07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
01-Basic IP Routing Commands
01-Basic IP Routing Commands 166.71 KB
display ip routing-table
display ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the information of the public network is displayed.
verbose: Displays detailed information about all routes, including both active and inactive routes. With this keyword absent, the command displays only brief information about active routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip routing-table to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a route entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and output interface. This command only displays active routes.
Use display ip routing-table verbose to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 9        Routes : 9
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
192.168.1.0/24      Direct 0    0            192.168.1.100   Vlan10
192.168.1.100/32    Direct 0    0            127.0.0.1       InLoop0
192.168.2.0/24      Direct 0    0            192.168.2.200   Vlan1000
192.168.2.200/32    Direct 0    0            127.0.0.1       InLoop0
192.168.3.0/24      Direct 0    0            192.168.3.1     Vlan2000
192.168.3.1/32      Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that presents the route.
Pre
Priority of the route.
Cost
Cost of the route.
NextHop
Address of the next hop on the route.
Output interface for packets to be forwarded along the route.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
         Destinations : 9        Routes : 11
  Destination: 1.1.1.1/32
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
 IpPrecedence:                    QosLcId:
      NextHop: 127.0.0.1        Interface: InLoopBack0
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv             Age: 01h29m07s
          Tag: 0
     Protocol: OSPF            Process ID: 1
   Preference: 10                    Cost: 0
      NextHop: 1.1.1.1          Interface: LoopBack0
        State: Invalid Adv            Age: 01h29m02s
          Tag: 0
  Destination: 127.0.0.0/8
        State: Active NoAdv           Age: 01h29m12s
          Tag: 0
  Destination: 127.0.0.1/32
        State: Active NoAdv           Age: 01h29m13s
          Tag: 0
  Destination: 192.168.1.0/24
      NextHop: 192.168.1.100    Interface: Vlan-interface10
        State: Active Adv             Age: 01h27m23s
          Tag: 0
  Destination: 192.168.1.100/32
        State: Active NoAdv           Age: 01h27m23s
          Tag: 0
  Destination: 192.168.2.0/24
      NextHop: 192.168.2.200    Interface: Vlan-interface1000
          Tag: 0
   Preference: 10                    Cost: 1
        State: Invalid Adv            Age: 01h27m19s
          Tag: 0
  Destination: 192.168.2.200/32
        State: Active NoAdv           Age: 01h27m24s
          Tag: 0
  Destination: 192.168.3.0/24
      NextHop: 192.168.3.1      Interface: Vlan-interface2000
        State: Active Adv             Age: 01h27m22s
          Tag: 0
  Destination: 192.168.3.1/32
        State: Active NoAdv           Age: 01h27m22s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Destination
Protocol
Process ID
Process ID.
Preference
Cost
Cost of the route.
IpPrecedence
IP precedence.
QosLcId
QoS-local ID.
NextHop
BkNextHop
Backup next hop.
BkInterface
Backup output interface.
RelyNextHop
Recursive next hop.
Neighbor
Neighboring address.
Tunnel ID
Tunnel ID.
Label
Label.
BKTunnel ID
Backup tunnel ID.
BKLabel
Backup label.
Route status:
·     Active—This is an active unicast route.
·     Adv—This route can be advertised.
·     Delete—This route is deleted.
·     Gateway—This is an indirect route.
·     Holddown—Number of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For detailed information, see corresponding routing protocols.
·     Int—The route was discovered by an Interior Gateway Protocol (IGP).
·     NoAdv—The route is not advertised when the router advertises routes based on policies.
·     NotInstallIn normal cases, among routes to a destination, the route with the highest priority is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but can be advertised.
·     Reject—The packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
·     Static—A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
·     Unicast—Unicast routes.
·     Inactive—Inactive routes.
·     Invalid—Invalid routes.
·     WaitQ—The route is the WaitQ during route recursion.
·     TunE—Tunnel.
·     GotQ—The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag.
display ip routing-table acl
display ip routing-table [ vpn-instance vpn-instance-name ] acl acl-number [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes. With this argument absent, the command displays only brief information about active routes.
Use display ip routing-table acl to display information about routes permitted by a specified basic ACL.
This command is intended for the follow-up display of routing policies.
For more information about routing policy, see Layer 3—IP Routing Configuration Guide.
