07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
15-Routing Policy Commands
15-Routing Policy Commands 197.11 KB
The common configuration commands of routing policy are applicable to both IPv4 and IPv6.
Common routing policy configuration commands
apply as-path
apply as-path as-number&<1-10> [ replace ]
undo apply as-path
View
Routing policy view
Default level
2: System level
as-number: Specifies an autonomous system number in the range of 1 to 4294967295.
&<1-10>: Indicates you can enter up to 10 AS numbers.
replace: Replaces the original AS numbers.
Use apply as-path to apply the specified AS numbers to BGP routes.
Use undo apply as-path to remove the clause configuration.
No AS_PATH attribute is set by default.
With the replace keyword included, the apply as-path command replaces the original AS_PATH attribute with the specified AS numbers. Without the replace keyword, this command adds the specified AS numbers before the original AS_PATH attribute.
# Configure node 10 in permit mode of routing policy policy1: add AS number 200 before the original AS_PATH attribute of BGP routing information matching AS path list 1.
[Sysname-route-policy] if-match as-path 1
[Sysname-route-policy] apply as-path 200
apply comm-list delete
undo apply comm-list
View
Routing policy view
Default level
2: System level
comm-list-number: Specifies a community list number. A basic community list number is in the range of 1 to 99. An advanced community list number is in the range of 100 to 199.
comm-list-name: Specifies a community list name, a string of 1 to 31 characters, which can contain letters, numbers, and signs.
Use apply comm-list delete to remove the COMMUNITY attributes specified by the community list from BGP routing information.
Use undo apply comm-list to remove the clause configuration.
No COMMUNITY attributes are removed from BGP routing information by default.
# Configure node 10 in permit mode of routing policy policy1: remove the COMMUNITY attributes specified in community list 1 from the BGP routing information matching AS path list 1.
[Sysname-route-policy] apply comm-list 1 delete
apply community
apply community { none | additive | { community-number&<1-16> | aa:nn&<1-16> | internet | no-advertise | no-export | no-export-subconfed } * [ additive ] }
undo apply community
View
Routing policy view
Default level
2: System level
none: Removes the COMMUNITY attributes of BGP routes.
community-number: Specifies a community sequence number in the range of 1 to 4294967295.
aa:nn: Specifies a community number; both aa and nn are in the range of 0 to 65535.
&<1-16>: Indicates the argument before it can be entered up to 16 times.
internet: Sets the INTERNET community attribute for BGP routes. Routes with this attribute can be advertised to all BGP peers.
no-advertise: Sets the NO_ADVERTISE community attribute for BGP routes. Routes with this attribute cannot be advertised to any peers.
no-export: Sets the NO_EXPORT community attribute for BGP routes. Routes with this attribute cannot be advertised out of the autonomous system or confederation, but can be advertised to other sub ASs in the confederation.
no-export-subconfed: Sets the NO_EXPORT_SUBCONFED community attribute for BGP routes. Routes with this attribute cannot be advertised out of the sub autonomous system.
additive: Adds the specified COMMUNITY attribute to the original community attribute of BGP routes.
Use apply community to set the specified COMMUNITY attribute for BGP routes.
Use undo apply community to remove the apply clause.
No COMMUNITY attribute is set for BGP routes by default.
Related commands: ip community-list and if-match community.
# Configure node 16 in permit mode of routing policy setcommunity: Set the NO_EXPORT community attribute for BGP routes matching AS path list 8.
[Sysname-route-policy] if-match as-path 8
[Sysname-route-policy] apply community no-export
apply cost
apply cost [ + | - ] value
undo apply cost
View
Routing policy view
Default level
2: System level
+: Increases a cost value.
-: Decreases a cost value.
value: Specifies a cost in the range of 0 to 4294967295.
Use apply cost to set a cost for routing information.
Use undo apply cost to remove the clause configuration.
No cost is set for routing information by default.
# Configure node 10 in permit mode of routing policy policy1: set a cost of 120 for routing information whose outgoing interface is VLAN-interface 11.
[Sysname-route-policy] if-match interface Vlan-interface 11
[Sysname-route-policy] apply cost 120
apply cost-type
apply cost-type { external | internal | type-1 | type-2 }
undo apply cost-type
View
Routing policy view
Default level
2: System level
external: Sets the cost type to IS-IS external route.
internal: Sets the cost type to IS-IS internal route, or sets the MED value for a matching BGP route as the IGP metric to the route's next hop.
type-1: Sets the cost type to Type-1 external route of OSPF.
type-2: Sets the cost type to Type-2 external route of OSPF.
