04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73104-Layer 2 - LAN Switching Command Reference
03-Port isolation commands
03-Port isolation commands 78.1 KB
IMPORTANT
IMPORTANT:
·     Port isolation is not supported on devices configured with enhanced IRF. For more information about enhanced IRF, see Virtual Technologies Configuration Guide.
·     In IRF mode, do not configure lite Layer 2 aggregation groups and port isolation groups on the same device. Otherwise, packet forwarding fails. For more information about lite Layer 2 aggregation groups, see Layer 2LAN Switching Configuration Guide.
community-vlan vlan
Use community-vlan vlan to configure community VLANs in an isolation group.
Use undo community-vlan to remove all community VLANs from an isolation group.
community-vlan vlan { vlan-id-list | all }
undo community-vlan
An isolation group does not contain any community VLANs.
Isolation group view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
all: Specifies all VLANs in the isolation group.
This command is available when the switch is operating in standalone mode or IRF mode with the enhanced IRF feature disabled.
You cannot configure new community VLANs for an isolation group that already contains community VLANs. To update the community VLANs in the isolation group, use the undo community-vlan vlan command to remove the existing community VLANs first.
# Configure VLAN 3 in isolation group 1 as a community VLAN.
[Sysname] port-isolate group 1
[Sysname-port-isolate-group1] community-vlan vlan 3
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ group-number ]
group-number: Specifies an isolation group by its number in the range of 1 to 16.
# Display all isolation groups.
<Sysname> display port-isolate group
 Port isolation group information:
 Group ID: 2
 Group members:
    GigabitEthernet3/0/1
 Group ID: 5
 Group members:
GigabitEthernet2/0/5     GigabitEthernet2/0/6
 Community VLAN ID: 3
Group ID
Isolation group number.
Group members
Isolated ports in the isolation group. No ports indicates that the isolation group contains no isolated ports.
Community VLAN ID
IDs of the community VLANs in the isolation group. None indicates that the isolation group contains no community VLANs.
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable group group-number
A port is not assigned to any isolation group.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
group group-number: Specifies an isolation group by its number in the range of 1 to 16.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
To assign ports to an isolation group, make sure the isolation group already exists.
# Assign ports GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 to isolation group 2.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] port-isolate enable group 2
[Sysname-GigabitEthernet3/0/1] quit
[Sysname] interface GigabitEthernet 3/0/2
[Sysname-GigabitEthernet3/0/2] port-isolate enable group 2
port-isolate group
Use port-isolate group to create an isolation group.
Use undo port-isolate group to delete isolation groups.
port-isolate group group-number
undo port-isolate group { group-number | all }
No isolation group exists.
all: Deletes all isolation groups.
# Create isolation group 2.
[Sysname] port-isolate group 2
