- 07-Layer 3 - IP Routing Command Reference
- 01-Basic IP Routing Commands
- 02-Static Routing Commands
- 03-RIP Commands
- 04-OSPF Commands
- 05-IS-IS Commands
- 06-BGP Commands
- 07-Policy-Based Routing Commands
- 08-Guard Route Commands
- 09-IPv6 Static Routing Commands
- 10-RIPng Commands
- 11-OSPFv3 Commands
- 12-IPv6 IS-IS Commands
- 13-IPv6 BGP Commands
- 14-IPv6 Policy-Based Routing Commands
- 15-Routing Policy Commands
| 04-OSPF Commands | 337.95 KB |
bandwidth-reference (OSPF view)
default-route-advertise (OSPF view)
description (OSPF/OSPF area view)
enable out-of-band-resynchronization
filter-policy export (OSPF view)
filter-policy import (OSPF view)
graceful-restart interval (OSPF view)
maximum load-balancing (OSPF view)
ospf packet-process prioritized-treatment
For OSPF TE related commands and OSPF VPN related commands, see MPLS Command Reference.
abr-summary (OSPF area view)
abr-summary ip-address { mask | mask-length } [ advertise | not-advertise ] [ cost cost ]
undo abr-summary ip-address { mask | mask-length }
View
OSPF area view
Default level
2: System level
ip-address: Specifies the destination IP address of the summary route, in dotted decimal notation.
mask: Specifies the mask of the IP address, in dotted decimal notation.
mask-length: Specifies the mask length in the range of 0 to 32 bits.
advertise | not-advertise: Advertises the summary route or not. If neither the advertise nor not-advertise keyword is set, the summary route is advertised.
cost cost: Specifies the cost of the summary route, in the range of 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
Use abr-summary to configure a summary route on the area border router.
Use undo abr-summary to remove a summary route.
By default, no route summarization is configured on an ABR.
You can enable advertising the summary route or not, and specify a route cost.
This command is usable only on an ABR. Multiple contiguous networks might be available in an area, where you can summarize them into one network on the ABR for advertisement. The ABR advertises only the summary route to other areas.
With the undo abr-summary command used, summarized routes will be advertised.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 into 36.42.0.0/16.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area (OSPF view)
area area-id
undo area area-id
View
OSPF view
Default level
2: System level
area-id: Specifies an area ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format by the system.
Use area to create an area and enter area view.
Use undo area to remove a specified area.
By default, no OSPF area is created.
# Create Area 0 and enter Area 0 view.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary
asbr-summary ip-address { mask | mask-length } [ cost cost | not-advertise | tag tag ] *
undo asbr-summary ip-address { mask | mask-length }
View
OSPF view
Default level
2: System level
ip-address: Specifies the IP address of the summary route in dotted decimal notation.
mask: Specifies the summary route mask in dotted decimal notation.
mask-length: Specifies the length of summary route mask, in the range of 0 to 32 bits.
cost cost: Specifies the cost of the summary route, in the range of 1 to 16777214. For Type-1 external routes, the cost defaults to the largest cost among routes that are summarized. For Type-2 external routes, the cost defaults to the largest cost among routes that are summarized plus 1.
not-advertise: Disables advertising the summary route. If the keyword is not specified, the route is advertised.
tag tag: Specifies a tag value for the summary route, used by a routing policy to control summary route advertisement, in the range of 0 to 4294967295. The default is 1.
Use asbr-summary to configure a summary route.
Use undo asbr-summary to remove a summary route.
By default, no ASBR route summarization is configured.
With the asbr-summary command configured on an ASBR, it summarizes redistributed routes within the specified address range into a single route. If the ASBR resides in an NSSA area, it advertises the summary route in a Type-7 LSA into the area.
With the asbr-summary command configured on an NSSA ABR, it summarizes routes described by Type-5 LSAs translated from Type-7 LSAs into a single route and advertises the summary route to other areas. This command does not take effect on non NSSA ABRs.
With the undo asbr-summary command used, summarized routes will be advertised.
Related command: display ospf asbr-summary.
# Summarize redistributed routes into a single route, specifying a tag value of 2 and a cost of 100 for the summary route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode
For MD5/HMAC-MD5 authentication:
authentication-mode { hmac-md5 | md5 } [ key-id [ cipher | plain ] password ]
undo authentication-mode
For simple authentication mode:
authentication-mode simple [ [ cipher | plain ] password ]
View
OSPF area view
Default level
2: System level
hmac-md5: Specifies the HMAC-MD5 authentication mode.
md5: Specifies the MD5 ciphertext authentication mode.
simple: Specifies the simple authentication mode.
key-id: Specifies the key ID in the range of 0 to 255.
cipher: Sets a ciphertext password.
plain: Sets a plaintext password.
password: Sets the authentication password. This argument is case sensitive. For simple authentication mode, it is a plaintext string of 1 to 8 characters, or a ciphertext string of 1 to 41 characters. For MD5/HMAC-MD5 authentication mode, it is a plaintext string of 1 to 16 characters, or a ciphertext string of 1 to 53 characters.
Use authentication-mode to specify an authentication mode and key ID for the OSPF area.
Use undo authentication-mode to remove the authentication mode.
By default, no authentication is performed for an OSPF area.
You can specify either MD5/HMAC-MD5 authentication mode or simple authentication mode for an OSPF area. When you specify the MD5/HMAC-MD5 authentication mode, you can execute the command multiple times to configure different key IDs.
If you configure interface authentication and area authentication at the same time, OSPF receives only the packets that pass interface authentication.
Related commands: ospf authentication-mode.
# Configure OSPF Area 0 to support MD5 authentication mode, and set the key ID to 15 and plaintext authentication password to abc.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5 15 plain abc
# Configure OSPF Area 0 to support simple authentication mode, and set the plaintext authentication password to abc.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode simple plain abc
bandwidth-reference value
undo bandwidth-reference
View
OSPF view
Default level
2: System level
value: Specifies the bandwidth reference value for link cost calculation, in the range of 1 to 2147483648 Mbps.
Use bandwidth-reference to specify a reference bandwidth value for link cost calculation.
Use undo bandwidth-reference to restore the default value.
The default value is 100 Mbps.
When links have no cost values configured, OSPF calculates their cost values: Cost=Reference bandwidth value / Link bandwidth. If the calculated cost is greater than 65535, the value of 65535 is used.
# Specify the reference bandwidth value as 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
default
default { cost cost | limit limit | tag tag | type type } *
undo default { cost | limit | tag | type } *
View
OSPF view
Default level
2: System level
cost: Specifies the default cost for redistributed routes, in the range of 0 to 16777214.
limit: Specifies the default upper limit of routes redistributed per time, in the range of 1 to 2147483647.
tag: Specifies the default tag for redistributed routes, in the range of 0 to 4294967295.
type: Specifies the default type for redistributed routes: 1 or 2.
Use default to configure default parameters for redistributed routes.
Use undo default to restore default values.
By default, the cost, route type, tag, and the upper limit are 1, 2, 1 and 1000.
Related commands: import-route.
# Configure the default cost, upper limit, tag and type as 10, 20000, 100 and 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 limit 20000 tag 100 type 2
default-cost (OSPF area view)
default-cost cost
undo default-cost
View
OSPF area view
Default level
2: System level
cost: Specifies a cost for the default route advertised to the Stub or NSSA area, in the range of 0 to 16777214.
Use default-cost to configure a cost for the default route advertised to the stub or NSSA area.
Use undo default-cost to restore the default value.
The cost defaults to 1.
This command is only applicable to the ABR of a stub area or the ABR/ASBR of an NSSA area.
Related commands: stub and nssa.
# Configure Area 1 as a stub area, and specify the cost of the default route advertised to the stub area as 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
default-route-advertise [ [ [ always | permit-calculate-other ] | cost cost | route-policy route-policy-name | type type ] * | summary cost cost ]
undo default-route-advertise
View
OSPF view
Default level
2: System level
always: Generates a default route in a Type-5 LSA into the OSPF routing domain regardless of whether there is a default route in the routing table. If this keyword is not specified, the router generates a default route in a Type-5 LSA into the OSPF routing domain only when an active default route that does not belong to the current OSPF process exists in the IP routing table.
permit-calculate-other: Calculates default routes from other routers with this keyword specified or does not calculate default routes from other routers without this keyword specified when the router generates a default route in a Type-5 LSA into the OSPF routing domain. If the router generates no default route in a Type-5 LSA into the OSPF routing domain, the router calculates default routes from other routers regardless of whether this keyword is specified.
cost cost: Specifies a cost for the default route, in the range of 0 to 16777214. If no cost is specified, the default cost specified by the default cost command applies..
route-policy route-policy-name: Specifies a routing policy name, a string of 1 to 63 case-sensitive characters. When a default route exists in the routing table and the specified routing policy is matched, the command distributes a default route in a Type-5 LSA into the OSPF routing domain, and the routing policy modifies some values in the Type-5 LSA. If the always keyword is specified at the same time, the command can distribute a default route in a Type-5 LSA into the OSPF routing domain when the specified routing policy is matched, regardless of whether a default route exists in the routing table, and the routing policy modifies some values in the Type-5 LSA.
type type: Specifies a type for the Type-5 LSA: 1 or 2. If type is not specified, the default type for the Type-5 LSA specified by the default type command applies.
summary: Advertises the Type-3 summary LSA of the specified default route.
Use default-route-advertise to generate a default route into the OSPF routing domain.
Use undo default-route-advertise to disable OSPF from distributing a default external route.
By default, no default route is distributed.
