05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
09-IP performance optimization commands
09-IP performance optimization commands 125.93 KB
display icmp statistics
Use display icmp statistics to display ICMP statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays ICMP statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command displays ICMP statistics for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
ICMP statistics include information about received and sent ICMP packets.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          175                 destination unreachable 0
         source quench 0                   redirects               0
         echo replies  201                 parameter problem       0
         timestamp     0                   information requests    0
         mask requests 0                   mask replies            0
         time exceeded 0                   invalid type            0
         router advert 0                   router solicit          0
         broadcast/multicast echo requests ignored            0
         broadcast/multicast timestamp requests ignored       0
 Output: echo          0                   destination unreachable 0
         echo replies  175                 parameter problem       0
         timestamp     0                   information replies     0
         time exceeded 0                   bad address             0
         packet error  1442                router advert           3
display ip statistics
Use display ip statistics to display IP packet statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays IP packet statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command displays IP packet statistics for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
IP statistics include information about received and sent packets and reassembly.
# Display IP packet statistics.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Input
sum
Total number of packets received.
local
Total number of packets destined for the device.
bad protocol
Total number of unknown protocol packets.
bad format
Total number of packets with incorrect format.
bad checksum
Total number of packets with incorrect checksum.
bad options
Total number of packets with incorrect option.
Output
forwarding
Total number of packets forwarded.
local
Total number of packets locally sent.
dropped
Total number of packets discarded.
no route
Total number of packets for which no route is available.
compress fails
Total number of packets failed to be compressed.
Fragment
input
Total number of fragments received.
output
Total number of fragments sent.
dropped
Total number of fragments dropped.
fragmented
Total number of packets successfully fragmented.
couldn't fragment
Total number of packets failed to be fragmented.
Reassembling
sum
Total number of packets reassembled.
timeouts
Total number of reassembly timeouts.
·     display ip interface
·     reset ip statistics
display rawip
Use display rawip to display brief information about RawIP connections.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays brief information about RawIP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
Brief RawIP connection information includes local and peer addresses, protocol, and PCB.
# Display brief information about RawIP connections.
<Sysname> display rawip
 Local Addr       Foreign Addr     Protocol  Slot  CPU PCB
 0.0.0.0          0.0.0.0          1         1     0   0x0000000000000009
 0.0.0.0          0.0.0.0          1         1     0   0x0000000000000008
 0.0.0.0          0.0.0.0          1         5     0   0x0000000000000002
Local Addr
Local IP address.
Foreign Addr
Peer IP address.
Protocol
Protocol number.
Slot
ID of the IRF member device.
CPU
CPU number.
PCB
Protocol control block.
display rawip verbose
Use display rawip verbose to display detailed information about RawIP connections.
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed RawIP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB. The index value range is 1 to 16.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays detailed information about RawIP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
The detailed information includes socket creator, state, option, type, protocol number, and the source and destination IP addresses of RawIP connections.
# Display detailed information about RawIP connections.
<Sysname> display rawip verbose
Total RawIP socket number: 1
 Slot: 6 CPU: 0
 Creator: ping[320]
 State: N/A
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/state): 0 / 9216 / 1 / N/A
 Type: 3
 Protocol: 1
 Connection info: src = 0.0.0.0, dst = 0.0.0.0
 Inpcb flags: N/A
 Inpcb vflag: INP_IPV4
 TTL: 255(minimum TTL: 0)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Total number of RawIP sockets.
Slot
CPU
CPU number.
Creator
Name of the operation that created the socket. The number in brackets is the process number of the creator.
State of the socket.
Options
Socket options.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/state)
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     RCVATMARK—Receiving tag.
¡     N/A—None of the above states.
Sending buffer (cc/hiwat/lowat/state)
Displays send buffer information in the following order:
·     cc—Used space.
Socket type:
·     1—SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2—SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3—SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of the protocol using the socket.
Connection info
Source IP address and destination IP address.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IP options.
·     INP_RECVRETOPTS—Receives replied IP options.
·     INP_RECVDSTADDR—Receives destination IP address.
·     INP_HDRINCL—Provides the entire IP header.
·     INP_REUSEADDR—Reuses the IP address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_RECVIF—Records the input interface of the packet.
·     INP_RECVTTL—Receives TTL of the packet. Only UDP and RawIP support this flag.
·     INP_DONTFRAG—Sets the Don't Fragment flag.
