07-IP Multicast Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10007-IP Multicast Command Reference
11-IPv6 multicast VLAN commands
11-IPv6 multicast VLAN commands 64.87 KB
display ipv6 multicast-vlan
Use display ipv6 multicast-vlan to display information about IPv6 multicast VLANs.
display ipv6 multicast-vlan [ vlan-id ]
vlan-id: Specifies an IPv6 multicast VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN ID, this command displays information about all IPv6 multicast VLANs.
# Display information about all IPv6 multicast VLANs.
<Sysname> display ipv6 multicast-vlan
Total 2 IPv6 multicast VLANs.
IPv6 multicast VLAN 100:
  Sub-VLAN list(3 in total):
    2-3, 6
  Port list(3 in total):
    GE1/0/1
    GE1/0/2
    GE1/0/3
IPv6 multicast VLAN 200:
  Sub-VLAN list(0 in total):
  Port list(0 in total):
Total number of IPv6 multicast VLANs.
Sub-VLAN list of the IPv6 multicast VLAN, and the total number of the sub-VLANs.
Port list of the IPv6 multicast VLAN, and the total number of the ports.
display ipv6 multicast-vlan group
Use display ipv6 multicast-vlan group to display information about IPv6 multicast groups in IPv6 multicast VLANs.
In standalone mode:
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | slot slot-number ] | verbose | vlan vlan-id ] *
In IRF mode:
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | chassis chassis-number slot slot-number ] | verbose | vlan vlan-id ] *
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about IPv6 multicast groups for all IPv6 multicast sources in IPv6 multicast VLANs.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast group, this command displays information about all IPv6 multicast groups in IPv6 multicast VLANs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv6 multicast groups in IPv6 multicast VLANs for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. The slot number is fixed at 0 for the PEX. If you do not specify a card or PEX, this command displays information about IPv6 multicast groups in IPv6 multicast VLANs for the global active MPU. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command displays IPv6 multicast VLAN information about IPv6 multicast groups for all IPv6 multicast VLANs.
# Display detailed information about all IPv6 multicast groups in IPv6 multicast VLANs.
<Sysname> display ipv6 multicast-vlan group verbose
Total 6 entries.
IPv6 multicast VLAN 10: Total 3 entries.
  (2::2, FF0E::2)
    Flags: 0x70000020
    Sub-VLANs (1 in total):
      VLAN 40
  (22::22, FF0E::4)
    Flags: 0x70000030
      VLAN 40
  (::, FF0E::10)
    Flags: 0x10000030
      VLAN 40
IPv6 multicast VLAN 20: Total 3 entries.
  (2::2, FF0E::2)
    Flags: 0x70000010
    Sub-VLANs (0 in total):
  (22::22, FF0E::4)
    Flags: 0x70000010
  (::, FF0E::10)
    Flags: 0x50000010
Total 6 entries
Total number of (S, G) entries.
Total number of (S, G) entries in IPv6 multicast VLAN 10.
(::, FF0E::10)
(S, G) entry, where a double colon (::) in the S position means all IPv6 multicast sources.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. For example, the value 0x70000020 means that the entry has flags 0x20, 0x10000000, 0x20000000, and 0x40000000.
The following flags are available for an entry:
·     0x10—The entry is created by the IPv6 multicast VLAN.
·     0x20—The entry is created by the sub-VLAN of the IPv6 multicast VLAN.
·     0x40—The entry is to be deleted.
·     0x10000000—This value represents one of the following situations:
¡     The entry is newly created.
¡     The switch receives an MLD query within an MLD general query interval.
·     0x20000000—The switch does not receive MLDv1 or MLDv2 reports that match the entry within an MLD general query interval.
·     0x40000000—The switch does not receive MLDv2 IS_EX (NULL) reports that match the entry within an MLD general query interval.
reset ipv6 multicast-vlan group
display ipv6 multicast-vlan forwarding-table
Use display ipv6 multicast-vlan forwarding-table to display IPv6 multicast VLAN forwarding entries.
In standalone mode:
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number ] | subvlan vlan-id | vlan vlan-id ] *
In IRF mode:
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number ] | subvlan vlan-id | vlan vlan-id ] *
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays IPv6 multicast VLAN forwarding entries for all IPv6 multicast sources.
prefix-length: Specifies a prefix length of the IPv6 multicast source address. The value range is 0 to 128 and the default value is 128.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast group, this command displays information about IPv6 multicast VLAN forwarding entries for all IPv6 multicast groups.
prefix-length: Specifies a prefix length of the IPv6 multicast group address. The value range is 8 to 128 and the default value is 128.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 multicast VLAN forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. The slot number is fixed at 0 for the PEX. If you do not specify a card or PEX, this command displays IPv6 multicast VLAN forwarding entries for the global active MPU. (In IRF mode.)
subvlan vlan-id: Specifies a sub-VLAN by its ID. If you do not specify a sub-VLAN, this command displays IPv6 multicast VLAN forwarding entries for all sub-VLANs.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command displays IPv6 multicast VLAN forwarding entries for all VLANs.
