04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18204-Layer 2 - LAN Switching Command Reference
09-GVRP Commands
09-GVRP Commands 105.04 KB
display garp statistics
display garp statistics [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-list: Displays the GARP statistics of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display garp statistics to display the GARP statistics of the specified ports. If no ports are specified, this command displays the GARP statistics for all ports.
This command displays the statistics about GVRP PDUs received, transmitted, and dropped on GVRP-enabled ports. When the system is restarted or after you perform the reset garp statistics command, the existing packet statistics are cleared and the system starts to collect new GARP statistics. With the statistics, you can judge whether a GVRP-enabled port is operating correctly.
·     If the number of received and transmitted GVRP PDUs on the port is the same as the remote port, it indicates that the two ends are transmitting and receiving GVRP PDUs correctly and no registration information is lost.
·     If GVRP PDU drop occurs on the port, you should check its registration mode. GVRP PDUs are likely to be dropped if the registration mode is fixed or forbidden, because dynamic VLANs cannot be registered in these two modes.
Related commands: reset garp statistics.
# Display GARP statistics on ports GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
<Sysname> display garp statistics interface GigabitEthernet 3/0/1 to GigabitEthernet 3/0/2
         GARP statistics on port GigabitEthernet3/0/1
         Number of GVRP Frames Received          : 5
         Number of GVRP Frames Transmitted       : 2
         Number of Frames Discarded              : 1
         GARP statistics on port GigabitEthernet3/0/2
         Number of GVRP Frames Received          : 3
         Number of GVRP Frames Transmitted       : 4
         Number of Frames Discarded              : 2
display garp timer
display garp timer [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-list: Displays the GARP timer settings of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
Use display garp timer to display GARP timer settings on specific ports. If no ports are specified, this command displays the GARP timer settings on all ports.
Related commands: garp timer hold, garp timer join, garp timer leave, and garp timer leaveall.
# Display GARP timer settings on port GigabitEthernet 3/0/1.
<Sysname> display garp timer interface GigabitEthernet 3/0/1
         GARP timers on port GigabitEthernet3/0/1
                 Garp Join Time          : 20 centiseconds
                 Garp Leave Time         : 60 centiseconds
                 Garp LeaveAll Time      : 1000 centiseconds
                 Garp Hold Time          : 10 centiseconds
display gvrp local-vlan
display gvrp local-vlan interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
Use display gvrp local-vlan to display the local VLAN information maintained by GVRP on the specified port.
# Display the local VLAN information maintained by GVRP on GigabitEthernet 3/0/1.
<Sysname> display gvrp local-vlan interface GigabitEthernet 3/0/1
 Following VLANs exist in GVRP local database:
  1(default),2-500
display gvrp state
display gvrp state interface interface-type interface-number vlan vlan-id [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Use display gvrp state to display GVRP state machines in a specified VLAN on a port.
# Display GVRP state machines in VLAN 2 on port GigabitEthernet 3/0/1.
<Sysname> display gvrp state interface GigabitEthernet 3/0/1 vlan 2
        GVRP state of VLAN 2 on port GigabitEthernet3/0/1
                 Applicant state machine      : VP
                 Registrar state machine      : MTR
Information about the GVRP state machines in VLAN 2 on port GigabitEthernet 3/0/1.
The Applicant state machine handles attribute declarations. Its state can be VA, AA, QA, LA, VP, AP, QP, VO, AO, QO, LO, VON, AON, and QON. Each state consists of two or three letters with the following meanings:
·     The first letter indicates the state: V for Very anxious, A for Anxious, Q for Quiet, and L for Leaving.
·     The second letter indicates the membership state: A for Active member, P for Passive member, O for Observer.
·     The third letter N (if any) stands for Non-participant.
For example, VP indicates "Very anxious, Passive member".
The Registrar state machine records the registration of attributes declared by other participants. Its state can be INN, LV, L3, L2, L1, MT, INR, LVR, L3R, L2R, L1R, MTR, INF, LVF, L3F, L2F, L1F, and MTF. Each state consists of two or three letters/numbers with the following meanings:
·     The first two letters/numbers indicate the state: IN stands for In; LV, L3, L2, and L1 all stand for Leaving, and L3, L2, L1 are three sub-states of LV; MT stands for Empty.
·     The third letter indicates the registration mode: N (or the third letter being absent) for normal registration, R for Registration fixed, and F for Registration forbidden.
For example, MTR stands for "Empty, Registration fixed", indicating the fixed registration mode in Empty state.
display gvrp statistics
display gvrp statistics [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-list: Displays the GVRP statistics of one or multiple Ethernet ports. You can specify up to 10 Ethernet port lists, by each of which you can specify an individual port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end-port number specified by interface-number2 must be greater than the start-port number specified by interface-number1.
Use display gvrp statistics to display the GVRP statistics of the specified trunk ports. If no ports are specified, this command displays the GVRP statistics for all trunk ports.
# Display GVRP statistics for trunk port GigabitEthernet 3/0/1.
<Sysname> display gvrp statistics interface GigabitEthernet 3/0/1
         GVRP statistics on port GigabitEthernet3/0/1
                 GVRP Status                     : Enabled
                 GVRP Running                    : YES
                 GVRP Failed Registrations       : 0
                 GVRP Last Pdu Origin            : 0000-0000-0000
                 GVRP Registration Type          : Normal
GVRP Status
Indicates whether GVRP is enabled or disabled.
GVRP Running
Indicates whether GVRP is running.
Indicates the number of GVRP registration failures.
Indicates the source MAC address in the last GVRP PDU.
Indicates the GVRP registration mode (fixed, forbidden, or normal) on the port.
display gvrp status
display gvrp status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display gvrp status to display the global enable/disable state of GVRP.
