07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
07-Policy-Based Routing Commands
07-Policy-Based Routing Commands 99.4 KB
apply access-vpn vpn-instance
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
View
PBR policy node view
Default level
2: System level
vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters.
Use apply access-vpn vpn-instance to set a VPN instance.
Use undo apply access-vpn vpn-instance to remove the specified VPN instance.
You can set only one VPN instance for a policy node. When a packet matches the criteria, it is forwarded according to the forwarding table of the VPN instance.
Using the undo apply access-vpn vpn-instance command with a VPN instance specified removes the VPN instance. Using this command without any VPN instance disables packet forwarding in VPN instance.
IMPORTANT:
The specified VPN instance must exist.
Related commands: apply ip-precedence and apply ip-address next-hop.
# Set VPN instance vpn1 for forwarding packets.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1
apply ip-address next-hop [ vpn-instance vpn-instance-name ] ip-address1 [ direct ] [ track track-entry-number ] [ ip-address2 [ direct ] [ track track-entry-number ] ]
undo apply ip-address next-hop [ [ vpn-instance vpn-instance-name ] ip-address1 | ip-address2 ] *
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. The specified VPN must already exist.
ip-address1: Specifies the IP address of the primary next hop.
ip-address2: Specifies the IP address of the backup next hop.
direct: Specifies the current next hop as valid when it is a directly connected next hop.
track track-entry-number: Specifies a track entry. The track-entry-number argument is in the range of 1 to 1024.
Use apply ip-address next-hop to set a next hop for packets.
Use undo apply ip-address next-hop to remove the configuration.
You can specify up to two next hops in one policy node.
If you configure two next hops for interface PBR at the same time, only the primary next hop takes effect. The backup next hop takes effect only when the primary next hop is invalid. When neither next hop is effective, packets are forwarded according to the routing table.
If you configure two next hops for local PBR at the same time, both next hops take effect to implement load sharing.
Using the undo apply ip-address next-hop command with a next hop specified removes the next hop. Using this command without any next hop specified removes all next hops.
# Set the directly connected next hop to 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply ip-address next-hop 1.1.1.1 direct
apply ip-precedence
apply ip-precedence value
undo apply ip-precedence
View
Default level
2: System level
value: Sets the precedence for IP packets. There are eight precedence values (0 to 7). Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and the corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
Use apply ip-precedence to set a precedence for packets.
Use undo apply ip-precedence to remove the configuration.
# Set the precedence to 5 (critical) for packets.
[Sysname-pbr-aa-11] apply ip-precedence critical
display ip policy-based-route
display ip policy-based-route [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip policy-based-route to display the PBR routing information.
# Display the PBR routing information.
<Sysname> display ip policy-based-route
Policy Name             interface
pr02                    local
pr01                    Vlan-interface 1
Policy Name
Policy name.
interface
PBR type:
This field displays local for a local PBR or a specific interface (such as Virtual-template 0) to which the policy has been applied to implement interface PBR.
display ip policy-based-route setup
Standalone mode:
display ip policy-based-route setup { policy-name | interface interface-type interface-number [ slot slot-number ] | local [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip policy-based-route setup { policy-name | interface interface-type interface-number [ chassis chassis-number slot slot-number ] | local [ chassis chassis-number slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays the PBR routing information of the specified policy. A policy name is a string of 1 to 19 characters.
interface interface-type interface-number: Displays the PBR routing information on the specified interface.
local: Displays the local PBR information.
slot slot-number: Displays the PBR routing information on a card. slot-number represents the number of the slot that holds the card.
chassis chassis-number slot slot-number: Displays the PBR routing information of a card on an IRF member device. chassis-number represents the ID of the IRF member device, and slot-number argument represents the number of the slot that holds the card.
Use display ip policy-based-route setup to display the specified PBR routing information.
# Display the PBR routing information on VLAN-interface 1.
<Sysname> display ip policy-based-route setup interface Vlan-interface 1
Interface Vlan-interface 1 policy based routing configuration information:
 policy-based-route pr01 permit node 1
 if-match acl 3101
The referenced policy name is pr01, the match mode is permit, and the policy has a node 1.
if-match acl 3101
Match packets against ACL 3101.
