08-IP Multicast Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18208-IP Multicast Command Reference
09-Multicast VPN Commands
09-Multicast VPN Commands 132.8 KB
Multicast VPN configuration commands······································································································································· 1
display bgp mdt group·················································································································································· 1
display bgp mdt peer····················································································································································· 3
display bgp mdt routing-table······································································································································ 6
display multicast-domain vpn-instance share-group······························································································· 8
display multicast-domain vpn-instance switch-group receive················································································ 9
display multicast-domain vpn-instance switch-group send················································································· 11
ipv4-family mdt······························································································································································· 13
multicast-domain holddown-time································································································································ 13
multicast-domain log switch-group-reuse················································································································· 14
multicast-domain share-group····································································································································· 14
multicast-domain switch-delay···································································································································· 15
multicast-domain switch-group-pool·························································································································· 16
peer enable (BGP-MDT sub-address family view)······························································································· 17
peer group (BGP-MDT sub-address family view)································································································· 18
peer reflect-client (BGP-MDT sub-address family view)······················································································· 19
reflect between-clients (BGP-MDT sub-address family view)············································································· 19
reflector cluster-id (BGP-MDT sub-address family view)······················································································ 20
reset bgp mdt·································································································································································· 21
The term "router" in this document refers to both routers and Layer 3 switches.
display bgp mdt group [ group-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-name: Specifies a BGP MDT peer group. A group name is a case-sensitive string of 1 to 47 characters and must not contain any space.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display bgp mdt group to display the information of a BGP MDT peer group.
# Display the information of the BGP MDT peer group test.
<Sysname> display bgp mdt group test
 BGP peer-group is test
 Remote AS 2004
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Connect-interface has been configured
 Multi-hop ebgp been enabled
 Peer Preferred Value: 0
  Members:
  Peer                    AS  MsgRcvd  MsgSent OutQ PrefRcv Up/Down  State
  2.2.2.1               2004        0        0    0       0 00:01:21 Active
BGP peer-group
BGP peer group name.
Remote AS
AS number of the peer group.
Type of the peer group:
·     External—EBGP peer group.
·     Internal—IBGP peer group.
Maximum number of allowed prefixes.
Threshold
Percentage of received prefixes from the peer group to maximum prefixes allowed to receive from the peer group.
Holdtime interval.
Keepalive interval.
Minimum route advertisement interval.
The source interface for TCP connection is configured.
The hop count of the peer's TCP connection can exceed 1 but cannot exceed the configured limit.
Preferred value specified for the routes from the peer.
Members
Detailed information about the members in the peer group.
Peer
IP address of the peer.
AS
AS number of the peer.
MsgRcvd
Number of received messages.
MsgSent
Number of sent messages.
OutQ
Number of messages to be sent.
PrefRcv
Number of received prefixes.
Up/Down
Length of time since the session was established/time elapsed in the current state (before the session is established).
State of the peer:
·     Active—Waiting for reestablishing a TCP connection after an establishment failure.
·     Connect—A TCP connection is required but not established yet.
·     Established—A TCP connection is established.
·     Idle—No TCP connections are required after the peer relationship is configured.
·     Idle(Admin)—The peer is configured at the CLI not to require any TCP connection.
·     Openconfirm—Waiting for the keepalive message after receiving an open message.
·     Opensent—An open message is successfully sent to the peer.
display bgp mdt peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Displays the information of the specified BGP MDT peer.
verbose: Displays detailed information.
Use display bgp mdt peer to display BGP MDT peer information.
# Display detailed information about the BGP MDT peer 2.2.2.1.
<Sysname> display bgp mdt peer 2.2.2.1 verbose
         Peer: 2.2.2.1   Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h01m51s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 1029     Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
         Address family IPv4 MDT: advertised and received
 Received: Total 5 messages, Update messages 1
 Sent: Total 4 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
 Routing policy configured:
Peer
Local
Local router ID.
Peer types:
·     IBGP link—IBGP peers.
·     EBGP link—EBGP peers.
remote router ID
Router ID of the peer.
BGP current state
Current state of the BGP peer:
·     Established— A TCP connection is established between peers.
BGP current event
Current event of the peer:
·     AdvTimerExpired—The route advertisement timer expires.
·     ConnCloesed—The TCP connection is closed.
·     ConnOpen—A TCP connection is required.
