07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
08-Guard Route Commands
08-Guard Route Commands 43.78 KB
ip route-guard
ip route-guard ip-address mask
undo ip route-guard ip-address mask
View
Default level
2: System level
ip-address: Specifies the destination IP address, in dotted decimal notation.
mask: Specifies the mask of the IP address, in dotted decimal notation.
Use ip route-guard to configure a Guard route.
Use undo ip route-guard to remove a Guard route.
By default, no Guard route is configured.
# Configure a Guard route with a destination address of 11.11.11.11.
[Sysname] ip route-guard 11.11.11.11 255.255.255.255