The default-route-advertise summary cost command is applicable only to VPNs, and the default route is redistributed in a Type-3 LSA. The PE router advertises the redistributed default route to the CE router.
Using the import-route command cannot redistribute a default route. To redistribute a default route, use the default-route-advertise command.
Related commands: import-route and default.
# Generate a default route in an ASE LSA into the OSPF routing domain, regardless of whether the default route is available in the routing table.
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
description description
View
OSPF view/OSPF area view
Default level
2: System level
description: Configures a description for the OSPF process in OSPF view, or for the OSPF area in OSPF area view. description is a string of up to 80 characters.
Use description to configure a description for an OSPF process or area.
Use undo description to remove the description.
By default, no description is configured.
Use of this command is only for the identification of an OSPF process or area. The description has no special meaning.
# Describe the OSPF process 100 as abc.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Describe the OSPF Area 0 as bone area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
display ospf abr-asbr
display ospf [ process-id ] abr-asbr [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. Use this argument to display information about the routes to the ABR/ASBR under the specified OSPF process.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ospf abr-asbr to display information about the routes to OSPF ABR/ASBR.
If you use this command on routers in a stub area, no ASBR information is displayed.
# Display information about the routes to the OSPF ABR and ASBR.
<Sysname> display ospf abr-asbr
OSPF Process 1 with Router ID 192.168.1.2
Routing Table to ABR and ASBR
Type Destination Area Cost Nexthop RtType
Inter 3.3.3.3 0.0.0.0 3124 10.1.1.2 ASBR
Intra 2.2.2.2 0.0.0.0 1562 10.1.1.2 ABR
Type |
Type of the route to the ABR or ASBR: · Intra—Intra-area route. · Inter—Inter-area route. |
Destination |
Router ID of an ABR/ASBR. |
Area |
ID of the area of the next hop. |
Cost |
Cost from the router to the ABR/ASBR. |
Nexthop |
Next hop address. |
RtType |
Router type: ABR, ASBR. |
display ospf [ process-id ] asbr-summary [ ip-address { mask | mask-length } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies an IP address mask in dotted decimal notation.
Use display ospf asbr-summary to display information about the redistributed routes that are summarized.
If no OSPF process is specified, related information of all OSPF processes is displayed.
If no IP address is specified, information about all summarized redistributed routes will be displayed.
Related commands: asbr-summary.
# Display information about all summarized redistributed routes.
<Sysname> display ospf asbr-summary
Summary Addresses
Total Summary Address Count: 1
Summary Address
Net : 30.1.0.0
Mask : 255.255.0.0
Tag : 20
Status : Advertise
Cost : 10 (Configured)
The Count of Route is : 2
Destination Net Mask Proto Process Type Metric
30.1.2.0 255.255.255.0 OSPF 2 2 1
30.1.1.0 255.255.255.0 OSPF 2 2 1
Total Summary Address Count |
Total summary route number. |
Net |
Address of the summary route. |
Mask |
Mask of the summary route address. |
Tag |
Tag of the summary route. |
Status |
Advertisement status of the summary route. |
Cost |
Cost to the summary net. |
The Count of Route |
Count of routes that are summarized. |
Destination |
Destination address of a summarized route. |
Net Mask |
Network mask of a summarized route. |
Proto |
Routing protocol. |
Process |
Process ID of routing protocol. |
Type |
Type of a summarized route. |
Metric |
Metric of a summarized route. |
display ospf brief
display ospf [ process-id ] brief [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf brief to display OSPF brief information. If no OSPF process is specified, brief information about all OSPF processes is displayed.
# Display OSPF brief information.
<Sysname> display ospf brief
OSPF Protocol Information
RouterID: 192.168.1.2 Router Type: NSSA
Route Tag: 0
Applications Supported: MPLS Traffic-Engineering
SPF-schedule-interval: 5 0 5000
LSA generation interval: 5 0 5000
LSA arrival interval: 1000
Route Preference: 10
ASE Route Preference: 150
SPF Computation Count: 22
RFC 1583 Compatible
Area Count: 1 Nssa Area Count: 1
ExChange/Loading Neighbors: 0
Area: 0.0.0.1 (MPLS TE not enabled)
Authtype: None Area flag: NSSA
SPF Scheduled Count: 5
Interface: 192.168.1.2 (Vlan-interface11)
Cost: 1 State: DR Type: Broadcast MTU: 1500
Priority: 1
Designated Router: 192.168.1.2
Backup Designated Router: 192.168.1.1
Timers: Hello 10 , Dead 40 , Poll 40 , Retransmit 5 , Transmit Delay 1
OSPF Process 1 with Router ID 192.168.1.2 |
OSPF process ID and OSPF router ID. |
RouterID |
Router ID. |
Router Type |
Router type: · ABR. · ASBR. · NSSA. · Null. |
Route Tag |
The tag of redistributed routes. |
Multi-VPN-Instance is not enabled |
The OSPF process does not support multi-VPN-instance. |
Applications Supported |
Applications supported. MPLS Traffic-Engineering means MPLS TE is supported. |
SPF-schedule-interval |
Interval for SPF calculations. |
LSA generation interval |
LSA generation interval. |
LSA arrival interval |
LSA arrival interval. |
Transmit pacing |
LSU packet transmit rate of the interface: · Interval—LSU transmit interval of the interface. · Count—Maximum number of LSU packets sent during each interval. |
Default ASE Parameter |
Default ASE Parameters: metric, tag, route type. |
Route Preference |
Internal route priority. |
ASE Route Preference |
External route priority. |
SPF Computation count |
SPF computation count of the OSPF process. |
RFC1583 Compatible |
Compatible with routing rules defined in RFC 1583. |
Area Count |
Area number of the current process. |
Nssa Area Count |
NSSA area number of the current process. |
7/5 translator state |
State of the translator that translates Type-7 LSAs to Type-5 LSAs. The value can be one of the following: · Enabled—The translator is specified through commands. · Elected—The translator is designated through election. · Disabled—The switch is not a translator. |
7/5 translate stability timer interval |
Stability interval for Type-7 LSA-to-Type-5 LSA translation. |
ExChange/Loading Neighbors |
Neighbors in ExChange/Loading state. |
Area |
Area ID in the IP address format. |
Authtype |
Authentication type of the area: · None—Non-authentication. · Simple—Simple authentication. · MD5—MD5 authentication. |
Area flag |
Type of the area. |
SPF scheduled Count |
SPF calculation count in the OSPF area. |
Interface in the area. |
Cost |
Interface cost. |
State |
Interface state. |
Type |
Interface network type. |
MTU |
Interface MTU. |
Priority |
Router priority. |
Designated Router |
Designated Router. |
Backup Designated Router |
Backup Designated Router. |
Timers |
Intervals of timers: hello, dead, poll, retransmit, and transmit delay. |
display ospf cumulative
display ospf [ process-id ] cumulative [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf cumulative to display OSPF statistics.
Use of this command is helpful for troubleshooting.
# Display OSPF statistics.
<Sysname> display ospf cumulative
Cumulations
IO Statistics
Type Input Output
Hello 61 122
DB Description 2 3
Link-State Req 1 1
Link-State Update 3 3
Link-State Ack 3 2
LSAs originated by this router
Router: 4
Network: 0
Sum-Net: 0
Sum-Asbr: 0
External: 0
NSSA: 0
Opq-Link: 0
Opq-Area: 0
Opq-As: 0
LSAs Originated: 4 LSAs Received: 7
Routing Table:
Intra Area: 2 Inter Area: 3 ASE/NSSA: 0
IO statistics |
Statistics about input/output packets and LSAs. |
Type |
OSPF packet type. |
Input |
Packets received. |
Output |
Packets sent. |
Hello |
Hell packet. |
DB Description |
Database Description packet. |
Link-State Req |
Link-State Request packet. |
Link-State Update |
Link-State Update packet. |
Link-State Ack |
Link-State Acknowledge packet. |
LSAs originated by this router |
LSAs originated by this router. |
Router |
Number of Type-1 LSAs originated. |
Network |
Number of Type-2 LSAs originated. |
Sum-Net |
Number of Type-3 LSAs originated. |
Sum-Asbr |
Number of Type-4 LSAs originated. |
External |
Number of Type-5 LSAs originated. |
NSSA |
Number of Type-7 LSAs originated. |
Opq-Link |
Number of Type-9 LSAs originated. |
Opq-Area |
Number of Type-10 LSAs originated. |
Opq-As |
Number of Type-11 LSAs originated. |
LSA originated |
Number of LSAs originated. |
LSA Received |
Number of LSAs received. |
Routing Table |
Routing table information. |
Intra Area |
Intra-area route number. |
Inter Area |
Inter-area route number. |
ASE |
ASE route number. |
display ospf error
display ospf [ process-id ] error [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf error to display OSPF error information.
If no process is specified, the OSPF error information of all OSPF processes is displayed.