Use apply cost-type to set a cost type for routing information.
Use undo apply cost-type to remove the clause configuration.
No cost type is set for routing information by default.
Used for IS-IS, the apply cost-type internal command sets the cost type of a matching IS-IS route as IS-IS internal route.
Use for BGP, the apply cost-type internal command sets the MED of a matching BGP route learned from an IBGP peer as the IGP metric to the route's next hop before BGP advertises the route to an EBGP peer.
# Create node 10 in permit mode of routing policy policy1: If a route has a tag of 8, set the cost type for the route to IS-IS internal route.
[Sysname-route-policy] if-match tag 8
[Sysname-route-policy] apply cost-type internal
apply extcommunity
apply extcommunity { { rt route-target }&<1-16> [ additive ] | soo site-of-origin additive }
undo apply extcommunity
View
Routing policy view
Default level
2: System level
rt route-target: Sets the route target extended community attribute, which is a string of 3 to 21 characters.
soo site-of-origin: Sets the Site of Origin (SOO) extended community attribute, which is a string of 3 to 21 characters.
A route-target or site-of-origin has one of the following three forms:
·     16-bit AS number:32-bit self-defined number. For example, 101:3.
·     32-bit IP address:16-bit self-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit self-defined number. For example, 70000:3. The AS number should be no less than 65536.
additive: Adds the specified attribute to the original RT community attribute.
Use apply extcommunity to apply the specified RT extended community attribute to BGP routes.
Use undo apply extcommunity to remove the clause configuration.
No RT extended community attribute is set for BGP routing information by default.
# Configure node 10 in permit mode of routing policy policy1: If a BGP route matches AS path list 1, add the RT extended community attribute 100:2 to the route.
[Sysname-route-policy] apply extcommunity rt 100:2 additive
# Configure node 10 in permit mode of routing policy policy2: If a BGP route matches AS path list 2, add the SOO extended community attribute 100:3 to the route.
[Sysname] route-policy policy2 permit node 10
[Sysname-route-policy] if-match as-path 2
[Sysname-route-policy] apply extcommunity soo 100:3 additive
apply isis
undo apply isis
View
Routing policy view
Default level
2: System level
level-1: Redistributes routes into IS-IS level-1.
level-1-2: Redistributes routes into both IS-IS level-1 and level-2.
level-2: Redistributes routes into IS-IS level-2.
Use apply isis to redistribute routes into a specified ISIS level.
Use undo apply isis to remove the clause configuration.
No IS-IS level is set by default.
# Configure node 10 in permit mode of routing policy policy1: If a route has a tag of 8, redistribute the route to IS-IS level-2.
[Sysname-route-policy] apply isis level-2
apply local-preference
undo apply local-preference
View
Routing policy view
Default level
2: System level
preference: Specifies a BGP local preference in the range of 0 to 4294967295.
Use apply local-preference to set the specified local preference for BGP routes.
Use undo apply local-preference to remove the clause configuration.
No local preference is set for BGP routing information by default.
# Configure node 10 in permit mode of routing policy policy1: If a route matches AS path list 1, set a local preference of 130 for the route.
[Sysname-route-policy] apply local-preference 130
apply mpls-label
apply mpls-label
undo apply mpls-label
View
Routing policy view
Default level
2: System level
None
Use apply mpls-label to set MPLS labels for routing information.
Use undo apply mpls-label to remove the clause configuration.
No MPLS label is set for routing information by default.
If MPLS labels failed to apply, the routing information cannot be advertised.
# Configure node 10 in permit mode of routing policy policy1: If routing information matches AS path list 1, set MPLS labels for it.
[Sysname-route-policy] apply mpls-label
apply origin
undo apply origin
View
Routing policy view
Default level
2: System level
egp: Sets the ORIGIN attribute of BGP routing information to EGP.
as-number: Sets an autonomous system number for EGP routes, in the range of 1 to 4294967295.
igp: Sets the ORIGIN attribute of BGP routing information to IGP.
incomplete: Sets the ORIGIN attribute of BGP routing information to unknown.
Use apply origin to set the specified ORIGIN attribute for BGP routes.
Use undo apply origin to remove the clause configuration.
No ORIGIN attribute is set for BGP routing information by default.
# Configure node 10 in permit mode of routing policy policy1: If BGP routing information matches AS path list 1, set the ORIGIN attribute of the routing information to IGP.
[Sysname-route-policy] apply origin igp
apply preference
apply preference preference
undo apply preference
View
Routing policy view
Default level
2: System level
preference: Specifies a routing protocol preference in the range of 1 to 255.
