05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
07-Adjacency table commands
07-Adjacency table commands 49.91 KB
IPv4 adjacency table commands
Use this feature to check the adjacency entries on tunnel interfaces. For information about tunnel interfaces, see "Configuring tunneling."
display adjacent-table
Use display adjacent-table to display IPv4 adjacency entries.
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
View
all: Displays all IPv4 adjacency entries.
physical-interface interface-type interface-number: Displays IPv4 adjacency entries for the specified physical interface.
routing-interface interface-type interface-number: Displays IPv4 adjacency entries for the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays IPv4 adjacency entries for all member devices if you do not specify a member device. On an IRF 3 system, this command displays IPv4 adjacency entries for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
count: Displays the number of IPv4 adjacency entries.
verbose: Displays detailed information about IPv4 adjacency entries.
# Display detailed information about all IPv4 adjacency entries.
   IP address                    : 0.0.0.0
   Routing interface             : Tunnel1
   Physical interface            : Tunnel1
   Logical interface             : N/A
   Service type                  : Tunnel
   Action type                   : Forwarding
   Link media type               : P2P
   Slot                          : 7
   Cpu                           : 0
   VPN Index                     : 0
   Virtual circuit information   : N/A
   Link head information(IP)     : 4500000000000000ff2f0000393939073939390500000
800
   Link head information(MPLS)   : 4500000000000000ff2f0000393939073939390500000
800
# Display the IPv4 adjacency entries on IRF member device 1.
<Sysname> display adjacent-table slot 1
IP address       Routing interface     Physical interface    Type     Slot Cpu
0.0.0.0           Tun1                      Tun1                      Tunnel
# Display the number of IPv4 adjacency entries on IRF member device 1.
<Sysname> display adjacent-table slot 1 count
 Total entries on slot 1: 1
IP address
IP address of the next hop.
·     For a P2P link, the IP address of the next hop is not needed. This field displays 0.0.0.0.
·     For an NBMA link, the value 0.0.0.0 indicates the default adjacency entry. Packets are forwarded through the default virtual circuit.
Routing interface
Output interface of the matching route entry.
Physical interface
Physical interface of which the outgoing packets are sent out.
Logical interface
Logical interface for sending the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Link layer protocol type, such as Tunnel.
Action type
Packet processing type, Forwarding or Drop.
Link media type
Link media type:
·     P2P—Point-to-point link.
·     NBMA—Non-broadcast multi-access link.
Slot
Member ID of the IRF member device.
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Information about the virtual circuit, such as PVC or DLCI. If the entry has no virtual circuit, this field displays N/A.
Link layer header for IPv4.
Link layer header for MPLS.
IPv6 adjacency table commands
display ipv6 adjacent-table
Use display ipv6 adjacent-table to display IPv6 adjacency entries.
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
all: Displays all IPv6 adjacency entries.
physical-interface interface-type interface-number: Displays IPv6 adjacency entries for the specified physical interface.
routing-interface interface-type interface-number: Displays IPv6 adjacency entries for the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays IPv6 adjacency entries for all member devices if you do not specify a member device. On an IRF 3 system, this command displays IPv6 adjacency entries for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
count: Displays the total number of IPv6 adjacency entries.
verbose: Displays detailed information about IPv6 adjacency entries.
# Display detailed information about all IPv6 adjacency entries.
<Sysname> display ipv6 adjacent-table all verbose
   IPv6 address                  : N/A
   Routing interface             : Tunnel2
   Physical interface            : Tunnel2
   Slot                          : 7
   Cpu                           : 0
   VPN index                     : 0
   Link head information(IPv6)   : 60000000000000ff00010000000000000000000000000
00100010000000000000000000000000002000086dd
# Display the IPv6 adjacency entries on IRF member device 1.
<Sysname> display ipv6 adjacent-table slot 1
IPv6 address          Routing interface        Physical interface       Type
N/A                   Tun2                     Tun2                     Tunnel
# Display the total number of IPv6 adjacency entries on IRF member device 1.
<Sysname> display ipv6 adjacent-table slot 1 count
IPv6 address
IPv6 address of the next hop.
·     For a P2P link, the IPv6 address of the next hop is not needed. This field has the value 0::0, and displays N/A.
·     For an NBMA link, the value 0.0.0.0 indicates a default adjacency table. Packets are forwarded through the default virtual circuit.
Routing interface
Physical interface
Logical interface
Logical interface that sends the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Action type
Link media type
Link media type:
Slot
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Link layer header for IPv6.