·     INP_ROUTER_ALERT—Receives packets with the router alert option. Only RawIP supports this flag.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_SNDBYLSPV—Sends through MPLS.
·     INP_RECVTOS—Receives TOS of the packet. Only UDP and RawIP support this flag.
·     INP_USEICMPSRC—Uses the specified IP address as the source IP address for outgoing ICMP packets.
·     INP_SYNCPCB—Waits until Internet PCB is synchronized.
·     N/A—None of the above flags.
Inpcb vflag
IP version flags in the Internet PCB:
·     INP_IPV4—IPv4 protocol.
·     INP_TIMEWAIT—In TIMEWAIT state.
·     INP_ONESBCAST—Sends broadcast packets.
·     INP_DROPPED—Protocol dropped flag.
·     INP_SOCKREF—Strong socket reference.
·     INP_DONTBLOCK—Do not block synchronization of the Internet PCB.
TTL
TTL value in the Internet PCB.
display tcp
Use display tcp to display brief information about TCP connections.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays brief information about TCP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
Brief TCP connection information includes local IP address, local port number, peer IP address, peer port number, and TCP connection state.
# Display brief information about TCP connections.
<Sysname> display tcp
 *: TCP MD5 Connection
 Local Addr:port       Foreign Addr:port     State       Slot  CPU PCB
*0.0.0.0:21            0.0.0.0:0             LISTEN      1     0   0x000000000000c387
 192.168.20.200:23     192.168.20.14:1284    ESTABLISHED 1     0   0x0000000000000009
 192.168.20.200:23     192.168.20.14:1283    ESTABLISHED 1     0   0x0000000000000002
Indicates that the TCP connection uses MD5 authentication.
Local Addr:port
Local IP address and port number.
Foreign Addr:port
Peer IP address and port number.
Slot
CPU
CPU number.
PCB
PCB index.
display tcp statistics
Use display tcp statistics to display TCP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays TCP traffic statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command displays TCP traffic statistics for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
TCP traffic statistics include information about received and sent TCP packets and Syncache/syncookie.
# Display TCP traffic statistics.
<Sysname> display tcp statistics
Received packets:
    Total: 4150
    packets in sequence: 1366 (134675 bytes)
    window probe packets: 0, window update packets: 0
    checksum error: 0, offset error: 0, short error: 0
    packets dropped for lack of memory: 0
    packets dropped due to PAWS: 0
    duplicate packets: 12 (36 bytes), partially duplicate packets: 0 (0 bytes)
    out-of-order packets: 0 (0 bytes)
    packets with data after window: 0 (0 bytes)
    packets after close: 0
    ACK packets: 3531 (795048 bytes)
    duplicate ACK packets: 33, ACK packets for unsent data: 0
Sent packets:
    Total: 4058
    urgent packets: 0
    control packets: 50
    window probe packets: 3, window update packets: 11
    data packets: 3862 (795012 bytes), data packets retransmitted: 0 (0 bytes)
    ACK-only packets: 150 (52 delayed)
    unnecessary packet retransmissions: 0
Syncache/syncookie related statistics:
    entries added to syncache: 12
    syncache entries retransmitted: 0
    duplicate SYN packets: 0
    reply failures: 0
    successfully build new socket: 12
    bucket overflows: 0
    zone failures: 0
    syncache entries removed due to RST: 0
    syncache entries removed due to timed out: 0
    ACK checked by syncache or syncookie failures: 0
    syncache entries aborted: 0
    syncache entries removed due to bad ACK: 0
    syncache entries removed due to ICMP unreachable: 0
    SYN cookies sent: 0
    SYN cookies received: 0
SACK related statistics:
    SACK recoveries: 1
    SACK retransmitted segments: 0 (0 bytes)
    SACK blocks (options) received: 0
    SACK blocks (options) sent: 0
    SACK scoreboard overflows: 0
Other statistics:
    retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
    persist timeout: 0
    keepalive timeout: 21, keepalive probe: 0
    keepalive timeout, so connections disconnected: 0
    fin_wait_2 timeout, so connections disconnected: 0
    initiated connections: 29, accepted connections: 12, established connections:
23
    closed connections: 50051 (dropped: 0, initiated dropped: 0)
    bad connection attempt: 0
    ignored RSTs in the window: 0
    listen queue overflows: 0
    RTT updates: 3518(attempt segment: 3537)
    correct ACK header predictions: 0
    correct data packet header predictions: 568
    resends due to MTU discovery: 0
    packets dropped with MD5 authentication: 0
    packets permitted with MD5 authentication: 0
reset tcp statistics
display tcp verbose
Use display tcp verbose to display detailed information about TCP connections.
pcb pcb-index: Displays detailed TCP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB. The index value range is 1 to 16.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays detailed information about TCP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
The detailed TCP connection information includes socket creator, state, option, type, protocol number, source IP address and port number, destination IP address and port number, and connection state.