# Display OSPF error information.
<Sysname> display ospf error
OSPF Process 1 with Router ID 192.168.80.100
OSPF Packet Error Statistics
0 : OSPF Router ID confusion 0 : OSPF bad packet
0 : OSPF bad version 0 : OSPF bad checksum
0 : OSPF bad area ID 0 : OSPF drop on unnumber interface
0 : OSPF bad virtual link 0 : OSPF bad authentication type
0 : OSPF bad authentication key 0 : OSPF packet too small
0 : OSPF Neighbor state low 0 : OSPF transmit error
0 : OSPF interface down 0 : OSPF unknown neighbor
0 : HELLO: Netmask mismatch 0 : HELLO: Hello timer mismatch
0 : HELLO: Dead timer mismatch 0 : HELLO: Extern option mismatch
0 : HELLO: neighbor unknown 0 : DD: MTU option mismatch
0 : DD: Unknown LSA type 0 : DD: Extern option mismatch
0 : LS ACK: Bad ack 0 : LS ACK: Unknown LSA type
0 : LS REQ: Empty request 0 : LS REQ: Bad request
0 : LS UPD: LSA checksum bad 0 : LS UPD: Received less recent LSA
0 : LS UPD: Unknown LSA type
Table 5 Command output
OSPF Router ID confusion |
Packets with duplicate route ID. |
OSPF bad packet |
Packets illegal. |
OSPF bad version |
Packets with wrong version. |
OSPF bad checksum |
Packets with wrong checksum. |
OSPF bad area ID |
Packets with invalid area ID. |
OSPF drop on unnumber interface |
Packets dropped on the unnumbered interface. |
OSPF bad virtual link |
Packets on wrong virtual links. |
OSPF bad authentication type |
Packets with invalid authentication type. |
OSPF bad authentication key |
Packets with invalid authentication key. |
OSPF packet too small |
Packets too small in length. |
OSPF Neighbor state low |
Packets received in low neighbor state. |
OSPF transmit error |
Packets with error when being transmitted. |
OSPF interface down |
Shutdown times of the interface. |
OSPF unknown neighbor |
Packets received from unknown neighbors. |
HELLO: Netmask mismatch |
Hello packets with mismatched mask. |
HELLO: Hello timer mismatch |
Hello packets with mismatched hello timer. |
HELLO: Dead timer mismatch |
Hello packets with mismatched dead timer. |
HELLO: Extern option mismatch |
Hello packets with mismatched option field. |
HELLO: Neighbor unknown |
Hello packets received from unknown Neighbors. |
DD: MTU option mismatch |
DD packets with mismatched MTU. |
DD: Unknown LSA type |
DD packets with unknown LSA type. |
DD: Extern option mismatch |
DD packets with mismatched option field. |
LS ACK: Bad ack |
Bad LSAck packets for LSU packets. |
LS ACK: Unknown LSA type |
LSAck packets with unknown LSA type. |
LS REQ: Empty request |
LSR packets with no request information. |
LS REQ: Bad request |
Bad LSR packets. |
LS UPD: LSA checksum bad |
LSU packets with wrong LSA checksum. |
LS UPD: Received less recent LSA |
LSU packets without latest LSA. |
LS UPD: Unknown LSA type |
LSU packets with unknown LSA type. |
display ospf interface
display ospf [ process-id ] interface [ interface-type interface-number | all ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the OSPF information of all interfaces.
Use display ospf interface to display OSPF interface information.
If no OSPF process is specified, the OSPF interface information of all OSPF processes is displayed.
# Display OSPF interface information.
<Sysname> display ospf interface
OSPF Process 1 with Router ID 192.168.1.1
Interfaces
Area: 0.0.0.0
IP Address Type State Cost Pri DR BDR
192.168.1.1 PTP P-2-P 1562 1 0.0.0.0 0.0.0.0
Area: 0.0.0.1
172.16.0.1 Broadcast DR 1 1 172.16.0.1 0.0.0.0
Table 6 Command output
Area |
Area ID of the interface. |
IP address |
Interface IP address (regardless of whether TE is enabled or not). |
Type |
Interface network type: PTP, PTMP, broadcast, or NBMA. |
State |
Interface state defined by interface state machine: · DOWN—Means the interface does not send or receive protocol traffic. · Waiting—Means the interface starts sending and receiving Hello packets and the router is trying to determine the identity of the (Backup) designated router for the network. · p-2-p—Means the interface will send Hello packets at the interval of HelloInterval, and try to establish an adjacency with the neighbor. · DR—Means the router itself is the designated router on the attached network. · BDR—Means the router itself is the backup designated router on the attached network. · DROther—Means the interface is on a network on which another router has been selected as the designated router. |
Cost |
Interface cost. |
Pri |
Router priority. |
DR |
DR on the interface's network segment. |
BDR |
BDR on the interface's network segment. |
display ospf lsdb
display ospf [ process-id ] lsdb [ brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays brief LSDB information.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
network: Displays Type-2 LSA (Network LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
router: Displays Type-1 LSA (Router LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
link-state-id: Specifies a link state ID in the IP address format.
originate-router advertising-router-id: Specifies an advertising router by its ID.
self-originate: Displays information about self-originated LSAs.
Use display ospf lsdb to display LSDB information.
If no OSPF process is specified, LSDB information of all OSPF processes is displayed.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
OSPF Process 1 with Router ID 192.168.0.1
Link State Database
Area: 0.0.0.0
Type LinkState ID AdvRouter Age Len Sequence Metric
Router 192.168.0.2 192.168.0.2 474 36 80000004 0
Router 192.168.0.1 192.168.0.1 21 36 80000009 0
Network 192.168.0.1 192.168.0.1 321 32 80000003 0
Sum-Net 192.168.1.0 192.168.0.1 321 28 80000002 1
Sum-Net 192.168.2.0 192.168.0.2 474 28 80000002 1
Area: 0.0.0.1
Router 192.168.0.1 192.168.0.1 21 36 80000005 0
Sum-Net 192.168.2.0 192.168.0.1 321 28 80000002 2
Sum-Net 192.168.0.0 192.168.0.1 321 28 80000002 1
Table 7 Command output
Area |
LSDB information of the area. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
The router that advertised the LSA. |
Age |
Age of the LSA. |
Len |
Length of the LSA. |
Sequence |
Sequence number of the LSA. |
Metric |
Cost of the LSA. |
# Display Type2 LSA (Network LSA) information in the LSDB.
<Sysname> display ospf 1 lsdb network
Area: 0.0.0.0
Link State Database
Type : Network
LS ID : 192.168.0.2
Adv Rtr : 192.168.2.1
LS Age : 922
Len : 32
Options : E
Seq# : 80000003
Checksum : 0x8d1b
Net Mask : 255.255.255.0
Attached Router 192.168.1.1
Attached Router 192.168.2.1
Area: 0.0.0.1
Link State Database
Type : Network
LS ID : 192.168.1.2
Adv Rtr : 192.168.1.2
LS Age : 782
Len : 32
Options : NP
Seq# : 80000003
Checksum : 0x2a77
Attached Router 192.168.1.2
Table 8 Command output
Type |
LSA type. |
LS ID |
DR IP address. |
Adv Rtr |
Router that advertised the LSA. |
LS Age |
LSA age time. |
Len |
LSA length. |
Options |
LSA options: · O—Opaque LSA advertisement capability. · E—AS External LSA reception capability. · EA—External extended LSA reception capability. · DC—On-demand link support. · N—NSSA external LSA support. · P—Capability of an NSSA ABR to translate Type-7 LSAs into Type-5 LSAs. |
Seq# |
LSA sequence number. |
Checksum |
LSA checksum. |
Net Mask |
Network mask. |
Attached Router |
ID of the router that established adjacency with the DR, and ID of the DR itself. |
display ospf nexthop
display ospf [ process-id ] nexthop [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf nexthop to display OSPF next hop information.
If no OSPF process is specified, the next hop information of all OSPF processes is displayed.
# Display OSPF next hop information.
<Sysname> display ospf nexthop
Routing Nexthop Information
Next Hops:
Address Refcount IntfAddr Intf Name
192.168.0.1 1 192.168.0.1 Vlan-interface11
192.168.0.2 1 192.168.0.1 Vlan-interface12
192.168.1.1 1 192.168.1.1 Vlan-interface12
Table 9 Command output
Next hops |
Information about Next hops. |
Address |
Next hop address. |
Refcount |
Reference count, namely, routes that reference the next hop. |
IntfAddr |
Output interface address. |
Intf Name |
Output interface name. |
display ospf peer
display ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed neighbor information.
neighbor-id: Specifies a neighbor router ID.
Use display ospf peer to display information about OSPF neighbors.
· If no OSPF process is specified, OSPF neighbor information of all OSPF processes is displayed.
· If the verbose keyword is specified, detailed information about neighbors of the specified OSPF process or all OSPF processes is displayed.
· If an interface is specified, the neighbor on the interface is displayed.
