08-IP Multicast Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18208-IP Multicast Command Reference
08-MBGP Commands
08-MBGP Commands 273.03 KB
MBGP configuration commands 1
aggregate (MBGP address family view) 1
balance (MBGP address family view) 2
bestroute as-path-neglect (MBGP address family view) 3
bestroute compare-med (MBGP address family view) 3
bestroute med-confederation (MBGP address family view) 4
compare-different-as-med (MBGP address family view) 5
dampening (MBGP address family view) 5
default local-preference (MBGP address family view) 6
default med (MBGP address family view) 7
default-route imported (MBGP address family view) 7
display ip multicast routing-table· 8
display ip multicast routing-table ip-address 10
display bgp multicast group· 12
display bgp multicast network· 14
display bgp multicast paths 15
display bgp multicast peer 16
display bgp multicast peer received ip-prefix· 19
display bgp multicast routing-table· 20
display bgp multicast routing-table as-path-acl 22
display bgp multicast routing-table cidr 23
display bgp multicast routing-table community· 24
display bgp multicast routing-table community-list 25
display bgp multicast routing-table dampened· 26
display bgp multicast routing-table dampening parameter 26
display bgp multicast routing-table different-origin-as 27
display bgp multicast routing-table flap-info· 28
display bgp multicast routing-table peer 29
display bgp multicast routing-table regular-expression· 31
display bgp multicast routing-table statistic· 31
filter-policy export (MBGP address family view) 32
filter-policy import (MBGP address family view) 33
import-route (MBGP address family view) 33
ipv4-family multicast 34
network (MBGP address family view) 35
peer advertise-community (MBGP address family view) 36
peer advertise-ext-community (MBGP address family view) 36
peer allow-as-loop (MBGP address family view) 37
peer as-path-acl (MBGP address family view) 38
peer capability-advertise orf (MBGP address family view) 39
peer default-route-advertise (MBGP address family view) 40
peer enable (MBGP address family view) 41
peer filter-policy (MBGP address family view) 41
peer group (MBGP address family view) 42
peer ip-prefix (MBGP address family view) 43
peer keep-all-routes (MBGP address family view) 44
peer next-hop-local (MBGP address family view) 44
peer preferred-value (MBGP address family view) 45
peer public-as-only (MBGP address family view) 46
peer reflect-client (MBGP address family view) 47
peer route-limit (MBGP address family view) 47
peer route-policy (MBGP address family view) 48
preference (MBGP address family view) 49
reflect between-clients (MBGP address family view) 50
reflector cluster-id (MBGP address family view) 50
refresh bgp ipv4 multicast 51
reset bgp ipv4 multicast 52
reset bgp ipv4 multicast dampening· 52
reset bgp ipv4 multicast flap-info· 53
summary automatic (MBGP address family view) 53
The term "router" in this chapter refers to both routers and Layer 3 switches.
For more information about routing policy commands, see Layer 3—IP Routing Command Reference.
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
undo aggregate ip-address { mask | mask-length }
View
IPv4 MBGP address family view
Default level
2: System level
ip-address: Summary address.
mask: Summary mask, in dotted decimal notation.
mask-length: Summary mask length, in the range 0 to 32.
as-set: Creates a summary with AS set.
attribute-policy route-policy-name: Sets the attributes of the summary route according to the routing policy. The routing policy name is a case-sensitive string of 1 to 63 characters.
detail-suppressed: Advertises the summary route only.
suppress-policy route-policy-name: Suppresses specific routes defined in the routing policy. The routing policy name is a case-sensitive string of 1 to 63 characters.
origin-policy route-policy-name: References the routing policy to determine routes for summarization. The routing policy name is a case-sensitive string of 1 to 63 characters.
The keywords of the command are described as follows:
Table 1 Functions of the keywords
Keywords
Function
as-set
Used to create a summary route, whose AS path contains the AS path information for summarized routes. Use this keyword carefully when many AS paths need to be summarized, because the frequent changes of these specific routes might lead to route flaps.
detail-suppressed
This keyword does not suppress the summary route, but it suppresses the advertisement of all the more specific routes. To summarize only some specific routes, use the peer filter-policy command.
suppress-policy
Used to create a summary route and suppress the advertisement of some summarized routes. If you want to suppress some routes selectively and leave other routes still advertised, use the if-match clause of the route-policy command.
origin-policy
Selects only routes meeting the routing policy for route summarization
attribute-policy
Sets attributes except the AS_PATH attribute for the summary route. The same work can be done by using the peer route-policy command.
Use aggregate to create a summary route in the IPv4 MBGP routing table.
Use undo aggregate to remove a summary route.
By default, no summary route is configured.
# In IPv4 MBGP address family view, create a summary of 192.213.0.0/16 in the IPv4 MBGP routing table.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family multicast
[Sysname-bgp-af-mul] aggregate 10.40.0.0 255.255.0.0
balance number
undo balance
View
Default level
2: System level
number: Number of MBGP routes for load balancing. When it is set to 1, load balancing is disabled.
Use balance to configure the number of MBGP routes for load balancing.
Use undo balance to restore the default.
By default, no load balancing is configured.
Unlike IGP, MBGP has no explicit metric for making load balancing decision. Instead, it implements load balancing by using route selection rules.
Related commands: display ip multicast routing-table.
# In IPv4 MBGP address family view, set the number of routes for BGP load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp-af-mul] balance 2
undo bestroute as-path-neglect
View
Default level
2: System level
None
Use bestroute as-path-neglect to configure MBGP not to consider the AS_PATH during best route selection.
Use undo bestroute as-path-neglect to restore the default.
By default, MBGP considers AS_PATH during best route selection.
# In IPv4 MBGP address family view, configure BGP to ignore the AS_PATH during best route selection.
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute as-path-neglect
undo bestroute compare-med
View
Default level
2: System level
None
Use bestroute compare-med to enable the comparison of the MED for paths from each AS during best route selection.
Use undo bestroute compare-med to disable this comparison.
The comparison is not enabled by default.
# In IPv4 MBGP address family view, enable the comparison of the MED for paths from each AS during best route selection.
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute compare-med
undo bestroute med-confederation
View
Default level
2: System level
None
Use bestroute med-confederation to enable the comparison of the MED for paths from confederation peers during best route selection.
Use undo bestroute med-confederation to disable the comparison.