# Display detailed information about TCP connections.
<Sysname> display tcp verbose
 Slot: 6 CPU: 0
 NSR standby: N/A
 Creator: bgpd[199]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/state): 0 / 65700 / 1 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65700 / 512 / N/A
 Type: 1
 Protocol: 6
 Connection info: src = 192.168.20.200:179 ,  dst = 192.168.20.14:4181
 Inpcb flags: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Send VRF: 0x0
 Receive VRF: 0x0
Table 5 Command output
TCP inpcb number
Number of TCP IP PCBs.
tcpcb number
Number of TCP PCBs.
Slot
CPU
CPU number.
NSR standby
ID of the IRF member device where the NSR standby card resides.
Creator
Options
Socket options.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Connection info
Inpcb flags
Inpcb vflag
TTL
NSR state
State of the TCP connections.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
display udp
Use display udp to display brief information about UDP connections.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays brief information about UDP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
Brief UDP connection information includes local IP address and port number, and peer IP address and port number.
# Display brief information about UDP connections.
<Sysname> display udp
 Local Addr:port        Foreign Addr:port     Slot  CPU PCB
 0.0.0.0:69             0.0.0.0:0             1     0   0x0000000000000003
 192.168.20.200:1024    192.168.20.14:69      5     0   0x0000000000000002
Table 6 Command output
Local Addr:port
Foreign Addr:port
Slot
CPU
CPU number.
PCB
PCB index.
display udp statistics
Use display udp statistics to display UDP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays UDP traffic statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command displays UDP traffic statistics for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
UDP traffic statistics include information about received and sent UDP packets.
# Display UDP traffic statistics.
<Sysname> display udp statistics
Received packets:
     Total: 240
     checksum error: 0, no checksum: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port(unicast): 0
     no socket on port(broadcast/multicast): 240
     not delivered, input socket full: 0
Sent packets:
     Total: 0
reset udp statistics
display udp verbose
Use display udp verbose to display detailed information about UDP connections.
pcb pcb-index: Displays detailed UDP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB. The index value range is 1 to 16.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays detailed information about UDP connections for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
The detailed information includes socket creator, status, option, type, protocol number, source IP address and port number, and destination IP address and port number for UDP connections.
# Display detailed UDP connection information.
<Sysname> display udp verbose
Total UDP socket number: 1
 Slot: 6 CPU: 0
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/state): 0 / 41600 / 1 / N/A
 Type: 2
 Protocol: 17
 Connection info: src = 0.0.0.0:69, dst = 0.0.0.0:0
 Inpcb flags: N/A
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 7 Command output
Total number of UDP sockets.
Slot
CPU
CPU number.
Creator
Socket state.
Options
Socket option.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb vflag
TTL
ip forward-broadcast
Use ip forward-broadcast to enable an interface to receive and forward directed broadcast packets destined for the directly connected network.
Use undo ip forward-broadcast to disable an interface from receiving and forwarding directed broadcast packets destined for the directly connected network.
An interface cannot forward directed broadcasts destined for the directly connected network but can receive directed broadcasts destined for the directly connected network.
Interface view
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
If an interface is allowed to forward directed broadcasts destined for the directly connected network, hackers can exploit this vulnerability to attack the target network. In some scenarios, however, an interface must receive and send such directed broadcast packets to support UDP helper and Wake on LAN.
This command enables an interface to accept directed broadcast packets that are destined for and received from the directly connected network to support UDP helper. UDP helper converts the directed broadcasts to unicasts and forwards them to a specific server.
The command also enables the interface to forward directed broadcast packets that are destined for the directly connected network and are received from another subnet to support Wake on LAN. Wake on LAN sends the directed broadcasts to wake up the hosts on the target network.
# Enable VLAN-interface 2 to receive and forward directed broadcast packets destined for the directly connected network.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp error-interval
Use ip icmp error-interval to set the bucket size and the interval for tokens to arrive in the bucket for ICMP error messages.