# Display all IPv6 multicast VLAN forwarding entries.
<Sysname> display ipv6 multicast-vlan forwarding-table
IPv6 multicast VLAN 100 Forwarding Table
Total 1 entries, 1 matched
00001. (1::1, FF0E::1)
     Flags: 0x10000
     IPv6 multicast VLAN: 100
     List of sub-VLANs (3 in total):
       1: VLAN 10
       2: VLAN 20
       3: VLAN 30
Forwarding entries for IPv6 multicast VLAN 100.
Total number of (S, G) entries, and the number of matching entries.
00001
Sequence number of the (S, G) entry.
(1::1, FF0E::1)
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x10000 means that the entry has only one flag 0x10000.
·     0x1—The entry is in inactive state.
·     0x4—The entry fails to update.
·     0x8—The sub-VLAN information fails to update for the entry.
·     0x200—The entry is in GR state.
·     0x10000—The entry is an IPv6 multicast VLAN forwarding entry.
ipv6 multicast-vlan
Use ipv6 multicast-vlan to configure an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
Use undo ipv6 multicast-vlan to remove an IPv6 multicast VLAN.
ipv6 multicast-vlan vlan-id
undo ipv6 multicast-vlan { all | vlan-id }
A VLAN is not configured as an IPv6 multicast VLAN.
vlan-id: Specifies an existing VLAN by its VLAN ID in the range of 1 to 4094.
all: Specifies all IPv6 multicast VLANs.
As a best practice, do not configure an IPv6 multicast VLAN on a device that is enabled with IPv6 multicast routing.
For a sub-VLAN-based IPv6 multicast VLAN, you must enable MLD snooping for the IPv6 multicast VLAN and all its sub-VLANs. For a port-based IPv6 multicast VLAN, you must enable MLD snooping for the IPv6 multicast VLAN and all user VLANs to which the user ports are connected.
# Enable MLD snooping for VLAN 100. Configure VLAN 100 as an IPv6 multicast VLAN and enter its view.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] ipv6 multicast-vlan 100
[Sysname-ipv6-mvlan-100]
·     mld-snooping enable
·     ipv6 multicast routing
ipv6 multicast-vlan entry-limit
Use ipv6 multicast-vlan entry-limit to set the maximum number of IPv6 multicast VLAN forwarding entries.
Use undo ipv6 multicast-vlan entry-limit to restore the default.
ipv6 multicast-vlan entry-limit limit
The maximum number of IPv6 multicast VLAN forwarding entries is not set.
limit: Specifies the maximum number of IPv6 multicast VLAN forwarding entries, in the range of 0 to 8192.
# Set the maximum number of IPv6 multicast VLAN forwarding entries to 512.
[Sysname] ipv6 multicast-vlan entry-limit 512
entry-limit (MLD-snooping view)
ipv6 port multicast-vlan
Use ipv6 port multicast-vlan to assign a port to an IPv6 multicast VLAN.
Use undo ipv6 port multicast-vlan to restore the default.
ipv6 port multicast-vlan vlan-id
A port does not belong to an IPv6 multicast VLAN.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
A port can be assigned to only one IPv6 multicast VLAN.
# Assign GigabitEthernet 1/0/1 to IPv6 multicast VLAN 100.
[Sysname-GigabitEthernet1/0/1] ipv6 port multicast-vlan 100
port (IPv6 multicast VLAN view)
Use port to assign user ports to an IPv6 multicast VLAN.
Use undo port to remove user ports from an IPv6 multicast VLAN.
port interface-list
undo port { all | interface-list }
An IPv6 multicast VLAN does not have user ports.
interface-list: Specifies a port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number to interface-type interface-number.
all: Specifies all user ports in the current IPv6 multicast VLAN.
You can assign only Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces as user ports to an IPv6 multicast VLAN.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 as user ports to IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/5
Use reset ipv6 multicast-vlan group to clear IPv6 multicast groups in IPv6 multicast VLANs.
reset ipv6 multicast-vlan group [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | vlan vlan-id ] *
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast group, this command clears all IPv6 multicast groups in IPv6 multicast VLANs.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command clears IPv6 multicast groups for all IPv6 multicast sources in IPv6 multicast VLANs.
vlan vlan-id: Specifies an IPv6 multicast VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify an IPv6 multicast VLAN, this command clears IPv6 multicast groups for all IPv6 multicast VLANs.
# Clear all IPv6 multicast groups for all IPv6 multicast VLANs.
<Sysname> reset ipv6 multicast-vlan group
subvlan (IPv6 multicast VLAN view)
Use subvlan to assign sub-VLANs to an IPv6 multicast VLAN.
Use undo subvlan to remove sub-VLANs from an IPv6 multicast VLAN.
subvlan vlan-list
undo subvlan { all | vlan-list }
An IPv6 multicast VLAN does not have sub-VLANs.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094. The specified VLANs must exist and cannot be an IPv6 multicast VLAN or a sub-VLAN of any other IPv6 multicast VLANs.
all: Specifies all sub-VLANs of the current IPv6 multicast VLAN.
# Assign VLAN 10 through VLAN 15 as sub-VLANs to multicast VLAN 100.
[Sysname-ipv6-mvlan-100] subvlan 10 to 15