The system only compares MED values for paths from peers within the confederation. Paths from external ASs are advertised throughout the confederation without MED comparison.
# In IPv4 MBGP address family view, enable the comparison of the MED for paths from peers within the confederation.
[Sysname] bgp 100
[Sysname-bgp-af-mul] bestroute med-confederation
undo compare-different-as-med
View
Default level
2: System level
None
Use compare-different-as-med to enable the comparison of the MED for paths from peers in different ASs.
Use undo compare-different-as-med to disable the comparison.
The comparison is disabled by default.
If several paths to one destination are available, the path with the smallest MED is selected.
Do not use this command unless associated ASs adopt the same IGP and routing selection method.
# In IPv4 MBGP address family view, enable the comparison of the MED for paths from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-af-mul] compare-different-as-med
undo dampening
View
Default level
2: System level
half-life-reachable: Specifies a half-life for active routes from 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes from 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes from 1 to 20000. A suppressed route whose penalty value decreases under the value is reused. By default, the reuse value is 750.
suppress: Specifies a suppression threshold from 1 to 20000. The route with a penalty value higher than the threshold is suppressed. The default value is 2000.
ceiling: Specifies a ceiling penalty value from 1001 to 20000. The value must be greater than the suppress value. By default, the value is 16000.
route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters.
Use dampening to configure IPv4 MBGP route dampening.
Use undo dampening to disable route dampening.
By default, no IPv4 MBGP route dampening is configured.
The command dampens only EBGP routes rather than IBGP routes.
# In IPv4 MBGP address family view, configure IPv4 MBGP route dampening.
[Sysname] bgp 100
[Sysname-bgp-af-mul] dampening 15 15 1000 2000 10000
undo default local-preference
View
Default level
2: System level
value: Default local preference, in the range 0 to 4294967295. The larger the value is, the higher the preference is.
Use default local-preference to configure the default local preference.
Use undo default local-preference to restore the default.
By default, the default local preference is 100.
Using this command can affect MBGP route selection.
# In IPv4 MBGP address family view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp-af-mul] default local-preference 180
default med med-value
undo default med
View
Default level
2: System level
med-value: Default MED value, in the range 0 to 4294967295.
Use default med to specify the default MED value.
Use undo default med to restore the default.
By default, the default MED value is 0.
Multi-exit discriminator (MED) is an external metric for routes. Different from local preference, MED is exchanged between ASs and will stay in the AS once it enters the AS. The route with a lower MED is preferred. When a device running BGP obtains several routes with an identical destination but different next-hops from various external peers, it will select the best route depending on the MED value. In the case that all other conditions are the same, the system selects the route with the smallest MED as the best external route.
# In IPv4 MBGP address family view, configure the default MED as 25.
[Sysname] bgp 100
[Sysname-bgp-af-mul] default med 25
undo default-route imported
View
Default level
2: System level
None
Use default-route imported to allow default route redistribution into the MBGP routing table.
Use undo default-route imported to restore the default.
By default, default route redistribution is not allowed.
To redistribute default routes of other protocols into the MBGP routing table, you must use the default-route imported command together with the import-route command.
Related commands: import-route.
# In IPv4 MBGP address family view, allow default route redistribution from OSPF into MBGP.
[Sysname] bgp 100
[Sysname-bgp-af-mul] default-route imported
[Sysname-bgp-af-mul] import-route ospf 1
display ip multicast routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
verbose: Displays detailed information about the multicast routing table, including both inactive and active multicast routes. Without the keyword, the command displays brief information about only the active MBGP routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip multicast routing-table to display the multicast BGP routing table.
All the active MBGP routes in the MBGP routing table are used for RPF check, but inactive MBGP routes are not.
# Display brief information about the active routes in the multicast BGP routing table.
<Sysname> display ip multicast routing-table
Routing Tables: Public
         Destinations : 6        Routes : 6
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan-interface2
2.2.2.1/32          Direct 0    0            127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0            192.168.80.10   Vlan-interface3
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destinations.
Routes
Number of routes.
Destination/Mask
Destination address /Mask length.
Proto
Routing protocol that discovered the route.
Pre
Route preference.
Cost
Route cost.
Nexthop
Next hop of the route.
Outgoing interface to reach the destination.
# Display detailed information about the multicast routing table.
<Sysname> display ip multicast routing-table verbose
Routing Table : Public
        Destinations : 2        Routes : 2
Destination: 192.168.80.0/24
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
 IpPrecedence:                    QosLcId:
      NextHop: 192.168.80.10    Interface: Vlan-interface2
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbour: 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active Adv             Age: 00h14m49s
          Tag: 0
Destination: 192.168.80.10/32
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 00h14m49s
          Tag: 0
Destination
Destination/mask.
Protocol
Process ID
Process ID.
Preference
Route preference.
Cost
Route cost.
QosLcId
QoS local ID.
NextHop
Nexthop of the route.
BkNextHop
Backup next hop.
BkInterface
Backup outgoing interface.
RelyNextHop
Recursive next hop.
Neighbour
Neighbor address.
Tunnel ID
Tunnel ID.
Label
Label.
Route state: Active, Inactive, Adv (can be advertised), NoAdv (cannot be advertised), GotQ (route recursion succeeded), WaitQ (route recursion has not succeeded yet)
Age
Age of the route, in the sequence of hour, minute, and second from left to right.
Tag
Route tag.
display ip multicast routing-table ip-address [mask-length |mask ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
ip-address: Destination IP address, in dotted decimal format.
mask-length: IP address mask length in the range 0 to 32.
mask: IP address mask in dotted decimal format.
longer-match: Displays the route with the longest mask.
verbose: Displays detailed information about both active and inactive routes. With this argument absent, the command displays only brief information about active routes.
Use display ip multicast routing-table ip-address to display information about multicast routes to a specified destination address.
Executing the command with different parameters yields different outputs:
It displays all multicast routes falling into the natural network of the IP address. If no such multicast routes are available, it displays only the longest matched active multicast route.
display ip multicast routing-table ip-address mask
It displays the multicast route exactly matching the IP address and mask.
# Display brief information about all multicast routes falling into the natural network of the IP address. (A multicast route is available.)