Use undo ip icmp error-interval to restore the default.
ip icmp error-interval milliseconds [ bucketsize ]
The bucket allows a maximum of 10 tokens, and a token is placed in the bucket every 100 milliseconds.
milliseconds: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds, and the default is 100 milliseconds. To disable the ICMP rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200, and the default is 10.
This command limits the rate at which ICMP error messages are sent. Use this command to avoid sending excessive ICMP error messages within a short period that might cause network congestion. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
# Set the bucket size to 40 tokens and the interval for tokens to arrive in the bucket to 200 milliseconds for ICMP error messages.
[Sysname] ip icmp error-interval 200 40
ip icmp fragment discarding
Use ip icmp fragment discarding to disable forwarding of ICMP fragments.
Use undo ip icmp fragment discarding to enable forwarding of ICMP fragments.
Forwarding of ICMP fragments is enabled.
Disabling forwarding of ICMP fragments can prevent ICMP fragment attacks.
# Disable forwarding of ICMP fragments.
[Sysname] ip icmp fragment discarding
ip icmp source
Use ip icmp source to enable specifying the source address for outgoing ICMP packets.
Use undo ip icmp source to restore the default.
undo ip icmp source [ vpn-instance vpn-instance-name ]
The device uses the IP address of the sending interface as the source IP address for outgoing ICMP packets.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the specified address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If the specified IP address is on the public network, do not use this option.
ip-address: Specifies an IP address.
It is a good practice to specify the IP address of the loopback interface as the source IP address for outgoing ping echo request and ICMP error messages. This feature helps users to locate the sending device easily.
# Specify 1.1.1.1 as the source address for outgoing ICMP packets.
[Sysname] ip icmp source 1.1.1.1
ip mtu
Use ip mtu to set an MTU for an interface.
Use undo ip mtu to restore the default.
ip mtu mtu-size
undo ip mtu
No MTU is set for an interface.
Interface view
mtu-size: Specifies an MTU in the range of 128 to 2000 bytes.
When a packet exceeds the MTU of the output interface, the device processes it in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set an appropriate MTU for an interface to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments a packet based on the MTU set by the ip mtu command.
# Set the MTU of VLAN-interface 100 to 1280 bytes.
[Sysname-Vlan-interface100] ip mtu 1280
ip redirects enable
Use ip redirects enable to enable sending ICMP redirect messages.
Use undo ip redirects enable to disable sending ICMP redirect messages.
ip redirects enable
Sending ICMP redirect messages is disabled.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing tables.
A host that has only one route destined for the default gateway sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop by following these rules:
·     The receiving and sending interfaces are the same.
·     The selected route is not created or modified by any ICMP redirect messages.
·     The selected route is not destined for 0.0.0.0.
·     There is no source route option in the received packet.
Layer 3 Ethernet interfaces and Layer 3 aggregate Ethernet interfaces do not support sending ICMP redirect messages.
# Enable sending ICMP redirect messages.
[Sysname] ip redirects enable
ip ttl-expires enable
Use ip ttl-expires enable to enable sending ICMP time exceeded messages.
Use undo ip ttl-expires enable to disable sending ICMP time exceeded messages.
Sending ICMP time exceeded messages is disabled.
A device sends ICMP time exceeded messages by following these rules:
·     The device sends an ICMP TTL exceeded in transit message to the source when the following conditions are met:
¡     The received packet is not destined for the device.
¡     The TTL field of the packet is 1.
·     When the device receives the first fragment of an IP datagram destined for the device itself, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
A device disabled from sending ICMP time exceeded messages does not send ICMP TTL exceeded in transit messages but can still send ICMP fragment reassembly time exceeded messages.
# Enable sending ICMP time exceeded messages.
[Sysname] ip ttl-expires enable
ip unreachables enable
Use ip unreachables enable to enable sending ICMP destination unreachable messages.
Use undo ip unreachables enable to disable sending ICMP destination unreachable messages.
Sending ICMP destination unreachable messages is disabled.
A device sends ICMP destination unreachable messages by following these rules:
·     The device sends the source an ICMP network unreachable message when the following conditions are met:
¡     The received packet does not match any route.
¡     No default route exists in the routing table.
·     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡     The received packet is destined for the device.
¡     The transport layer protocol of the packet is not supported by the device.
·     The device sends the source an ICMP port unreachable message when the following conditions are met:
¡     The received UDP packet is destined for the device.