·     ConnOpenFailed—Fail to establish a TCP connection.
·     CRTTimerExpired—The connect timer expires.
·     HOLDTimerExpired—The holdtime timer expires.
·     KATTimerExpired—The keepalive timer expires.
·     RecvKeepalive—A keepalive message is received from the peer.
·     RecvNotification—A notification message is received from the peer.
·     RecvOpen—An open message is received from the peer.
·     RecvRouteRefresh—A route-refresh message is received from the peer.
·     RecvUpdate—An update message is received from the peer.
·     Start—No TCP connections are required after the peer relationship is configured.
·     Stop—The peer is configured not to require any TCP connection at the CLI.
·     TransFatalError—A fatal mistake occurs during the establishment of the TCP connection.
BGP last state
Previous state of the peer:
·     Established—A TCP connection is established between peers.
Port
Local and remote TCP port numbers for establishing a TCP connection.
Configured
Locally configured timer value:
·     Active Hold Time—The holdtime interval for the connection to the peer.
·     Keepalive Time—The keepalive interval for the connection to the peer.
Received
Received timer settings on the peer:
Negotiated
Negotiated timer settings:
Optional capabilities supported by the peer.
The peer supports multiprotocol BGP extensions.
The peer supports the BGP route refresh function.
Routes are advertised and received in IPv4 unicast.
Routes are advertised and received in IPv4 multicasts.
Received
Total numbers of received packets and updates.
Sent
Total numbers of sent packets and updates.
Threshold
Optional capabilities enabled by the peer.
Local routing policy.
display bgp mdt { all | route-distinguisher route-distinguisher } routing-table [ ip-address [ mask | mask-length ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all the BGP MDT routes.
route-distinguisher route-distinguisher: Specifies a route distinguisher. The route-distinguisher argument identifies the route distinguisher name, a string of 3 to 21 characters in the form of nn:nn or IP-address:nn.
ip-address: Specifies a destination IP address.
mask: Specifies a network mask, 225.225.225.225 by default.
mask-length: Specifies a mask length in the range 0 to 32. The default is 32.
Use display bgp mdt all routing-table to display the BGP MDT routing information.
# Display all the BGP MDT routing information.
<Sysname> display bgp mdt all routing-table
 BGP Local router ID is 2.2.2.2
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
                  h - history,  i - internal, s - suppressed, S - Stale
                  Origin : i - IGP, e - EGP, ? - incomplete
 Total number of MDT routes: 1
 Route Distinguisher: 100:1
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
 *>  1.1.1.1/32         3.3.3.3         0          100        10      ?
Total number of MDT routes.
Network
MD source address displayed in the BGP routing table.
MED
Metric associated with the destination network.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops.
Ogn
Origin attribute of the route:
·     i—The route is interior to the AS. Aggregate routes and the routes injected with the network command are considered IGP routes.
·     eThe route is learned from the EGP.
·     ?The origin of the route is unknown, such as the MDT routes redistributed from other routing protocols.
display multicast-domain vpn-instance vpn-instance-name share-group { local | remote } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance-name: Name of an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
local: Displays the local share-group information.
remote: Displays the remote share-group information.
Use display multicast-domain vpn-instance share-group to display the share-group information of the specified VPN instance in the MD.
# Display the local share-group information of VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn share-group local
MD local share-group information for VPN-Instance: mvpn
  Share-group: 225.2.2.2
  MTunnel address: 1.1.1.1
# Display the remote share-group information of VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn share-group remote
MD remote share-group information for VPN-Instance: mvpn
  Route-Distinguisher    Router-ID        Share-Group      Next-Hop
  1:1                        2.2.2.2          225.2.2.2        10.1.1.1
Local share-group information of VPN instance mvpn.
Remote share-group information of VPN instance mvpn.
Share-group
Share-group address.
MTunnel address
MTI address associated with the share-group address.
Router-ID
Router ID of the peer that sends the route information.
Next-Hop
IP address of the next hop.
display multicast-domain vpn-instance vpn-instance-name switch-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance-name: Specifies a name of an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
brief: Displays the brief switch-group information received by the specified VPN instance.
active: Displays the received switch-group information about active multicast domains.
group-address: Specifies a public network multicast group address in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies a public network multicast source address.
vpn-source-address: Specifies a VPN multicast source address.
mask: Specifies the address subnet mask, 255.255.255.255 by default.
mask-length: Specifies the address mask length in the range of 0 to 32. The default is 32.
vpn-group-address: Specifies a VPN multicast group address in the range of 224.0.0.0 to 239.255.255.255.
