08-IP Multicast Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18208-IP Multicast Command Reference
11-IPv6 PIM Snooping Commands
11-IPv6 PIM Snooping Commands 81.84 KB
IPv6 PIM snooping configuration commands
display pim-snooping ipv6 neighbor
In standalone mode:
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094. If no VLAN is specified, this command displays the IPv6 PIM snooping neighbor information in all VLANs.
slot slot-number: Displays the IPv6 PIM snooping neighbor information of the card specified by its slot number. If no slot is specified, the command displays the IPv6 PIM snooping neighbor information of all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the IPv6 PIM snooping neighbor information on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, the command displays the IPv6 PIM snooping neighbor information of all cards in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display pim-snooping ipv6 neighbor to display IPv6 PIM snooping neighbor information.
# Display IPv6 PIM snooping neighbor information about VLAN 2.
<Sysname> display pim-snooping ipv6 neighbor vlan 2
  Total number of neighbors: 2
  VLAN ID: 2
    Neighbor        Port                          Expires   Option Flags
    FE80::6401:101  GE3/0/1                       02:02:23  LAN Prune Delay(T)
    FE80::C801:101  GE3/0/2                       03:00:05  LAN Prune Delay
Total number of IPv6 PIM snooping neighbors.
Neighbor
IP address of the IPv6 PIM snooping neighbor.
Port
Name of the port that connects to the IPv6 PIM snooping neighbor.
Expires
Remaining time before the IPv6 PIM snooping neighbor expires. If the IPv6 PIM snooping neighbor never expires, this field displays never.
Option Flags
Possible values:
·     LAN Prune DelayThe IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option.
·     LAN Prune Delay(T)The IPv6 PIM hello messages received from the neighbor carry the LAN_Prune_Delay option, and the join suppression function has been disabled.
display pim-snooping ipv6 routing-table
In standalone mode:
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094. If no VLAN is specified, this command displays the IPv6 PIM snooping routing entries in all VLANs.
slot slot-number: Displays the IPv6 PIM snooping routing entries of the card specified by its slot number. If no slot is specified, the command displays information about the IPv6 PIM snooping routing entries on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the IPv6 PIM snooping routing entries on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, this command displays the IPv6 PIM snooping routing entries on all active MPUs in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
Use display pim-snooping ipv6 routing-table to display the IPv6 PIM snooping routing table.
In standalone mode:
¡     To display the Upstream port field of an upstream interface that is not on the MPU, you must specify the slot slot-number option for the interface.
¡     To display the Expires and FSM fields of a non-aggregate interface that is not on the MPU, you must specify the slot slot-number option for the interface. There is no such restriction to aggregate interfaces.
·     In IRF mode:
¡     To display the Upstream port field of an upstream interface that is not on the MPU, you must specify the chassis chassis-number slot slot-number option for the interface.
¡     To display the Expires and FSM fields of a non-aggregate interface that is not on the MPU, you must specify the chassis chassis-number slot slot-number option for the interface. There is no such restriction to aggregate interfaces.
# Display the IPv6 PIM snooping routing entries of VLAN 2.
<Sysname> display pim-snooping ipv6 routing-table vlan 2
  Total 1 entry(ies)
  FSM Flag: NI-no info, J-join, PP-prune pending
  VLAN ID: 2
    Total 1 entry(ies)
    (2000::1, FF1E::1)
      Upstream neighbor: FE80::101
        Upstream port: GE3/0/1
        Total number of downstream ports: 2
          1: GE3/0/3
          2: GE3/0/4
      Upstream neighbor: FE80::102
        Upstream port: GE3/0/2
        Total number of downstream ports: 1
          1: GE 3/0/5
Total 1 entry(ies)
Total number of (S, G) entries and (*, G) entries in the IPv6 PIM snooping routing table.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
(2000::1, FF1E::1)
(S, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Upstream port
Upstream port of the (S, G) entry or (*, G) entry).
Total number of downstream ports contained in the upstream neighbor of the (S, G) or (*, G) entry.
FSM
State machine of the downstream port.
display pim-snooping ipv6 statistics
display pim-snooping ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display pim-snooping ipv6 statistics to display statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
# Display statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
<Sysname> display pim-snooping ipv6 statistics
 Received IPv6 PIM IPv6 hello: 100
 Received IPv6 PIM IPv6 join/prune: 100
 Received IPv6 PIM IPv6 error: 0
 Received IPv6 PIM IPv6 messages in total: 200
Number of received IPv6 PIM hello messages.
Number of received IPv6 PIM join/prune messages.
Number of received IPv6 PIM messages with errors.
Total number of received IPv6 PIM messages.
pim-snooping ipv6 enable
undo pim-snooping ipv6 enable
View
VLAN view
Default level
2: System level
None
Use pim-snooping ipv6 enable to enable IPv6 PIM snooping in a VLAN.
Use undo pim-snooping ipv6 enable to disable IPv6 PIM snooping in a VLAN.
By default, IPv6 PIM snooping is disabled.
Before you enable IPv6 PIM snooping in a VLAN, be sure to enable MLD snooping globally and specially in the VLAN.
IPv6 PIM snooping does not take effect in a sub-VLAN of a multicast VLAN.
Related commands: mld-snooping enable.
# Enable MLD snooping globally, and enable MLD snooping and IPv6 PIM snooping in VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] pim-snooping ipv6 enable
reset pim-snooping ipv6 statistics
View
Default level
2: System level
None
Use reset pim-snooping ipv6 statistics to clear statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
# Clear statistics for IPv6 PIM messages learned by IPv6 PIM snooping.
<Sysname> reset pim-snooping ipv6 statistics
