanning tree topologies
Configuration files
·     Device A:
vlan 1
vlan 10
vlan 20
vlan 30
 stp mode pvst
 stp global enable
 port trunk permit vlan 1 10 20
 port trunk permit vlan 1 20 30
 port trunk permit vlan 1 10 20 30
·     Device B:
vlan 1
vlan 10
vlan 20
vlan 30
 stp mode pvst
 stp global enable
·     Device C:
vlan 1
vlan 10
vlan 20
 stp mode pvst
 stp global enable
·     Device D:
vlan 1
vlan 20
vlan 30
 stp mode pvst
 stp global enable
Example: Configuring RSTP
As shown in Figure 8, Device A operates at the core layer, Device B and Device C operate at the distribution layer, and Device D and Device E operate at the access layer. The ports on the devices have the same path cost.
Configure RSTP as follows:
·     Configure Device A as the root bridge, and enable root guard to retain its root bridge role when configuration errors or malicious attacks occur.
·     Configure Device C as a backup of Device B. When Device B fails, traffic is forwarded through Device C.
·     Configure GigabitEthernet 1/0/4 on Device D and GigabitEthernet 1/0/4 on Device E as edge ports, and enable BPDU guard on the ports.
Figure 8 Network diagram
Analysis
For Device C to be a backup of Device B, make sure Device C's priority is lower than Device B's priority. In this example, configure the priorities of Device B and Device C as 4096 and 8192.
For Device A to be the root bridge, make sure Device A has the lowest bridge ID (containing the device's priority and MAC address) in the network. In this example, because Device A already has the lowest MAC address, configure the priority as 4096 for Device A to hold the lowest bridge ID.
To configure a device as the root bridge, you also can use the stp root primary or stp priority 0 command to set the device's priority to 0.
To retain Device A's root bridge role, enable root guard on the designated ports of Device A, Device B, and Device C. To identify the designated ports, use either of the following methods:
·     Use the display stp brief command to display the brief spanning tree information. The role is DESI for a designated port.
·     Identify the designated ports in the RSTP topology that is calculated based on the device configuration, as shown in Figure 9.
Figure 9 RSTP topology
Procedures
# Set the spanning tree mode to RSTP.
[DeviceA] stp mode rstp
# Configure the priority as 4096 for Device A.
[DeviceA] stp priority 4096
# Enable root guard on designated ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceA] interface range gigabitethernet 1/0/1 gigabitethernet 1/0/2
[DeviceA-if-range] stp root-protection
[DeviceB] stp mode rstp
# Configure the priority as 4096 for Device B.
[DeviceB] stp priority 4096
# Enable root guard on designated ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3.
[DeviceB-if-range] stp root-protection
# Bring up GigabitEthernet 1/0/4.
[DeviceB] interface gigabitethernet 1/0/4
[DeviceB-GigabitEthernet1/0/4] port link-mode bridge
[DeviceB-GigabitEthernet1/0/4] undo shutdown
[DeviceB-GigabitEthernet1/0/4] quit
[DeviceC] stp mode rstp
# Configure the priority as 8192 for Device C.
[DeviceC] stp priority 8192
[DeviceC-if-range] stp root-protection
# Bring up GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4.
[DeviceC] interface range gigabitethernet 1/0/3 to gigabitethernet 1/0/4
[DeviceD] stp mode rstp
# Configure GigabitEthernet 1/0/4 as an edge port, and enable BPDU guard.
[DeviceD] interface gigabitethernet 1/0/4
[DeviceD-GigabitEthernet1/0/4] port link-mode bridge
[DeviceD-GigabitEthernet1/0/4] stp edged-port
[DeviceD-GigabitEthernet1/0/4] undo shutdown
[DeviceD-GigabitEthernet1/0/4] quit
[DeviceD] stp bpdu-protection
# Bring up GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
Configuring Device E
# Configure Device E in the same way Device D is configured. (Details not shown.)
1.     Verify that Layer 2 loops have been eliminated in the network:
# Display the brief spanning tree information on Device A.
# Display the brief spanning tree information on Device B.
 0        GigabitEthernet1/0/4                ROOT  FORWARDING  NONE
# Display the brief spanning tree information on Device C.
 0        GigabitEthernet1/0/3                ALTE  DISCARDING  NONE
# Display the brief spanning tree information on Device D.
 0        GigabitEthernet1/0/4                DESI  FORWARDING  BPDU
# Display the brief spanning tree information on Device E.
[DeviceE] display stp brief
Based on the output, the topology for the network is shown in Figure 10.