· If a neighbor ID is specified, detailed information about the neighbor is displayed,
· If neither interface nor neighbor ID is specified, brief information about neighbors of the specified OSPF process or all OSPF processes is displayed.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
Neighbors
Area 0.0.0.0 interface 1.1.1.1(Vlan-interface11)'s neighbors
Router ID: 1.1.1.2 Address: 1.1.1.2 GR State: Normal
State: Full Mode: Nbr is Master Priority: 1
DR: 1.1.1.2 BDR: 1.1.1.1 MTU: 0
Dead timer due in 33 sec
Neighbor is up for 02:03:35
Table 10 Command output
Area areaID interface IPAddress(InterfaceName)'s neighbors |
Neighbor information of the interface in the specified area: · areaID—Area to which the neighbor belongs. · IPAddress—Interface IP address. · InterfaceName—Interface name. |
Router ID |
Neighbor router ID. |
Address |
Neighbor router address. |
GR State |
GR state. |
State |
Neighbor state: · Down—This is the initial state of a neighbor conversation. · Init—In this state, the router has seen a Hello packet from the neighbor. However, the router has not established bidirectional communication with the neighbor (the router itself did not appear in the neighbor's hello packet). · Attempt—Available only in an NBMA network, Under this state, the OSPF router has not received any information from a neighbor for a period but can send Hello packets with a longer interval to keep neighbor relationship. · 2-Way—In this state, communication between the two routers is bidirectional. The router itself appears in the neighbor's Hello packet. · Exstart—The goal of this state is to decide which router is the master, and to decide upon the initial Database Description (DD) sequence number. · Exchange—In this state, the router is sending DD packets to the neighbor, describing its entire link-state database. · Loading—In this state, the router sends Link State Request packets to the neighbor, requesting more recent LSAs. · Full—In this state, the neighboring routers are fully adjacent. |
Mode |
Neighbor mode for LSDB synchronization: · Nbr is Master—Means the neighboring router is the master. · Nbr is Slave—Means the neighboring router is the slave. |
Priority |
Neighboring router priority. |
DR |
BDR |
MTU |
Interface MTU. |
Dead timer due in 33 sec |
Dead timer times out in 33 seconds. |
Neighbor is up for 02:03:35 |
The neighbor has been up for 02:03:35. |
Authentication Sequence |
Authentication sequence number. |
Neighbor state change count |
Count of neighbor state changes. |
# Display brief OSPF neighbor information.
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time Interface State
1.1.1.2 1.1.1.2 1 40 Vlan11 Full/DR
Table 11 Command output
Area |
Neighbor area. |
Router ID |
Address |
Neighbor interface address. |
Pri |
Dead-Time |
Dead interval remained. |
Interface connected to the neighbor. |
State |
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading, or Full. |
display ospf peer statistics
display ospf [ process-id ] peer statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf peer statistics to display OSPF neighbor statistics.
If no OSPF process is specified, OSPF neighbor statistics of all OSPF processes is displayed.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
OSPF Process 1 with Router ID 10.3.1.1
Neighbor Statistics
Area ID Down Attempt Init 2-Way ExStart Exchange Loading Full Total
0.0.0.0 0 0 0 0 0 0 0 1 1
0.0.0.2 0 0 0 0 0 0 0 1 1
Total 0 0 0 0 0 0 0 2 2
Table 12 Command output
Area ID |
The state statistics of all the routers in the area to which the router belongs is displayed. |
Down |
Number of neighboring routers in Down state in the same area. |
Attempt |
Number of neighboring routers in Attempt state in the same area. |
Init |
Number of neighboring routers in Init state in the same area. |
2-Way |
Number of neighboring routers in 2-Way state in the same area. |
ExStart |
Number of neighboring routers in ExStart state in the same area. |
Exchange |
Number of neighboring routers in Exchange state in the same area. |
Loading |
Number of neighboring routers in Loading state in the same area. |
Full |
Number of neighboring routers in Full state in the same area. |
Total |
Total number of neighbors in the same state, namely, Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, or Full. |
display ospf request-queue
display ospf [ process-id ] request-queue [ interface-type interface-number ] [ neighbor-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
neighbor-id: Specifies a neighbor's router ID.
Use display ospf request-queue to display OSPF request queue information.
If no OSPF process is specified, the OSPF request queue information of all OSPF processes is displayed.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
The Router's Neighbor is Router ID 2.2.2.2 Address 10.1.1.2
Interface 10.1.1.1 Area 0.0.0.0
Request list:
Type LinkState ID AdvRouter Sequence Age
Router 2.2.2.2 1.1.1.1 80000004 1
Network 192.168.0.1 1.1.1.1 80000003 1
Sum-Net 192.168.1.0 1.1.1.1 80000002 2
Table 13 Command output
The Router's Neighbor is Router ID |
Address |
Neighbor interface IP address. |
Local interface IP address. |
Area |
Area ID. |
Request list |
Request list information. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
Advertising router. |
Sequence |
Age |
LSA age. |
display ospf retrans-queue
display ospf [ process-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf retrans-queue to display retransmission queue information.
If no OSPF process is specified, the retransmission queue information of all OSPF processes is displayed.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
Retransmit list:
Router 2.2.2.2 2.2.2.2 80000004 1
Network 12.18.0.1 2.2.2.2 80000003 1
Sum-Net 12.18.1.0 2.2.2.2 80000002 2
Table 14 Command output
Address |
Interface address of the router. |
Area |
Area ID. |
Retrans List |
Retransmission list. |
Type |
LSA type. |
LinkState ID |
Link state ID. |
AdvRouter |
Sequence |
Age |
LSA age. |
display ospf routing
display ospf [ process-id ] routing [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays routes passing the specified output interface.
nexthop nexthop-address: Displays OSPF routing information with the specified next hop.
Use display ospf routing to display OSPF routing information.
If no OSPF process is specified, the routing information of all OSPF processes is displayed.
# Display OSPF routing information.
<Sysname> display ospf routing
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
192.168.1.0/24 1562 Stub 192.168.1.2 192.168.1.2 0.0.0.0
172.16.0.0/16 1563 Inter 192.168.1.1 192.168.1.1 0.0.0.0
Total Nets: 2
Intra Area: 1 Inter Area: 1 ASE: 0 NSSA: 0
Table 15 Command output
Destination |
Destination network. |
Cost |
Cost to destination. |
Type |
Route type: intra-area, transit, stub, inter-area, type1 external, type2 external. |
NextHop |
Next hop address. |
AdvRouter |
Area |
Area ID. |
Total Nets |
Total networks. |
Intra Area |
Total intra-area routes. |
Inter Area |
Total inter-area routes. |
ASE |
Total ASE routes. |
NSSA |
Total NSSA routes. |
display ospf vlink
display ospf [ process-id ] vlink [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf vlink to display OSPF virtual link information.
If no OSPF process is specified, the OSPF virtual link information of all OSPF processes is displayed.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
Virtual Links
Virtual-link Neighbor-ID -> 2.2.2.2, Neighbor-State: Full
Interface: 10.1.2.1 (Vlan-interface11)
Cost: 1562 State: P-2-P Type: Virtual
Transit Area: 0.0.0.1
Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
MD5 authentication enabled.
The last key is 3.
The rollover is in progress, 1 neighbor(s) left.
Table 16 Command output
Virtual-link Neighbor-ID |
ID of the neighbor on the virtual link. |
Neighbor-State |
Neighbor State: Down, Init, 2-Way, ExStart, Exchange, Loading, Full. |
Local interface's IP address and name of the virtual link. |
Cost |
Interface route cost. |
State |
Interface state. |
Type |
Type: virtual link. |
Transit Area |
Transit area ID. |
Timers |
Values of timers: hello, dead, poll (NBMA), retransmit, and interface transmission delay. |
MD5 authentication enable |
Authentication mode configured for the virtual link. |
The last Key |
Latest MD5 authentication key ID. |
neighbor(s) left |
Number of neighbors that have not accomplished MD5 authentication key rollover. |
display router id
display router id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display router id to display the global router ID.
# Display the global router ID.
<Sysname> display router id
Configured router ID is 1.1.1.1
enable link-local-signaling
undo enable link-local-signaling
View
OSPF view
Default level
2: System level
None
Use enable link-local-signaling to enable the OSPF link-local signaling (LLC) capability.
Use undo enable link-local-signaling to disable the OSPF link-local signaling capability.
By default, this capability is disabled.
# Enable link-local signaling for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
enable log
enable log [ config | error | state ]
undo enable log [ config | error | state ]
View
OSPF view
Default level
2: System level
config: Enables configuration logging.
error: Enables error logging.
state: Enables state logging.
Use enable log to enable specified OSPF logging.
Use undo enable log to disable specified OSPF logging.
By default, OSPF logging is disabled.
If no keyword is specified, all logging is enabled.
# Enable OSPF logging.
[Sysname] ospf 100
[Sysname-ospf-100] enable log
undo enable out-of-band-resynchronization
View
OSPF view
Default level
2: System level
None
Use enable out-of-band-resynchronization to enable the OSPF out-of-band resynchronization (OOB-Resynch) capability.
Use undo enable out-of-band-resynchronization to disable the OSPF out-of-band resynchronization capability.
By default, the capability is disabled.
Before configuring this command, you must enable the link-local signaling capability.
Related commands: enable link-local-signaling.
# Enable the out-of-band resynchronization capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
fast-reroute
fast-reroute { auto [ abr-only ] | route-policy route-policy-name }
undo fast-reroute
View
OSPF view
Default level
2: System level
auto: Calculates a backup next hop automatically for all routes.
abr-only: Selects only the route to the ABR as the backup path.
route-policy route-policy-name: References a routing policy to designate a backup next hop. The route-policy-name argument is a string of 1 to 63 case-sensitive characters.
Use fast-reroute to configure OSPF fast reroute (FRR).
Use undo fast-reroute to restore the default.
By default, OSPF FRR is not configured.
IMPORTANT: · Do not use OSPF FRR and BFD (for OSPF) at the same time; otherwise, OSPF FRR might fail to take effect. · Do not use the fast-reroute auto command with the following commands: vlink-peer and sham-link, enable traffic-adjustment, and enable traffic-adjustment advertise in MPLS Command Reference. |
# Enable FRR to automatically calculate a backup next hop for all routes in OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] fast-reroute auto
# Enable FRR to designate a backup next hop by using routing policy frr for OSPF process 100.
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface Vlan-interface 1000 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] ospf 100
[Sysname-ospf-100] fast-reroute route-policy frr
filter
filter { acl-number | ip-prefix ip-prefix-name } { export | import }
View
OSPF area view
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters. For more information about IP prefix lists, see Layer 3—IP Routing Configuration Guide.
export: Filters Type-3 LSAs advertised to other areas.
import: Filters Type-3 LSAs advertised into the area.
Use filter to configure incoming/outgoing Type-3 LSAs filtering on an ABR.
