- 03 Layer 2 - LAN Switching Configuration Guide
- 01-Ethernet interface configuration
- 02-Loopback, null, and inloopback interface configuration
- 03-Bulk interface configuration
- 04-MAC address table configuration
- 05-Ethernet link aggregation configuration
- 06-Port isolation configuration
- 07-Spanning tree configuration
- 08-Loop detection configuration
- 09-VLAN configuration
- 10-MVRP configuration
- 11-QinQ configuration
- 12-VLAN mapping configuration
- 13-LLDP configuration
- 14-Service loopback group configuration
- 15-Cut-through forwarding configuration
| 14-Service loopback group configuration | 64.63 KB |
Configuring service loopback groups
Displaying and maintaining service loopback groups
Service loopback group configuration example
A service loopback group provides one of the following services:
· Tunnel—Supports unicast tunnel traffic.
· Multicast tunnel—Supports multicast tunnel traffic.
· Multiport—Supports multiport ARP traffic.
The device supports only one service loopback group for each service type. You can use a service loopback group with multiple features.
Member ports in a service loopback group are load balanced.
Configuration procedure
Follow these guidelines when you configure a service loopback group:
· Make sure the ports you are assigning to a service loopback group meet the following requirements:
¡ The ports are not used for any other purposes. The configuration on a port is removed when it is assigned to a service loopback group.
¡ The ports support the service type of the service loopback group and are not members of any other service loopback group.
· You cannot change the service type of a service loopback group.
· For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
To configure a service loopback group:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create a service loopback group and specify its service type. |
service-loopback group number type { { multicast-tunnel | tunnel } * | multiport } |
N/A |
3. Enter Layer 2 Ethernet interface view. |
N/A |
4. Assign the port to the service loopback group. |
port service-loopback group number |
By default, a service loopback group does not contain ports. You can assign a maximum of 32 ports to a service loopback group. |
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ number ] |
Network requirements
All Ethernet ports on Device A support the tunnel service.
Assign FortyGigE 1/1/1 through FortyGigE 1/1/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Assign FortyGigE 1/1/1 through FortyGigE 1/1/3 to service loopback group 1.
[DeviceA] interface fortygige 1/1/1
[DeviceA-FortyGigE1/1/1] port service-loopback group 1
[DeviceA-FortyGigE1/1/1] quit
[DeviceA] interface fortygige 1/1/2
[DeviceA-FortyGigE1/1/2] port service-loopback group 1
[DeviceA-FortyGigE1/1/2] quit
[DeviceA] interface fortygige 1/1/3
[DeviceA-FortyGigE1/1/3] port service-loopback group 1
[DeviceA-FortyGigE1/1/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[DeviceA] interface tunnel 1 mode gre
[DeviceA-Tunnel1]
