10 High Availability Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10010 High Availability Configuration Guide
10-Process placement configuration
10-Process placement configuration 87.53 KB
Overview
Process placement enables placing processes to specific CPUs (also called nodes) in your system for optimal distribution of CPU and memory resources.
Process
A process comprises a set of codes and provides specific functionality. For example, an AAA process provides AAA functions.
Each process runs in a protected memory space to prevent problems with one process from impacting the entire system.
1:N process redundancy
The system backs up each active process running on one node to all the other nodes. When an active process fails, one of its standby processes promptly takes over without impacting any other service.
Each CPU in the system corresponds to a node. On a device, only one CPU exists. The system cannot support 1:N process redundancy. All active processes are running on this CPU. In an IRF fabric, multiple CPUs exist. The system can perform 1:N process redundancy. An active process can run on each CPU.
This 1:N process redundancy does the following:
·     Improves service availability.
·     Enables the system to quickly regain reliability after device status changes, including the following:
?     IRF split.
?     Removal of an IRF member.
Process placement policy and optimization
Process placement policies
For an active process running only on the master device, it does not support placement optimization (by displaying a configuration failure prompt). When such an active process fails, the system automatically restarts the process. The standby processes are used for active/standby switchover and ISSU.
Some active processes can run on either the master or subordinate device. When such an active process fails, the system uses a placement policy to select a new active process among standby processes.
The system provides a default process placement policy that takes effect for all processes. You can modify the default placement policy in the view you enter with the placement program default command. You can also configure a placement policy for a specific process in the view you enter with the placement program program-name [ instance instance-name ] command. A placement policy for a process takes precedence over the default process placement policy.
By default, the default process placement policy defines the following rules:
·     The active process runs on the main CPU of the master, and the standby processes run on other CPUs.
·     A process runs at the location where it ran the last time and does not move to any other location during startup or operation.
·     The addition of a new node does not impact current active processes. A new active process selects one node with sufficient CPU and memory resources. (You can use the display cpu-usage and display memory commands to view CPU and memory usage information.)
Optimizing process placement
You can configure the following settings for a process placement policy to optimize process placement:
·     affinity location-set—Location affinity, the preference for the process to run on a specific node.
·     affinity location-type—Location type affinity, the preference for the process to run on a particular type of node. For more information about node types, see "Configuring a location type affinity."
·     affinity program—Process affinity, the preference for the process to run on the same node as a particular process.
·     affinity self—Self affinity, the preference for one instance of the process to run on the same node as any other instance of the process.
Affinities include positive affinities (attract) and negative affinities (repulse), all represented by integers in the range of 1 to 100000.
·     The higher the attract value, the stronger the preference.
·     The higher the repulse value, the weaker the preference.
After you apply new placement policies, the system makes placement decisions based on the new policies, node resources, and topology status. If the new location for an active process is different from the current node, the system changes the state of the process to standby, and uses the standby process on the preferred location as the new active process.
The system determines the location for each active process, and there is no need to optimize process placement. If optimization is needed, work with H3C engineers to avoid service interruption.
Process placement configuration task list
Tasks at a glance
Configuring process placement policy:
·     (Optional.) Configuring a location affinity
·     (Optional.) Configuring a location type affinity
·     (Optional.) Configuring a process affinity
·     (Optional.) Configuring a self affinity
(Required.) Optimizing process placement
Step
Remarks
N/A
2.     Enter placement process view.
·     Enter default placement process view:
·     Enter placement process view:
placement program
{ program-name [ instance instance-name ]
Settings in default placement process view take effect for all processes. Settings in placement process view take effect for the specified process only.
3.     Set the location affinity.
affinity location-set { slot slot-number [ cpu cpu-number ] }&<1-5> { attract strength | default | none | repulse strength }
By default, no location affinity is set.
The following location types are available:
·     current—Current location of the active process, which can be displayed with the display placement program command.
·     paired—Locations of standby processes.
·     primary—Master device.
To configure a location type affinity:
Step
Remarks
N/A
placement program
3.     Set the location type affinity.
affinity location-type { current | paired | primary } { attract strength | repulse strength | default | none }
By default, no location type affinity is set.
Step
Remarks
N/A
placement program
3.     Configure the affinity to another process.
affinity program program-name { attract strength | repulse strength | default | none }
By default, no process affinity is set.
Perform this task to configure the preference for one instance of a process to run on the same node as any other instance of the process. The self affinity setting does not take effect for a process that has only one instance.
To configure a self affinity:
Step
Remarks
N/A
placement program
3.     Configure a self affinity.
affinity self { attract strength | repulse strength | default | none }
By default, no self affinity is set.
Step
Remarks
N/A
2.     Optimize process placement.
placement reoptimize
To keep the system stable, H3C recommends not performing any operation that requires process restart when you execute this command.
Displaying process placement
Display process placement policy information.
display placement policy program { program-name | all | default }
Display the location of a process.
display placement program { program-name | all }
Display the running processes on a specific location.
display placement location { slot slot-number [ cpu cpu-number ] | all }
Display the predicted location of a process after process placement optimization.
display placement reoptimize program { program-name [ instance instance-name ] | all }
Display the location and status of a service group.
display ha service-group { program-name [ instance instance-name ] | all }