# Display the global GVRP enable/disable state.
<Sysname> display gvrp status
                 GVRP is enabled
display gvrp vlan-operation
display gvrp vlan-operation interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
Use display gvrp vlan-operation to display information about dynamic VLAN operations on a port.
# Display information about dynamic VLAN operations on GigabitEthernet 3/0/1.
<Sysname> display gvrp vlan-operation interface GigabitEthernet 3/0/1
         Dynamic VLAN operations on port GigabitEthernet3/0/1
                 Operations of creating VLAN              :  2-100
                 Operations of deleting VLAN              :  none
                 Operations of adding VLAN to TRUNK       :  2-100
                 Operations of deleting VLAN from TRUNK   :  none
garp timer hold
garp timer hold timer-value
undo garp timer hold
View
Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
timer-value: Hold timer setting (in centiseconds), which must be a multiple of 5 and in the range of 10 (inclusive) to half the Join timer setting (inclusive).
Use garp timer hold to set the GARP Hold timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer hold to restore the default of the GARP Hold timer. This operation might fail if the default is beyond the valid value range for the Hold timer.
By default, the Hold timer is set to 10 centiseconds.
Related commands: display garp timer and garp timer join.
# Set the GARP Hold timer to 15 centiseconds, assuming that the Join timer is 30 centiseconds.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] garp timer hold 15
garp timer join
garp timer join timer-value
undo garp timer join
View
Default level
2: System level
timer-value: Join timer setting (in centiseconds), which must be a multiple of 5 and in the range of twice the Hold timer (inclusive) and half the Leave timer (inclusive).
Use garp timer join to set the GARP Join timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer join to restore the default of the GARP Join timer. This operation might fail if the default is beyond the valid value range for the Join timer.
By default, the Join timer is set to 20 centiseconds.
Related commands: display garp timer, garp timer hold, and garp timer leave.
# Set the GARP Join timer to 25 centiseconds, assuming that both the Hold timer and the Leave timer are using the default values.
[Sysname-GigabitEthernet3/0/1] garp timer join 25
garp timer leave
garp timer leave timer-value
undo garp timer leave
View
Default level
2: System level
timer-value: Leave timer setting (in centiseconds), which must be a multiple of 5 and in the range of twice the Join timer (exclusive) to the LeaveAll timer setting (exclusive).
Use garp timer leave to set the GARP Leave timer for an Ethernet port, Layer 2 aggregate interface, or all ports in a port group.
Use undo garp timer leave to restore the default of the GARP Leave timer. This operation might fail if the default is beyond the valid value range for the Leave timer.
By default, the Leave timer is set to 60 centiseconds.
Related commands: display garp timer, garp timer join, and garp timer leaveall.
# Set the GARP Leave timer to 100 centiseconds, assuming that both the Join timer and the LeaveAll timer are using the default values.
[Sysname-GigabitEthernet3/0/1] garp timer leave 100
garp timer leaveall
garp timer leaveall timer-value
undo garp timer leaveall
View
Default level
2: System level
timer-value: LeaveAll timer setting (in centiseconds), which must be a multiple of 5 and in the range of the maximum Leave timer on the switch (exclusive) to 32765 (inclusive).
Use garp timer leaveall to set the GARP LeaveAll timer.
Use undo garp timer leaveall to restore the default. This operation might fail if the default is beyond the valid value range for the LeaveAll timer.
By default, the setting of the LeaveAll timer is 1000 centiseconds.
To keep the dynamic VLANs learned through GVRP stable, do not set the LeaveAll timer smaller than its default value.
Related commands: display garp timer and garp timer leave.
# Set the leaveall timer to 2000 centiseconds, assuming that the Leave timer on every port is set to 60 centiseconds.
[Sysname] garp timer leaveall 2000
gvrp
gvrp
undo gvrp
View
System view, Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
None
Use gvrp to enable GVRP.
Use undo gvrp to disable GVRP.
By default, GVRP is disabled both globally and on ports.
Settings in system view take effect globally. Settings in Ethernet view or Layer 2 aggregate interface take effect on the interface. Settings in port group view take effect on all ports in the port group.
Enable GVRP globally before you can enable it on a port.
In interface view, you can use this command on trunk ports only.
You cannot change the link type of a GVRP-enabled trunk port.
Related commands: display gvrp status.
# Enable GVRP globally.
[Sysname] gvrp
GVRP is enabled globally.
gvrp registration
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Default level
2: System level
fixed: Sets the GVRP registration mode to fixed.
forbidden: Sets the GVRP registration mode to forbidden.
normal: Sets the GVRP registration mode to normal.
Use gvrp registration to configure the GVRP registration mode.
Use undo gvrp registration to restore the default.
The default GVRP registration mode is normal.
Settings in system view take effect globally. Settings in Ethernet view or Layer 2 aggregate interface take effect on the current interface. Settings in port group view take effect on all ports in the port group.
This command is only available on trunk ports.
Related commands: display garp statistics.
# Set the GVRP registration mode to fixed on port GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] port link-type trunk
[Sysname-GigabitEthernet3/0/1] gvrp registration fixed
reset garp statistics [ interface interface-list ]
View
Default level
2: System level
interface interface-list: Clear the GARP statistics of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where the end port number specified by interface-number2 must be greater than the start port number specified by interface-number1.
Use reset garp statistics to clear the GARP statistics on the specified ports. If no ports are specified, this command clears the GARP statistics on all ports.
The cleared statistics include the statistics about GVRP PDUs sent, received, and dropped.
# Clear the GARP statistics on all ports.
<Sysname> reset garp statistics