<Sysname> display ip multicast routing-table 169.0.0.0
Summary Count : 1
Destination/Mask    Proto  Pre  Cost  NextHop         Interface
169.0.0.0/16        Direct 0    0     127.0.0.1       InLoop0
For more information about the output, see Table 2.
# Display brief information about the longest matched active multicast route. (No multicast route falls into the natural network of the IP address.)
<Sysname> display ip multicast routing-table 169.253.0.0
Summary Count : 1
# Display detailed information about multicast routes falling into the natural network of the IP address. (A multicast route is available.)
<Sysname> display ip multicast routing-table 2.2.2.1 verbose
Summary Count : 1
Destination: 2.2.2.1/32
        State: Active NoAdv                  Age: 05h38m46s
          Tag: 0
For more information about the output, see Table 3.
# Display detailed information about the longest matched active multicast route. (No multicast route falls into the natural network of the IP address.)
<Sysname> display ip multicast routing-table 169.253.2.1 verbose
Summary Count : 1
Destination: 169.0.0.0/8
      NextHop: 169.1.1.1        Interface: Vlan-interface2
        State: Active Adv             Age: 00h00m32s
          Tag: 0
display bgp multicast group [ group-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
group-name: MBGP peer group name, a string of 1 to 47 characters.
Use display bgp multicast group to display IPv4 MBGP peer group information.
# Display information about the IPv4 MBGP peer group aaa.
<Sysname> display bgp multicast group aaa
 BGP peer-group is aaa
 Remote AS 200
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 0
  Members:
  Peer            AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  2.2.2.1         200        0        0     0       0 00:00:35 Active
BGP peer-group
Name of the peer group.
Remote AS
AS number of the peer group.
Type of the peer group: IBGP or EBGP.
Maximum allowed prefix number.
Threshold
Percentage of received prefixes from the peer group to maximum prefixes allowed to receive from the peer group; If the percentage is reached, the system generates alarm messages.
Holdtime interval.
Keepalive interval.
Minimum interval for route advertisement.
Preferred value specified for the routes from the peer.
No routing policy is configured.
Members
Detailed information about the members in the peer group.
Peer
IPv4 address of the peer.
AS
AS number of the peer.
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages to be sent.
PrefRcv
Number of prefixes received.
Up/Down
Time elapsed.
State machine of the peer.
display bgp multicast network [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast network to display IPv4 MBGP routing information advertised with the network command.
# Display IPv4 MBGP routing information advertised with the network command.
<Sysname> display bgp multicast network
  BGP Local Router ID is 10.1.4.2.
  Local AS Number is 400.
  Network          Mask            Route-policy        Short-cut
  100.1.2.0        255.255.255.0
  100.1.1.0        255.255.255.0                       Short-cut
Table 5 Command output
BGP Local Router ID
BGP Local Router ID.
Local AS Number
Local AS Number.
Network
Network address.
Mask
Mask.
Route-policy
Routing policy referenced.
Short-cut
Short-cut route.
display bgp multicast paths [ as-regular-expression | | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
as-regular-expression: AS path regular expression, a string of 1 to 80 case-sensitive characters, including spaces.
Use display bgp multicast paths to display the AS path information for IPv4 MBGP routes.
# Display the AS path information for IPv4 MBGP routes.
<Sysname> display bgp multicast paths ^200
    Address       Hash    Refcount  MED         Path/Origin
    0x5917100     11      1                     200 300i
Table 6 Command output
Address
Route address in the local database, in dotted hexadecimal notation.
Hash
Hash index.
Refcount
Count of routes that reference the path.
MED
MED of the path.
Path
AS_PATH attribute of the path, recording the ASs it has passed to avoid routing loops.
Origin
Origin attribute of the path:
·     i—Indicates the route is interior to the AS. Summary routes and routes injected using the network command are considered IGP routes.
·     e—Indicates the route is learned from the Exterior Gateway Protocol (EGP).
·     ?—Indicates the origin of the route is unknown. Routes redistributed from other routing protocols have this ORIGIN attribute.
display bgp multicast peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
ip-address: IP address of an IPv4 MBGP peer to be displayed, in dotted decimal notation.
verbose: Displays detailed information about the peer/peer group.
Use display bgp multicast peer to display IPv4 MBGP peer information.
# Display detailed information about the IPv4 MBGP peer 10.110.25.20.
<Sysname> display bgp multicast peer 10.110.25.20 verbose
         Peer: 10.110.25.20 Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h01m51s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 1029     Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Peer support bgp route AS4 capability
         Address family IPv4 Unicast: advertised and received
         Address family IPv4 Multicast: advertised and received
 Received: Total 5 messages, Update messages 1
 Sent: Total 4 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
  ORF advertise capability based on prefix (type 64):
    Local: both
    Negotiated: send
 BFD: Enabled
 Routing policy configured:
Table 7 Command output
Peer
IP address of the peer.
Local
Local router ID.
Peer type.
BGP version
BGP version.
remote router ID
Router ID of the peer.
BGP current state
Current state of the peer.
BGP current event
Current event of the peer.
BGP last state
Previous state of the peer.
Port
TCP port numbers.
Local holdtime interval and keepalive interval.
Received: Active Hold Time
Remote holdtime interval.
Negotiated: Active Hold Time   Keepalive Time:60 sec
Negotiated holdtime interval and keepalive interval.
Optional capabilities supported by the peer, including multiprotocol BGP extensions and route refresh.
The peer supports multiprotocol BGP extensions.
The peer supports route refresh.
The peer supports 4-byte router IDs.
Routes are advertised and received in IPv4 unicasts.
Received
Total numbers of received packets and updates.
Sent
Total numbers of sent packets and updates.
Threshold
Threshold value.
Minimum route advertisement interval.
Optional capabilities enabled by the peer (displayed only after optional capabilities are configured).
The route-refresh capability has been enabled.
The BGP peer supports the ORF capability based on IP prefix. The capability value is 64. (This field is displayed only after the ORF capability is enabled for the BGP peer.)
Local: both
The local BGP router supports both the ORF sending and receiving capabilities. (This field is displayed only after the ORF capability is enabled for the BGP peer.)
Negotiated: send
Negotiation result: the local BGP router can send Router-refresh messages carrying the ORF information, and the peer can receive route-refresh messages carrying the ORF information.
·     If receive is displayed, the local BGP router can receive Router-refresh messages carrying the ORF information, and the peer can send route-refresh messages carrying the ORF information.
