- 08-IP Multicast Command Reference
- 01-IGMP Snooping Commands
- 02-PIM Snooping Commands
- 03-Multicast VLAN Commands
- 04-Multicast Routing and Forwarding Commands
- 05-IGMP Commands
- 06-PIM Commands
- 07-MSDP Commands
- 08-MBGP Commands
- 09-Multicast VPN Commands
- 10-MLD Snooping Commands
- 11-IPv6 PIM Snooping Commands
- 12-IPv6 Multicast VLAN Commands
- 13-IPv6 Multicast Routing and Forwarding Commands
- 14-MLD Commands
- 15-IPv6 PIM Commands
- 16-IPv6 MBGP Commands
| 04-Multicast Routing and Forwarding Commands | 165.67 KB |
Multicast routing and forwarding configuration commands
display multicast forwarding-table
display multicast forwarding-table df-info
display multicast routing-table
display multicast routing-table static
multicast forwarding on-demand
multicast forwarding-table downstream-limit
multicast forwarding-table route-limit
multicast rpf-fail-pkt bridging
multicast rpf-fail-pkt trap-to-cpu
reset multicast forwarding-table
The term "router" in this document refers to both routers and Layer 3 switches.
delete ip rpf-route-static
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If this option is not specified, the command deletes all multicast static routes on the public network.
Use delete ip rpf-route-static to delete all multicast static routes.
Related commands: ip rpf-route-static.
# Delete all multicast static routes on the public network.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:
display mac-address multicast
display mac-address [ mac-address [ vlan vlan-id ] | [ multicast ] [ vlan vlan-id ] [ count ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mac-address: Specifies a multicast MAC address. The MAC address can be any legal multicast MAC address except 0100-5Exx-xxxx and 3333-xxxx-xxxx, where "x" represents any hexadecimal numbers from 0 to F.
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, this command displays static multicast MAC address entries for all VLANs.
multicast: Specifies static multicast MAC address entries.
count: Specifies the number of static multicast MAC address entries. If this keyword is specified, this command displays the number of matching static multicast MAC address entries. If this keyword is not specified, this command displays the contents of the matching entries rather than the entry count.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display mac-address multicast to display the static multicast MAC address entries.
With no parameters specified or with only vlan, count, or both of them specified, this command displays all MAC address table entries, including static multicast MAC address entries and unicast MAC address entries.
Related commands: mac-address multicast; display mac-address (Layer 2—LAN Switching Command Reference).
# Display the static multicast MAC address entries for VLAN 2.
<Sysname> display mac-address multicast vlan 2
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
0100-0001-0001 2 Multicast GigabitEthernet3/0/1 NOAGED
GigabitEthernet3/0/2
GigabitEthernet3/0/3
GigabitEthernet3/0/4
--- 1 mac address(es) found ---
MAC ADDR |
MAC address. |
VLAN ID |
ID of the VLAN to which the network device identified by the MAC address belongs. |
STATE |
Status of the MAC address. If the multicast MAC address entry is static, this field displays Multicast. |
PORT INDEX |
Outgoing ports of the multicast MAC address entry. |
AGING TIME(s) |
State of the aging timer. For a static multicast MAC address entry, this field displays NOAGED because this entry never expires. |
1 mac address(es) found |
One static multicast MAC address entry is found. |
display multicast boundary
display multicast [ all-instance | vpn-instance vpn-instance-name ] boundary [ group-address [ mask | mask-length ] ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all VPN instances.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
mask: Specifies the address mask, 255.255.255.255 by default.
mask-length: Specifies the address mask length in the range of 4 to 32. The default is 32.
Use display multicast boundary to display the multicast boundary information on the specified interface or all interfaces.
If neither all-instance nor vpn-instance is specified, this command displays the information on the public network.
Related commands: multicast boundary.