Use apply preference to set a preference for a routing protocol.
Use undo apply preference to remove the clause configuration.
No preference is set for a routing protocol by default.
If you have set preferences for routing protocols with the preference command, using the apply preference command will set a new preference for the matching routing protocol. Non-matching routing protocols still use the preferences set by the preference command.
# Configure node 10 in permit mode of routing policy policy1: Set the preference for OSPF external routes to 90.
[Sysname-route-policy] if-match route-type external-type1or2
[Sysname-route-policy] apply preference 90
apply preferred-value
undo apply preferred-value
View
Routing policy view
Default level
2: System level
preferred-value: Specifies a preferred value in the range of 0 to 65535.
Use apply preferred-value to set a preferred value for BGP routes.
Use undo apply preferred-value to remove the clause configuration.
No preferred value is set for BGP routes by default.
# Configure node 10 in permit mode of routing policy policy1: Set a preferred value of 66 for BGP routing information matching AS path list 1.
[Sysname-route-policy] apply preferred-value 66
apply tag
apply tag value
undo apply tag
View
Routing policy view
Default level
2: System level
value: Specifies the tag value in the range of 0 to 4294967295.
Use apply tag to set a specified tag value for RIP, OSPF or IS-IS routing information.
Use undo apply tag to remove the clause configuration.
No routing tag is set for RIP, OSPF or IS-IS routing information by default.
# Configure node 10 in permit mode of routing policy policy1: set a tag of 100 for OSPF external routes.
[Sysname-route-policy] apply tag 100
continue
continue [ node-number ]
undo continue
View
Routing policy view
Default level
2: System level
node-number: Specifies the policy node number in the range of 0 to 65535.
Use continue to specify the next node of the routing policy to be matched.
Use undo continue to remove the configuration.
By default, no next policy node is specified.
The node number specified must be larger than the current node number.
Example
# Create routing policy policy1 with node 10, and specify the match mode as permit. Specify the number of the next policy node to be matched as 20.
[Sysname-route-policy] continue 20
display ip as-path
display ip as-path [ as-path-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
as-path-number: Specifies an AS path list by its number in the range of 1 to 256.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip as-path to display BGP AS path list information.
Information about all BGP AS path lists will be displayed if no as-path-number is specified.
Related commands: ip as-path, if-match as-path, and apply as-path.
# Display the information of BGP AS path list 1.
ListID    Mode      Expression
1         permit    2
ListID
AS path list ID.
Mode
Match mode, permit, deny.
Expression
Regular expression.
display ip community-list
display ip community-list [ basic-community-list-number | adv-community-list-number | comm-list-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
comm-list-name: Specifies a community list by its name, a string of 1 to 31 characters, which can contain letters, numbers, and signs.
Use display ip community-list to display BGP community list information.
All BGP community list information will be displayed if no basic-community-list-number or adv-community-list-number is specified.
Related commands: ip community-list, if-match community, and apply community.
# Display the information of the BGP community list 1.
<Sysname> display ip community-list 1
Community List Number 1
         permit  1:1 1:2 2:2
display ip extcommunity-list
display ip extcommunity-list [ ext-comm-list-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ext-comm-list-number: Specifies an extended community list by its number in the range of 1 to 199.
Use display ip extcommunity-list to display BGP extended community list information.
All BGP extended community list information will be displayed if no ext-comm-list-number is specified.
Related commands: ip extcommunity-list, if-match extcommunity, and apply extcommunity.
# Display the information of BGP extended community list 1.
         permit rt : 9:6
display route-policy
display route-policy [ route-policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Use display route-policy to display routing policy information.
All routing policy information will be displayed if no route-policy-name is specified.
Related commands: route-policy.
# Display the information of routing policy 1.
<Sysname> display route-policy policy1
Route-policy : policy1
  permit : 10
        if-match ip-prefix abc
        apply cost 120
Table 2 Command output.
Route-policy
Routing policy name.
Permit
Match mode of routing policy node 10.
Match criterion.
apply cost 120
Apply a cost of 120 for matching routes.
if-match as-path
if-match as-path as-path-number&<1-16>
undo if-match as-path [ as-path-number&<1-16> ]
View
Routing policy view
Default level
2: System level
as-path-number: Specifies an AS path list number in the range of 1 to 256.
Use if-match as-path to specify AS path lists for matching against the AS_PATH attribute of BGP routing information.
Use undo if-match as-path to remove the match criterion.
The match criterion is not configured by default.
