04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release7374-6W73104-Layer 2 - LAN Switching Command Reference
08-QinQ commands
08-QinQ commands 60.68 KB
QinQ commands
This document uses the following terms:
·     CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     SVLANService provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display the QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specify an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 3/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qinq enable
[Sysname-GigabitEthernet3/0/1] display qinq interface gigabitethernet 3/0/1
# Enable QinQ on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname-GigabitEthernet3/0/1] quit
[Sysname] interface gigabitethernet 3/0/3
[Sysname-GigabitEthernet3/0/3] qinq enable
[Sysname-GigabitEthernet3/0/3] display qinq
Interface name.
QinQ-enabled interface.
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to restore the default.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
display qinq