Figure 10 Network topology
2.     Verify that root guard can retain Device A's root bridge role:
# Verify that Device A is the root bridge in the network.
-------[CIST Global Info] [Mode RSTP] -------
 Bridge ID           : 32768.00e0-fc00-c518
 Bridge times        : Hello 2s MaxAge 20s FwdDelay 15s MaxHops 20
 Root ID/ERPC        : 4096.0000-fc00-47cd, 40
 RegRoot ID/IRPC     : 32768.00e0-fc00-c518, 0
# Set the priority to 0 for Device D. Because the priority is higher than the priority of Device A, Device D considers itself as the root bridge and sends BPDUs that contain its bridge ID 0.00e0-fc00-c518.
[DeviceD] stp priority 0
 Bridge ID           : 0.00e0-fc00-c518
 Root ID/ERPC        : 0.00e0-fc00-c518, 0
 RegRoot ID/IRPC     : 0.00e0-fc00-c518, 0
# Set the priority to 0 for Device E. Because the priority is higher than the priority of Device A. Device E considers itself as the root bridge and sends BPDUs that contain its bridge ID 0.7425-8a0f-8000.
[DeviceE] stp priority 0
 Bridge ID           : 0.7425-8a0f-8000
 Root ID/ERPC        : 0.7425-8a0f-8000, 0
 RegRoot ID/IRPC     : 0.7425-8a0f-8000, 0
# Verify that Device A is still the root bridge in the network.
 Bridge ID           : 4096.7425-8a02-4c00
 Root ID/ERPC        : 4096.0000-fc00-47cd, 20
 RegRoot ID/IRPC     : 4096.7425-8a02-4c00, 0
 Bridge ID           : 8192.0cda-41b1-d1c0
 RegRoot ID/IRPC     : 8192.0cda-41b1-d1c0, 0
# Verify that Device A cannot retain its root bridge role when root guard is disabled on a designated port on Device B (for example, GigabitEthernet 1/0/2).
[DeviceB-GigabitEthernet1/0/2] undo stp root-protection
[DeviceB-GigabitEthernet1/0/2] display stp
 Root ID/ERPC        : 0.7425-8a0f-8000, 20
[DeviceB-GigabitEthernet1/0/2] display stp brief
 0        GigabitEthernet1/0/1                DESI  DISCARDING  ROOT
 0        GigabitEthernet1/0/4                DESI  FORWARDING  NONE
3.     Verify that traffic is forwarded through Device C when Device B fails:
# Reboot Device B. (Details not shown.)
# Display the brief spanning tree information on Device A, Device C, Device D, and Device E before Device B completes the reboot.
[DeviceA] dis stp brief
 0        GigabitEthernet1/0/2                DESI  FORWARDING  ROOT
[DeviceC] dis stp brief
 0        GigabitEthernet1/0/1                DESI  FORWARDING  ROOT
[DeviceD] dis stp brief
[DeviceE] dis stp brief
Based on the network topology, the topology for the network is shown in Figure 11.
Figure 11 Network topology
4.     Verify that BPDU guard can protect edge ports from attacks:
# Verify that the edge port GigabitEthernet 1/0/4 on Device D goes down when the port receives configuration BPDUs.
[DeviceD] display stp down-port
 Down Port                           Reason
 GigabitEthernet1/0/4                BPDU-Protected
# Verify that GigabitEthernet 1/0/4 goes up when it does not receive any configuration BPDUs from the peer end.
[DeviceD] display interface brief | include UP
InLoop0              UP   UP(s)    --
M-E0/0/0             UP   UP       192.168.2.125
NULL0                UP   UP(s)    --
GE1/0/1              UP   1G(a)   F(a)   T    1
GE1/0/2              UP   1G(a)   F(a)   T    1
GE1/0/4              UP   1G(a)   F(a)   A    1
Configuration files
·     Device A:
vlan 1
 stp instance 0 priority 4096
 stp mode rstp
 stp global enable
 stp root-protection
 stp root-protection
·     Device B:
vlan 1
 stp mode rstp
 stp global enable
 stp root-protection
 stp root-protection
 stp root-protection
interface GigabitEthernet1/0/4
·     Device C:
vlan 1
 stp instance 0 priority 8192
 stp mode rstp
 stp global enable
 stp root-protection
 stp root-protection
·     Device D:
vlan 1
 stp mode rstp
 stp bpdu-protection
 stp global enable
 stp edged-port
·     Device E:
vlan 1
 stp mode rstp
 stp bpdu-protection
 stp global enable
 stp edged-port
Related documentation
·     H3C S7500E Switch Series Layer 2—LAN Switching Configuration Guide-R7536P05
·     H3C S7500E Switch Series Layer 2—LAN Switching Command Reference-R7536P05
