05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
06-Fast forwarding commands
06-Fast forwarding commands 45.36 KB
display ip fast-forwarding aging-time
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
 Aging time: 30s
display ip fast-forwarding cache
Use display ip fast-forwarding cache to display fast forwarding table information.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify the ip-address argument, this command displays all fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays fast forwarding entries on all member devices.
This command displays fast forwarding entries. Each entry includes the source IP address, source port number, destination IP address, destination port number, protocol number, input and output interfaces, and internal tag of a data flow.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 2
SIP             SPort DIP             DPort Pro Input_If    Output_If   Flg
192.168.0.71    23    192.168.0.18    3313  6   InLoop0     M-GE0/0/0   1
192.168.0.18    3313  192.168.0.71    23    6   M-GE0/0/0   InLoop0     1
SIP
Source IP address.
SPort
Source port number.
DIP
Destination IP address.
DPort
Destination port number.
Pro
Protocol number.
Input_If
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output_If
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
Flg
Internal tag, marking internal operation information, such as fragmentation.
reset ip fast-forwarding cache
display ip fast-forwarding fragcache
Use display ip fast-forwarding fragcache to display fast forwarding table information for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify this argument, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays fast forwarding entries for the fragmented packets on all member devices.
This command displays fast forwarding entries for fragmented packets. Each entry includes the source IP address, source port number, destination IP address, destination port number, protocol number, input interface, and fragment ID.
# Display fast forwarding table information about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 2
SIP             SPort DIP             DPort Pro Input_If    ID
7.0.0.13        68    8.0.0.1         67    17  InLoop0     2
8.0.0.1         67    7.0.0.13        68    17  M-GE0/0/0   3
SIP
Source IP address.
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
Input_If
ID
Fragment ID.
Use ip fast-forwarding aging-time to configure the aging time of fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time of fast forwarding entries is 30 seconds.
aging-time: Specifies the aging time for fast forwarding entries, in the range of 10 to 300 seconds.
# Set the aging time of fast forwarding entries to 20 seconds.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding load-sharing
Use ip fast-forwarding load-sharing to enable fast-forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast-forwarding load sharing.
Fast-forwarding load sharing is enabled.
Fast-forwarding load sharing enables the device to identify a data flow by using the five-tuple (source IP, source port, destination IP, destination port, and protocol). The device then forwards packets of the same flow to implement load sharing.
If fast-forwarding load sharing is disabled, the device identifies a data flow by the five-tuple and the input interface. No load sharing is implemented.
# Enable fast-forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
Use reset ip fast-forwarding cache to clear fast forwarding table information.
reset ip fast-forwarding cache [ slot slot-number ]
Predefined use roles
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command clears fast forwarding table information on all IRF member devices.
# Clear fast forwarding table information.
<Sysname> reset ip fast-forwarding cache
·     display ip fast-forwarding cache
·     display ip fast-forwarding fragcache