If the specified ACL does not exist or it has no rules configured, the entire routing table is displayed.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access list : 2000
Summary Count : 6
Destination/Mask    Proto  Pre  Cost         NextHop       Interface
10.1.1.0/24         Direct 0    0            10.1.1.2      Vlan1
10.1.1.2/32         Direct 0    0            127.0.0.1     InLoop0
10.1.2.0/24         Direct 0    0            10.1.2.1      Vlan11
10.1.2.1/32         Direct 0    0            127.0.0.1     InLoop0
10.1.3.0/24         Direct 0    0            10.1.3.1      Vlan12
10.1.3.1/32         Direct 0    0            127.0.0.1     InLoop0
For output description, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count: 6
Destination: 10.1.1.0/24
      NextHop: 10.1.1.2         Interface: Vlan-interface1
        State: Active Adv             Age: 1d00h25m32s
          Tag: 0
Destination: 10.1.1.2/32
      NextHop: 127.0.0.1        Interface: InLoop0
        State: Active NoAdv           Age: 1d00h41m34s
          Tag: 0
Destination: 10.1.2.0/24
      NextHop: 10.1.2.1         Interface: Vlan-interface11
        State: Active Adv             Age: 1d00h05m42s
          Tag: 0
Destination: 10.1.2.1/32
        State: Active NoAdv           Age: 1d00h05m42s
          Tag: 0
Destination: 10.1.3.0/24
      NextHop: 10.1.3.1         Interface: Vlan-interface12
        State: Active Adv             Age: 1d00h05m31s
          Tag: 0
Destination: 10.1.3.1/32
        State: Active NoAdv           Age: 1d00h05m32s
          Tag: 0
For output description, see Table 2.
display ip routing-table ip-address
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 { mask | mask-length } ip-address2 { mask | mask-length } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Specifies a destination IP address, in dotted decimal notation.
mask: Specifies the IP address mask in dotted decimal notation.
mask-length: Specifies the IP address mask length in the range of 0 to 32.
longer-match: Displays the route with the longest mask.
Use display ip routing-table ip-address to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
·     display ip routing-table ip-address
¡     The system ANDs the input destination IP address with the subnet mask in each route entry;
¡     The system ANDs the destination IP address in each route entry with its corresponding subnet mask;
¡     If the two operations yield the same result for an entry and this entry is active, it is displayed.
·     display ip routing-table ip-address mask
¡     The system ANDs the input destination IP address with the input subnet mask;
¡     The system ANDs the destination IP address in each route entry with the input subnet mask;
¡     If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
·     display ip routing-table ip-address longer-match
¡     If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
·     display ip routing-table ip-address mask longer-match
¡     If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
<Sysname> display ip routing-table 11.1.1.1
Routing Table : Public
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
# Display route entries by specifying a destination IP address and mask.
<Sysname> display ip routing-table 11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and the longer-match keyword.
<Sysname> display ip routing-table 11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 24 longer-match
Summary Count : 1
# Display route entries for destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1       Vlan3
3.3.3.1/32          Direct 0    0            127.0.0.1     InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1       Vlan4
4.4.4.1/32          Direct 0    0            127.0.0.1     InLoop0
display ip routing-table ip-prefix
display ip routing-table [ vpn-instance vpn-instance-name ] ip-prefix ip-prefix-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the information of the public network is displayed.
ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters.
Use display ip routing-table ip-prefix to display information about routes permitted by a specified prefix list.
This command is intended for the follow-up display of routing policies. If the specified prefix list is not configured, detailed information about all routes (with the verbose keyword) or brief information about all active routes (without the verbose keyword) is displayed.
# Configure a prefix list named test, permitting routes with a prefix of 2.2.2.0 and a mask length between 24 and 32.
[Sysname] ip ip-prefix test permit 2.2.2.0 24 less-equal 32
# Display brief information about active routes permitted by the prefix list test.
[Sysname] display ip routing-table ip-prefix test
Routes Matched by Prefix list : test
Summary Count : 2
2.2.2.1/32         Direct  0    0          127.0.0.1       InLoop0
# Display detailed information about all routes permitted by IP prefix list test.
[Sysname] display ip routing-table ip-prefix test verbose
Routes Matched by Prefix list  test :
Summary Count : 2
Destination: 2.2.2.0/24
      NextHop: 2.2.2.1          Interface: Vlan-interface2
        State: Active Adv             Age: 1d00h20m52s
          Tag: 0
Destination: 2.2.2.1/32
        State: Active NoAdv           Age: 1d00h20m52s
          Tag: 0
display ip routing-table protocol
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Specifies a routing protocol. It can be bgp, direct, isis, ospf, rip, static, or guard.
inactive: Displays information about only inactive routes. With this argument absent, the command displays information about all routes.
verbose: Displays detailed routing table information. With this argument absent, the command displays brief routing table information.
