08-IP Multicast Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18208-IP Multicast Command Reference
01-IGMP Snooping Commands
01-IGMP Snooping Commands 216.31 KB
IGMP snooping configuration commands
The term "router" in this document refers to both routers and Layer 3 switches.
display igmp-snooping group
Standalone mode:
display igmp-snooping group [ vlan vlan-id ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display igmp-snooping group [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan vlan-id: Specifies a VLAN. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, this command displays information about IGMP snooping groups in all VLANs.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays the IGMP snooping group information on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, this command displays the information of IGMP snooping groups on all MPUs in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
verbose: Displays the detailed IGMP snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display igmp-snooping group to display IGMP snooping group information, including both dynamic entries and static entries.
# Display detailed IGMP snooping group information on VLAN 2000 on the card in slot 5.
<Sysname> display igmp-snooping group vlan 22000 slot 5 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2000.
    Router port unit board: Mask(0x0)
    Router port(s):total 0 port.
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:225.0.0.1
        (0.0.0.0, 225.0.0.1):
          Attribute:    Host Port
          Host port unit board: Mask(0x0)
          Host port(s):total 1 port.
            GE5/0/33              (D) ( 00:04:12 )
    MAC group(s):
      MAC group address:0100-5e00-0001
            GE5/0/33
Total number of IP multicast groups.
Total number of multicast sources.
Total number of MAC multicast groups.
Port flags:
·     D—Dynamic port.
·     S—Static port.
·     C—Port copied from a (*, G) entry to an (S, G) entry.
·     P—Port added by PIM snooping.
Sub-VLAN flags:
·     R—Real egress sub-VLAN under the current entry.
·     C—sub-VLAN copied from a (*, G) entry to an (S, G) entry.
Mask indicating a board with a router port residing on it.
Router port(s)
Number of router ports.
( 00:04:12)
Remaining time of the aging timer for the dynamic member port or router port:
·     In standalone mode, to display the remaining life of a non-aggregation port that does not belong to the MPU, you must specify the number of the slot where the corresponding card resides by using slot slot-number. This is not required for an aggregation port.
·     In IRF mode, to display the remaining life of a non-aggregation port that does not belong to the MPU, you must specify the member ID of the device in the IRF and the slot number of the card with chassis chassis-number slot slot-number. For an aggregation port, you do not need to do this.
IP group address
Address of IP multicast group.
(S, G) entry. If the multicast source is not specified, the field in the S position displays 0.0.0.0.
MAC group address
Address of MAC multicast group.
Attribute
Attribute of IP multicast group.
Mask indicating a board with a member port residing on it.
Host port(s)
Number of member ports.
display igmp-snooping host
Standalone mode:
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group group-address: Specifies a multicast group address. The value range for the group-address argument ranges is 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a source address. The value for the source-address argument is a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
slot slot-number: Specifies a card by its slot number. If no slot is specified, the command displays information about the IGMP snooping tracked host on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device, and the slot-number argument represents the number of the slot that holds the card. If this option is not specified, this command displays information about the hosts tracked by IGMP snooping on all MPUs in the IRF member devices. To obtain the chassis number and slot number, you can use the display device command. (In IRF mode.)
Use display igmp-snooping host to display information about the hosts tracked by IGMP snooping.
# Display information about the hosts tracked by IGMP snooping on VLAN 2 that are in multicast group 224.1.1.1.
<Sysname> display igmp-snooping host vlan 2 group 224.1.1.1
VLAN(ID) : 2
  (0.0.0.0, 224.1.1.1)
    Port : GigabitEthernet3/0/1
      Host                                    Uptime          Expires
      1.1.1.1                                 00:02:20        00:00:40
      2.2.2.2                                 00:02:21        00:00:39
    Port : GigabitEthernet3/0/2
      Host                                    Uptime          Expires
      3.3.3.3                                 00:02:20        00:00:40
Port
Member port.
Host
Host IP address.
Uptime
Host running duration.
Expires
Host expiration time. If the host has expired, this field displays timeout.
display igmp-snooping statistics
display igmp-snooping statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display igmp-snooping statistics to display statistics for IGMP messages learned through IGMP snooping.
# Display statistics for IGMP messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
  Received IGMP general queries:0.