# Display the multicast boundary information on all interfaces on the public network.
<Sysname> display multicast boundary
Multicast boundary information of VPN-Instance: public net
Boundary Interface
224.1.1.0/24 Vlan77
239.2.2.0/24 Vlan88
Multicast boundary information of VPN-Instance: public net |
Multicast boundary for the public network. |
Boundary |
Multicast group corresponding to the multicast boundary. |
Interface: |
Boundary interface corresponding to the multicast boundary. |
In standalone mode:
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { exclude | include | match } { interface-type interface-number | register } | statistics | slot slot-number ] * [ port-info ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { exclude | include | match } { interface-type interface-number | register } | statistics | chassis chassis-number slot slot-number ] * [ port-info ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source-address: Specifies a multicast source address.
mask-length: Specifies the address mask length. The default is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
incoming-interface: Specifies the multicast forwarding entries that include the specified incoming interface.
interface-type interface-number: Specifies the interface by its type and number.
register: Specifies the multicast forwarding entries that include the registered incoming interface of PIM-SM.
outgoing-interface: Specifies the multicast forwarding entries that include the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not include the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that include the specified interface in the outgoing interface list.
match: Specifies the forwarding entries that include only the specified interface in the outgoing interface list.
statistics: Displays statistics of the multicast forwarding table.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays the multicast forwarding table information of the main board. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not configured, the command displays the multicast forwarding table information of all main boards in the IRF member device. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
port-info: Displays Layer 2 port information.
Use display multicast forwarding-table to display the multicast forwarding table information.
Multicast forwarding tables guide multicast forwarding. You can view the forwarding state of multicast traffic by checking the multicast forwarding table.
Related commands: display multicast routing-table, multicast forwarding-table downstream-limit, and multicast forwarding-table route-limit.
# Display the multicast forwarding table information on the public network.
<Sysname> display multicast forwarding-table
Multicast Forwarding Table of VPN-Instance: public net
Total 2 entries
Total 2 entries matched
00001. (172.168.0.2, 227.0.0.1)
MID: 0, Flags: 0x0:0
Incoming interface: Vlan-interface20
List of 1 outgoing interfaces:
1: Vlan-interface50
Matched 19648 packets(20512512 bytes), Wrong If 0 packets
00002. (100.1.1.10, 224.1.1.5)
MID: 1199, Flags: 0x100000:0
Uptime: 00:00:29, Timeout in: 00:03:26
Incoming interface: Vlan-interface30 (subvlan: 31)
1: Vlan-interface60
Matched 110 packets(11555 bytes), Wrong If 0 packets
Forwarded 110 packets(11555 bytes)
Multicast Forwarding Table of VPN-Instance: public net |
Multicast forwarding table for the public network. |
Total 2 entries |
Total number of (S, G) entries in the multicast forwarding table. |
Total 2 entries matched |
Total number of matched (S, G) entries in the multicast forwarding table. |
00001 |
Sequence number of the (S, G) entry. |
(172.168.0.2,227.0.0.1) |
(S, G) entry of the multicast forwarding table. |
MID |
(S, G) entry ID. Each (S, G) entry has a unique MID. |
Flags |
Current state of the (S, G) entry. Different bits indicate different states of (S, G) entries. For major values of this field, see Table 4. |
Uptime |
Length of time for which the (S, G) entry has been up, in the format hh:mm:ss. |
Timeout in |
Length of time in which the (S, G) entry will expire, in the format hh:mm:ss. |
Incoming interface |
Incoming interface of the (S, G) entry. |
subvlan |
If the incoming interface of the (S, G) entry is a super VLAN interface, this field displays sub VLAN where the incoming interface resides. · If the multicast source matches an ARP entry of the sub VLAN, the field displays VLAN ID of this sub VLAN. · If the multicast source does not match an ARP entry of the sub VLAN, or the sub VLAN that learned the matched ARP entry does not belong to the super VLAN, this field displays unknown. |
List of 1 outgoing interface: 1: Vlan-interface50 |
Outgoing interface list. Interface number: outgoing interface and number. |
Matched 19648 packets(20512512 bytes), Wrong If 0 packets |
(S, G)-matched packets (bytes), packets with incoming interface errors. |
Forwarded 19648 packets(20512512 bytes) |
(S, G)-forwarded packets (bytes). |
Table 4 Major values of the flags field
Value |
Meaning |
0x1 |
A register-stop message must be sent. |
0x2 |
Whether the multicast source corresponding to the (S, G) is active. |
0x4 |
Null forwarding entry. |
0x8 |
Whether the RP is a PIM domain border router. |
0x10 |
A register outgoing interface is available. |
0x400 |
(S, G) entry to be deleted. |
0x8000 |
The (S, G) entry is in the smoothening process after active/standby switchover. |
0x10000 |
The (S, G) has been updated during the smoothing process. |
0x80000 |
The (S, G) entry has been updated and needs to be deleted before a new entry is added. |
0x100000 |
An entry is successfully added. |
0x1000000 |
Multicast forwarding entry for BIDIR-PIM. |
0x2000000 |
RP for BIDIR-PIM. |
In standalone mode:
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table df-info [ rp-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table df-info [ rp-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all-instance: Specifies all MPLS L3VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
rp-address: Specifies an RP address of BIDIR-PIM.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays the DF information of the multicast forwarding table for the main board. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument refers to the ID of the IRF member device, and the slot-number argument refers to the number of the slot where the card resides. If this option is not configured, the command displays the DF information of the multicast forwarding tables for all main boards in the IRF member device. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
exclude: Displays the lines that do not match the specified regular expression.