Use display ip routing-table protocol to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing Table Status : < Active>
Summary Count :  6
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   Vlan11
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing Table Status : < Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing Table Status : < Active>
Summary Count :  0
Static Routing table Status : < Inactive>
Summary Count : 2
1.2.3.0/24          Static 60   0            1.2.4.5         Vlan10
3.0.0.0/8           Static 60   0            2.2.2.2         Vlan11
display ip routing-table statistics
display ip routing-table [ vpn-instance vpn-instance-name ] statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ip routing-table statistics to display the route statistics of the routing table.
# Display route statistics in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
RIP        0           0           0           0             0
OSPF       0           0           0           0             0
IS-IS      0           0           0           0             0
BGP        0           0           0           0             0
Total      28          5           29          1             0
Proto
Origin of the routes.
route
Number of routes from the origin.
active
Number of active routes from the origin.
added
Number of routes added into the routing table since the router started up or the routing table was last cleared.
deleted
Number of routes marked as deleted, which will be freed after a period.
freed
Number of routes that got freed, that is, got removed permanently.
Total
Total number.
display ipv6 routing-table
display ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed information about all IPv6 routes, including both active and inactive routes. With this argument absent, the command displays only brief information about active routes.
Use display ipv6 routing-table to display brief IPv6 routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and output interface.
The command displays only active routes, namely, the brief information about the current optimal routes.
Use display ipv6 routing-table verbose to display detailed information about all IPv6 routes, including both active and inactive routes. The output shows the statistics of the entire routing table, and then the detailed information of each route.
# Display brief routing table information
<Sysname> display ipv6 routing-table
        Destinations : 1        Routes : 1
Destination : ::1/128                           Protocol    : Direct
NextHop     : ::1                               Preference  : 0
Interface   : InLoop0                           Cost        : 0
Destination
IPv6 address of the destination network/host.
NextHop
Next hop address.
Preference
Route priority.
Output interface.
Protocol
Routing protocol.
Cost
Route cost.
# Display detailed routing table information.
<Sysname> display ipv6 routing-table verbose
 Destination  : ::1                                     PrefixLength : 128
 IpPrecedence :                                         QosLcId      :
 RelayNextHop : ::                                      Tag          : 0H
 Neighbor     : ::                                      ProcessID    : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 22161sec
Table 5 Command output
Destination
PrefixLength
Prefix length of the address.
NextHop
Next hop.
Preference
Route priority.
IpPrecedence
IP precedence.
QosLcId
QoS-local ID.
RelayNextHop
Recursive next hop.
Tag
Tag of the route.
Neighbor
Neighbor address.
ProcessID
Process ID.
Output interface.
Protocol
Routing protocol.
State of the route: Active, Inactive, Adv (advertised), or NoAdv (not advertised)
Cost
Route cost.
Tunnel ID
Tunnel ID.
Label
Label.
Age
Time that has elapsed since the route was generated.
display ipv6 routing-table acl
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl acl6-number [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl6-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the ACL. Without this keyword, only brief information about active routes is displayed.
Use display ipv6 routing-table acl to display routing information permitted by the IPv6 ACL.
If the specified IPv6 ACL is not available, all routing information is displayed.
# Display brief routing information permitted by ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Routes Matched by Access list  2000  :
Summary Count : 2
Destination : 1:1::/64                          Protocol   : Static
NextHop     : ::                                Preference : 60
Interface   : NULL0                             Cost       : 0
For output description, see Table 4.
display ipv6 routing-table ipv6-address
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address prefix-length [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the matched route having the longest prefix length.
ipv6-address1/ipv6-address2: Specifies an IPv6 address range from IPv6 address1 to IPv6 address2.
prefix-length1/prefix-length2: Specifies a prefix length in the range of 0 to 128.
verbose: Displays detailed information about all routes. Without this keyword, only brief information about active routes is displayed.
Use display ipv6 routing-table ipv6-address to display routing information about the specified destination IPv6 address.