  Received IGMPv1 reports:0.
  Received IGMPv2 reports:19.
  Received IGMP leaves:0.
  Received IGMPv2 specific queries:0.
  Sent     IGMPv2 specific queries:0.
  Received IGMPv3 reports:1.
  Received IGMPv3 reports with right and wrong records:0.
  Received IGMPv3 specific queries:0.
  Received IGMPv3 specific sg queries:0.
  Sent     IGMPv3 specific queries:0.
  Sent     IGMPv3 specific sg queries:0.
  Received error IGMP messages:19.
general queries
General query messages.
specific queries
Group-specific query messages.
reports
Report messages.
leaves
Leave messages.
Report messages with correct and incorrect records.
specific sg query packet(s)
Group-and-source-specific query message or messages.
error IGMP messages
IGMP messages with errors.
entry-limit (IGMP-snooping view)
entry-limit limit
undo entry-limit
View
IGMP-snooping view
Default level
2: System level
limit: Specifies the maximum number of entries in the IGMP snooping forwarding table, in the range of 0 to 2000.
Use entry-limit to configure the maximum number of entries in the IGMP snooping forwarding table globally.
Use undo entry-limit to restore the default.
By default, the upper limit is 2000.
Related commands: multicast-vlan entry-limit.
# Configure the IGMP snooping forwarding table to contain at most 512 entries.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] entry-limit 512
fast-leave (IGMP-snooping view)
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
vlan vlan-list: Specifies one or multiple VLANs. You can provide up to 10 VLAN lists. For each list, you can specify an individual VLAN in the form of vlan-id, or a VLAN range in the form of start-vlan-id to end-vlan-id, where the end VLAN ID must be greater than the start VLAN ID. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command takes effect for all VLANs. If you specify one or more VLANs, the command takes effect on the specified VLANs only.
Use fast-leave to enable IGMP snooping fast-leave processing globally. With this function enabled, when the switch receives an IGMP leave message on a port, it directly removes that port from the multicast forwarding entry of a specific group.
Use undo fast-leave to disable IGMP snooping fast-leave processing globally.
By default, IGMP snooping fast-leave processing is disabled.
This command is also effective on VLANs with IGMP enabled on their VLAN interfaces.
Related commands: igmp-snooping fast-leave.
# Enable IGMP snooping fast-leave processing globally on VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
group-policy (IGMP-snooping view)
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
acl-number: Specifies a basic or advanced ACL number in the range of 2000 to 3999. A host can only join the multicast groups that match the permit statement in the specified ACL. The source address or address range specified in the advanced ACL rule matches the multicast source addresses specified in IGMPv3 reports, rather than the source address in the IP packets. The system assumes that an IGMPv1 or IGMPv2 report or an IGMPv3 IS_EX or TO_EX report that does not carry a multicast source address carries a multicast source address of 0.0.0.0.
Use group-policy to configure a global multicast group filter to control the multicast groups a host can join.
Use undo group-policy to remove the configured global multicast group filter.
By default, no global multicast group filter is configured and a host can join any valid multicast group.
If the specified ACL does not exist or the ACL rule is null, all multicast groups will be filtered out.
You can configure different ACL rules for a port in different VLANs. For a given VLAN, a newly configured ACL rule will override the existing one.
Related commands: igmp-snooping group-policy.
# Apply ACL 2000 as a multicast group filter on VLAN 2 so that hosts in this VLAN can join 225.1.1.1 only.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
host-aging-time (IGMP-snooping view)
host-aging-time interval
undo host-aging-time
View
IGMP-snooping view
Default level
2: System level
interval: Specifies a dynamic member port aging timer in seconds, in the range of 200 to 1000.
Use host-aging-time to configure the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
By default, the aging timer of a dynamic member port is 260 seconds.
Related commands: igmp-snooping host-aging-time.
# Set the aging timer for dynamic member ports to 300 seconds globally.
[Sysname-igmp-snooping] host-aging-time 300
host-tracking (IGMP-snooping view)
host-tracking
undo host-tracking
View
IGMP-snooping view
Default level
2: System level
None
Use host-tracking to enable the IGMP snooping host tracking function globally.
Use undo host-tracking to disable the IGMP snooping host tracking function globally.
By default, this function is disabled.