Use display multicast-domain vpn-instance switch-group receive to display the switch-group information received by the specified VPN instance in the MD.
Related commands: display multicast-domain vpn-instance switch-group send.
# Display switch-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive
MD switch-group information received by VPN-Instance: mvpn
Total 2 switch-groups for 8 entries
Total 2 switch-groups for 8 entries matched
switch group:  226.1.1.0 ref count: 4, active count: 2
  sender:  172.100.1.1 active count: 1
    (192.6.1.5, 239.1.1.1)       expire time: 00:03:10  active
    (192.6.1.5, 239.1.1.158)     expire time: 00:03:10
  sender:  181.100.1.1 active count: 1
    (195.6.1.2, 239.1.2.12)      expire time: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     expire time: 00:03:10
switch group:  229.1.1.0 ref count: 4, active count: 2
  sender:  185.100.1.1 active count: 1
    (198.6.1.5, 239.1.3.62)      expire time: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     expire time: 00:03:10
  sender:  190.100.1.1 active count: 1
    (200.6.1.2, 225.1.4.80)      expire time: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     expire time: 00:03:10
# Display brief switch-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive brief
Table 5 Command output
Switch-group information received by VPN instance mvpn.
Totally two switch-groups, corresponding to eight (S, G) entries.
Totally two switch-groups are matched, corresponding to eight (S, G) entries.
switch group
Switch-group address received.
sender
BGP peer address of the PE device that sent the switch-group information.
ref count
Number of VPN multicast groups referenced by the switch-group.
active count
Number of active VPN multicast groups (multicast groups with active receivers) referenced by the switch-group.
expire time
Remaining time of the VPN (S, G) entry referenced by the switch-group.
display multicast-domain vpn-instance vpn-instance-name switch-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
reuse interval: Displays the information about switch-group reuses that took place during the specified length of time in seconds. The value range for the interval argument is 1 to 2147483647.
Use display multicast-domain vpn-instance switch-group send to display the switch-group information sent by the specified VPN instance in the MD.
Related commands: display multicast-domain vpn-instance switch-group receive.
# Display the switch-group information sent by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group send
MD switch-group information sent by VPN-Instance: mvpn
Total 2 switch-groups for 6 entries
Total 2 switch-groups for 6 entries matched
  226.1.1.0 reference_count: 3
    (192.6.1.5, 239.1.1.1)                  switch time: 00:00:21
    (192.6.1.5, 239.1.1.158)                switch time: 00:00:21
    (192.6.1.5, 239.1.2.50)                 switch time: 00:00:05
  226.1.1.1 reference_count: 3
    (192.6.1.2, 225.1.1.1)                  switch time: 00:00:21
    (192.6.1.2, 225.1.2.50)                 switch time: 00:00:05
    (192.6.1.5, 239.1.1.159)                switch time: 00:00:21
# Display the switch-group reuse information sent by VPN instance mvpn during 30 seconds in the MD.
<Sysname> display multicast-domain vpn-instance mvpn switch-group send reuse 30
Total 2 switch-groups for 3 entries
Total 2 switch-groups for 3 entries matched
  226.1.1.0 reuse_count: 1
  226.1.1.1 reuse_count: 1
  226.1.1.2 reuse_count: 1
Table 6 Command output
Switch-group information sent by VPN instance mvpn.
Totally two switch-groups, corresponding to six (S, G) entries.
Totally two switch-groups are matched, corresponding to six (S, G) entries.
reference_count
Number of VPN multicast groups referenced by the sent switch-group.
switch time
Switching time of the VPN (S, G) entry referenced by the switch-group.
reuse_count
Number of switch-group reuses during the specified length of time.
ipv4-family mdt
ipv4-family mdt
undo ipv4-family mdt
View
BGP view
Default level
2: System level
None
Use ipv4-family mdt to enter BGP-MDT sub-address family view.
Use undo ipv4-family mdt to remove all the settings made in BGP-MDT sub-address family view.