·     If both send and receive are displayed, the local BGP router and the peer can both send and receive route-refresh messages carrying the ORF information.
·     This field is not displayed if neither the send nor the receive capability is supported.
·     This field is displayed only after the ORF capability is enabled for the BGP peer.
BFD
Status of BGP (enabled/disabled).
Local routing policy.
display bgp multicast peer ip-address received ip-prefix [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: IP address of a BGP peer.
Use display bgp multicast peer received ip-prefix to display the prefix entries in the ORF information for the specified BGP peer.
# Display the prefix information received from the BGP peer 10.110.25.20.
<Sysname> display bgp multicast peer 10.110.25.20 received ip-prefix
ORF ip-prefix entries: 2
ge: greater-equal   le: less-equal
  Index  Rule   Prefix                 Ge    Le
  10     permit 111.111.111.0/24       26    32
  20     deny   2.1.1.0/24             26    32
Table 8 Command output
Number of ORF prefix entries.
Index
Index of a prefix entry.
Rule
Matching rule of the prefix.
Prefix
Prefix information.
Ge
Greater-equal, indicating the mask length must be greater than or equal to the specific value.
Le
Less-equal, indicating the mask length must be less than or equal to the specific value.
display bgp multicast routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Destination IP address.
mask: Network mask, in dotted decimal notation.
mask-length: Mask length, in the range 0 to 32.
longer-prefixes: Matches the longest prefix.
Use display bgp multicast routing-table to display IPv4 MBGP routing information.
# Display the IPv4 MBGP routing table.
<Sysname> display bgp multicast routing-table
 Total Number of Routes: 1
 BGP Local router ID is 10.10.10.1
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  40.40.40.0/24      20.20.20.1                            0       200 300i
Table 9 Command output
Total Number of Routes.
BGP Local router ID
BGP local router ID.
Status codes
Status codes, including:
·     * – valid—Valid route.
·     ^ – VPNv4 best—Best VPNv4 route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     i – internal—Internal route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
Origin
Origin attributes, including:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Learned by some other means.
Network
Destination network address.
Next Hop
Next hop.
MED
Measurement value of the route.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops.
Ogn
Origin attribute of the route, which can be one of the following values:
·     i—Indicates that the route is interior to the AS. Summary routes and the routes injected with the network command are considered IGP routes.
·     e—Indicates that the route is learned from the Exterior Gateway Protocol (EGP).
·     ?—Short for INCOMPLETE. It indicates that the origin of the route is unknown and the route is learned by some other means. BGP marks routes redistributed from IGP as incomplete.
display bgp multicast routing-table as-path-acl as-path-acl-number [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
as-path-acl-number: Displays IPv4 MBGP routing information matching the AS path ACL, which is specified with a number from 1 to 256.
Use display bgp multicast routing-table as-path-acl to display IPv4 MBGP routes matching an AS-path ACL.
# Display IPv4 MBGP routes matching AS path ACL 1.
<Sysname> display bgp multicast routing-table as-path-acl 1
 BGP Local router ID is 20.20.20.1
               Origin : i - IGP, e - EGP, ? – incomplete
*>   40.40.40.0/24      30.30.30.1      0                     0       300i
For more information about the output, see Table 9.
display bgp multicast routing-table cidr [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast routing-table cidr to display IPv4 MBGP Classless Inter-Domain Routing (CIDR) routing information.
# Display IPv4 MBGP CIDR routing information.
<Sysname> display bgp multicast routing-table cidr
display bgp multicast routing-table community [ aa:nn ]&<1-13> [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
aa:nn: Community number. Both aa and nn are in the range 0 to 65535.
&<1-13>: Argument before it can be entered up to 13 times.
no-advertise: Displays MBGP routes that cannot be advertised to any peer.
no-export: Displays MBGP routes that cannot be advertised out of the AS. If a confederation is configured, it displays routes that cannot be advertised out of the confederation, but can be advertised to other sub ASs in the confederation.
no-export-subconfed: Displays MBGP routes that cannot be advertised out of the AS or to other sub ASs in the confederation.
whole-match: Displays the MBGP routes exactly matching the specified COMMUNITY attributes.
Use display bgp multicast routing-table community to display IPv4 MBGP routing information with the specified BGP COMMUNITY attribute.
# Display IPv4 MBGP routing information with the specified BGP COMMUNITY attribute.
<Sysname> display bgp multicast routing-table community 11:22
 *>  10.10.10.0/24      0.0.0.0         0                     0       i
display bgp multicast routing-table community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
basic-community-list-number: Specifies a basic community-list number from 1 to 99.
adv-community-list-number: Specifies an advanced community-list number from 100 to 199.
comm-list-name: Community list name, a string of 1 to 31 characters (not all are numbers).
whole-match: Displays routes exactly matching the specified basic-community-list.
&<1-16>: Specifies the argument before it can be entered up to 16 times.
Use display bgp multicast routing-table community-list to display IPv4 MBGP routing information matching the specified BGP community list.
# Display MBGP routing information matching the community list 100.
<Sysname> display bgp multicast routing-table community-list 100
BGP Local router ID is 30.30.30.1
 *>  30.30.30.0/24     1.2.3.4       0                    0       i
 *>  40.40.40.0/24     1.2.3.4       0                    0       i
display bgp multicast routing-table dampened [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast routing-table dampened to display dampened IPv4 MBGP routes.
# Display dampened IPv4 MBGP routes.
<Sysname> display bgp multicast routing-table dampened
 BGP Local router ID is 2.2.2.2
     Network            From              Reuse     Path/Origin
 *d  77.0.0.0           12.1.1.1          00:29:20  100?
Table 10 Command output
From
IP address from which the route was received.
Reuse
Reuse time of the route.
display bgp multicast routing-table dampening parameter [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast routing-table dampening parameter to display IPv4 MBGP route dampening parameters.
Related commands: dampening.
# Display IPv4 MBGP route dampening parameters.
<Sysname> display bgp multicast routing-table dampening parameter
 Maximum Suppress Time(in second) : 3069
 Ceiling Value                    : 16000
 Reuse Value                      : 750
 Reach HalfLife Time(in  second)  : 900
 Unreach HalfLife Time(in  second): 900
 Suppress-Limit                   : 2000
Table 11 Command output
Maximum Suppress Time.
