07-IP Multicast Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10007-IP Multicast Command Reference
08-Multicast VPN commands
08-Multicast VPN commands 70.6 KB
address-family ipv4 mdt
Use address-family ipv4 mdt to create a BGP IPv4 MDT address family and enter the BGP IPv4 MDT address family view.
Use undo address-family ipv4 mdt to delete the BGP IPv4 MDT address family and configuration in BGP IPv4 MDT address family view.
No BGP IPv4 MDT address family exists.
BGP view
Execute this command before you enable BGP peers to exchange MDT information by using the peer enable command. MDT information includes the IP address of the PE and default-group to which the PE belongs. On a public network running PIM-SSM, the multicast VPN establishes a default-MDT rooted at the PE (multicast source) based on the MDT information.
Configuration in BGP IPv4 MDT address family view takes effect only on BGP MDT messages, BGP MDT peers, and BGP MDT peer groups.
# Create a BGP IPv4 MDT address family, and enter the BGP IPv4 MDT family address view.
[Sysname] bgp 100
[Sysname-bgp] address-family ipv4 mdt
[Sysname-bgp-mdt]
peer enable (see Layer 3IP Routing Configuration Guide)
data-delay
Use data-delay to set the data-delay period (delay period before the default-MDT switches to the data-MDT).
Use undo data-delay to restore the default.
data-delay delay
undo data-delay
The data-delay period is 3 seconds.
MD view
delay: Specifies a data-delay period in the range of 1 to 60 seconds.
# Set the data-delay period to 20 seconds for VPN instance mvpn.
[Sysname] multicast-domain vpn-instance mvpn
[Sysname-md-mvpn] data-delay 20
data-group
Use data-group to specify a data-group range and optionally configure the criterion for the default-MDT to data-MDT switchover.
Use undo data-group to restore the default.
data-group group-address { mask-length | mask } [ acl acl-number ]
undo data-group
The data-group range is not configured, and the default-MDT to data-MDT switchover never occurs.
MD view
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
mask-length: Specifies an address mask length in the range of 25 to 32.
mask: Specifies an address mask in the range of 255.255.255.x, where x can only be 128, 192, 224, 240, 248, 252, 254, or 255.
acl acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999. If you specify an ACL, the configured MDT switchover criteria applies to the (S, G) entries that the ACL permits. If you do not specify an ACL, the configured MDT switchover criteria applies to all (S, G) entries. To make the ACL effective, specify the protocol type as IP, and include the source and destination keywords when you create an ACL rule. The source and destination keywords specify a multicast source address range and a multicast group address range, respectively.
On a PE device, the data-group range for a VPN instance cannot include the default-group or data-groups of any other VPN instance.
The data-group ranges for different VPN instances on different PE devices cannot overlap with one another if the PIM mode is not PIM-SSM on the public network.
If you execute this command multiple times in an MD, the most recent configuration takes effect.
After you execute this command, the default-MDT to data-MDT switchover occurs a data-delay period after the VPN multicast data that matches the switchover criterion first arrives. The switchover takes place regardless of whether the VPN multicast data keeps arriving during the period.
# Specify 239.1.2.0 through 239.1.2.255 as the data-group range for VPN instance mvpn.
[Sysname-md-mvpn] data-group 239.1.2.0 25
default-group
Use default-group to specify a default-group.
Use undo default-group to restore the default.
default-group group-address
undo default-group
The default-group is not specified.
MD view
group-address: Specifies a default-group address in the range of 224.0.1.0 to 239.255.255.255.
You must specify the same default-group on all PE devices that belong to the same VPN instance.
The default-group for a VPN instance must be different from the default-group and the data-group used by any other VPN instance.
# Specify 239.1.1.1 as the default-group for VPN instance mvpn.
[Sysname-md-mvpn] default-group 239.1.1.1
display bgp routing-table ipv4 mdt
Use display bgp routing-table ipv4 mdt to display BGP MDT routing information.
display bgp routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info ] ]
route-distinguisher route-distinguisher: Specifies a Router Distinguisher (RD), a string of 3 to 21 characters. If you do not specify an RD, this command displays information about all RDs. An RD can be in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
ip-address: Specifies a multicast source by its IP address. The ip-address argument specifies the IP address of the PE device in the default-MDT. If you do not specify a multicast source, this command displays brief information about all multicast sources.
advertise-info: Displays advertisement information. If you do not specify this keyword, no advertisement information is displayed.