¡     The packet's port number does not match the running process.
·     The device sends the source an ICMP source route failed message when the following conditions are met:
¡     The source uses Strict Source Routing to send packets.
¡     The intermediate device finds that the next hop specified by the source is not directly connected.
·     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡     The MTU of the sending interface is smaller than the packet.
¡     The packet has Don't Fragment set.
# Enable sending ICMP destination unreachable messages.
[Sysname] ip unreachables enable
reset ip statistics
Use reset ip statistics to clear IP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command clears IP traffic statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command clears IP traffic statistics for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
Use this command to clear history IP traffic statistics before you collect IP traffic statistics for a time period.
# Clear IP traffic statistics.
<Sysname> reset ip statistics
·     display ip statistics
Use reset tcp statistics to clear TCP traffic statistics.
# Clear TCP traffic statistics.
<Sysname> reset tcp statistics
Use reset udp statistics to clear UDP traffic statistics.
# Clear UDP traffic statistics.
<Sysname> reset udp statistics
tcp mss
Use tcp mss to set the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
No TCP MSS is set.
Interface view
value: Specifies the TCP MSS in the range of 128 to 2048 bytes.
This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
This configuration is effective only on IP packets. If MPLS is enabled on the interface, do not set the TCP MSS on the interface.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment.
If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, it fragments the segment according to the receiver's MSS.
If you set a TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
# Set the TCP MSS to 300 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] tcp mss 300
tcp path-mtu-discovery
Use tcp path-mtu-discovery to enable TCP path MTU discovery.
Use undo tcp path-mtu-discovery to disable TCP path MTU discovery.
TCP path MTU discovery is disabled.
aging age-time: Specifies the aging time for the path MTU, in the range of 10 to 30 minutes. The default aging time is 10 minutes.
no-aging: Does not age out the path MTU.
After you enable TCP path MTU discovery, all new TCP connections detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
After you disable TCP path MTU discovery, the system stops all path MTU timers. The TCP connections established later do not detect the path MTU, but the TCP connections previously established still can detect the path MTU.
# Enable TCP path MTU discovery and set the path MTU aging time to 20 minutes.
[Sysname] tcp path-mtu-discovery aging 20
tcp syn-cookie enable
Use tcp syn-cookie enable to enable SYN Cookie to protect the device from SYN flood attacks.
Use undo tcp syn-cookie enable to disable SYN Cookie.
SYN Cookie is disabled.
A TCP connection is established through a three-way handshake:
1.     The sender sends a SYN packet to the server.
2.     The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3.     The sender receives the SYN ACK packet and replies with an ACK packet. Then, a TCP connection is established.
An attacker can exploit this mechanism to mount SYN flood attacks. The attacker sends a large number of SYN packets, but they do not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and cannot handle normal services.
SYN Cookie can protect the server from SYN flood attacks. When the server receives a SYN packet, it responds to the request with a SYN ACK packet without establishing a TCP semi-connection.
The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the sender.
# Enable SYN Cookie.
[Sysname] tcp syn-cookie enable
tcp timer fin-timeout
Use tcp timer fin-timeout to set the TCP FIN wait timer.
Use undo tcp timer fin-timeout to restore the default.
The TCP FIN wait timer is 675 seconds.
time-value: Specifies the TCP FIN wait timer in the range of 76 to 3600 seconds.
TCP starts the FIN wait timer when the state changes to FIN_WAIT_2. If no FIN packet is received within the timer interval, the TCP connection is terminated.
If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer and tears down the connection when the timer expires.
# Set the TCP FIN wait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
tcp timer syn-timeout
Use tcp timer syn-timeout to set the TCP SYN wait timer.
Use undo tcp timer syn-timeout to restore the default.
The TCP SYN wait timer is 75 seconds.
time-value: Specifies the TCP SYN wait timer in the range of 2 to 600 seconds.
TCP starts the SYN wait timer after sending a SYN packet. If no response packet is received within the SYN wait timer interval, TCP fails to establish the connection.
# Set the TCP SYN wait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp window
Use tcp window to set the size of the TCP receive/send buffer.
Use undo tcp window to restore the default.
tcp window window-size
undo tcp window
The size of the TCP receive/send buffer is 64 KB.
window-size: Specifies the size of the TCP receive/send buffer in KB, in the range of 1 to 64.
# Set the size of the TCP receive/send buffer to 3 KB.
[Sysname] tcp window 3