Related commands: display igmp-snooping host and igmp-snooping host-tracking.
# Enable the IGMP snooping host tracking function globally.
[Sysname-igmp-snooping] host-tracking
igmp-snooping
igmp-snooping
undo igmp-snooping
View
Default level
2: System level
None
Use igmp-snooping to enable IGMP snooping globally and enter IGMP-snooping view.
Use undo igmp-snooping to disable IGMP snooping globally.
By default, IGMP snooping is disabled.
Related commands: igmp-snooping enable.
# Enable IGMP snooping globally and enter IGMP-snooping view.
igmp-snooping drop-unknown
undo igmp-snooping drop-unknown
View
VLAN view
Default level
2: System level
None
Use igmp-snooping drop-unknown to enable dropping unknown multicast data in the current VLAN.
Use undo igmp-snooping drop-unknown to disable dropping unknown multicast data in the current VLAN.
By default, this function is disabled and unknown multicast data is flooded.
This command takes effect only if IGMP snooping is enabled in the VLAN.
After you enable dropping unknown multicast data, the switch does not drop the unknown multicast data with the multicast MAC address of 0100-5E00-00xx (where "x" represents any hexadecimal number from 0 to F) or 0100-5E00-0101. Instead, the switch floods the multicast data in the VLANs to which they belong.
# On VLAN 2, enable IGMP snooping and the function of dropping unknown multicast data.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping drop-unknown
undo igmp-snooping enable
View
VLAN view
Default level
2: System level
None
Use igmp-snooping enable to enable IGMP snooping in the current VLAN.
Use undo igmp-snooping enable to disable IGMP snooping in the current VLAN.
By default, IGMP snooping is disabled in a VLAN.
IGMP snooping must be enabled globally before it can be enabled in a VLAN.
Related commands: igmp-snooping.
# Enable IGMP snooping on VLAN 2.
[Sysname] vlan 2
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
Use igmp-snooping fast-leave to enable IGMP snooping fast-leave processing on the current port or group of ports. With this function enabled, when the switch receives an IGMP leave message on a port, it directly removes that port from the multicast forwarding entry of a specific group.
Use undo igmp-snooping fast-leave to disable IGMP snooping fast-leave processing on the current port or group of ports.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect on all VLANs to which the interface belongs. If you specify one or more VLANs, the command takes effect on the specified VLANs to which the interface belongs.
If you do not specify any VLAN when using this command in port group view, the command takes effect on all the ports in this group. If you specify one or more VLANs, the command takes effect only on those ports in this group that belong to the specified VLANs.
Related commands: fast-leave.
# Enable IGMP snooping fast-leave processing on GigabitEthernet 3/0/1 on VLAN 2.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip
igmp-snooping general-query source-ip { ip-address | current-interface }
undo igmp-snooping general-query source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP general queries.
Use igmp-snooping general-query source-ip to configure the source address of IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
By default, the source IP address of IGMP general queries is 0.0.0.0.
# On VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
View
Default level
2: System level
limit: Specifies the maximum number of multicast groups that a port can join, in the range of 1 to 1024.
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to restore the default.
By default, the upper limit is 1024.
You can also use the igmp group-limit command to limit the number of multicast groups that an interface can join. However, if you configure the limit both on a VLAN and on a VLAN interface of this VLAN by using these two commands, inconsistencies might exist between Layer 2 and Layer 3 table entries. Therefore, H3C recommends that you configure the limit only on the VLAN interface.
Related commands: igmp group-limit.
# Specify to allow GigabitEthernet 3/0/1 on VLAN 2 to join up to 10 multicast groups.
[Sysname-GigabitEthernet3/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
View
Default level
2: System level
acl-number: Specifies a basic or advanced ACL number in the range of 2000 to 3999. A host can only join the multicast groups that match the permit statement in the specified ACL. The source address or address range specified in the advanced ACL rule matches the multicast source address or addresses specified in IGMPv3 reports, rather than the source address in the IP packets. The system assumes that an IGMPv1 or IGMPv2 report or an IGMPv3 IS_EX and TO_EX report that does not carry a multicast source address carries a multicast source address of 0.0.0.0.
Use igmp-snooping group-policy to configure a multicast group filter on the current port or ports to control the multicast groups that the port or ports can join.