Use display multicast forwarding-table df-info to display the DF information of the multicast forwarding table.
If neither all-instance nor vpn-instance is specified, this command displays the DF information for the public network.
# Display the DF information of the multicast forwarding table for the public network.
<Sysname> display multicast forwarding-table df-info
Multicast DF information of VPN-Instance: public net
Total 1 RP
Total 1 RP matched
00001. RP Address: 1.1.1.1
MID: 0, Flags: 0x2100000:0
Uptime: 00:08:32
RPF interface: GigabitEthernet4/0/1
List of 1 DF interfaces:
1: GigabitEthernet4/0/2
Table 5 Command output
Total 1 RP |
Total number of RPs. |
Total 1 RP matched |
Total number of matched RPs. |
00001 |
Sequence number of the RP. |
MID |
ID of the RP. Each RP has a unique MID. |
Flags |
Current state of the RP. Different bits indicate different states of an RP. For major values of this field, see Table 4. |
Uptime |
Length of time for which the RP has been up, in the format hh:mm:ss. |
RPF interface |
RPF interface to the RP. |
List of 1 DF interfaces |
DF interface list. |
display multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } | outgoing-interface { exclude | include | match } { interface-type interface-number | register } ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
incoming-interface: Specifies the multicast routing entries that include the specified incoming interface.
register: Specifies the multicast routing entries that include the specified register interface of PIM-SM.
outgoing-interface: Specifies the multicast routing entries that include the specified outgoing interface.
exclude: Specifies the multicast routing entries that do not include the specified interface in the outgoing interface list.
include: Specifies the multicast routing entries that include the specified interface in the outgoing interface list.
match: Specifies the multicast routing entries that include only the specified interface in the outgoing interface list.
Use display multicast routing-table to display the multicast routing table information.
Multicast routing tables are the basis of multicast forwarding. You can view the establishment state of an (S, G) entry by checking the multicast routing table.
Related commands: display multicast forwarding-table.
# Display routing information about the multicast routing table in the public network.
<Sysname> display multicast routing-table
Multicast routing table of VPN-Instance: public net
Total 1 entry
Uptime: 00:00:28
Upstream Interface: Vlan-interface55
List of 2 downstream interfaces
1: Vlan-interface66
2: Vlan-interface77
Table 6 Command output
Total 1 entry |
Total number of (S, G) entries in the multicast routing table. |
00001 |
(172.168.0.2, 227.0.0.1) |
Uptime |
Upstream interface |
Upstream interface the (S, G) entry. Multicast packets should arrive at this interface. |
List of 2 downstream interfaces |
Downstream interface list. These downstream interfaces need to forward multicast packets. |
display multicast routing-table [ all-instance | vpn-instance vpn-instance-name ] static [ source-address { mask-length | mask } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
mask: Specifies the address mask.
mask-length: Specifies the address mask length in the range of 0 to 32.
Use display multicast routing-table static to display the information of multicast static routes.
# Display all the multicast static routes on the public network.
<Sysname> display multicast routing-table static
Multicast Routing Table of VPN-Instance: public net
Routes : 1
Mroute 10.10.0.0/16
Interface = Vlan-interface66 RPF Neighbor = 2.2.2.2
Matched routing protocol = <none>, Route-policy = <none>
Preference = 1, Order = 1
Running Configuration = ip rpf-route-static 10.10.0.0 16 2.2.2.2 order 1
Table 7 Command output
Multicast Routing Table of VPN-Instance: public net |
Multicast routing table for the public network. |
Mroute |
Multicast route source address and its mask length. |
Outgoing interface to the multicast source. |
RPF Neighbor |
IP address of the RPF neighbor through which the multicast source is reachable. |
Route-policy |
Routing policy. The multicast source address of the route should match the routing policy. |
Preference |
Route preference. |
Order |
Sequence number of the route. |
Running Configuration |
Command line that configures the multicast static route. |
display multicast rpf-info
display multicast [ all-instance | vpn-instance vpn-instance-name ] rpf-info source-address [ group-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
Use display multicast rpf-info to display RPF information about a multicast source.