Executing the command with different parameters yields different outputs:
·     display ipv6 routing-table ipv6-address
¡     The system ANDs the input destination IPv6 address with the prefix length in each route entry;
¡     The system ANDs the destination IPv6 address in each route entry with the prefix length in each entry;
·     display ipv6 routing-table ipv6-address prefix-length
¡     The system ANDs the input destination IPv6 address with the input prefix length;
¡     The system ANDs the destination IPv6 address in each route entry with the input prefix length;
¡     If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
·     display ipv6 routing-table ipv6-address prefix-length longer-match
¡     If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the one that is active with the longest prefix length is displayed.
Use display ipv6 routing-table ipv6-address1 ipv6-address2 to display routes whose destinations are in the specified IPv6 address range.
# Display brief information about the routes with destination IPv6 address 10::1.
<Sysname> display ipv6 routing-table 10::1
Routing Table: Public
Summary Count: 3
Destination: 10::/64                                    Protocol  : Static
NextHop    : ::                                         Preference: 60
Destination: 10::/68                                    Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the route with destination IPv6 address 10::1 and prefix length 100.
<Sysname> display ipv6 routing-table 10::1 100
Summary Count: 3
# Display brief information about the route with destination IPv6 address 10:: and the longest prefix length.
<Sysname> display ipv6 routing-table 10:: longer-match
Summary Count : 1
# Display brief information about the route matching destination IPv6 address 10::1, prefix length 100, and the longest prefix length.
<Sysname> display ipv6 routing-table 10::1 100 longer-match
Summary Count: 1
# Display routes whose destinations are in the specified IPv6 address range.
<Sysname> display ipv6 routing-table 100:: 64 300:: 64
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
display ipv6 routing-table ipv6-prefix
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-prefix ipv6-prefix-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-prefix-name: Specifies an IPv6 prefix list by its name, a string of 1 to 19 characters.
Use display ipv6 routing-table ipv6-prefix to display routes permitted by the IPv6 prefix list.
# Display brief active routing information permitted by the IPv6 prefix list test2.
<Sysname> display ipv6 routing-table ipv6-prefix test2
Routes Matched by Prefix list  test2  :
Summary Count : 1
display ipv6 routing-table protocol
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
protocol: Displays routes of a routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
inactive: Displays only inactive routes. Without the keyword, all routes are displayed.
Use display ipv6 routing-table protocol to display IPv6 routes of a specified routing protocol.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary Count : 1
Direct Routing Table Status : <Active>
Summary Count : 1
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Direct Routing Table Status : <Inactive>
Summary Count : 0
display ipv6 routing-table statistics
display ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ipv6 routing-table statistics to display IPv6 routing statistics, including total route number, added route number and deleted route number.
# Display routing statistics.
<Sysname> display ipv6 routing-table statistics
Protocol   route      active     added      deleted     freed
DIRECT     1          1          1          0           0
STATIC     3          0          3          0           0
RIPng      0          0          0          0           0
OSPFv3     0          0          0          0           0
IS-ISv6    0          0          0          0           0
BGP4+      0          0          0          0           0
Total      4          1          4          0           0
Table 6 Command output
Protocol
Routing protocol.
route
Route number of the protocol.
active
Number of active routes.
added
Routes added after the last startup of the router.
deleted
Deleted routes, which will be released after a specified time.
freed
Released (totally removed from the routing table) route number.
Total
Total number of routes.
max-ecmp-num
max-ecmp-num number
undo max-ecmp-num
View
Default level
2: System level
number: Specifies the maximum number of ECMP routes. The value can be 16 or 32.
Use max-ecmp-num to configure the maximum number of ECMP routes.
Use undo max-ecmp-num to restore the default.
By default, the maximum number of ECMP routes is 16.
# Configure the maximum number of ECMP routes as 32.
[Sysname] max-ecmp-num 32
reset ip routing-table statistics protocol
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the routing statistics of the public network is cleared.
protocol: Clears statistics for the routing protocol, which can be bgp, direct, is-is, ospf, rip, or static.
all: Clears statistics for all routing protocols.
Use reset ip routing-table statistics protocol to clear routing statistics for the routing table.
# Clear routing statistics in the routing table of VPN instance Sysname1.
<Sysname> reset ip routing-table statistics protocol vpn-instance Sysname1 all
reset ipv6 routing-table statistics
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
View
Default level
2: System level
protocol: Clears statistics for the routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
Use reset ipv6 routing-table statistics to clear the route statistics of the routing table.
# Clear statistics for all routing protocols.
<Sysname> reset ipv6 routing-table statistics protocol all