Related commands: ip as-path.
# Define AS path list 2, allowing BGP routing information containing AS number 200 or 300 to pass. Configure node 10 in permit mode of routing policy test: specify AS path list 2 for matching.
if-match community
if-match community { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16>
undo if-match community [ { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number ]&<1-16>
View
Routing policy view
Default level
2: System level
basic-community-list-number: Specifies a basic community list number in the range of 1 to 99.
adv-community-list-number: Specifies an advanced community list number in the range of 100 to 199.
whole-match: Exactly matches the specified community lists.
Use if-match community to specify community lists for matching against the COMMUNITY attribute of BGP routing information.
Use undo if-match community to remove the match criterion.
Related commands: ip community-list.
# Define community list 1, allowing BGP routing information with community number 100 or 200 to pass. Then configure node 10 in permit mode of routing policy test to specify community list 1 for matching.
[Sysname-route-policy] if-match community 1
if-match cost
if-match cost value
undo if-match cost
View
Routing policy view
Default level
2: System level
Use if-match cost to match routing information having the specified cost.
Use undo if-match cost to remove the match criterion.
# Configure node 10 in permit mode of routing policy policy1 to define an if-match clause to permit routing information with a cost of 8.
[Sysname-route-policy] if-match cost 8
if-match extcommunity ext-comm-list-number&<1-16>
undo if-match extcommunity [ ext-comm-list-number&<1-16> ]
View
Routing policy view
Default level
2: System level
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 199.
Use if-match extcommunity to specify extended community lists for matching against the extended community attribute of BGP routing information.
Use undo if-match extcommunity to remove the match criterion.
# Configure node 10 in permit mode of routing policy policy1 to match BGP routing information against extended community lists 100 and 150.
[Sysname-route-policy] if-match extcommunity 100 150
if-match interface
View
Routing policy view
Default level
2: System level
Use if-match interface to specify interfaces for matching against the outgoing interface of routing information.
Use undo if-match interface to remove the match criterion.
BGP does not support criteria for matching against the outgoing interface of routing information.
# Configure node 10 in permit mode of routing policy policy1 to permit routing information with the outgoing interface as VLAN-interface 1.
[Sysname-route-policy] if-match interface vlan-interface 1
if-match mpls-label
if-match mpls-label
undo if-match mpls-label
View
Routing policy view
Default level
2: System level
None
Use if-match mpls-label to specify the MPLS label match criterion.
Use undo if-match mpls-label to remove the match criterion.
# Configure node 10 in permit mode of routing policy policy1 to match the MPLS labels of routing updates.
[Sysname-route-policy] if-match mpls-label
if-match route-type
if-match route-type { external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
undo if-match route-type [ external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 ] *
View
Routing policy view
Default level
2: System level
external-type1: Matches OSPF Type 1 external routes.
external-type1or2: Matches OSPF Type 1 or 2 external routes.
external-type2: Matches OSPF Type 2 external routes.
internal: Matches internal routes (OSPF intra-area and inter-area routes).
is-is-level-1: Matches IS-IS Level-1 routes.
is-is-level-2: Matches IS-IS Level-2 routes.
nssa-external-type1: Matches OSPF NSSA Type 1 external routes.
nssa-external-type1or2: Matches OSPF NSSA Type 1 or 2 external routes.
nssa-external-type2: Matches OSPF NSSA Type 2 external routes.
Use if-match route-type to configure a route type match criterion.
Use undo if-match route-type to remove the match criterion.
# Configure node 10 in permit mode of routing policy policy1 to match OSPF internal routes.
[Sysname-route-policy] if-match route-type internal
if-match tag
if-match tag value
undo if-match tag
View
Routing policy view
Default level
2: System level
value: Specifies a tag from 0 to 4294967295.
Use if-match tag to match routing information having the specified tag.
Use undo if-match tag to remove the match criterion.
# Configure node 10 in permit mode of routing policy policy1 to permit RIP, OSPF and IS-IS routing information with a tag of 8.
ip as-path
ip as-path as-path-number { deny | permit } regular-expression
undo ip as-path as-path-number
View
Default level
2: System level
deny: Specifies the match mode for the AS path list as deny.
permit: Specifies the match mode for the AS path list as permit.
regular-expression: Specifies an AS_PATH regular expression, a string of 1 to 50 characters.
BGP routing updates contain the AS_PATH attribute field that identifies the autonomous systems through which the routing information has passed. An AS_PATH regular expression, for example, ^200. *100$, matches the AS path attribute that starts with AS 200 and ends with AS 100. For the meanings of special characters used in regular expressions, see Fundamentals Configuration Guide.