Related commands: display multicast forwarding-table and display multicast routing-table.
# Display all the RPF information about multicast source 192.168.1.55 on the public network.
<Sysname> display multicast rpf-info 192.168.1.55
RPF information about source 192.168.1.55:
VPN instance: public net
RPF interface: Vlan-interface66, RPF neighbor: 10.1.1.1
Referenced route/mask: 192.168.1.0/24
Referenced route type: igp
Load splitting rule: disable
Table 8 Command output
RPF neighbor |
IP address of the RPF neighbor. |
Referenced route/mask |
Referenced route and its mask length. |
Referenced route type |
Type of the referenced route: · igp—Unicast route (IGP). · egp—Unicast route (EGP). · unicast (direct)—Unicast route (directly connected). · unicast—Other unicast route (such as unicast static route). · mbgp—MBGP route. · multicast static—Multicast static route. |
Route selection rule |
Rule for RPF route selection, based on the preference of the routing protocol or based on the longest match on the destination address. |
Load splitting rule |
Status of the load splitting rule: enabled/disabled. |
ip rpf-route-static
ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ] { rpf-nbr-address | interface-type interface-number } [ preference preference ] [ order order-number ]
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask | mask-length } [ protocol [ process-id ] ] [ route-policy policy-name ]
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN, where the vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If this option is not specified, this command configures a multicast static route on the public network.
protocol: Routing protocol:
· bgp: Specifies the BGP protocol.
· isis: Specifies the IS-IS protocol.
· ospf: Specifies the OSPF protocol.
· rip: Specifies the RIP protocol.
· static: Specifies a static route.
process-id: Specifies a process number of the unicast routing protocol, in the range of 1 to 65535. This argument must be provided if IS-IS, OSPF or RIP is the specified unicast routing protocol.
policy-name: Specifies the name of the routing policy used for matching multicast static routes, a case-sensitive string of 1 to 63 characters.
rpf-nbr-address: Specifies an RPF neighbor by the IP address.
interface-type interface-number: Specifies an RPF neighbor by providing the type and number of the interface connecting the RPF neighbor.
preference: Specifies a route preference. The value range is 1 to 255 and the default is 1.
order-number: Specifies a match order for routes on the same segment, in the range of 1 to 100.
Use ip rpf-route-static to configure a multicast static route.
Use undo ip rpf-route-static to delete a multicast static route from the multicast static routing table.
By default, no multicast static route is configured.
The arguments source-address { mask | mask-length }, protocol and policy-name are critical elements in multicast static route configuration. The variation of any of these arguments results in a different configuration.
When you configure a multicast static route, the system first checks whether any of these argument exists. If the system finds a match, you must modify the corresponding fields without changing the configuration sequence. Otherwise, the system adds a multicast static route.
When you configure a multicast static route, specify an RPF neighbor only by providing its IP address (rpf-nbr-address) rather than providing the type and number (interface-type interface-number) of the interface connecting the RPF if the interface of the RPF neighbor is a Layer 3 Ethernet interface, Layer 3 aggregate interface, Loopback interface, Layer 3 RPR logical interface, or VLAN interface.
Because outgoing interface iteration might fail or the specified interface might be in the down state, the multicast static route configured with this command might fail to take effect. Therefore, use the display multicast routing-table static command after you configure a multicast static route to check whether the route has been successfully configured or whether the route has taken effect.
Related commands: delete ip rpf-route-static and display multicast routing-table static.
# Configure a multicast static route to the multicast source 10.1.1.1/24, specifying a router with the IP address of 192.168.1.23 as its RPF neighbor.
