05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
02-IP addressing commands
02-IP addressing commands 49.96 KB
display ip interface
Use display ip interface to display IP configuration and statistics for the specified Layer 3 interface or all Layer 3 interfaces.
display ip interface [ interface-type interface-number ]
Use the display ip interface command to display IP configuration and statistics for the specified Layer 3 interface. The statistics include the following information:
·     The number of unicast packets, bytes, and multicast packets the interface has sent and received.
·     The number of TTL-invalid packets and ICMP packets the interface has received.
The packet statistics helps you locate a possible attack on the network.
If you do not specify an interface, the command displays information about all Layer 3 interfaces.
# Display IP configuration and statistics for VLAN-interface 10.
<Sysname> display ip interface vlan-interface 10
Vlan-interface10 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
current state
Current physical state of the interface:
·     Administrative DOWN—The interface is shut down with the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down, which might be caused by a connection or link failure.
·     UP—Both the administrative and physical states of the interface are up.
Current state of the link layer protocol:
·     DOWN—The protocol state of the interface is down.
·     UP—The protocol state of the interface is up.
·     UP (spoofing)—The protocol state of the interface pretends to be up. However, no corresponding link is present, or the corresponding link is not present permanently but is established as needed.
Internet Address
IP address of an interface followed by:
·     Primary—A primary IP address.
·     Sub—A secondary IP address.
·     MTunnel—An MTunnel interface IP address.
·     SSLVPN—An SSL VPN interface IP address.
·     PPP-Negotiated—A PPP negotiated IP address.
·     Unnumbered—An unnumbered IP address.
·     DHCP-Allocated—An IP address obtained through DHCP.
·     BOOTP-Allocated—An IP address obtained through BOOTP.
·     Cluster—A cluster IP address.
·     Mad—A MAD IP address.
Broadcast address
Broadcast address of the subnet attached to an interface.
Maximum transmission units on the interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
Unicast packets, bytes, and multicast packets received on an interface (statistics start at the device startup).
Number of TTL-invalid packets received on the interface (statistics start at the device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at the device startup):
·     Echo reply packets.
·     Unreachable packets.
·     Source quench packets.
·     Routing redirect packets.
·     Echo request packets.
·     Router advertisement packets.
·     Router solicitation packets.
·     Time exceeded packets.
·     IP header bad packets.
·     Timestamp request packets.
·     Timestamp reply packets.
·     Information request packets.
·     Information reply packets.
·     Netmask request packets.
·     Netmask reply packets.
·     Unknown type packets.
·     display ip interface brief
·     ip address
Use display ip interface brief to display brief IP configuration information for the specified Layer 3 interface or all Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief
interface-type: Specifies the interface type.
interface-number: Specifies the interface number.
Information displayed by the command includes the state of the physical and link layer protocols, IP address, and interface descriptions.
If you do not specify the interface type and interface number, the command displays the brief IP configuration information for all Layer 3 interfaces.
If you specify only the interface type, the command displays the brief IP configuration information for all Layer 3 interfaces of the specified type.
If you specify both the interface type and interface number, the command displays the brief IP configuration information for the specified interface.
# Display brief IP configuration information for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface                Physical Protocol IP Address      Description
Vlan10                   down     down     6.6.6.1         Link to CoreRo...
Vlan2                    down     down     7.7.7.1         --
The interface is administratively shut down with the shutdown command.
(s) : spoofing
Spoofing attribute of the interface. It indicates that an interface might have no link present even when its link layer protocol is up or the link is established only on demand.
Interface name.
Physical
Physical state of the interface:
·     *down—The interface is administratively shut down with the shutdown command.
·     down—The interface is administratively up but its physical state is down (possibly because of poor connection or line failure).
·     up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the interface:
·     down—The protocol state of the interface is down.
·     down(l)—The protocol state of the interface is down (loopback).
·     up—The protocol state of the interface is up.
·     up(l)—The protocol state of the interface is up (loopback).
·     up(s)—The protocol state of the interface is up (spoofing).
IP Address
IP address of the interface. If no IP address is configured, this field displays hyphens (--).
Interface description information. If no description is configured, this field displays hyphens (--).
·     ip address
ip address
Use ip address to assign an IP address to the interface.
Use undo ip address to remove the IP address from the interface.
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
No IP address is assigned to an interface.
Interface view
ip-address: Specifies the IP address of the interface, in dotted decimal notation.
mask-length: Specifies the subnet mask length in the range of 1 to 31. For a loopback interface, the value range is 1 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
sub: Assigns a secondary IP address to the interface.
Use the command to configure a primary IP address for an interface. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
An interface can have only one primary IP address. A newly configured primary IP address overwrites the previous address.
You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP or DHCP.
The undo ip address command removes all IP addresses from the interface. The undo ip address ip-address { mask | mask-length } command removes the primary IP address. The undo ip address ip-address { mask | mask-length } sub command removes a secondary IP address. Before removing the primary IP address, remove all secondary IP addresses.
The primary and secondary IP addresses assigned to the interface can be located on the same network segment. Different interfaces on your device must reside on different network segments.
# Assign VLAN-interface 10 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1, with subnet masks both 255.255.255.0.
[Sysname-Vlan-interface10] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface10] ip address 202.38.160.1 255.255.255.0 sub
ip address unnumbered
Use ip address unnumbered to configure the current interface as IP unnumbered to borrow an IP address from the specified interface.
Use undo ip address unnumbered to disable IP unnumbered on the interface.
The interface does not borrow IP addresses from other interfaces.
Tunnel interface view
interface interface-type interface-number: Specifies an interface from which the current interface can borrow an IP address.
Typically, you assign an IP address to an interface either manually or through DHCP. If the IP addresses are not enough, or the interface is used only occasionally, you can configure an interface to borrow an IP address from other interfaces. This is called IP unnumbered, and the interface borrowing the IP address is called IP unnumbered interface.
Multiple interfaces can use the same unnumbered IP address. If an interface has multiple manually configured IP addresses, only the primary IP address manually configured can be borrowed.
You cannot enable a dynamic routing protocol on the interface that has no IP address configured. To enable the interface to communicate with other devices, you must configure a static route to the peer device on the interface.
Before entering tunnel interface view, make sure the tunnel interface has been created. For information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
# Configure the interface Tunnel 1 to borrow the IP address of VLAN-interface 100.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] ip address unnumbered interface vlan-interface 100