Use undo filter to disable Type-3 LSA filtering.
By default, Type-3 LSAs filtering is disabled.
NOTE: This command is only available on an ABR. |
# Apply IP prefix list my-prefix-list to filter inbound Type-3 LSAs, and apply ACL 2000 to filter outbound Type-3 LSAs in OSPF Area 1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] filter ip-prefix my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
View
OSPF view
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter redistributed routes.
protocol: Specifies a protocol from which to filter redistributed routes. The protocol can be direct, static, rip, ospf, isis or bgp. If no protocol is specified, all redistributed routes are filtered.
process-id: Specifies a process by its ID, which is required when the protocol is rip, ospf or isis, in the range of 1 to 65535.
Use filter-policy export to configure the filtering of redistributed routes.
Use undo filter-policy export to disable the filtering.
By default, the filtering of redistributed routes is not configured.
You can use this command to filter redistributed routes as needed.
If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route while the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
# Filter redistributed routes using ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny ip source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter redistributed routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
filter-policy { acl-number [ gateway ip-prefix-name ] | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] | route-policy route-policy-name } import
undo filter-policy import
View
OSPF view
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter incoming routes.
gateway ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter routes based on the next hop of the routing information. For more information about IP prefix lists, see Layer 3—IP Routing Configuration Guide.
ip-prefix ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter incoming routes based on destination IP address. For more information about IP prefix lists, see Layer 3—IP Routing Configuration Guide.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter incoming routes based on routing policy. For more information about routing policy, see Layer 3—IP Routing Configuration Guide.
Use filter-policy import to configure the filtering of routes calculated from received LSAs.
Use undo filter-policy import to disable the filtering.
If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command or in the routing policy, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route while the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
By default, the filtering is not configured.
# Filter incoming routes using ACL 2000.
[Sysname-acl-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter incoming routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
graceful-restart (OSPF view)
graceful-restart [ ietf | nonstandard ]
undo graceful-restart
View
OSPF view
Default level
2: System level
ietf: Enables the IETF GR capability.
nonstandard: Enables the non-IETF GR capability.
Use graceful-restart to enable OSPF Graceful Restart capability.
Use undo graceful-restart to disable OSPF Graceful Restart capability.
By default, OSPF Graceful Restart capability is disabled.
Enable Opaque LSA advertisement and reception with the opaque-capability enable command before enabling the IETF GR capability for OSPF.
Before enabling non-IETF GR capability for OSPF, enable OSPF LLS (link local signaling) with the enable link-local-signaling command and OOB (out of band resynchronization) with the enable out-of-band-resynchronization command.
If the keywords nonstandard and ietf are not specified when OSPF GR is enabled, nonstandard is the default.
Do not configure OSPF NSR on a device that acts as a GR restarter. The graceful-restart command and the ospf non-stop-routing command are mutually exclusive and cannot be configured on a switch at the same time.
Related commands: enable link-local-signaling, enable out-of-band-resynchronization, and opaque-capability enable.
# Enable IETF Graceful Restart for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# Enable non-IETF Graceful Restart for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
graceful-restart help
graceful-restart help { acl-number | prefix prefix-list }
undo graceful-restart help
View
OSPF view
Default level
2: System level
acl-number: Specifies a basic or advanced ACL by its number in the range of 2000 to 3999.
prefix-list: Specifies an IP prefix list by its name, a string of 1 to 19 characters.
Use graceful-restart help to configure for which OSPF neighbors the current router can serve as a GR helper. (The neighbors are specified by the ACL or the IP prefix list.)
Use undo graceful-restart help to restore the default.
By default, the router can serve as a GR helper for any OSPF neighbor.
# Enable IETF standard GR for OSPF process 1 and configure the router as a GR helper for OSPF neighbors defined in the ACL 2001.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart help 2001
# Enable non IETF standard GR for OSPF process 1 and configure the router as a GR helper for OSPF neighbors defined in the ACL 2001.
[Sysname] ospf 1
graceful-restart interval interval-value
undo graceful-restart interval
View
OSPF view
Default level
2: System level
interval-value: Specifies the Graceful Restart interval in the range of 40 to 1800 seconds.
Use graceful-restart interval to configure the Graceful Restart interval.
Use undo graceful-restart interval to restore the default Graceful Restart interval.
By default, the Graceful Restart interval is 120 seconds.
The Graceful Restart interval of OSPF cannot be less than the maximum value of dead intervals on all OSPF interfaces; otherwise, the Graceful Restart of OSPF might fail.
Related commands: ospf timer dead.
# Configure the Graceful Restart interval for OSPF process 1 as 100 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
host-advertise
host-advertise ip-address cost
undo host-advertise ip-address
View
OSPF area view
Default level
2: System level
ip-address: Specifies the IP address of a host
cost: Specifies a cost for the route, in the range of 1 to 65535.
Use host-advertise to advertise a host route.
Use undo host-advertise to remove a host route.
By default, no host route is advertised.
# Advertise route 1.1.1.1 with a cost of 100.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
import-route (OSPF view)
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | type type | tag tag | route-policy route-policy-name ] *
View
OSPF view
Default level
2: System level
protocol: Redistributes routes from the specified protocol, which can be bgp, direct, isis, ospf, rip, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default is 1. It is available only when the protocol is rip, ospf, or isis.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows IBGP routes redistribution. It is optional only when the protocol is bgp.
cost cost: Specifies a route cost in the range of 0 to 16777214. The default is 1.
type type: Specifies a cost type, 1 or 2. The default is 2.
tag tag: Specifies a tag for external LSAs, in the range of 0 to 4294967295. The default is 1.
route-policy route-policy-name: Specifies a routing policy to redistribute qualified routes only. A routing policy name is a string of up to 63 case-sensitive characters.
Use import-route to redistribute routes from another protocol.
Use undo import-route to disable route redistribution from a protocol.
By default, route redistribution from another protocol is not configured.
OSPF prioritize routes as follows:
· Intra-area route
· Inter-area route
· Type1 External route
· Type2 External route
An intra-area route is a route in an OSPF area. An inter-area route is between any two OSPF areas. Both of them are internal routes.
An external route is a route to a destination outside the OSPF AS.
A Type-1 external route has high reliability and its cost is comparable with the cost of OSPF internal routes. Therefore, the cost from an OSPF router to a Type-1 external route's destination equals the cost from the router to the corresponding ASBR plus the cost from the ASBR to the external route's destination.
A Type-2 external route has low credibility, so OSPF considers the cost from the ASBR to a Type-2 external route is much bigger than the cost from the ASBR to an OSPF internal router. Therefore, the cost from an internal router to a Type-2 external route's destination equals the cost from the ASBR to the Type-2 external route's destination.
Related commands: default-route-advertise.
The import-route command cannot redistribute default routes.
Use the import-route bgp allow-ibgp command with care, because it redistributes both EBGP and IBGP routes that might cause routing loops.
Only active routes can be redistributed. You can use the display ip routing-table protocol command to display route state information.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute routes from RIP process 40 and specify the type, tag, and cost as 2, 33 and 50 for redistributed routes.
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
ispf enable
ispf enable
undo ispf enable
View
OSPF view
Default level
2: System level
None
Use ispf enable to enable OSPF ISPF.
Use undo ispf enable to disable OSPF ISPF.
By default, OSPF ISPF is disabled.
When a network topology is changed, ISPF allows the system to recompute only the affected part of the shortest path tree (SPT), instead of the entire SPT.
# Enable OSPF ISPF.
[Sysname] ospf 100
[Sysname-ospf-100] ispf enable
log-peer-change
log-peer-change
undo log-peer-change
View
OSPF view
Default level
2: System level
None
Use log-peer-change to enable the logging of OSPF neighbor state changes.
Use undo log-peer-change to disable the logging.
By default, the logging is enabled.
With this feature enabled, information about neighbor state changes is displayed on the terminal.
# Disable the logging of neighbor state changes for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
lsa-arrival-interval
lsa-arrival-interval interval
undo lsa-arrival-interval
View
OSPF view
Default level
2: System level
interval: Specifies the LSA arrival interval in milliseconds, in the range of 0 to 60000.
Use lsa-arrival-interval to specify the LSA arrival interval.
Use undo lsa-arrival-interval to restore the default.
The interval defaults to 1000 milliseconds.
If an LSA that has the same LSA type, LS ID, originating router ID with the previous LSA is received within the interval, the LSA will be discarded. This feature helps protect routers and bandwidth from being over-consumed due to frequent network changes.
H3C recommends setting the interval with the lsa-arrival-interval command to be smaller than or equal to the initial interval set with the lsa-generation-interval command.
Related commands: lsa-generation-interval.
# Set the LSA arrival interval to 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-arrival-interval 200
lsa-generation-interval maximum-interval [ initial-interval [ incremental-interval ] ]
undo lsa-generation-interval
View
OSPF view
Default level
2: System level
maximum-interval: Specifies the maximum LSA generation interval in seconds, in the range of 1 to 60. The default is 5.
initial-interval: Specifies the minimum LSA generation interval in milliseconds, in the range of 10 to 60000. The default is 0, that is, no limit to the minimum LSA generation interval.
incremental-interval: Specifies the LSA generation incremental interval in milliseconds, in the range of 10 to 60000. The default is 5000 milliseconds.
Use lsa-generation-interval to configure the OSPF LSA generation interval.
Use undo lsa-generation-interval to restore the default.
By default, the maximum LSA generation interval is 5 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 5000 milliseconds.