[Sysname] ip rpf-route-static 10.1.1.1 24 192.168.1.23
In system view:
undo mac-address [ multicast ] [ [ mac-address [ interface interface-list ] ] vlan vlan-id ]
In Ethernet interface view or Layer 2 aggregate interface view:
undo mac-address [ multicast ] mac-address vlan vlan-id
In port group view:
undo mac-address multicast mac-address vlan vlan-id
View
System view, Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
mac-address: Specifies a static multicast MAC address, which can be any legal multicast MAC address except 0100-5Exx-xxxx and 3333-xxxx-xxxx, where "x" represents any hexadecimal number from 0 to F. Multicast MAC addresses are the MAC addresses whose the least signification bit of the most significant octet is 1. The system will give a prompt if the configured static multicast MAC address conflicts with the MAC address of other protocols.
interface-list: Specifies a list of interfaces. You can specify up to four single interfaces, interface ranges, or combinations of both for the list. A single interface takes the form of interface-type interface-number. An interface range takes the form of interface-type interface-number to interface-type interface-number, where the end interface number must be greater than the start interface number.
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094. The specified VLAN must exist and the system gives a prompt if the specified interface does not belong to the VLAN.
Use mac-address multicast to configure a static multicast MAC address entry.
Use undo mac-address multicast to delete a static multicast MAC address entry.
By default, no static multicast MAC address entry is configured.
If multicast is not specified when using the undo mac-address multicast command, all MAC address entries including static multicast MAC address entries and unicast MAC address entries will be deleted.
Related commands: display mac-address multicast; mac-address (Layer 2—LAN Switching Command Reference).
# Configure a static multicast MAC address entry with the MAC address of 0100-0001-0001 and outgoing interfaces GigabitEthernet 3/0/1 through GigabitEthernet 3/0/5 in VLAN 2.
[Sysname] mac-address multicast 0100-0001-0001 interface GigabitEthernet 3/0/1 to GigabitEthernet 3/0/5 vlan 2
# Configure a static multicast MAC address entry with the MAC address of 0100-0001-0001 in interface view of GigabitEthernet 3/0/1 in VLAN 2.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] mac-address multicast 0100-0001-0001 vlan 2
mtracert
mtracert source-address [ [ last-hop-router-address ] group-address ]
View
Default level
1: Monitor level
last-hop-router-address: Specifies a last-hop router address, which is the IP address of the local router by default.
Use mtracert to trace the path down which the multicast traffic flows to the last-hop router.
If the last-hop-router-address argument is given in the command to trace the path for a specific (S, G) multicast stream, the interface corresponding to the last-hop router address must be the outgoing interface for the (S, G) entry. Otherwise the multicast traceroute will fail.
# Trace the path down which the (6.6.6.6, 225.2.1.1) multicast traffic flows to the last-hop router with an IP address of 5.5.5.8.
<Sysname> mtracert 6.6.6.6 5.5.5.8 225.2.1.1
Type Ctrl+C to quit mtrace facility
Tracing reverse path of (6.6.6.6, 225.2.1.1) from last-hop router (5.5.5.8) to source via multicast routing-table
-1 5.5.5.8
Incoming interface address: 4.4.4.8
Previous-hop router address: 4.4.4.7
Input packet count on incoming interface: 17837
Output packet count on outgoing interface: 0
Total number of packets for this source-group pair: 8000
Protocol: PIM
Forwarding TTL: 0
Forwarding code: No error
-2 4.4.4.7
Incoming interface address: 6.6.6.7
Previous-hop router address: 0.0.0.0
Input packet count on incoming interface: 2
Output packet count on outgoing interface: 259
Total number of packets for this source-group pair: 8100
Protocol: PIM
Forwarding TTL: 0
Table 9 Command output
(6.6.6.6, 225.2.1.1) |
(S, G) multicast stream for which the forwarding path is being traced. |
-1 5.5.5.8 |
(S, G) outgoing interface address of each hop, starting from the last-hop router. |
Incoming interface address |
Address of the interface on which the (S, G) packets arrive. |
Previous-hop router address |
IP address of the router from which this router receives packets from this source. |
Input packet count on incoming interface |
Total number of multicast packets received on the incoming interface. |
Output packet count on outgoing interface |
Total number of multicast packets transmitted on the outgoing interface. |
Total number of packets for this source-group pair |
Total number of packets from the specified source forwarded by this router to the specified group. |
Protocol |
Multicast routing protocol in use. |
Forwarding TTL |
Minimum TTL that a packet is required to have before it can be forwarded over the outgoing interface. |
multicast boundary
multicast boundary group-address { mask | mask-length }
undo multicast boundary { group-address { mask | mask-length } | all }
View
Interface view
Default level
2: System level
all: Specifies to remove all forwarding boundaries configured on the interface.
Use multicast boundary to configure a multicast forwarding boundary.
Use undo multicast boundary to remove a multicast forwarding boundary.