Ceiling Value
Ceiling penalty value.
Reuse Value
Reuse value.
HalfLife Time
Half-life time of active routes.
Suppress-Limit
Threshold at which a route is suppressed.
display bgp multicast routing-table different-origin-as [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast routing-table different-origin-as to display IPv4 MBGP routes originating from different autonomous systems.
# Display IPv4 MBGP routes originating from different autonomous systems.
<Sysname> display bgp multicast routing-table different-origin-as
 *>  55.0.0.0          12.1.1.1        0                     0       100?
 *                     14.1.1.2        0                     0       300?
display bgp multicast routing-table flap-info [ regular-expression as-regular-expression | [ as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ] [ | { begin | exclude | include } regular-expression ] ]
View
Default level
2: Monitor level
as-regular-expression: Displays route flap information that matches the AS path regular expression.
as-path-acl-number: Displays route flap information matching the AS path ACL. The number is in the range 1 to 256.
mask: Mask, in dotted decimal notation.
longer-match: Matches the longest prefix.
Use display bgp multicast routing-table flap-info to display IPv4 MBGP route flap statistics. If no parameter is specified, this command displays all IPv4 MBGP route flap statistics.
# Display IPv4 MBGP route flap statistics.
<Sysname> display bgp multicast routing-table flap-info
     Network        From        Flaps  Duration     Reuse   Path/Origin
 *>  55.0.0.0       12.1.1.1    2      00:00:16             100?
 *d  77.0.0.0       12.1.1.1    5      00:34:02   00:27:08  100?
Table 12 Command output
From
Source IP address of the route.
Flaps
Number of routing flaps.
Duration
Route flap duration.
Reuse
display bgp multicast routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
ip-address: IP address of an IPv4 MBGP peer.
advertised-routes: Displays routing information advertised to the specified peer.
received-routes: Displays routing information received from the specified peer.
network-address: IP address of the destination network.
mask: Mask of the destination network, in dotted decimal notation.
statistic: Displays route statistics.
Use display bgp multicast routing-table peer to display IPv4 MBGP routing information advertised to or received from the specified IPv4 MBGP peer.
Related commands: display bgp multicast peer.
# Display IPv4 MBGP routing information advertised to the peer 20.20.20.1.
<Sysname> display bgp multicast routing-table peer 20.20.20.1 advertised-routes
 Total Number of Routes: 2
 *>  30.30.30.0/24      0.0.0.0         0                     0       i
 *>  40.40.40.0/24      0.0.0.0         0                     0       i
display bgp multicast routing-table regular-expression as-regular-expression
View
Default level
2: Monitor level
Use display bgp multicast routing-table regular-expression to display IPv4 MBGP routing information matching the specified AS path regular expression.
# Display IPv4 MBGP routing information matching AS path regular expression 300$.
<Sysname> display bgp multicast routing-table regular-expression 300$
display bgp multicast routing-table statistic [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
Use display bgp multicast routing-table statistic to display IPv4 MBGP routing statistics.
# Display IPv4 MBGP routing statistics.
<Sysname> display bgp multicast routing-table statistic
 Total Number of Routes: 4
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
undo filter-policy export [ direct | isis process-id | ospf process-id | rip process-id | static ]
View
Default level
2: System level
acl-number: Number of an ACL used to filter outgoing routing information, in the range of 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter outgoing routing information, a string of 1 to 19 characters.
direct: Filters direct routes.
isis process-id: Filters outgoing routes redistributed from an ISIS process. The process ID is in the range 1 to 65535.
ospf process-id: Filters outgoing routes redistributed from the OSPF process with an ID from 1 to 65535.
rip process-id: Filters outgoing routes redistributed from a RIP process. The process ID is in the range 1 to 65535.
static: Filters static routes.
Use filter-policy export to configure the filtering of outgoing routes.
Use undo filter-policy export to remove the filtering.
By default, the filtering is not configured.
If no routing protocol is specified, all redistributed routes are filtered.
# In IPv4 MBGP address family view, reference ACL 2000 to filter all outgoing routes.
[Sysname] bgp 100
[Sysname-bgp-af-mul] filter-policy 2000 export
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy import
View
Default level
2: System level
acl-number: Number of an ACL used to filter incoming routing information, in the range of 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter incoming routing information, a string of 1 to 19 characters.
Use filter-policy import to configure the filtering of incoming routing information.
Use undo filter-policy import to disable the filtering.
By default, incoming routing information is not filtered.
# In IPv4 MBGP address family view, reference ACL 2000 to filter incoming routing information.
[Sysname] bgp 100
[Sysname-bgp-af-mul] filter-policy 2000 import
View
Default level
2: System level
protocol: Redistributes routes from the routing protocol, which can be direct, isis, nat, ospf, rip or static.
process-id: Process ID, in the range 1 to 65535. It is available only when the protocol is isis, ospf or rip.
all-processes: Redistributes routes from all the processes of the specified routing protocol. It is available only when the specified protocol is isis, ospf or rip.
allow-direct: Redistributes direct routes from the specified routing protocol. This keyword is available only when the specified routing protocol is OSPF. Without this keyword, BGP does not redistribute direct routes from OSPF. If you specify the route-policy route-policy-name keyword together with the allow-direct keyword, make sure that no rule in the routing policy conflicts with any direct route. For example, do not configure the if-match route-type command for the routing policy to filter OSPF routes. Otherwise, the allow-direct keyword does not take effect.
med-value: Specifies a MED value for redistributed routes, in the range of 0 to 4294967295. If the argument is not specified, the cost of a redistributed route is used as its MED in the BGP routing domain.
route-policy-name: Name of a routing policy used to filter redistributed routes, a case-sensitive string of 1 to 63 characters.
Use import-route to enable route redistribution from a specified routing protocol.
Use undo import-route to disable route redistribution from a routing protocol.
By default, MBGP does not redistribute routes from other protocols.
The origin attribute of routes redistributed with the import-route command is INCOMPLETE.
The undo import-route protocol all-processes command can cancel only the configuration that you make by using the import-route protocol all-processes command. To cancel the configuration that you make by using the import-route protocol process-id command, you must use the undo import-route protocol process-id command.