# Display brief information about BGP MDT routes for all multicast sources.
<Sysname> display bgp routing-table ipv4 mdt
 Route distinguisher: 100:1
 Total number of routes: 2
* >  1.1.1.1/32         0.0.0.0                               32768   ?
* >i 2.2.2.2/32         2.2.2.2                    100        0       ?
# Display detailed information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP MDT information of source 1.1.1.1:
 Default-group   : 224.1.1.1
 Original nexthop: 0.0.0.0
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : pref-val 32768
 State           : valid, local, best
# Display advertisement information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1 advertise-info
 Paths:   1 best
 Default-group: 224.1.1.1
     6.6.6.6
BGP local router ID
ID of the local router.
Status codes
Codes of route status:
·     * – valid—Valid route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the route information:
·     i – IGP—Originated in the AS. The origins of the routes advertised by the network command are IGP.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Learned by some other means. The origins of routes redistributed by IGP are incomplete.
Total number of BGP MDT routes.
Network
Source IP address of the default-MDT.
NextHop
IP address of the next hop.
MED
Attribute value of Multi-Exit-Discrimination (MED).
LocPrf
Local preference value.
PrefVal
Preferred value of a route.
Path/Ogn
AS PATH attribute and ORIGIN attribute:
·     AS_PATH—Records the ASs the packet has passed to avoid routing loops.
·     ORIGIN—Identifies the origin of the BGP MDT routes.
Paths
Number of the BGP MDT routes:
·     available—number of valid BGP MDT routes.
·     best—Number of the best BGP MDT routes.
BGP MDT information of the multicast source 1.1.1.1.
Default-group
Default-group address to which the route belongs.
Peers to which the route has been advertised and total number of peers.
From
IP address of the BGP peer that advertises the route.
Original nexthop
IP address of the original next hop.
If the route is learned from the BGP update message, this field displays the IP address of the next hop that receives the message.
AS-path
AS PATH attribute of the path, recording the ASs it has passed to avoid routing loops.
Attribute value
Attributes of the BGP MDT routes:
·     MED—MED value related to destination network.
·     Localpref—Local preferred value.
·     pref-val—Preferred value of the route.
·     pre—Preferred value of the protocol.
Current states:
·     valid—Valid routes.
·     internal—Internal routes.
·     external—External routes.
·     local—Local routes.
·     synchronize—Synchronized routes.
·     best—Best routes.
display multicast-domain data-group receive
Use display multicast-domain data-group receive to display data-group information received by a VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
active: Specifies the data-group that has joined the data-MDT.
group group-address: Specifies a public network multicast group address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies a public network multicast source address.
vpn-source-address: Specifies a VPN multicast source address.
mask-length: Specifies a mask length of the specified VPN multicast source/group address, in the range of 0 to 32. The default value is 32.
mask: Specifies a subnet mask of the specified VPN multicast source/group address, 255.255.255.255 by default.
vpn-group-address: Specifies a VPN multicast group address in the range of 224.0.0.0 to 239.255.255.255.
# Display data-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group receive
MD data-group information received by VPN instance: mvpn
Total 2 data-groups for 8 entries
Total 2 data-groups and 8 entries matched
Data-group: 226.1.1.0   Reference count: 4   Active count: 2
  Sender: 172.100.1.1   Active count: 1
    (192.6.1.5, 239.1.1.1)       expires: 00:03:10 active
    (192.6.1.5, 239.1.1.158)     expires: 00:03:10
  Sender:  181.100.1.1, active count: 1
    (195.6.1.2, 239.1.2.12)      expires: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     expires: 00:03:10
Data-group: 229.1.1.0   Reference count: 4   Active count: 2
  Sender: 185.100.1.1   Active count: 1
    (198.6.1.5, 239.1.3.62)      expires: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     expires: 00:03:10
  Sender: 190.100.1.1   Active count: 1
    (200.6.1.2, 225.1.4.80)      expires: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     expires: 00:03:10
# Display brief data-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group receive brief
Data group: 226.1.1.0   Reference count: 4   Active count: 2
Data group: 229.1.1.0   Reference count: 4   Active count: 2
Data-group information received by VPN instance mvpn.
A total of two data-groups, associated with eight (S, G) entries.
A total of two data-groups are matching, associated with eight (S, G) entries.
Data-group
Data-group address received.
Sender
BGP peer address of the PE device that sent the data-group information.