With this command configured, when network changes are not frequent, LSAs are generated at the initial-interval. If network changes become frequent, LSA generation interval is incremented by a specified value each time a generation happens, up to the maximum-interval.
Related commands: lsa-arrival-interval.
# Configure the maximum LSA generation interval as 2 seconds, minimum interval as 100 milliseconds and incremental interval as 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
lsdb-overflow-limit
lsdb-overflow-limit number
undo lsdb-overflow-limit
View
OSPF view
Default level
2: System level
number: Specifies the upper limit of external LSAs in the LSDB, in the range of 1 to 1000000.
Use lsdb-overflow-limit to specify the upper limit of external LSAs in the LSDB.
Use undo lsdb-overflow-limit to restore the default.
By default, external LSAs in the LSDB are not limited.
# Specify the upper limit of external LSAs as 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
maximum load-balancing (OSPF view)
maximum load-balancing maximum
undo maximum load-balancing
View
OSPF view
Default level
2: System level
maximum: Specifies the maximum number of ECMP routes. The value range depends on the system operating mode:
· The value range is 1 to 32 when the switch operates in standard mode, enhanced Layer 2 mode, enhanced Layer 3 mode, or advanced mode.
· The value range is 1 to 16 when the switch operates in standard hybrid mode, enhanced Layer 2 hybrid mode, enhanced Layer 3 hybrid mode, or advanced hybrid mode.
For more information about system operating modes, see Fundamentals Configuration Guide.
Use maximum load-balancing to specify the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
By default, the maximum number of ECMP routes depends on the system operating mode:
· The maximum number of ECMP routes is 32 when the switch operates in standard mode, enhanced Layer 2 mode, enhanced Layer 3 mode, or advanced mode.
· The maximum number of ECMP routes is 16 when the switch operates in standard hybrid mode, enhanced Layer 2 hybrid mode, enhanced Layer 3 hybrid mode, or advanced hybrid mode.
# Specify the maximum number of ECMP routes as 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
network (OSPF area view)
undo network ip-address wildcard-mask
View
OSPF area view
Default level
2: System level
ip-address: Specifies the IP address of a network.
wildcard-mask: Specifies the wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
Use network to enable OSPF on the interface attached to the specified network in the area.
Use undo network to disable OSPF for the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
You can configure one or multiple interfaces in an area to run OSPF. The interface's primary IP address must be in the specified network segment to make the interface run OSPF. If only the interface's secondary IP address is in the network segment, the interface cannot run OSPF.
Related commands: ospf.
# Specify the interface whose primary IP address is on network 131.108.20.0/24 to run OSPF in Area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
nssa
nssa [ default-route-advertise | no-import-route | no-summary | translate-always | translator-stability-interval value ] *
undo nssa
View
OSPF area view
Default level
2: System level
default-route-advertise: Usable on an NSSA ABR or an ASBR only. If it is configured on an NSSA ABR, the ABR generates a default route in a Type-7 LSA into the NSSA regardless of whether the default route is available. If it is configured on an ASBR, only a default route is available on the ASBR can it generates the default route in a Type-7 LSA into the attached area.
no-import-route: Usable only on an NSSA ABR that is also the ASBR of the OSPF routing domain to disable redistributing routes in Type-7 LSAs into the NSSA area, making sure that routes can be redistributed correctly.
no-summary: Usable only on an NSSA ABR to advertise only a default route in a Type-3 summary LSA into the NSSA area. In this way, all the other summary LSAs are not advertised into the area. Such an area is a totally NSSA area.
translate-always: Specifies the NSSA ABR as a translator to translate Type-7 LSAs to Type-5 LSAs.
translator-stability-interval value: Specifies the stability interval of the translator, that is, the interval during which the translator can maintain its translating capability after a switch with a higher priority becomes a new translator. The value argument is the stability interval in the range of 0 to 900 seconds and defaults to 0 (which means the translator does not maintain its translating capability when a new translator arises).
Use nssa to configure the current area as an NSSA area.
Use undo nssa to restore the default.
By default, no NSSA area is configured.
All routers attached to an NSSA area must be configured with the nssa command in area view.
Related commands: default-cost.
# Configure Area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] nssa
undo opaque-capability
View
OSPF view
Default level
2: System level
None
Use opaque-capability enable to enable opaque LSA advertisement and reception. With the command configured, the OSPF switch can receive and advertise the Type-9, Type-10 and Type-11 opaque LSAs.
Use undo opaque-capability to restore the default.
By default, the feature is disabled.
# Enable advertising and receiving opaque LSAs.
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
ospf
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
undo ospf [ process-id ]
View
Default level
2: System level
router-id router-id: Specifies an OSPF router ID in dotted decimal notation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN that the OSPF process belongs to. vpn-instance-name is a case-sensitive string of 1 to 31 characters.
Use ospf to enable an OSPF process.
Use undo ospf to disable an OSPF process.
By default, no OSPF process is enabled.
You can enable multiple OSPF processes on a router and specify different Router IDs for these processes.
Enabling OSPF first is required before performing other tasks.
# Enable OSPF process 100 and specify Router ID 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
ospf authentication-mode
For MD5/HMAC-MD5 authentication:
ospf authentication-mode { hmac-md5 | md5 } key-id [ cipher | plain ] password
undo ospf authentication-mode { hmac-md5 | md5 } key-id
For simple authentication:
ospf authentication-mode simple [ cipher | plain ] password
undo ospf authentication-mode simple
View
Interface view
Default level
2: System level
hmac-md5: Specifies HMAC-MD5 authentication.
md5: Specifies MD5 authentication.
simple: Specifies simple authentication.
key-id: Specifies an authentication key ID in the range of 1 to 255.
cipher: Sets a ciphertext password.
plain: Sets a plaintext password.
password: Sets the authentication password. This argument is case sensitive. For simple authentication mode, it is plaintext string of 1 to 8 characters, or a ciphertext string of 1 to 41 characters. For MD5/HMAC-MD5 authentication mode, it is a plaintext string of 1 to 16 characters, or a ciphertext string of 1 to 53 characters.
Use ospf authentication-mode to set the authentication mode and key ID on an interface.
Use undo ospf authentication-mode to remove specified configuration.
By default, no authentication is available on an interface.
Interfaces attached to the same network segment must have the same authentication password. You can specify either MD5/HMAC-MD5 authentication mode or simple authentication mode for an interface. When you specify the MD5/HMAC-MD5 authentication mode, you can execute the command multiple times to configure different key IDs.
If you configure interface authentication and area authentication at the same time, OSPF receives only the packets that pass interface authentication.
Related commands: authentication-mode.
# Configure VLAN-interface 10 to support MD5 authentication, and set the interface key ID to 15 and plaintext authentication password to abc.
[Sysname-Vlan-interface10] ospf authentication-mode md5 15 plain abc
# Configure VLAN-interface 10 to support simple authentication, and set for the interface the plaintext authentication password to abc.
[Sysname-Vlan-interface10] ospf authentication-mode simple plain abc
ospf bfd enable
ospf bfd enable [ echo ]
undo ospf bfd enable
View
Interface view
Default level
2: System level
echo: Configures BFD echo packet single-hop detection. If this keyword is not specified, BFD control packet bidirectional detection is enabled.
Use ospf bfd enable to enable BFD for link failure detection on an OSPF interface.
Use undo ospf bfd enable to disable BFD on an OSPF interface.
By default, an OSPF interface is not enabled with BFD.
# Enable OSPF and BFD on VLAN-interface 11.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.255.255
[Sysname-Vlan-interface11] ospf bfd enable
ospf cost
ospf cost value
undo ospf cost
View
Interface view
Default level
2: System level
value: Specifies an OSPF cost in the range of 0 to 65535 for a loopback interface and 1 to 65535 for other interfaces.
Use ospf cost to set an OSPF cost for the interface.
Use undo ospf cost to restore the default.
The default cost depends on the interface type: 1 for a VLAN interface; 0 for a loopback interface; computed according to the bandwidth for other interfaces with the formula: Interface OSPF cost = Bandwidth reference value (100 Mbps) ÷ Interface bandwidth (Mbps).
If the calculated cost is greater than 65535, the value of 65535 is used; if the calculated cost is smaller than 1, the value of 1 is used.
# Set the OSPF cost for the interface to 65.
[Sysname-Vlan-interface10] ospf cost 65
ospf dr-priority
ospf dr-priority priority
undo ospf dr-priority
View
Interface view
Default level
2: System level
priority: Specifies the DR priority of the interface, in the range of 0 to 255.
Use ospf dr-priority to set the priority for DR/BDR election on an interface.
Use undo ospf dr-priority to restore the default value.
By default, the priority is 1.
The bigger the value, the higher the priority. If a switch has a priority of 0, it will not be elected as a DR or BDR.
# Set the DR priority on the current interface to 8.
[Sysname-Vlan-interface10] ospf dr-priority 8
ospf mib-binding
ospf mib-binding process-id
undo ospf mib-binding
View
Default level
2: System level
Use ospf mib-binding to bind an OSPF process to MIB operation for responding to SNMP requests.
Use undo ospf mib-binding to restore the default.
By default, MIB operation is bound to the OSPF process with the smallest process ID.
# Bind OSPF process 100 to MIB operation.
[Sysname] ospf mib-binding 100
# Restore the default, that is, bind the OSPF process with the smallest process ID to MIB operation.
[Sysname] undo ospf mib-binding
ospf mtu-enable
ospf mtu-enable
undo ospf mtu-enable
View
Interface view
Default level
2: System level
None
Use ospf mtu-enable to enable an interface to add the real MTU into DD packets.
Use undo ospf mtu-enable to restore the default.
