05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
13-IPv6 fast forwarding commands
13-IPv6 fast forwarding commands 42.63 KB
display ipv6 fast-forwarding aging-time
Use display ipv6 fast-forwarding aging-time to display the aging time of IPv6 fast forwarding entries.
# Display the aging time of IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time
Aging time of IPv6 fast forwarding entries.
display ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding table information.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays IPv6 fast forwarding entries on all member devices.
This command displays IPv6 fast forwarding entries. Each entry includes the following fields:
·     Source IPv6 address
·     Source port number
·     Destination IPv6 address
·     Destination port number
·     Protocol number
·     VPN instance
·     Input and output interface
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 2002::1                                        Src port: 129
Dst IP: 2001::1                                        Dst port: 65535
Protocol: 58
VPN instance: vpn1
Input interface: FGE1/1/2
Output interface: FGE1/1/1
Src IP: 2001::1                                        Src port: 128
Dst IP: 2002::1                                        Dst port: 0
Protocol: 58
VPN instance: vpn2
Input interface: FGE1/1/1
Output interface: FGE1/1/2
Number of IPv6 fast forwarding entries.
Src IP
Source IPv6 address.
Src port
Source port number.
Dst IP
Destination IPv6 address.
Dst Port
Destination port number.
Protocol
Protocol number.
VPN instance
VPN instance.
Input interface
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output interface
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
reset ipv6 fast-forwarding cache
Use ipv6 fast-forwarding aging-time to set the aging time of IPv6 fast forwarding entries.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time of IPv6 fast forwarding entries is 30 seconds.
aging-time: Sets the aging time for IPv6 fast forwarding entries, in the range of 10 to 300 seconds.
# Set the aging time for IPv6 fast forwarding entries to 20 seconds.
[Sysname] ipv6 fast-forwarding aging-time 20
ipv6 fast-forwarding load-sharing
Use ipv6 fast-forwarding load-sharing to enable IPv6 fast-forwarding load sharing.
Use undo ipv6 fast-forwarding load-sharing to disable IPv6 fast-forwarding load sharing.
IPv6 fast-forwarding load sharing is enabled.
IPv6 fast-forwarding load sharing enables the device to identify a data flow by using the five-tuple (source IP, source port, destination IP, destination port, and protocol). The device then forwards packets of the same flow to implement load sharing.
If IPv6 fast-forwarding load sharing is disabled, the device identifies a data flow by the five-tuple and the input interface. No load sharing is implemented.
# Enable IPv6 fast-forwarding load sharing.
<Sysname> system-Views
[Sysname] ipv6 fast-forwarding load-sharing
Use reset ipv6 fast-forwarding cache to clear IPv6 fast forwarding table information.
reset ipv6 fast-forwarding cache [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command clears the IPv6 fast forwarding table information on all IRF member devices.
# Clear IPv6 fast forwarding table information.
<Sysname> reset ipv6 fast-forwarding cache