Use undo igmp-snooping group-policy to remove a multicast group filter on the current port or ports.
By default, no multicast group filter is configured on an interface and a host can join any valid multicast group.
Related commands: group-policy.
# Apply ACL 2000 as a multicast group filter so that hosts on GigabitEthernet 3/0/1 on VLAN 2 can join only 225.1.1.1.
[Sysname-GigabitEthernet3/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
View
VLAN view
Default level
2: System level
Use igmp-snooping host-aging-time to set the aging timer for the dynamic member ports in a VLAN.
Use undo igmp-snooping host-aging-time to restore the default.
Related commands: host-aging-time and igmp-snooping enable.
# Enable IGMP snooping and set the aging timer for the dynamic member ports in VLAN 2 to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
View
Default level
2: System level
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies a source address. The value for this argument should be a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
vlan vlan-id: Specifies a VLAN that comprises the port or ports. The value range for the vlan-id argument is 1 to 4094.
Use igmp-snooping host-join to enable simulated joining on a port. You configure the current port as a member host for the specified multicast group or multicast source group.
Use undo igmp-snooping host-join to remove the current port or ports as simulated member host or hosts for the specified multicast group or source and group.
The version of IGMP on the simulated host is consistent with the version of IGMP snooping running in the VLAN.
This command is also effective on VLANs with IGMP enabled on their VLAN interfaces. The version of IGMP on the simulated host is consistent with the version of IGMP running on the VLAN interfaces.
The source-ip source-address option in the command is meaningful only for IGMPv3 snooping. If IGMPv2 snooping is running, the source-ip source-address option does not take effect although you can include source-ip source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this feature takes effect only if the interface belongs to the specified VLAN.
In port group view, this feature takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 3/0/1 as a simulated member host on VLAN 2 for the multicast source and group (1.1.1.1, 232.1.1.1).
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet3/0/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
undo igmp-snooping host-tracking
View
VLAN view
Default level
2: System level
None
Use igmp-snooping host-tracking to enable the IGMP snooping host tracking function in a VLAN.
Use undo igmp-snooping host-tracking to disable the IGMP snooping host tracking function in a VLAN.
Before you configure this command, enable IGMP snooping in the VLAN first.
Related commands: display igmp-snooping host, host-tracking, and igmp-snooping enable.
# Enable IGMP snooping and IGMP snooping host tracking on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
igmp-snooping last-member-query-interval
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
View
VLAN view
Default level
2: System level
interval: Specifies an IGMP last-member query interval in seconds, in the range of 1 to 5.
Use igmp-snooping last-member-query-interval to configure the IGMP last-member query interval for a VLAN.
Use undo igmp-snooping last-member-query-interval to restore the default.
By default, the IGMP last-member query interval is 1 second.
The IGMP last-member query interval for a VLAN determines the interval for sending IGMP group-specific queries and the maximum response delay for IGMP group-specific queries in the VLAN.
Related commands: igmp-snooping enable and last-member-query-interval.
# Enable IGMP snooping and set the IGMP last-member query interval for VLAN 2 to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping leave source-ip
igmp-snooping leave source-ip { ip-address | current-interface }
undo igmp-snooping leave source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies a source address for the IGMP leave messages sent by the IGMP snooping proxy, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP leave messages sent by the IGMP snooping proxy. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
Use igmp-snooping leave source-ip to configure the source IP address of the IGMP leave messages sent by the IGMP snooping proxy.
Use undo igmp-snooping leave source-ip to restore the default.
By default, the source IP address of the IGMP leave messages sent by the IGMP snooping proxy is 0.0.0.0.
You must enable IGMP snooping for a VLAN before you configure this command for the VLAN.
The source IP address configured in the igmp-snooping leave source-ip command also applies when the simulated host sends IGMP leave messages.
# Enable IGMP snooping on VLAN 2 and configure the source IP address of IGMP leave messages sent by the IGMP snooping proxy on VLAN 2 to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
igmp-snooping max-response-time
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
View
VLAN view
Default level
2: System level
interval: Specifies the maximum response delay in seconds for IGMP general queries, in the range of 1 to 25.
Use igmp-snooping max-response-time to configure the maximum response delay for IGMP general queries in the VLAN.
