- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-EAA commands
- 09-Process monitoring and maintenance commands
- 10-Sampler commands
- 11-Mirroring commands
- 12-NetStream commands
- 13-IPv6 NetStream commands
- 14-sFlow commands
- 15-Information center commands
- 16-GOLD commands
- 17-Packet capture commands
- 18-VCF fabric commands
11-Mirroring commands | 68.05 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its number. The value range for this argument is 1 to 16.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
Ten-GigabitEthernet1/0/1 Inbound
Monitor port: Ten-GigabitEthernet1/0/2
Ten-GigabitEthernet1/0/3
Ten-GigabitEthernet1/0/4
Mirroring group |
Number of the mirroring group. |
Type |
Type of the mirroring group: · Local. · Remote source. · Remote destination. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Mirroring port |
Source port. |
Mirroring CPU |
Source CPU. |
Monitor port |
Destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
In standalone mode:
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
In IRF mode:
mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 16.
slot slot-number-list: Specifies a space-separated list of up to eight slot number items. An item specifies a card by its slot number or specifies a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In standalone mode.)
chassis chassis-number slot slot-number-list: Specifies cards on an IRF member device or specifies PEXs. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of a PEX. The slot-number-list argument specifies a space-separated list of up to eight slot number items. An item specifies a card by its slot number, a range of cards in the form of start-slot-number to end-slot-number, or a PEX by its virtual slot number. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# (In standalone mode.) Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
You can configure source ports only for local mirroring groups and remote source groups.
A Layer 2 or Layer 3 aggregate interface cannot be configured as a source port for a mirroring group.
Do not assign a source port of a mirroring group to a source VLAN or the remote probe VLAN of the mirroring group.
A port can act as a source port for multiple mirroring groups.
A source port cannot be used as a reflector port, monitor port, or egress port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port Ten-GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 remote-source
[Sysname-Ten-GigabitEthernet1/0/2] mirroring-group 2 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of Ten-GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port ten-gigabitethernet 1/0/1 both
# Create remote source group 2 to monitor the bidirectional traffic of Ten-GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 mirroring-port ten-gigabitethernet 1/0/2 both
mirroring-group
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
Do not assign the egress port of a mirroring group to a source VLAN of the mirroring group.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
· Spanning tree.
· 802.1X.
· IGMP snooping.
· Static ARP.
· MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure Ten-GigabitEthernet 1/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress ten-gigabitethernet 1/0/1
# Create remote source group 2. Configure Ten-GigabitEthernet 1/0/2 as its egress port in interface view.
[Sysname-Ten-GigabitEthernet1/0/2] mirroring-group 2 monitor-egress
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
You can configure monitor ports only for local mirroring groups and remote destination groups.
Do not assign the monitor port of a mirroring group to a source VLAN of the mirroring group.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform either of the following tasks:
· Configure its member ports as source ports of the mirroring group.
· Assign its member ports to a source VLAN of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
A Layer 2 or Layer 3 aggregate interface cannot be configured as the monitor port for a Layer 2 remote destination group.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
# Create local mirroring group 1 and configure Ten-GigabitEthernet 1/0/1 as its monitor port.
[Sysname-Ten-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure Ten-GigabitEthernet 1/0/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-Ten-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-list
undo mirroring-group group-id monitor-port interface-list
No monitor port is configured for a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform any of the following tasks:
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port ten-gigabitethernet 1/0/1
[Sysname] mirroring-group 2 monitor-port ten-gigabitethernet 1/0/2
# Create local mirroring group 3 and configure ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/5 as its monitor ports.
[Sysname] mirroring-group 3 local
[Sysname] mirroring-group 3 monitor-port ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3 ten-gigabitethernet 1/0/5
mirroring-group
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
You can configure reflector ports only for remote source groups.
Do not assign the reflector port of a mirroring group to a source VLAN of the mirroring group.
The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on a reflector port.
If an IRF port is bound to only one physical interface, do not configure the physical interface as a reflector port. Otherwise, the IRF might split.
You can configure a port as a reflector port only when the port is operating with the default setting of the following parameters:
· Duplex mode.
· Speed.
· MDI settings.
You cannot change the duplex mode, MDI settings, or speed for a reflector port.
The member port of an aggregate interface can be configured as a reflector port.
# Create remote source group 1. Configure Ten-GigabitEthernet 1/0/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port ten-gigabitethernet 1/0/1
# Create remote source group 2. Configure Ten-GigabitEthernet 1/0/2 as its reflector port in interface view.
[Sysname-Ten-GigabitEthernet1/0/2] mirroring-group 2 reflector-port
mirroring-group
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
The encapsulation parameters for the mirrored packets are available only when the mirrored packets are sent out of Ethernet interfaces.
# Create traffic behavior 1 and configure the action of mirroring traffic to Ten-GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface ten-gigabitethernet 1/0/1
# Create traffic behavior 1, configure the action of mirroring traffic to Ten-GigabitEthernet 1/0/1, and use the sampler samp.
[Sysname-behavior-1] mirror-to interface ten-gigabitethernet 1/0/1 sampler samp
# Create traffic behavior 1, and configure the action of mirroring traffic to Ten-GigabitEthernet 1/0/1 for the traffic behavior. Specify the following parameters for the mirrored packets sent to Ten-GigabitEthernet 1/0/1:
· Specify 1.1.1.1 and 2.2.2.2 as the source address and destination address, respectively.
· Specify 20, 100, and vrf1 as the DSCP value, VLAN, and the VPN instance name, respectively.
[Sysname-behavior-1] mirror-to interface ten-gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