# Enter BGP-MDT sub-address family view.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family mdt
[Sysname-bgp-af-mdt]
multicast-domain holddown-time interval
undo multicast-domain holddown-time
View
VPN instance view
Default level
2: System level
interval: Specifies a switch-holddown period (delay time before multicast traffic to be switched from the switch-MDT back to the share-MDT) in seconds, in the range of 0 to 180.
Use multicast-domain holddown-time to configure the switch-holddown period.
Use undo multicast-domain holddown-time to restore the default.
By default, the switch-holddown period is 60 seconds.
This command cannot be configured without previous share-MDT configuration in the VPN instance.
# Set the switch-holddown period to 80 seconds in VPN instance mvpn.
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast-domain holddown-time 80
undo multicast-domain log
View
VPN instance view
Default level
2: System level
None
Use multicast-domain log switch-group-reuse to enable switch-group reuse logging.
Use undo multicast-domain log to disable switch-group reuse logging.
By default, the switch-group reuse logging function is disabled.
This command cannot be configured without the previous share-MDT configuration in the VPN instance.
# Enable switch-group reuse logging in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast-domain log switch-group-reuse
multicast-domain share-group group-address binding mtunnel mtunnel-number
undo multicast-domain share-group
View
VPN instance view
Default level
2: System level
mtunnel-number: Specifies the number of the MTI interface to be created. The value range for this argument varies with the system operating modes. For more information, see Fundamentals Configuration Guide.
Use multicast-domain share-group to configure a share-group address and associate an MTI with the current VPN instance.
Use undo multicast-domain share-group to restore the default.
By default, no share-group address is configured and no MTI is associated with a VPN instance.
To specify a multicast group address on the public network SSM group range as a share-group address, you must first configure BGP MDT peers or peer groups.
On the same PE device, different VPN instances must not have the same group address, and group-address must not coincide with the switch-group address of any VPN instance; in addition, mtunnel-number must not coincide with the number of any MTI already created.
This command must not be used multiple times in the same VPN instance view. To configure a new group address and MTI for a VPN instance, you must remove the existing configuration.
The undo multicast-domain share-group command removes the configured MTI and the configurations of the multicast-domain switch-group-pool, multicast-domain log switch-group-reuse and multicast-domain switch-delay commands.
IP multicast routing must be enabled in the VPN instance before this command can take effect.
Related commands: multicast routing-enable, multicast-domain log switch-group-reuse, multicast-domain switch-delay, and multicast-domain switch-group-pool.
# Specify 224.1.1.1 as the share-group address in VPN instance mvpn and associate MTI 0 with the VPN instance.
[Sysname-vpn-instance-mvpn] multicast-domain share-group 224.1.1.1 binding mtunnel 0
multicast-domain switch-delay switch-delay
undo multicast-domain switch-delay
View
VPN instance view
Default level
2: System level
switch-delay: Specifies a switch-delay period (delay time for multicast traffic to be switched from the share-MDT to the switch-MDT) in seconds, in the range of 3 to 60.
Use multicast-domain switch-delay to configure the switch-delay period.
Use undo multicast-domain switch-delay to restore the default.
By default, the switch-delay period is 5 seconds.
# Set the switch-delay period to 20 seconds in VPN instance mvpn.
[Sysname-vpn-instance-mvpn] multicast-domain switch-delay 20
multicast-domain switch-group-pool switch-group-pool { mask | mask-length } [ acl acl-number ]
undo multicast-domain switch-group-pool
View
VPN instance view
Default level
2: System level
switch-group-pool: Specifies the start address of the switch-group-pool, in the range of 224.0.1.0 to 239.255.255.255.
mask: Specifies the mask for addresses in the switch-group-pool. The value range for this argument varies with the system operating modes. For more information, see Fundamentals Configuration Guide.
mask-length: Specifies the mask length for addresses in the switch-group-pool. The value range for this argument varies with the system's operating mode. For more information, see Fundamentals Configuration Guide.
acl-number: Specifies an advanced ACL number in the range of 3000 to 3999. An advanced ACL defines the (S, G) entry or entries to which the configured MDT switching condition will apply. If you do not specify an ACL, the configured MDT switching condition will apply to all (S, G) entries. When you configure this ACL, specify the protocol type as IP, and use the source and destination parameters to specify a multicast source address range and a multicast group address range, respectively.
Use multicast-domain switch-group-pool to configure the address range of the switch-group-pool and the switching condition.