Use ip as-path to create an AS path list.
Use undo ip as-path to remove an AS path list.
No AS path list is created by default.
# Configure AS path list 1 to permit routing information whose AS_PATH attribute starts with 10.
ip community-list
ip community-list { basic-comm-list-num | basic comm-list-name } { deny | permit } [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
undo ip community-list { basic-comm-list-num | basic comm-list-name } [ deny | permit ] [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
ip community-list { adv-comm-list-num | advanced comm-list-name } { deny | permit } regular-expression
undo ip community-list { adv-comm-list-num | advanced comm-list-name } [ deny | permit ] [ regular-expression ]
View
Default level
2: System level
basic-comm-list-num: Specifies a basic community list number in the range of 1 to 99.
basic: Specifies a basic communist list name.
advanced: Specifies an advanced communist list name.
adv-comm-list-num: Specifies an advanced community list number in the range of 100 to 199.
regular-expression: Specifies a regular expression for advanced community attribute, a string of 1 to 50 characters. For more information about regular expressions, see Fundamentals Configuration Guide
deny: Specifies the match mode for the community list as deny.
permit: Specifies the match mode for the community list as permit.
community-number-list: Specifies a community number list, which is in the community number or aa:nn format; a community number is in the range of 1 to 4294967295; aa and nn are in the range of 0 to 65535. Up to 16 community numbers can be entered.
internet: Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Routes with this attribute cannot be advertised to other BGP peers.
no-export: Routes with this attribute cannot be advertised out the local AS, or the confederation but can be advertised to other ASs in the confederation.
no-export-subconfed: Routes with this attribute cannot be advertised out the local AS, or to other sub ASs in the confederation.
Use ip community-list to define a community list entry.
Use undo ip community-list to remove a community list or entry.
No community list is defined by default.
# Define basic community list 1 to permit routing information with the INTERNET community attribute.
# Define advanced community list 100 to permit routing information with the COMMUNITY attribute starting with 10.
ip extcommunity-list ext-comm-list-number { deny | permit } { rt route-target | soo site-of-origin }&<1-16>
undo ip extcommunity-list ext-comm-list-number
View
Default level
2: System level
deny: Specifies the match mode for the extended community list as deny.
permit: Specifies the match mode for the extended community list as permit.
rt route-target: Specifies the route target extended community attribute, which is a string of 3 to 21 characters.
soo site-of-origin: Sets the SOO extended community attribute, which is a string of 3 to 21 characters.
A route-target or site-of-origin has three forms:
·     32-bit AS number:16-bit self-defined number. For example, 70000:3. The AS number must be no less than 65536.
Use ip extcommunity-list to define an extended community list entry.
Use undo ip extcommunity-list to remove an extended community list.
No extended community list is defined by default.
# Define extended community list 1 to permit routing information with RT 200:200.
# Define extended community list 2 to permit routing information with SOO 100:100.
route-policy
View
Default level
2: System level
route-policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters.
deny: Specifies the match mode of the routing policy node as deny. If a route matches all the if-match clauses of the node, it cannot pass the node and will not go to the next node.
permit: Specifies the match mode of the routing policy node as permit. If a route matches all the if-match clauses of the node, it passes the node and then is executed with the apply clauses of the node. If not, it goes to the next node of the routing policy.
node node-number: Specifies a node number in the range of 0 to 65535. A node with a smaller number is matched first.
Use route-policy to create a routing policy and a node of it and enter routing policy view.
Use undo route-policy to remove a routing policy or a node of it.
No routing policy is created by default.
A routing policy is used for routing information filtering. It contains several nodes and each node comprises a set of if-match and apply clauses. The if-match clauses define the matching criteria of the node and the apply clauses define the actions to be taken on packets passing the node. The relation between the if-match clauses of a node is logic AND, namely, all the if-match clauses must be matched. The relation between different routing policy nodes is logic OR, namely, a packet passing a node passes the routing policy.
# Configure node 10 in permit mode of routing policy policy1 and enter routing policy view.
IPv4 routing policy configuration commands
apply fast-reroute
undo apply fast-reroute
View
Routing policy view
Default level
2: System level
backup-interface interface-type interface-number: Specifies a backup outgoing interface by its type and number. If the specified backup outgoing interface is a non-P2P interface (such as VLAN interface), you need to specify a backup next hop at the same time.
backup-nexthop ip-address: Specifies the backup next hop address.
Use apply fast-reroute to configure FRR.