Use undo igmp-snooping max-response-time to restore the default.
By default, the maximum response delay for IGMP general queries is 10 seconds.
Related commands: igmp-snooping enable, igmp-snooping query-interval, and max-response-time.
# Enable IGMP snooping and set the maximum response delay for IGMP general queries to 5 seconds on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
View
Default level
2: System level
Use igmp-snooping overflow-replace to enable the multicast group replacement function for a port.
Use undo igmp-snooping overflow-replace to disable the multicast group replacement function for a port.
By default, the multicast group replacement function on a port is disabled.
Related commands: overflow-replace.
# Enable the multicast group replacement function for GigabitEthernet 3/0/1 on VLAN 2.
[Sysname-GigabitEthernet3/0/1] igmp-snooping overflow-replace vlan 2
igmp-snooping proxying enable
undo igmp-snooping proxying enable
View
VLAN view
Default level
2: System level
None
Use igmp-snooping proxying enable to enable the IGMP snooping proxying function for a VLAN.
Use undo igmp-snooping proxying enable to disable the IGMP snooping proxying function for a VLAN.
By default, IGMP snooping proxying is disabled for all VLANs.
# Enable IGMP snooping and then IGMP snooping proxying on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxying enable
igmp-snooping querier
undo igmp-snooping querier
View
VLAN view
Default level
2: System level
None
Use igmp-snooping querier to enable the IGMP snooping querier function.
Use undo igmp-snooping querier to disable the IGMP snooping querier function.
By default, the IGMP snooping querier function is disabled.
This command does not take effect in a sub-VLAN of a multicast VLAN.
Related commands: igmp-snooping enable and subvlan.
# Enable IGMP snooping and the IGMP snooping querier function on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
View
VLAN view
Default level
2: System level
interval: Specifies an interval between IGMP general queries, in the range of 2 to 300 seconds.
Use igmp-snooping query-interval to configure the interval between IGMP general queries.
Use undo igmp-snooping query-interval to restore the default.
By default, the IGMP general query interval is 60 seconds.
Related commands: igmp-snooping enable, igmp-snooping max-response-time, igmp-snooping querier, and max-response-time.
# Enable IGMP snooping and set the interval between IGMP general queries to 20 seconds on VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
igmp-snooping report source-ip
igmp-snooping report source-ip { ip-address | current-interface }
undo igmp-snooping report source-ip
View
VLAN view
Default level
2: System level
ip-address: Specifies a source address for the IGMP reports sent by the IGMP snooping proxy, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP reports sent by the IGMP snooping proxy. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
Use igmp-snooping report source-ip to configure the source IP address of the IGMP reports sent by the IGMP snooping proxy.
Use undo igmp-snooping report source-ip to restore the default.
By default, the source IP address of the IGMP reports sent by the IGMP snooping proxy is 0.0.0.0.
The source IP address configured in the igmp-snooping report source-ip command also applies when the simulated host sends IGMP reports.
# Enable IGMP snooping on VLAN 2 and configure the source IP address of IGMP reports sent by the IGMP snooping proxy in the VLAN to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
igmp-snooping router-aging-time
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
View
VLAN view
Default level
2: System level
interval: Specifies a dynamic router port aging timer in the range of 1 to 1000 seconds.
Use igmp-snooping router-aging-time to configure the aging timer for the dynamic router ports in a VLAN.
Use undo igmp-snooping router-aging-time to restore the default.
By default, the aging timer of a dynamic router port is 105 seconds.
Related commands: igmp-snooping enable and router-aging-time.
# Enable IGMP snooping and set the aging timer for the dynamic router ports in VLAN 2 to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
igmp-snooping router-port-deny
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
View
Default level
2: System level
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to restore the default.
By default, a port can become a dynamic router port.
# Disable GigabitEthernet 3/0/1 from becoming a dynamic router port on VLAN 2.
[Sysname-GigabitEthernet3/0/1] igmp-snooping router-port-deny vlan 2
igmp-snooping special-query source-ip
igmp-snooping special-query source-ip { ip-address | current-interface }
undo igmp-snooping special-query source-ip
View
VLAN view
Default level
2: System level
ip-address: Sets the source address of IGMP group-specific queries to the specified address.
current-interface: Sets the source address of IGMP group-specific queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 will be used as the source IP address of IGMP group-specific queries.
