02-OAP configuration | 79.2 KB |
Configuring OAP
Overview
H3C Open Application Platform (OAP) is an open application protocol that is based on H3C Open Application Architecture (OAA). OAA allows products from different vendors to operate together to meet service requirements.
As shown in Figure 1, OAA includes the following components:
· Routing/switching component—Provides routing and switching services. This component is the control center of the entire architecture.
· Standalone service component—Provides services to meet specific requirements.
· Interfacing component—Connects the standalone service component to the routing/switching component.
OAP is used for communication and cooperation between the routing/switching component and the standalone service component. The routing/switching component is the OAP manager, and the standalone service component is the OAP client.
The device can act as the OAP manager. The OAP manager software is integrated in the Comware system.
The OAP client can be a third-party product or an H3C OAP module. OAP modules provide value-added services, such as security and wireless control. OAP modules have their own CPUs and storage media. The OAP client software is integrated in the operating system of the OAP module as a function.
You can install an OAP module in the device. For example, you can install an IDS/IPS OAP module in the device to provide intrusion detection and protection services.
OAP functions
OAP provides the following functions:
· OAP clients register with and deregister from the OAP manager.
· The OAP manager assigns IDs to OAP clients to uniquely identify the clients.
· The OAP manager and an OAP client exchange information to, for example, monitor each other and synchronize the clock.
From the OAP manager, you can perform the following tasks:
· Restart OAP clients.
· Shut down OAP clients.
· Display OAP client information.
An OAP manager can manage up to 255 OAP clients.
OAP manager timers
The OAP manager uses the following timers:
· Clock synchronization timer—Regularly triggers the OAP manager to send clock and time zone synchronization notifications to OAP clients. This mechanism keeps the clients' clocks synchronized with the manager's clock.
· Client monitoring timer—Regularly triggers the OAP manager to send client monitoring packets to OAP clients.
Configuring OAP
OAP configuration is available only on an LSU1FWCEA0.
Enabling OAP
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable OAP. |
oap enable |
By default, OAP is disabled on an interface. |
Setting the clock synchronization timer
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the clock synchronization timer. |
oap timer clock-sync minutes |
By default, the clock synchronization timer is set to 5 minutes. |
Setting the client monitoring timer
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the client monitoring timer. |
oap timer monitor seconds |
By default, the client monitoring timer is set to 5 seconds. |
Managing OAP clients
This feature is available only on an LSU1FWCEA0.
Restarting an OAP client
Step |
Command |
system-view |
2. Restart an OAP client. |
oap client reboot client-id |
Shutting down an OAP client
This feature applies only to OAP clients on Linux.
To shut down an OAP client:
Step |
Command |
system-view |
2. Shut down an OAP client. |
oap client close client-id |
Displaying and maintaining OAP
Task |
Command |
Display the summary registration information of OAP clients. |
display oap client summary [ client-id ] |
Display OAP client information. |
display oap client info [ client-id ] |