By default, an interface adds a MTU of 0 into DD packets, that is, no real MTU is added.
After a virtual link is established through a Virtual-Template or Tunnel, two switches on the link from different vendors might have different MTU values. To make them consistent, set the attached interfaces' default MTU to 0.
After this command is configured, upon receiving a DD packet, the interface checks whether the MTU in the packet is greater than its own MTU; if yes, the interface discards the packet.
# Enable the interface to add the real MTU value into DD packets.
[Sysname-Vlan-interface10] ospf mtu-enable
ospf network-type
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ peer-address-check ] }
undo ospf network-type
View
Interface view
Default level
2: System level
broadcast: Specifies the network type as Broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
unicast: Specifies the P2MP interface to unicast OSPF packets. By default, a P2MP interface multicasts OSPF packets.
p2p: Specifies the network type as P2P.
peer-address-check: Checks whether the peer address is on the same subnet when the network type of the OSPF interface is P2P.
Use ospf network-type to set the network type for an interface.
Use undo ospf network-type to restore the default network type for an interface.
By default, the network type of an interface depends on its link layer protocol.
If a router on a broadcast network does not support multicast, you can configure the interface's network type as NBMA.
If any two routers on an NBMA network are directly connected through a virtual link, that is, the network is fully meshed, you can configure the network type as NBMA; otherwise you need to configure it as P2MP for two routers having no direct link to exchange routing information through another router.
When the network type of an interface is NBMA or P2MP unicast, you need to use the peer command to specify a neighbor.
If only two routers run OSPF on a network segment, you can configure associated interfaces' network type as P2P.
When the network type of an interface is P2MP unicast, all OSPF packets are sent out of the interface through unicast.
Related commands: ospf dr-priority.
# Configure the interface's network type as NBMA.
[Sysname-Vlan-interface10] ospf network-type nbma
undo ospf non-stop-routing
View
Default level
2: System level
None
Use ospf non-stop-routing to enable OSPF NSR.
Use undo ospf non-stop-routing to disable OSPF NSR.
By default, OSPF NSR is disabled.
IMPORTANT: A device enabled with OSPF NSR cannot act as a GR restarter. The opaque-capability enable or graceful-restart command and the ospf non-stop-routing command are mutually exclusive and cannot be configured on a switch at the same time. |
# Enable OSPF NSR.
[Sysname] ospf non-stop-routing
ospf packet-process prioritized-treatment
undo ospf packet-process prioritized-treatment
View
Default level
2: System level
None
Use ospf packet-process prioritized-treatment to enable OSPF to give priority to receiving and processing Hello packets.
Use undo ospf packet-process prioritized-treatment to restore the default.
By default, this function is not enabled.
# Enable OSPF to give priority to receiving and processing Hello packets.
[Sysname] ospf packet-process prioritized-treatment
ospf timer dead
ospf timer dead seconds
undo ospf timer dead
View
Interface view
Default level
2: System level
seconds: Specifies the dead interval in seconds, in the range of 1 to 2147483647.
Use ospf timer dead to set the dead interval.
Use undo ospf timer dead to restore the default.
The dead interval defaults to 40 seconds for Broadcast, P2P interfaces and defaults to 120 seconds for P2MP and NBMA interfaces.
If an interface receives no hello packet from the neighbor within the dead interval, the interface considers the neighbor down. The dead interval on an interface is at least four times the hello interval. Any two routers attached to the same segment must have the same dead interval.
Related commands: ospf timer hello.
# Configure the dead interval on the current interface as 60 seconds.
[Sysname-Vlan-interface10] ospf timer dead 60
ospf timer hello
ospf timer hello seconds
undo ospf timer hello
View
Interface view
Default level
2: System level
seconds: Specifies the hello interval in seconds, in the range of 1 to 65535.
Use ospf timer hello to set the hello interval on an interface.
Use undo ospf timer hello to restore the default hello interval on an interface.
The hello interval defaults to 10 seconds for P2P and Broadcast interfaces, and defaults to 30 seconds for P2MP and NBMA interfaces.
The shorter the hello interval is, the faster the topology converges and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Configure the hello interval on the current interface as 20 seconds.
[Sysname-Vlan-interface10] ospf timer hello 20
ospf timer poll
ospf timer poll seconds
undo ospf timer poll
View
Interface view
Default level
2: System level
seconds: Specifies the poll interval in seconds, in the range of 1 to 2147483647.
Use ospf timer poll to set the poll interval on an NBMA interface.
Use undo ospf timer poll to restore the default value.
By default, the poll interval is 120 seconds.
When an NBMA interface finds its neighbor is down, it will send hello packets at the poll interval.
IMPORTANT: The poll interval must be at least four times the hello interval. |
# Set the poll timer interval on the current interface to 130 seconds.
[Sysname-Vlan-interface10] ospf timer poll 130
ospf timer retransmit
ospf timer retransmit interval
undo ospf timer retransmit
View
Interface view
Default level
2: System level
interval: Specifies the LSA retransmission interval in seconds, in the range of 1 to 3600.
Use ospf timer retransmit to set the LSA retransmission interval on an interface.
Use undo ospf timer retransmit to restore the default.
The interval defaults to 5 seconds.
After sending an LSA, an interface waits for an acknowledgement packet. If the interface receives no acknowledgement within the retransmission interval, it will retransmit the LSA.
The retransmission interval should not be so small to avoid unnecessary retransmissions.
# Set the LSA retransmission interval to 8 seconds.
[Sysname-Vlan-interface10] ospf timer retransmit 8
ospf trans-delay
ospf trans-delay seconds
undo ospf trans-delay
View
Interface view
Default level
2: System level
seconds: Specifies the LSA transmission delay in seconds, in the range of 1 to 3600.
Use ospf trans-delay to set the LSA transmission delay on an interface.
Use undo ospf trans-delay to restore the default.
By default, the LSA transmission delay is 1 second.
Each LSA in the LSDB has an age that is incremented by 1 every second, but the age does not change during transmission. It is necessary to add a transmission delay into its age time, which is important for low speed networks.
# Set the LSA transmission delay to 3 seconds on the current interface.
[Sysname-Vlan-interface10] ospf trans-delay 3
peer
peer ip-address [ cost value | dr-priority dr-priority ]
undo peer ip-address
View
OSPF view
Default level
2: System level
ip-address: Specifies a neighbor by its IP address.
cost value: Specifies the cost to reach the neighbor, in the range of 1 to 65535.
dr-priority dr-priority: Specifies the DR priority of the neighbor, in the range of 0 to 255. The default is 1.
Use peer to specify a neighbor, and the DR priority of the neighbor.
Use undo peer to remove the configuration.
On an X.25 or Frame Relay network, you can configure mappings to make the network fully meshed (any two routers have a direct link in between), so OSPF can handle DR/BDR election as it does on a broadcast network. However, since routers on the network cannot find neighbors by broadcasting hello packets, you need to specify neighbors and neighbor DR priorities on the routers.
After startup, a router sends a hello packet to neighbors with DR priorities higher than 0. When the DR and BDR are elected, the DR will send hello packets to all neighbors for adjacency establishment.
The cost set with the peer command is the cost to the specified neighbor on the P2MP link. If no cost is specified, the cost to the neighbor equals the local interface's cost.
A router uses the priority set with the peer command to determine whether to send a hello packet to the neighbor rather than for DR election. The DR priority set with the ospf dr-priority command is used for DR election.
# Specify the neighbor 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
preference
preference [ ase ] [ route-policy route-policy-name ] value
undo preference [ ase ]
View
OSPF view
Default level
2: System level
ase: Sets a priority for ASE routes. If the keyword is not specified, using the command sets a priority for OSPF internal routes.
route-policy route-policy-name: Applies a routing policy to set priorities for specified routes. A route-policy-name is a string of 1 to 63 case-sensitive characters.
value: Specifies the priority value in the range of 1 to 255. A smaller value represents a higher priority.
Use preference to set the priority of OSPF routes.
Use undo preference to restore the default.
The priority of OSPF internal routes defaults to 10, and the priority of OSPF external routes defaults to 150.
If a routing policy is specified, priorities defined by the routing policy will apply to matching routes, and the priorities set with the preference command apply to OSPF routes not matching the routing policy.
A router might run multiple routing protocols. When several routing protocols find routes to the same destination, the router uses the route found by the protocol with the highest priority.
# Set a priority of 200 for OSPF external routes.
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
reset ospf counters
reset ospf [ process-id ] counters [ neighbor [ interface-type interface-number ] [ router-id ] ]
View
Default level
1: Monitor level
process-id: Clears the statistics of the specified OSPF process, which is in the range of 1 to 65535.
neighbor: Clears neighbor statistics.
interface-type interface-number: Clears the statistics of the neighbor connected to the specified interface.
router-id: Clears the statistics of the specified neighbor.
Use reset ospf counters to clear OSPF statistics.
# Clear OSPF statistics.
<Sysname> reset ospf counters
reset ospf process
View
Default level
2: System level
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535.
graceful-restart: Resets the OSPF process using GR.
Use reset ospf process to reset all OSPF processes or a specified process.
The reset ospf process command can do the following:
· Clear all invalid LSAs without waiting for their timeouts.
· Make a newly configured Router ID take effect.
· Start a new round of DR/BDR election.
· Not remove any previous OSPF configurations.
The system prompts whether to reset OSPF process upon execution of this command.
# Reset all OSPF processes.
<Sysname> reset ospf process
Warning : Reset OSPF process? [Y/N]:Y
# Reset all OSPF processes using GR.
<Sysname> reset ospf process graceful-restart
reset ospf redistribution
View
Default level
2: System level
Use reset ospf redistribution to restart route redistribution.