By default, no multicast forwarding boundary is configured.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet will not be forwarded.
An interface can act as a forwarding boundary for multiple multicast groups in different address ranges. To achieve this, use this command on the interface for each multicast address range.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. If B is configured after A, A still takes effect. If A is configured after B, B will be removed.
Related commands: display multicast boundary.
# Configure VLAN-interface 100 to be the forwarding boundary of multicast groups in the range of 239.2.0.0/16.
[Sysname-Vlan-interface100] multicast boundary 239.2.0.0 16
undo multicast forwarding on-demand
View
VLAN view
Default level
2: System level
None
Use multicast forwarding on-demand to enable the multicast forwarding on-demand function in the VLAN.
Use undo multicast forwarding on-demand to restore the default.
By default, multicast forwarding on-demand is disabled.
After using this command in a VLAN that has been enabled with BIDIR-PIM, you must clear all entries in the multicast forwarding table. Otherwise, this configuration cannot take effect.
After using this command in a multicast VLAN, you must clear all the IGMP snooping multicast group information in the VLAN. Otherwise, this configuration cannot take effect.
After using this command in a non-multicast VLAN with a Layer 3 multicast protocol (IGMP or PIM) enabled on the corresponding VLAN interface, you must clear the Layer 2 port information of all IGMP multicast groups in the VLAN and the IGMP multicast group information on the corresponding VLAN interface. Otherwise, this configuration cannot take effect.
This command cannot take effect in a non-multicast VLAN with IGMP snooping enabled in the VLAN.
Related commands: igmp-snooping enable, reset igmp group, reset igmp group port-info, and reset igmp-snooping group.
# Enable multicast forwarding on-demand in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] multicast forwarding on-demand
multicast forwarding-table downstream-limit limit
undo multicast forwarding-table downstream-limit
View
System view, VPN instance view
Default level
2: System level
limit: Specifies the maximum number of downstream nodes (the maximum number of outgoing interfaces) for a single multicast forwarding entry. The value range for this argument is 0 to 256.
Use multicast forwarding-table downstream-limit to configure the maximum number of downstream nodes for a single entry in the multicast forwarding table.
Use undo multicast forwarding-table downstream-limit to restore the default.
By default, the maximum number of downstream nodes for a single multicast forwarding entry is 256.
# Set the maximum number of downstream nodes for a single multicast forwarding entry in the public network to 120.
[Sysname] multicast forwarding-table downstream-limit 120
# Set the maximum number of downstream nodes for a single multicast forwarding entry of VPN instance mvpn to 60.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast forwarding-table downstream-limit 60
multicast forwarding-table route-limit limit
undo multicast forwarding-table route-limit
View
Default level
2: System level
limit: Specifies the maximum number of entries in the multicast forwarding table. The value range for this argument is 0 to the maximum number that the switch allows.
Use multicast forwarding-table route-limit to configure the maximum number of entries in the multicast forwarding table.
Use undo multicast forwarding-table route-limit to restore the maximum number of entries in the multicast forwarding table to the system default.
The default upper limit for the public network depends on the system operating mode. For more information about the system operating modes, see Fundamentals Configuration Guide.
The default upper limit for VPN instance is 1024.
# Set the maximum number of entries in the multicast forwarding table in the public network to 200.
[Sysname] multicast forwarding-table route-limit 200
# Set the maximum number of entries in the multicast forwarding table of VPN instance mvpn to 200.
[Sysname-vpn-instance-mvpn] multicast forwarding-table route-limit 200
multicast load-splitting
multicast load-splitting { source | source-group }
undo multicast load-splitting
View
Default level
2: System level
source: Specifies to implement per-source load splitting.
source-group: Specifies to implement per-source and per-group load splitting simultaneously.
Use multicast load-splitting to enable load splitting of multicast traffic.
Use undo multicast load-splitting to disable load splitting of multicast traffic.
By default, load splitting of multicast traffic is disabled.
This command does not take effect on BIDIR-PIM.
# Enable per-source load splitting of multicast traffic on the public network.
[Sysname] multicast load-splitting source
# Enable per-source load splitting of multicast traffic in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast load-splitting source
multicast longest-match
undo multicast longest-match
View
Default level
2: System level
None
Use multicast longest-match to configure the device to select the RPF route based on the longest match principle.
Use undo multicast longest-match to restore the default.
By default, the device selects the route with the highest priority as the RPF route.