# In IPv4 MBGP address family view, enable route redistribution from RIP.
[Sysname] bgp 100
[Sysname-bgp-af-mul] import-route rip
undo ipv4-family multicast
View
BGP view
Default level
2: System level
None
Use ipv4-family multicast to enter IPv4 MBGP address family view.
Use undo ipv4-family multicast to remove all configurations made in IPv4 MBGP address family view and return to BGP view.
# Enter IPv4 MBGP address family view.
[Sysname] bgp 100
network ip-address [ mask | mask-length ] [ short-cut | route-policy route-policy-name ]
undo network ip-address [ mask | mask-length ] [ short-cut ]
View
Default level
2: System level
mask: Mask of the network address, in dotted decimal notation.
short-cut: Specifies the route to use the local preference. If the route is an EBGP route whose preference is higher than the local preference, using this keyword can configure the EBGP route to use the local preference, and thus the route can hardly become the optimal route.
route-policy-name: Routing policy applied to the route. The name is a case-sensitive string of 1 to 63 characters.
Use network to inject a network to the IPv4 MBGP routing table.
Use undo network to remove a network from the IPv4 MBGP routing table.
By default, no network route is injected.
The network route to be injected must exist in the local IP routing table, and using a routing policy makes route management more flexible.
The origin attribute of the network route injected with the network command is IGP.
# In IPv4 MBGP address family view, inject the network 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp-af-mul] network 10.0.0.0 255.255.0.0
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
View
Default level
2: System level
group-name: Name of an IPv4 MBGP peer group, a string of 1 to 47 characters.
Use peer advertise-community to advertise the COMMUNITY attribute to a peer/peer group.
Use undo peer advertise-community to disable the COMMUNITY attribute advertisement to a peer/peer group.
By default, no COMMUNITY attribute is advertised to any peer group/peer.
Related commands: apply community, if-match community, and ip community-list (Layer 3—IP Routing Command Reference).
# In IPv4 MBGP address family view, advertise the COMMUNITY attribute to the existing peer group test.
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp] peer test as-number 200
[Sysname-bgp-af-mul] peer test enable
[Sysname-bgp-af-mul] peer test advertise-community
peer { group-name | ip-address } advertise-ext-community
undo peer { group-name | ip-address } advertise-ext-community
View
Default level
2: System level
Use peer advertise-ext-community to advertise the extended community attribute to a peer/peer group.
Use undo peer advertise-ext-community to disable the extended community attribute advertisement to a peer/peer group.
By default, no extended community attribute is advertised to a peer/peer group.
Related commands: apply extcommunity, if-match extcommunity, and ip extcommunity-list (Layer 3—IP Routing Command Reference).
# In IPv4 MBGP address family view, advertise the extended community attribute to the existing peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test advertise-ext-community
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
View
Default level
2: System level
number: Specifies the number of times the local AS number can appear in routes from the peer/peer group, in the range 1 to 10. The default number is 1.
Use peer allow-as-loop to allow the local AS number to exist in the AS_PATH attribute of routes from a peer/peer group, and to configure the number of times the local AS number can appear.
Use undo peer allow-as-loop to remove the configuration.
By default, the local AS number is not allowed.
Related commands: display bgp multicast routing-table peer.
# In IPv4 MBGP address family view, configure the number of times the local AS number can appear in routes from the peer 1.1.1.1 as 2.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 200
[Sysname-bgp-af-mul] peer 1.1.1.1 enable
[Sysname-bgp-af-mul] peer 1.1.1.1 allow-as-loop 2
peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
View
Default level
2: System level
as-path-acl-number: AS path ACL number, in the range 1 to 256.
export: Filters outgoing routes.
import: Filters incoming routes.
Use peer as-path-acl to configure the filtering of routes incoming from or outgoing to an MBGP peer/peer group based on a specified AS path ACL.
Use undo peer as-path-acl to remove the filtering.
By default, no AS path ACL based filtering is configured.
Related commands: apply as-path, if-match as-path, and ip as-path (Layer 3—IP Routing Command Reference).
# In IPv4 MBGP address family view, reference the AS path ACL 1 to filter routes outgoing to the peer group test.
[Sysname]bgp 100
[Sysname-bgp]group test external
[Sysname-bgp]peer test as-number 200
[Sysname-bgp]ipv4-family multicast
[Sysname-bgp-af-mul] peer test as-path-acl 1 export
peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
undo peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
View
Default level
2: System level
group-name: Name of an MBGP peer group, a string of 1 to 47 characters.
ip-address: IP address of an MBGP peer.
both: Supports sending and receiving route-refresh messages carrying the ORF information.
receive: Supports receiving route-refresh messages carrying the ORF information.
send: Supports sending route-refresh messages carrying the ORF information.
Use peer capability-advertise orf to enable the ORF capability for an MBGP peer or peer group.
Use undo peer capability-advertise orf to disable the ORF capability for the MBGP peer or peer group.
By default, the ORF capability is not enabled for an MBGP peer or peer group.
·     After you enable the ORF capability, the local MBGP router negotiates the ORF capability with the MBGP peer through Open messages. After that, the MBGP router can process route-refresh messages carrying the standard ORF information from the peer or send route-refresh messages carrying the standard ORF information to the peer. For non-standard ORF capability negotiation, you need also to configure the peer capability-advertise orf non-standard command in IPv4 unicast view.
·     After you disable the ORF capability, the local BGP router does not negotiate the ORF capability with the specified peer or peer group.
Table 13 Description of the both, send, and receive parameters and the negotiation result
Local parameter
Peer parameter
Negotiation result
send
·     receive
·     both
The ORF sending capability is enabled locally and the ORF receiving capability is enabled on the peer.
receive
·     send
·     both
The ORF receiving capability is enabled locally and the ORF sending capability is enabled on the peer.
both
both
Both the ORF sending and receiving capabilities are enabled locally and on the peer.
# Enable the ORF capability for the BGP peer 18.10.0.9. Then, after negotiation, the local router can exchange multicast ORF information with the peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp-af-mul] peer 18.10.0.9 enable
[Sysname-bgp-af-mul] peer 18.10.0.9 capability-advertise orf ip-prefix both
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address } default-route-advertise
View
Default level
2: System level
Use peer default-route-advertise to advertise a default route to a peer/peer group.
Use undo peer default-route-advertise to disable default route advertisement to a peer/peer group.
By default, no default route is advertised to a peer/peer group.