The matched packets are sent to next hop 1.1.1.1.
display ip policy-based-route statistics
Standalone mode:
display ip policy-based-route statistics { interface interface-type interface-number | local } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip policy-based-route statistics { interface interface-type interface-number | local } [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the PBR statistics on the specified interface.
local: Displays the statistics of local PBR.
slot slot-number: Displays the PBR statistics on a card. slot-number represents the number of the slot that holds the card. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Displays the PBR statistics of a card on an IRF member switch. The chassis-number represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode.
Use display ip policy-based-route statistics to display PBR statistics.
# Display the statistics of PBR on GigabitEthernet 3/0/1.
<Sysname> display ip policy-based-route statistic interface GigabitEthernet 3/0/1
policy-based-route: 111
   permit node 1:
     if-match acl 3004
     apply ip-address next-hop 3.3.3.3
   matched: 0
 Total matched: 0
The policy name is 111.
permit node 1
The match mode of node 1 is permit.
if-match acl 3004
Match packets against ACL 3104.
matched: 0
Matching packets on node 1.
Total matched: 0
Total matching packets on all nodes of policy 111.
display policy-based-route
display policy-based-route [ policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays information about the specified policy. A policy name is a string of 1 to 19 characters.
Use display policy-based-route to display PBR policy information.
If no policy name is specified, all PBR policy information is displayed. If a policy name is specified, information about the specified policy is displayed.
# Display the PBR policy information.
<Sysname> display policy-based-route
Policy based routing configuration information:
 policy-based-route : p1
    Node 10 permit :
       apply ip-address next-hop 10.1.1.1
       apply ip-address next-hop vpn-instance vpn1 1.1.1.1
    Node 11 permit :
apply ip-address next-hop vpn-instance vpn2 2.1.1.1
       apply ip-address next-hop vpn-instance vpn3 3.1.1.1
Table 5 Command output
policy-based-route : aaa
The policy name is aaa.
Node  1  permit :
The matching mode of node 1 is permit.
Specify a next hop for matched packets.
The output shows the backup next hop and then the primary next hop.
if-match acl
if-match acl acl-number
undo if-match acl
View
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
Use if-match acl to define an ACL match criterion.
Use undo if-match acl to remove the ACL match criterion.
# Permit the packets matching ACL 2010.
[Sysname-pbr-aa-11] if-match acl 2010
ip local policy-based-route
ip local policy-based-route policy-name
undo ip local policy-based-route policy-name
View
Default level
2: System level
policy-name: Specifies a policy by its name, a string of 1 to 19 characters.
Use ip local policy-based-route to configure local PBR based on a specified policy.
Use undo ip local policy-based-route to remove the configuration.
No policy is referenced for local PBR by default.
Only one policy can be referenced for local PBR.
Local PBR is used to route packets generated locally. Unless otherwise required, H3C recommends not configuring local PBR.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
ip policy-based-route policy-name
undo ip policy-based-route policy-name
View
Interface view
Default level
2: System level
Use ip policy-based-route to configure PBR based on a specified policy on the interface.
Use undo ip policy-based-route to remove the configuration.
No policy is referenced for interface PBR by default.
Only one policy can be referenced by an interface for PBR.
The referenced policy applies to all packets arriving on the interface.
Related commands: ip local policy-based-route.
# Configure PBR based on policy aaa on VLAN-interface 2000.
[Sysname] interface Vlan-interface 2000
[Sysname-Vlan-interface2000] ip policy-based-route aaa
policy-based-route
undo policy-based-route policy-name [ deny | node node-number | permit ]
View
Default level
2: System level
deny: Specifies the match mode of the policy node as deny.
permit: Specifies the match mode of the policy node as permit.
node node-number: Number of a policy node, in the range of 0 to 65535. A node with a smaller node-number has a higher match priority than a node with a greater one.
Use policy-based-route to create a policy or/and policy node and enter PBR policy node view.
Use undo policy-based-route to remove a created policy or policy node.
No policy or policy node is created by default.
The default match mode of a policy node is permit.
# Configure the match mode of node 10 of policy 1 as permit, and enter PBR policy node view.
reset policy-based-route statistics
reset policy-based-route statistics [ policy-name ]
View
Default level
1: Monitor level
Use reset policy-based-route statistics to clear PBR statistics.
If no policy name is specified, this command clears all the PBR statistics.
# Clear all PBR statistics.
<Sysname> reset policy-based-route statistics