# Configure the device to select the RPF route based on the longest match principle on the public network.
[Sysname] multicast longest-match
# Configure route selection based on the longest match in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast longest-match
multicast routing-enable
undo multicast routing-enable
View
Default level
2: System level
None
Use multicast routing-enable to enable IP multicast routing.
Use undo multicast routing-enable to disable IP multicast routing.
By default, IP multicast routing is disabled.
You must enable IP multicast routing on the public network or VPN instance before you can execute other Layer 3 multicast commands in the corresponding instance.
The device does not forward any multicast packets before IP multicast routing is enabled.
When the system is operating in standard mode, you must configure a reserved VLAN before you configure multicast routing and forwarding for a VPN instance. For more information about the system operating mode, see Fundamentals Configuration Guide. For more information about the configuration and commands about a reserved VLAN, see MPLS Configuration Guide and MPLS Command Reference.
# Enable IP multicast routing on the public network.
[Sysname] multicast routing-enable
# Enable IP multicast routing in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] route-distinguisher 100:1
[Sysname-vpn-instance-mvpn] multicast routing-enable
undo multicast rpf-fail-pkt bridging
View
Default level
2: System level
None
Use multicast rpf-fail-pkt bridging to enable forwarding of multicast packets in case of RPF check failure on VLAN interfaces.
Use undo multicast rpf-fail-pkt bridging to restore the default.
By default, multicast packets that fail RPF check on a VLAN interface are discarded.
After using this command, you must clear all the entries in the multicast forwarding table. Otherwise, this configuration cannot take effect.
Related commands: reset multicast forwarding-table.
# Enable forwarding of multicast packets that fail RPF check on VLAN interfaces.
[Sysname] multicast rpf-fail-pkt bridging
undo multicast rpf-fail-pkt trap-to-cpu
View
Default level
2: System level
None
Use multicast rpf-fail-pkt trap-to-cpu to enable sending multicast data packets that have failed an RPF check to the CPU.
Use undo multicast rpf-fail-pkt trap-to-cpu to restore the default.
By default, this function is disabled.
After using this command, you must clear all the entries in the multicast forwarding table. Otherwise this configuration cannot take effect.
# Configure the device to send multicast data packets that have failed an RPF check to the CPU.
[Sysname] multicast rpf-fail-pkt trap-to-cpu
reset multicast [ all-instance | vpn-instance vpn-instance-name ] forwarding-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
incoming-interface: Specifies to clear multicast forwarding entries of which the incoming interface is the specified one.
register: Specifies to clear multicast forwarding entries of which the incoming interface is the specified register interface of PIM-SM.
all: Specifies to clear all the forwarding entries from the multicast forwarding table.
Use reset multicast forwarding-table to clear the multicast forwarding table.
If neither all-instance nor vpn-instance is specified, this command clears the forwarding table information on the public network.
When a forwarding entry is deleted from the multicast forwarding table, the corresponding routing entry is also deleted from the multicast routing table.
Related commands: display multicast forwarding-table, display multicast routing-table, and reset multicast routing-table.
# Clear the multicast forwarding entries related to multicast group 225.5.4.3 from the multicast forwarding table in the public network.
<Sysname> reset multicast forwarding-table 225.5.4.3
# Clear the multicast forwarding entries related to multicast group 226.1.2.3 from the multicast forwarding table of VPN instance mvpn.
<Sysname> reset multicast vpn-instance mvpn forwarding-table 226.1.2.3
reset multicast [ all-instance | vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } } * | all }
View
Default level
2: System level
incoming-interface: Specifies to clear the routing entries of which the incoming interface is the specified one.
register: Specifies to clear the routing entries of which the incoming interface is the specified register interface of PIM-SM.
all: Specifies to clear all the routing entries from the multicast routing table.
Use reset multicast routing-table to clear the multicast routing table.
When a routing entry is deleted from the multicast routing table, the corresponding forwarding entry is also deleted from the multicast forwarding table.
Related commands: display multicast forwarding-table, display multicast routing-table, and reset multicast forwarding-table.
# Clear the route entries related to multicast group 225.5.4.3 from the multicast routing table in the public network.
<Sysname> reset multicast routing-table 225.5.4.3
# Clear the route entries related to multicast group 226.1.2.3 from the multicast routing table of VPN instance mvpn.
<Sysname> reset multicast vpn-instance mvpn routing-table 226.1.2.3