Use undo apply fast-reroute to remove the configuration.
By default, FRR is not configured.
When a link or a router in the network fails, the packets on the path might be discarded, or a routing loop might occur. Then, the traffic will be interrupted until the routing protocol completes routing convergence based on the new network topology.
With FRR, a routing protocol can designate a backup next hop by using the referenced routing policy when a network failure is detected, and packets are directed to the backup next hop for forwarding, thus to reduce traffic recovery time greatly.
This command allows you to specify a backup next hop in a routing policy for routes matching specified criteria.
# Create a routing policy named policy1, and specify backup outgoing interface VLAN-interface 1 and backup next hop 193.1.1.8 in the routing policy for packets destined to 100.1.1.0/24.
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface vlan-interface 1 backup-nexthop 193.1.1.8
apply ip-address next-hop
apply ip-address next-hop ip-address [ vpn-instance vpn-instance-name | public ]
undo apply ip-address next-hop
View
Routing policy view
Default level
2: System level
ip-address: Specifies the IP address of the next hop.
vpn-instance-name: Specifies the VPN instance of the next hop.
public: Specifies that the next hop is on the public network.
Use apply ip-address next-hop to set a next hop for IPv4 routes and specify the VPN instance of the next hop.
Use undo apply ip-address next-hop to remove the clause configuration.
By default, no next hop is set for IPv4 routes.
You can specify the vpn-instance vpn-instance-name option or the public keyword of the next hop for only the routing policy to be referenced in VPN view. If the vpn-instance vpn-instance-name option or the public keyword is not specified, the VPN instance of the route to be processed by this clause applies to the next hop.
This command cannot set a next hop and its VPN instance for redistributed routes.
# Configure node 10 in permit mode of routing policy policy1 to set next hop 193.1.1.8 for routes matching AS path list 1 and specify the VPN instance of the next hop.
[Sysname-route-policy] apply ip-address next-hop 193.1.1.8 vpn-instance vpn1
display ip ip-prefix
display ip ip-prefix [ ip-prefix-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters.
Use display ip ip-prefix to display the statistics of an IPv4 prefix list. If no ip-prefix-name is specified, statistics for all IPv4 prefix lists will be displayed.
Related commands: ip ip-prefix.
# Display the statistics of IPv4 prefix list abc.
<Sysname> display ip ip-prefix abc
Prefix-list abc
Permitted 0
Denied 0
        index: 10               permit  1.0.0.0/11              ge  22  le  32
Table 3 Command output.
Prefix-list
Name of the IPv4 prefix list.
Permitted
Number of routes matching the criterion.
Denied
Number of routes not matching the criterion.
index
Index of the IPv4 prefix list.
permit
Match mode: permit or deny.
1.0.0.0/11
IP address and mask.
ge
greater-equal, the lower limit.
le
less-equal, the higher limit.
if-match acl
if-match acl acl-number
undo if-match acl
View
Routing policy view
Default level
2: System level
acl-number: Specifies an ACL number in the range of 2000 to 3999.
Use if-match acl to configure an ACL match criterion.
Use undo if-match acl to remove the match criterion.
No ACL match criterion is configured by default.
# Configure node 10 of routing policy policy1 to permit routes matching ACL 2000.
[Sysname-route-policy] if-match acl 2000
if-match ip
if-match ip { next-hop | route-source } { acl acl-number | ip-prefix ip-prefix-name }
undo if-match ip { next-hop | route-source } [ acl | ip-prefix ]
View
Routing policy view
Default level
2: System level
next-hop: Matches the next hop of routing information.
route-source: Matches the IP address of the BGP neighbor.
acl acl-number: Matches an ACL with a number from 2000 to 2999.
ip-prefix ip-prefix-name: Matches an IP prefix list with a name being a string of 1 to 19 characters.
Use if-match ip to configure a next hop or source address match criterion for IPv4 routes.
Use undo if-match ip to remove the match criterion.
# Configure node 10 of routing policy policy1 to permit routing information whose next hop address matches IP prefix list p1.
[Sysname-route-policy] if-match ip next-hop ip-prefix p1
if-match ip-prefix
if-match ip-prefix ip-prefix-name
undo if-match ip-prefix
View
Routing policy view
Default level
2: System level
Use if-match ip-prefix to configure an IP prefix list based match criterion.
Use undo if-match ip-prefix to remove the match criterion.
No IP prefix list based match criterion is configured by default.