With this command used, the router unconditionally sends a default route with the next hop being itself to the peer/peer group regardless of whether the default route is available in the routing table.
# In IPv4 MBGP address family view, advertise a default route to the existing peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test default-route-advertise
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
View
Default level
2: System level
Use peer enable to enable the specified peer/peer group that has been created in BGP view.
Use undo peer enable to disable the specified peer/peer group that has been created in BGP view.
If a peer is disabled, the device will not exchange routing information with the peer.
# Enable the peer 18.10.0.9.
[Sysname] bgp 100
peer { group-name | ip-address } filter-policy acl-number { export | import }
undo peer { group-name | ip-address } filter-policy [ acl-number ] { export | import }
View
Default level
2: System level
acl-number: ACL number, in the range 2000 to 3999.
export: Uses the ACL to filter routes outgoing to the peer/peer group.
import: Uses the ACL to filter routes incoming from the peer/peer group.
Use peer filter-policy to configure an ACL-based filter policy for a peer or peer group.
Use undo peer filter-policy to remove the filtering.
By default, no ACL-based filter policy is configured for a peer or peer group.
Related commands: peer as-path-acl.
# In IPv4 MBGP address family view, reference ACL 2000 to filter routes sent to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test filter-policy 2000 export
peer ip-address group group-name
undo peer ip-address group group-name
View
Default level
2: System level
Use peer group to add an IPv4 MBGP peer to an IPv4 MBGP peer group.
Use undo peer group to delete a specified peer from a peer group.
By default, no peer is added into a peer group.
# In IPv4 MBGP address family view, add the peer 10.1.1.1 to the multicast EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp-af-mul] peer 10.1.1.1 group test
peer { group-name | ip-address } ip-prefix ip-prefix-name { export | import }
undo peer { group-name | ip-address } ip-prefix { export | import }
View
Default level
2: System level
ip-prefix-name: IP prefix list name, a string of 1 to 19 characters.
export: Applies the filter to routes outgoing to the specified peer/peer group.
import: Applies the filter to routes from the specified peer/peer group.
Use peer ip-prefix to reference an IP prefix list to filter routes received from or advertised to a peer or peer group.
Use undo peer ip-prefix to remove the configuration.
By default, no IP prefix list based filtering is configured.
# In IPv4 MBGP address family view, use the IP prefix list 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test ip-prefix list1 export
peer { group-name | ip-address } keep-all-routes
undo peer { group-name | ip-address } keep-all-routes
View
Default level
2: System level
Use peer keep-all-routes to save original routing information from a peer or peer group, including routes that fail to pass the inbound policy (if configured).
Use undo peer keep-all-routes to disable this feature.
By default, the feature is not enabled.
# In IPv4 MBGP address family view, save all the routing information from peer 131.108.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 131.108.1.1 as-number 100
[Sysname-bgp-af-mul] peer 131.108.1.1 enable
[Sysname-bgp-af-mul] peer 131.108.1.1 keep-all-routes
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
View
Default level
2: System level
Use peer next-hop-local to specify the router as the next hop for routes sent to a peer/peer group.
Use undo peer next-hop-local to remove the configuration.
By default, the routes advertised to an EBGP peer/peer group take the local router as the next hop, but the routes outgoing to an IBGP peer/peer group do not take the local router as the next hop.
# In IPv4 MBGP address family view, specify the router as the next hop for routes sent to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] group test internal
[Sysname-bgp-af-mul] peer test next-hop-local
peer { group-name | ip-address } preferred-value value
undo peer { group-name | ip-address } preferred-value
View
Default level
2: System level
value: Preferred value, in the range 0 to 65535.
Use peer preferred-value to specify a preferred value for routes received from a peer or peer group.
Use undo peer preferred-value to restore the default value.
The default preferred value is 0.
Routes learned from a peer have an initial preferred value. Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the route to the destination.
If you both reference a routing policy and use the peer { group-name | ip-address } preferred-value value command to set a preferred value for routes from a peer/peer group, the routing policy sets the specified preferred value for routes matching it. Other routes not matching the routing policy uses the value set with the peer preferred-value command. If the preferred value specified in the routing policy is zero, the routes matching it will also use the value set with the peer preferred-value command.
For information about using a routing policy to set a preferred value, see the command peer { group-name | ip-address } route-policy route-policy-name { export | import } in this document, and the command apply preferred-value preferred-value in Layer 3—IP Routing Command Reference.
# In IPv4 MBGP address family view, configure the preferred value as 50 for routes from peer 131.108.1.1.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer 131.108.1.1 preferred-value 50
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
View
Default level
2: System level
Use peer public-as-only to not keep private AS numbers in BGP updates sent to a peer/peer group.
Use undo peer public-as-only to keep private AS numbers in BGP updates sent to a peer/peer group.
By default, outgoing BGP updates can carry private AS numbers.
The command does not take effect for BGP updates with both public and private AS numbers. The range of private AS numbers is from 64512 to 65535.
# In IPv4 MBGP address family view, disable updates sent to the peer group test from carrying private AS numbers.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test public-as-only
peer { group-name | peer-address } reflect-client
undo peer { group-name | peer-address } reflect-client
View
Default level
2: System level
peer-address: IP address of an IPv4 MBGP peer.
Use peer reflect-client to configure the router as a route reflector and specify a peer/peer group as a client.
Use undo peer reflect-client to remove the configuration.
By default, neither the route reflector nor the client is configured.
Related commands: reflect between-clients and reflect cluster-id.
# In IPv4 MBGP address family view, configure the local device as a route reflector and specify the IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 100
[Sysname-bgp-af-mul] peer test reflect-client
peer { group-name | ip-address } route-limit limit [ percentage ]
undo peer { group-name | ip-address } route-limit
View
Default level
2: System level
limit: Upper limit of IP prefixes that can be received from the peer or peer group, in the range of 1 to 262144.
percentage: If the number of received routes divided by the upper limit reaches the specified percentage, the system will generate alarm information. The percentage is in the range 1 to 100. The default is 75.
Use peer route-limit to set the maximum number of routes that can be received from a peer/peer group.
Use undo peer route-limit to restore the default.
The number is unlimited by default.