Reference count
Number of VPN multicast groups referenced by the data-group.
Active count
Number of active VPN multicast groups (multicast groups with active receivers) referenced by the data-group.
expires
Remaining time for the VPN (S, G) entry referenced by the data-group.
display multicast-domain data-group send
Use display multicast-domain data-group send to display data-group information sent by a VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name data-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
group group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
reuse interval: Sets an interval during which the data-group address reuses occur, in the range of 1 to 2147483647 seconds.
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32.
mask: Specifies a subnet mask. The default is 255.255.255.255.
# Display data-group information sent by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group send
MD data-group information sent by VPN instance: mvpn
Total 2 data-groups for 6 entries
Total 2 data-groups and 6 entries matched
  Reference count of 226.1.1.0: 3
    (192.6.1.5, 239.1.1.1)                  switch time: 00:00:21
    (192.6.1.5, 239.1.1.158)                switch time: 00:00:21
    (192.6.1.5, 239.1.2.50)                 switch time: 00:00:05
  Reference count of 226.1.1.1: 3
    (192.6.1.2, 225.1.1.1)                  switch time: 00:00:21
    (192.6.1.2, 225.1.2.50)                 switch time: 00:00:05
    (192.6.1.5, 239.1.1.159)                switch time: 00:00:21
# Display the data-group reuse information sent by VPN instance mvpn within 30 seconds in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group send reuse 30
Total 2 data-groups for 3 entries
Total 2 data-groups and 3 entries matched
  Reuse count of 226.1.1.0: 1
  Reuse count of 226.1.1.1: 1
  Reuse count of 226.1.1.2: 1
Data-group information sent by VPN instance mvpn.
A total of two data-groups, associated with six (S, G) entries.
A total of two data-groups are matching, associated with six (S, G) entries.
Number of VPN multicast groups referenced by the sent data-group.
switch time
Switchover time of the VPN (S, G) entry referenced by the data-group.
Number of data-group reuses during the specified length of time.
display multicast-domain default-group
Use display multicast-domain default-group to display the default-group information.
display multicast-domain [ vpn-instance vpn-instance-name ] default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays default-group information of all VPN instances.
local: Displays local default-group information.
remote: Displays remote default-group information.
# Display information about local default-groups for all VPN instances.
<Sysname> display multicast-domain default-group local
MD local default-group information:
 Group address    Source address   Interface     VPN instance
 239.1.1.1        1.1.1.1          MTunnel0      mvpna
 239.2.1.1        1.1.1.1          MTunnel1      mvpnb
 239.3.1.1        --               MTunnel2      mvpnc
# Display information about remote default-groups for all VPN instances.
<Sysname> display multicast-domain default-group remote
MD remote default-group information:
 Group address   Source address  Next hop         VPN instance
 239.1.1.1       1.2.0.1         1.2.0.1          a
 239.1.1.1       1.2.0.2         1.2.0.2          a
 239.1.1.1       1.2.0.3         1.2.0.3          a
 239.1.1.2       1.2.0.1         1.2.0.1          b
 239.1.1.2       1.2.0.2         1.2.0.2          b
 239.1.1.3       1.2.0.1         1.2.0.1          -
Group address
Address of the default-group.
Source address
IP address of the MD source interface, which is used by the MTI as the source address to encapsulate the VPN multicast packets.
MTI interface.
Next hop
VPN instance
VPN instance to which the default-group belongs.
log data-group-reuse
Use log data-group-reuse to enable data-group reuse logging.
Use undo log data-group-reuse to disable data-group reuse logging.
Data-group reuse logging is disabled.
MD view
# Enable data-group reuse logging for VPN instance mvpn.
[Sysname-md-mvpn] log data-group-reuse
multicast-domain
Use multicast-domain to create an MD for a VPN instance and enter MD view.
Use undo multicast-domain to clear configurations in MD view for a VPN instance.
undo multicast-domain vpn-instance vpn-instance-name
No MD exists for a VPN instance.
# Create an MD for VPN instance mvpn and enter the MD view.
[Sysname-md-mvpn]
source
Use source to specify an MD source interface.
Use undo source to restore the default.
source interface-type interface-number
undo source
No MD source interface is specified.
MD view
For the PE device to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MD source interface.
# Specify Loopback 1 as the MD source interface for VPN instance mvpn. (Loopback 1 is the source interface used for establishing BGP peer relationship.)
[Sysname-md-mvpn] source loopback 1