# Configure node 10 of routing policy policy2 to permit routes whose destination address matches IP prefix list p1.
[Sysname-route-policy] if-match ip-prefix p1
ip ip-prefix
ip ip-prefix ip-prefix-name [ index index-number ] { deny | permit } ip-address mask-length [ greater-equal min-mask-length ] [ less-equal max-mask-length ]
undo ip ip-prefix ip-prefix-name [ index index-number ]
View
Default level
2: System level
ip-prefix-name: Specifies an IPv4 prefix list name, a string of 1 to 19 characters.
index-number: Specifies an index number in the range of 1 to 65535, for uniquely specifying an item of the IPv4 prefix list. An index with a smaller number is matched first.
deny: Specifies the match mode for the IPv4 prefix list as deny. If a route matches the IPv4 prefix list, the route neither passes the filter nor matches against the next item; if not, the route matches against the next item (suppose the IPv4 prefix list has multiple items configured).
permit: Specifies the match mode for the IPv4 prefix list as permit. If a route matches the IPv4 prefix list, it passes the IPv4 prefix list. If not, it matches against the next item (suppose the IPv4 prefix list has multiple items configured).
ip-address mask-length: Specifies an IPv4 prefix and mask length. The mask-length is in the range of 0 to 32.
min-mask-length, max-mask-length: Specifies the prefix range. greater-equal means "greater than or equal to" and less-equal means "less than or equal to." The range relation is mask-length <= min-mask-length <= max-mask-length <= 32. If only the min-mask-length is specified, the prefix length range is [ min-mask-length, 32 ]. If only the max-mask-length is specified, the prefix length range is [ mask-length, max-mask-length ]. If both min-mask-length and max-mask-length are specified, the prefix length range is [ min-mask-length, max-mask-length ].
Use ip ip-prefix to configure an IPv4 prefix list or an item of it.
Use undo ip ip-prefix to remove an IPv4 prefix list or an item of it.
No IPv4 prefix list is configured by default.
An IPv4 prefix list is used to filter IPv4 addresses. It might have multiple items, each of which specifies a range of IPv4 prefixes. The relation between the items is logic OR, namely, if an item is passed, the IPv4 prefix list is passed. If no item is passed, the IP prefix list cannot be passed.
The IP prefix range is determined by mask-length and [ min-mask-length, max-mask-length ]. If both mask-length and [ min-mask-length, max-mask-length ] are specified, the IP address must meet both of them.
If both ip-address and mask-length are specified as 0.0.0.0 0, only the default route will be matched.
To match all routes, use 0.0.0.0 0 less-equal 32.
# Define IP prefix list p1 to permit routes matching network 10.0.192.0/8 and with mask length 17 or 18.
[Sysname] ip ip-prefix p1 permit 10.0.192.0 8 greater-equal 17 less-equal 18
reset ip ip-prefix
reset ip ip-prefix [ ip-prefix-name ]
View
Default level
2: System level
ip-prefix-name: Specifies an IP prefix list name, a string of 1 to 19 characters.
Use reset ip ip-prefix to clear the statistics of a specified IPv4 prefix list. If no ip-prefix-name is specified, the statistics of all IPv4 prefix lists will be cleared.
# Clear the statistics of IPv4 prefix list abc.
<Sysname> reset ip ip-prefix abc
IPv6 routing policy configuration commands
apply ipv6 next-hop
undo apply ipv6 next-hop
View
Routing policy view
Default level
2: System level
ipv6-address: Specifies the next hop IPv6 address.
Use apply ipv6 next-hop to configure a next hop for IPv6 routes.
Use undo apply ipv6 next-hop to remove the clause configuration.
No next hop address is configured for IPv6 routing information by default.
This command cannot configure a next hop for redistributed routes.
# Configure node 10 of routing policy policy1 to configure next hop 3ff3:506::1 for IPv6 routing information matching AS path list 1.
[Sysname-route-policy] apply ipv6 next-hop 3ffe:506::1
display ip ipv6-prefix
display ip ipv6-prefix [ ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-prefix-name: Specifies an IPv6 prefix list by its name, a string of 1 to 19 characters.
Use display ip ipv6-prefix to display the statistics of the specified IPv6 prefix list. If no IPv6 prefix list is specified, the statistics of all IPv6 prefix lists will be displayed.
# Display the statistics of all IPv6 prefix lists.
<Sysname> display ip ipv6-prefix
Prefix-list6 abc
Permitted 0
Denied 0
         index:   10            permit  ::/0
         index:   20             permit  ::/1                 ge  1   le  128
Prefix-list6
Name of the IPv6 prefix list.
Permitted
Number of routes satisfying the match criterion.