Use undo multicast-domain switch-group-pool to restore the default.
By default, no switch-group-pool is configured and multicast traffic is never switched to a switch-MDT.
On a given PE device, the switch-group address range for a VPN must not contain the share-group of any VPN.
On a given PE device, the switch-group address range for a VPN instance must not overlap with that for any other VPN instance. A new configuration with this command in the same VPN instance supersedes the existing configuration.
If you use the multicast-domain switch-group-pool command on a switch, share-MDT to switch-MDT switching will take place after the switch receives multicast traffic for this VPN instance and has maintained it for the switch-delay period.
Related commands: multicast-domain switch-delay.
# Configure the address range of the switch-group-pool in VPN instance mvpn as 225.2.2.0 to 225.2.2.15.
[Sysname-vpn-instance-mvpn] multicast-domain switch-group-pool 225.2.2.0 28
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
View
Default level
2: System level
group-name: Name of a BGP MDT peer group, a case-sensitive string of 1 to 47 characters. A peer group name must not contain any space.
ip-address: IP address of a BGP MDT peer.
Use peer enable to enable the specified peer or peer group.
Use undo peer enable to disable the specified peer or peer group.
By default, no BGP MDT peer or peer group is enabled.
The BGP peer or peer group must be configured before this command can take effect.
Related commands: group, peer as-number, and peer group (Layer 3—IP Routing Command Reference).
# Configure and enable the BGP MDT peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp-af-mdt] peer 18.10.0.9 enable
peer ip-address group group-name
undo peer ip-address group group-name
View
Default level
2: System level
Use peer group to add a peer to the BGP MDT peer group.
Use undo peer group to delete a peer from the peer group.
By default, a peer belongs to no peer groups.
The BGP MDT peer and peer group must be configured and enabled before this command can take effect.
Related commands: peer enable.
# Configure and enable the BGP MDT peer 10.1.1.1 and the peer group test, and then add the peer to the peer group.
[Sysname] bgp 100
[Sysname-bgp] group test
[Sysname-bgp] peer test as-number 2004
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp-af-mdt] peer test enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 group test
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
View
Default level
2: System level
group-name: Name of a BGP MDT peer group, a case-sensitive string of 1 to 47 characters. A peer name must not contain any space.
Use peer reflect-client to configure the router as a route reflector and specify a peer or peer group as its client.
Use undo peer reflect-client to remove the configuration.
By default, neither route reflectors nor clients are configured.
Before you configure this command, BGP MDT peers or peer groups should be configured.
Related commands: peer enable, reflect between-clients, and reflect cluster-id.
# Configure and activate BGP MDT peer group test, and then configure the local device as a route reflector and specify the BGP MDT peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] peer test reflect-client
undo reflect between-clients
View
Default level
2: System level
None
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable this function.
By default, route reflection between clients is enabled.
Related commands: peer reflect-client and reflector cluster-id.
# Disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] undo reflect between-clients
undo reflector cluster-id
View
Default level
2: System level
cluster-id: Specifies a cluster ID of the route reflector, in the range 1 to 4294967295.
ip-address: Specifies a cluster ID of the route reflector, which is the IP address of the specified BGP MDT peer.
Use reflector cluster-id to configure the cluster ID of the route reflector.
Use undo reflector cluster-id to remove the configured cluster ID.
By default, a route reflector uses its router ID as the cluster ID.
In general, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability, and they must have the same cluster ID configured to avoid routing loops.
Related commands: reflect between-clients and peer reflect-client.
# Specify 80 as the cluster ID for the route reflector.
[Sysname] bgp 100
[Sysname-bgp-af-mdt] reflector cluster-id 80
reset bgp mdt
reset bgp mdt { as-number | ip-address | all | external | group group-name | internal }
View
Default level
2: System level
as-number: Specifies an AS number in the range of 1 to 4294967295.
ip-address: Specifies a BGP MDT peer.
all: Specifies all the BGP MDT connections.
external: Specifies all the EBGP MDT connections.
group group-name: Specifies a BGP peer group. A peer group name is a case-sensitive string of 1 to 47 characters and must not contain any space.
internal: Specifies all the IBGP MDT connections.
Use reset bgp mdt to reset BGP MDT connections.
# Reset all the BGP MDT connections.
<Sysname> reset bgp mdt all