Use igmp-snooping special-query source-ip to configure the source IP address of IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
By default, the source IP address of IGMP group-specific queries is 0.0.0.0.
# On VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
igmp-snooping static-group
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
View
Default level
2: System level
Use igmp-snooping static-group to configure the static (*, G) or (S, G) joining function. You can configure the current port or port group as static multicast group or source-group members.
Use undo igmp-snooping static-group to restore the default.
By default, no ports are static member ports.
# Configure GigabitEthernet 3/0/1 on VLAN 2 to be a static member port for (1.1.1.1, 232.1.1.1).
[Sysname] vlan 2
[Sysname-GigabitEthernet3/0/1] igmp-snooping static-group 232.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
View
Default level
2: System level
Use igmp-snooping static-router-port to configure the current port or ports as static router port or ports.
Use undo igmp-snooping static-router-port to restore the default.
By default, no ports are static router ports.
Related commands: subvlan.
# Enable the static router port function on GigabitEthernet 3/0/1 on VLAN 2.
[Sysname-GigabitEthernet3/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
View
VLAN view
Default level
2: System level
version-number: Specifies an IGMP snooping version, 2 or 3.
Use igmp-snooping version to configure the IGMP snooping version.
Use undo igmp-snooping version to restore the default.
By default, the IGMPv2 snooping is used.
This command can take effect only if IGMP snooping is enabled in the VLAN.
# Enable IGMP snooping on VLAN 2, and specify IGMPv3 snooping.
[Sysname] vlan 2
last-member-query-interval (IGMP-snooping view)
undo last-member-query-interval
View
IGMP-snooping view
Default level
2: System level
Use last-member-query-interval to set the IGMP last-member query globally.
Use undo last-member-query-interval to restore the default.
The IGMP last-member query interval determines the interval for sending IGMP group-specific queries and the maximum response delay for IGMP group-specific queries.
Related commands: igmp-snooping last-member-query-interval.
# Set the IGMP last-member query interval to 3 seconds globally.
[Sysname-igmp-snooping] last-member-query-interval 3
max-response-time (IGMP-snooping view)
undo max-response-time
View
IGMP-snooping view
Default level
2: System level
interval: Specifies the maximum response time to IGMP general queries, in the range of 1 to 25 seconds.
Use max-response-time to configure the maximum response time to IGMP general queries globally.
Use undo max-response-time to restore the default value.
Related commands: igmp-snooping max-response-time and igmp-snooping query-interval.
# Set the maximum response time to IGMP general queries globally to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
overflow-replace (IGMP-snooping view)
undo overflow-replace [ vlan vlan-list ]
View
IGMP-snooping view
Default level
2: System level
Use overflow-replace to enable the multicast group replacement function globally.
Use undo overflow-replace to disable the multicast group replacement function globally.
By default, the multicast group replacement function is disabled.
Related commands: igmp-snooping overflow-replace.
# Enable the multicast group replacement function globally on VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation (IGMP-snooping view)
report-aggregation
undo report-aggregation
View
IGMP-snooping view
Default level
2: System level
None
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
By default, IGMP report suppression is enabled.
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
View
Default level
2: System level
group-address: Specifies an IGMP snooping group in the range of 224.0.1.0 to 239.255.255.255.
all: Specifies all IGMP snooping groups.
Use reset igmp-snooping group to remove the dynamic group entries of a specific IGMP snooping group or all IGMP snooping groups.
This command cannot remove the static group entries of IGMP snooping groups.
# Remove the dynamic group entries of all IGMP snooping groups.
<Sysname> reset igmp-snooping group all
reset igmp-snooping statistics
View
Default level
2: System level
None
Use reset igmp-snooping statistics to clear statistics for the IGMP messages learned through IGMP snooping.
# Clear statistics for all IGMP messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
router-aging-time (IGMP-snooping view)
undo router-aging-time
View
IGMP-snooping view
Default level
2: System level
Use router-aging-time to configure the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
Related commands: igmp-snooping router-aging-time.
# Set the aging timer for dynamic router ports to 100 seconds globally.
[Sysname-igmp-snooping] router-aging-time 100