If no process ID is specified, using the command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
rfc1583 compatible
rfc1583 compatible
undo rfc1583 compatible
View
OSPF view
Default level
2: System level
None
Use rfc1583 compatible to enable compatibility with RFC 1583.
Use undo rfc1583 compatible to disable the function.
By default, compatibility with RFC 1583 is enabled.
RFC 1583 and RFC 2328 use different rules for selecting the best route among multiple AS external routes destined for the same network. Using this command can make them compatible. If RFC 2328 is compatible with RFC 1583, the intra-area route in the backbone area is preferred, if not, the intra-area route in the non-backbone area is preferred to reduce the burden of the backbone area.
# Disable compatibility with RFC 1583.
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
router id
router id router-id
undo router id
View
Default level
2: System level
router-id: Specifies the router ID, in the form of a dotted decimal IPv4 address.
Use router id to configure a global router ID.
Use undo router id to remove the global router ID.
By default, no global router ID is configured.
Some routing protocols use a router ID to identify a device. You can configure a global router ID, which is used by routing protocols that have no router ID configured.
If no global router ID is configured, the highest loopback interface IP address, if any, is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status.
During an active/standby switchover, the standby main processing unit (MPU) checks whether the previous router ID that is backed up before switchover is valid. If not, it selects a new router ID.
If the interface whose IP address is the router ID is removed or modified, a new router ID is selected. Other events, (the interface goes down; after a physical interface address is selected as the router ID, an IP address is configured for a loopback interface; a higher interface IP address is configured) will not trigger a router ID re-selection.
After a router ID is changed, you need to use the reset ospf process command to make it effective.
# Configure a global router ID.
[Sysname] router id 1.1.1.1
silent-interface (OSPF view)
View
OSPF view
Default level
2: System level
all: Disables all interfaces from sending OSPF packets.
Use silent-interface to disable an interface or all interfaces from receiving and sending OSPF packets.
Use undo silent-interface to restore the default.
By default, an interface receives and sends OSPF packets.
A disabled interface is a passive interface, which cannot receive or send any hello packet.
To make no routing information obtained by other routers on a network segment, you can use this command to disable the interface from receiving and sending OSPF packets.
# Disable an interface from receiving and sending OSPF packets.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface vlan-interface 10
snmp-agent trap enable ospf
snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
undo snmp-agent trap enable ospf [ process-id ] [ ifauthfail | ifcfgerror | ifrxbadpkt | ifstatechange | iftxretransmit | lsdbapproachoverflow | lsdboverflow | maxagelsa | nbrstatechange | originatelsa | vifcfgerror | virifauthfail | virifrxbadpkt | virifstatechange | viriftxretransmit | virnbrstatechange ] *
View
Default level
3: Manage level
ifauthfail: Interface authentication failure information.
ifcfgerror: Interface configuration error information.
ifrxbadpkt: Information about error packets received.
ifstatechange: Interface state change information.
iftxretransmit: Packet receiving and forwarding information.
lsdbapproachoverflow: Information about cases approaching LSDB overflow.
lsdboverflow: LSDB overflow information.
maxagelsa: LSA max age information.
nbrstatechange: Neighbor state change information.
originatelsa: Information about LSAs originated locally.
vifcfgerror: Virtual interface configuration error information.
virifauthfail: Virtual interface authentication failure information.
virifrxbadpkt: Information about error packets received by virtual interfaces.
virifstatechange: Virtual interface state change information.
viriftxretransmit: Virtual interface packet retransmission information.
virnbrstatechange: Virtual interface neighbor state change information.
Use snmp-agent trap enable ospf to enable the sending of SNMP traps for a specified OSPF process. If no process is specified, the feature is enabled for all processes.
Use undo snmp-agent trap enable ospf to disable the feature.
By default, this feature is enabled.
For related information, see Network Management and Monitoring Command Reference.
# Enable the sending of SNMP traps for OSPF process 1.
[Sysname] snmp-agent trap enable ospf 1
spf-schedule-interval
undo spf-schedule-interval
View
OSPF view
Default level
2: System level
maximum-interval: Specifies the maximum OSPF route calculation interval in seconds, in the range of 1 to 60.
minimum-interval: Specifies the minimum OSPF route calculation interval in milliseconds, in the range of 10 to 60000, which defaults to 0.
incremental-interval: Specifies the incremental value in milliseconds, in the range of 10 to 60000, which defaults to 5000.
Use spf-schedule-interval to set the OSPF SPF calculation interval.
Use undo spf-schedule-interval to restore the default.
By default, the interval is 5 seconds.
Based on its LSDB, an OSPF router calculates the shortest path tree with itself being the root, and uses it to determine the next hop to a destination. Through adjusting the SPF calculation interval, you can protect bandwidth and router resources from being over-consumed due to frequent network changes.
With this command configured, when network changes are not frequent, SPF calculation applies at the minimum-interval. If network changes become frequent, the SPF calculation interval is incremented by the incremental-interval each time a calculation happens, up to the maximum-interval.
# Configure the SPF calculation maximum interval as 10 seconds, minimum interval as 500 milliseconds and incremental interval as 200 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 200
stub (OSPF area view)
undo stub
View
OSPF area view
Default level
2: System level
default-route-advertise-always: Usable only on a stub ABR. With this keyword, the ABR advertises a default route in a Type-3 LSA into the stub area regardless of whether FULL-state neighbors exist in the backbone area. Without this keyword, the ABR advertises a default route in a Summary LSA into the stub area only when at least one FULL-state neighbor exists in the backbone area.
no-summary: Usable only on a stub ABR. With this keyword, the ABR advertises only a default route in a Type-3 LSA into the stub area (such a stub area is known as a totally stub area).
Use stub to configure an area as a stub area.
Use undo stub to remove the configuration.
By default, no area is stub area.
To cancel the no-summary configuration on the ABR, simply execute the stub command again to overwrite it.
To configure an area as a stub area, all routers attached to it must be configured with this command.
# Configure Area 1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
stub-router
stub-router
undo stub-router
View
OSPF view
Default level
2: System level
None
Use stub-router to configure the router as a stub router.
Use undo stub-router to restore the default.
By default, no router is configured as a stub router.
The router LSAs from the stub router might contain different link type values. A value of 3 means a link to the stub network, so the cost of the link remains unchanged. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network or a virtual link; in such cases, a maximum cost value of 65535 is used. Thus, other neighbors find the links to the stub router have such big costs, they will not send packets to the stub router for forwarding as long as there is a route with a smaller cost.
# Configure a stub router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
transmit-pacing
undo transmit-pacing
View
OSPF view
Default level
2: System level
interval: Specifies the interval at which an interface sends LSU packets, in milliseconds. The value range is 10 to 1000. If the router has a number of OSPF interfaces, increase this interval to reduce the total numbers of LSU packets sent by the router every second.
count: Specifies the maximum number of LSU packets sent by an interface at each interval. The value range is 1 to 200. If the router has a number of OSPF interfaces, decrease this interval to reduce the total numbers of LSU packets sent by the router every second.
Use transmit-pacing to configure the maximum number of LSU packets that can be sent every the specified interval.
Use undo transmit-pacing to restore the default.
By default, an OSPF interface sends up to three LSU packets every 20 milliseconds.
# Configure all the interfaces under OSPF process 1 to send up to 10 LSU packets every 30 milliseconds.
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
vlink-peer (OSPF area view)
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | { simple cipher | plain ] password | { hmac-md5 | md5 } key-id [ cipher | plain ] password } ] *
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead | { simple | { hmac-md5 | md5 } key-id } ] *
View
OSPF area view
Default level
2: System level
router-id: Specifies the router ID of the neighbor on the virtual link.
hello seconds: Specifies the hello interval in seconds, in the range of 1 to 8192. The default is 10. It must be identical to the hello interval on its virtual link neighbor.
retransmit seconds: Specifies the retransmission interval in seconds, in the range of 1 to 3600, which defaults to 5.
trans-delay seconds: Specifies the transmission delay interval in seconds, in the range of 1 to 3600, which defaults to 1.
dead seconds: Specifies the dead interval in seconds, in the range of 1 to 32768, which defaults to 40 and is identical to the value on its virtual link neighbor. The dead interval is at least four times the hello interval.
simple: Specifies the simple authentication.
key-id: Specifies a key ID for MD5 or HMAC-MD5 authentication, in the range of 1 to 255.
password: Sets the authentication password. This argument is case sensitive. For simple authentication mode, it is a plaintext string of 1 to 8 characters, or a ciphertext string of 1 to 41 characters. For MD5/HMAC-MD5 authentication mode, it is a plaintext string of 1 to 16 characters, or a ciphertext string of 1 to 53 characters.
Use vlink-peer to configure a virtual link.
Use undo vlink-peer to remove a virtual link.
As defined in RFC 2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
Considerations on parameters:
· The smaller the hello interval is, the faster the network converges and the more network resources are consumed.
· A so small retransmission interval will lead to unnecessary retransmissions. A big value is appropriate for a low speed link.
· You need to specify an appropriate transmission delay with the trans-delay keyword.
You can specify either MD5/HMAC-MD5 authentication mode or simple authentication mode for a virtual link. When you specify the MD5/HMAC-MD5 authentication mode, you can execute the command multiple times to configure different key IDs.
If you configure virtual link authentication and backbone area authentication at the same time, OSPF receives only the packets that pass virtual link authentication.
Related commands: authentication-mode and display ospf vlink.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