# In IPv4 MBGP address family view, set the number of routes that can be received from peer 131.108.1.1 to 10000.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer 131.108.1.1 route-limit 10000
undo peer { group-name | ip-address } route-policy route-policy-name { export | import }
View
Default level
2: System level
group-name: Peer group name, a string of 1 to 47 characters.
export: Applies the routing policy to routes advertised to the peer/peer group.
import: Applies the routing policy to routes received from the peer/peer group.
Use peer route-policy to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use undo peer route-policy to remove the configuration.
By default, no routing policy is applied to routes from/to the peer/peer group.
The peer route-policy command does not apply the if-match interface clause in the referenced routing policy. For more information, see Layer 3—IP Routing Command Reference.
# In IPv4 MBGP address family view, apply the routing policy test-policy to routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-mul] peer test route-policy test-policy export
undo preference
View
Default level
2: System level
external-preference: Preference of EBGP routes, in the range 1 to 255.
internal-preference: Preference of IBGP routes, in the range 1 to 255.
local-preference: Preference of local routes, in the range 1 to 255.
route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters. Using a routing policy can set preferences for the routes matching it. As for the unmatched routes, the default preferences are adopted.
Use preference to configure preferences for external, internal, and local routes.
Use undo preference to restore the default.
The default preference values of external, internal and local BGP routes are 255, 255, and 130.
# In IPv4 MBGP address family view, configure preferences for EBGP, IBGP, and local IPv4 MBGP routes as 20, 20, and 200.
[Sysname]bgp 100
[Sysname-bgp-af-mul] preference 20 20 200
undo reflect between-clients
View
Default level
2: System level
None
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable this function.
By default, route reflection between clients is enabled.
After a route reflector is configured, it reflects the routes of a client to other clients. If the clients of a route reflector are fully meshed, you need to disable route reflection between clients to reduce routing costs.
Related commands: reflector cluster-id and peer reflect-client.
# Disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-mul] undo reflect between-clients
undo reflector cluster-id
View
Default level
2: System level
cluster-id: Cluster ID of the route reflector, in the range 1 to 4294967295.
ip-address: Cluster ID of the route reflector, in the format of an IP address.
Use reflector cluster-id to configure the cluster ID of the route reflector.
Use undo reflector cluster-id to remove the configured cluster ID.
By default, each route reflector uses its router ID as the cluster ID.
A route is reflected by a route reflector from a client to another client. The router ID of the route reflector is the ID of the cluster. You can configure multiple route reflectors to improve network stability. If a cluster has multiple route reflectors, you need to use the reflector cluster-id command to specify the same cluster ID for these route reflectors to avoid routing loops.
Related commands: reflect between-clients and peer reflect-client.
# Specify 80 as the cluster ID for the device, which is one of multiple route reflectors in the cluster.
[Sysname] bgp 100
[Sysname-bgp-af-mul] reflector cluster-id 80
refresh bgp ipv4 multicast { all | ip-address | group group-name | external | internal } { export | import }
View
Default level
2: Monitor level
all: Soft-resets all BGP connections.
external: Soft-resets EBGP connections.
internal: Soft-resets IBGP connections.
export: Outbound soft reset.
import: Inbound soft reset.
Use refresh bgp ipv4 multicast to perform soft reset on specified IPv4 MBGP connections. This method can also refresh the MBGP routing table and apply a new routing policy seamlessly.
To perform BGP soft reset, all BGP devices in the network must support route-refresh. If a device not supporting the route-refresh function exists, you must configure the peer keep-all-routes command to save all the routing information for the peer before BGP soft reset.
# Soft-reset all the IPv4 MBGP connections.
<Sysname> refresh bgp ipv4 multicast all import
reset bgp ipv4 multicast
reset bgp ipv4 multicast { all | as-number | ip-address | group group-name | external | internal }
View
Default level
2: System level
all: Resets all MBGP connections.
as-number: Resets MBGP connections to peers in the AS.
ip-address: Resets the connection with an IPv4 MBGP peer.
group group-name: Resets connections with the specified BGP peer group.
external: Resets all the multicast EBGP connections.
internal: Resets all the multicast IBGP connections.
Use reset bgp ipv4 multicast to reset specified MBGP connections.
# Reset all the IPv4 MBGP connections.
<Sysname> reset bgp ipv4 multicast all
reset bgp ipv4 multicast dampening
reset bgp ipv4 multicast dampening [ ip-address [ mask | mask-length ] ]
View
Default level
1: Monitor level
mask: Mask, in dotted decimal notation. The default is 255.255.255.255.
mask-length: Mask length, in the range 0 to 32. The default is 32.
Use reset bgp ipv4 multicast dampening to clear route dampening information and release suppressed routes.
Related commands: dampening and display bgp multicast routing-table dampened.
# Clear damping information for route 20.1.0.0/16 and release the suppressed route.
<Sysname> reset bgp ipv4 multicast dampening 20.1.0.0 255.255.0.0
reset bgp ipv4 multicast flap-info
reset bgp ipv4 multicast flap-info [ regexp as-path-regular-expression | as-path-acl as-path-acl-number | ip-address [ mask | mask-length ] ]
View
Default level
1: Monitor level
as-path-regular-expression: Clears the flap statistics of routes matching the AS path regular expression, which is a string of 1 to 80 case-sensitive characters with spaces included.
as-path-acl-number: Clears the flap statistics for routes matching the AS path ACL, number of which is in the range 1 to 256.
ip-address: Clears the flap statistics of a route.
Use reset bgp ipv4 multicast flap-info to clear IPv4 MBGP routing flap statistics.
The flap statistics of all the routes will be cleared if no parameter is specified.
# Clear the flap statistics of all IPv4 MBGP routes matching AS path ACL 10.
<Sysname> reset bgp ipv4 multicast flap-info as-path-acl 10
summary automatic (MBGP address family view)
summary automatic
undo summary automatic
View
Default level
2: System level
None
Use summary automatic to enable automatic summarization for redistributed subnets.
Use undo summary automatic to disable automatic summarization.
By default, automatic summarization is disabled.
The default routes and the routes imported with the network command cannot be automatically summarized.
The summary automatic command helps IPv4 MBGP limit the number of routes redistributed from IGP.
# In IPv4 MBGP address family view, enable automatic route summarization.
[Sysname]bgp 100
[Sysname-bgp] ipv4-family multicast
[Sysname-bgp-af-mul] summary automatic
