- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-EAA commands
- 09-Process monitoring and maintenance commands
- 10-Sampler commands
- 11-Mirroring commands
- 12-NetStream commands
- 13-IPv6 NetStream commands
- 14-sFlow commands
- 15-Information center commands
- 16-GOLD commands
- 17-Packet capture commands
- 18-VCF fabric commands
10-Sampler commands | 31.58 KB |
Sampler commands
display sampler
Use display sampler to display configuration information for a sampler.
In standalone mode:
display sampler [ sampler-name ] [ slot slot-number ]
In IRF mode:
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ]
sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, this command displays configuration information for all samplers.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays sampler configuration information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF 2 member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF 2 member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command displays sampler configuration information for the global active MPU. (In IRF mode.)
# Display the configuration information about sampler 256.
<Sysname> display sampler 256
Sampler name: 256
Mode: Fixed; Packet-interval: 8; IsNpower: Y
Sampler name |
Name of the sampler. |
Mode |
Sampling mode. |
Packet-interval |
Sampling rate. |
IsNpower |
Whether the sampling rate is 2 to the nth power: · Y—Yes. · N—No. |
sampler
Use sampler to create a sampler.
Use undo sampler to delete a sampler.
sampler sampler-name mode fixed packet-interval n-power rate
undo sampler sampler-name
No samplers exist.
fixed: Specifies the fixed sampling mode. A sampler in this mode selects the first packet per sampling.
n-power: Specifies the sampling rate as 2 to the nth power.
rate: Specifies the sampling rate. The sampling rate is 2 to the nth power, where n is value of the rate argument. For example, if the rate argument is set to 8, one packet is selected from 256 (2 to the 8th power) packets in each sampling. The value range for the rate argument is 1 to 12.
This command takes effect on all cards.
# Create sampler abc in fixed sampling mode. Set the sampling rate to 8 to select one packet form 256 packets in each sampling.
[Sysname] sampler abc mode fixed packet-interval n-power 8