Denied
Number of routes not satisfying the match criterion.
Index
Index number of the prefix list.
Permit
Match mode of the item: permit, or deny.
::/1
IPv6 address and prefix length for matching.
ge
greater-equal, the lower prefix length.
Le
less-equal, the upper prefix length.
if-match ipv6
if-match ipv6 { address | next-hop | route-source } { acl acl6-number | prefix-list ipv6-prefix-name }
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
View
Routing policy view
Default level
2: System level
address: Matches the destination address of IPv6 routing information.
next-hop: Matches the next hop of IPv6 routing information.
route-source: Matches the IPv6 address of the BGP neighbor.
acl acl6-number: Specifies the number of an IPv6 ACL for filtering, in the range of 2000 to 3999 for address, and 2000 to 2999 for next-hop and route-source.
prefix-list ipv6-prefix-name: Specifies the name of a IPv6 prefix list for filtering, a string of 1 to 19 characters.
Use if-match ipv6 to configure a destination, next hop or source address based match criterion for IPv6 routes.
Use undo if-match ipv6 to remove the match criterion.
# Configure node 10 of routing policy policy1 to permit routing information whose next hop address matches IPv6 prefix list p1.
[Sysname-route-policy] if-match ipv6 next-hop prefix-list p1
ip ipv6-prefix
ip ipv6-prefix ipv6-prefix-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
undo ip ipv6-prefix ipv6-prefix-name [ index index-number ]
View
Default level
2: System level
ipv6-prefix-name: Specifies an IPv6 prefix list name, a string of 1 to 19 characters, for uniquely specifying an IPv6 prefix list.
index-number: Specifies an index number in the range of 1 to 65535, for uniquely specifying an IPv6 prefix list item. An item with a smaller index-number will be matched first.
deny: Specifies the match mode for the IPv6 prefix list as deny. If a route matches the IPv6 prefix list, the route neither passes the filter nor matches against the next item; if not, the route matches against the next item (suppose the IPv6 prefix list has multiple items configured).
permit: Specifies the match mode for the IPv6 prefix list as permit. If a route matches the IPv6 prefix list, it passes the IPv6 prefix list. If not, it matches against the next item (suppose the IPv6 prefix list has multiple items configured).
ipv6-address prefix-length: Specifies an IPv6 prefix and prefix length. A prefix-length is in the range of 0 to 128. When specified as :: 0, the arguments match the default route.
greater-equal min-prefix-length: Greater than or equal to the minimum prefix length.
less-equal max-prefix-length: Less than or equal to the maximum prefix length.
The length relation is mask-length <= min-mask-length <= max-mask-length <= 128. If only the min-prefix-length is specified, the prefix length range is [ min-prefix-length, 128 ]. If only the max-prefix-length is specified, the prefix length range is [ prefix-length, max-prefix-length ]. If both the min-prefix-length and max-prefix-length are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
Use ip ipv6-prefix to configure an IPv6 prefix list or an item of it.
Use undo ip ipv6-prefix to remove an IPv6 prefix list or an item.
No IPv6 prefix list is configured by default.
An IPv6 prefix list might have multiple items, and each of them specifies a range of IPv6 prefixes. The relation between items is logic OR, namely, if a route passes an item of it, the route will pass the IPv6 prefix list.
The IPv6 prefix range is determined by prefix-length and [ min-prefix-length, max-prefix-length ]. If both mask-length and [ min-mask-length, max-mask-length ] are specified, then the IPv6 addresses must satisfy both of them.
If ipv6-address prefix-length is specified as :: 0, only the default route matches.
To match all routes, configure :: 0 less-equal 128.
# Permit IPv6 addresses with a mask length between 32 bits and 64 bits.
[Sysname] ip ipv6-prefix abc permit :: 0 greater-equal 32 less-equal 64
# Deny IPv6 addresses with the prefix being 3FFE:D00::/32, and prefix length being greater than or equal to 32 bits.
[Sysname] ip ipv6-prefix abc deny 3FFE:D00:: 32 less-equal 128
reset ip ipv6-prefix
reset ip ipv6-prefix [ ipv6-prefix-name ]
View
Default level
2: System level
ipv6-prefix-name: Specifies an IPv6 prefix list name, a string of 1 to 19 characters.
Use reset ip ipv6-prefix to clear the statistics of the specified IPv6 prefix list. If no name is specified, the statistics of all IPv6 prefix lists will be cleared.
# Clear the statistics of IPv6 prefix list abc.
<Sysname> reset ip ipv6-prefix abc
