- 04-Layer 2 - LAN Switching Command Reference
- 01-VLAN Commands
- 02-MAC Address Table Commands
- 03-Spanning Tree Commands
- 04-Ethernet Link Aggregation Commands
- 05-Port Isolation Commands
- 06-QinQ Commands
- 07-VLAN Mapping Commands
- 08-BPDU Tunneling Commands
- 09-GVRP Commands
- 10-Loopback Detection Commands
- 11-VLAN Termination Commands
- 12-MAC-in-MAC Commands
- 13-LLDP Commands
- 14-MVRP Commands
| 03-Spanning Tree Commands | 279.82 KB |
active region-configuration
View
MST region view
Default level
2: System level
None
Use active region-configuration to activate your MST region configuration.
When you configure MST region–related parameters, MSTP launches a new spanning tree calculation process that might cause network topology instability. This is most likely to occur when you configure the VLAN-to-instance mapping table. The launch will occur only after the MST region–related parameters are activated with the active region-configuration command, or you enable the spanning tree feature with the stp enable command.
H3C recommends you to use the check region-configuration command to determine whether the MST region configurations to be activated are correct and that you run this command only if they are correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, and check region-configuration.
# Map VLAN 2 to MSTI 1 and manually activate the MST region configuration.
[Sysname-mst-region] instance 1 vlan 2
View
MST region view
Default level
2: System level
None
Use check region-configuration to display MST region pre-configuration information, including the region name, revision level, and VLAN-to-instance mapping settings.
Two or more spanning tree switches belong to the same MST region only if they are configured with the same format selector (0 by default, not configurable), MST region name, MST region revision level, and the same VLAN-to-instance mapping entries in the MST region, and if they are connected through a physical link.
H3C recommends that you use this command to determine whether the MST region configurations to be activated are correct and that you activate them only if they are correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, and active region-configuration.
# Display MST region pre-configurations.
[Sysname-mst-region] check region-configuration
Admin Configuration
Format selector :0
Region name :00e0fc009512
Revision level :0
Configuration digest :0x41b5018aca57daa8dcfdba2984d99d06
Instance Vlans Mapped
0 1 to 9, 11 to 4094
15 10
Format selector |
Format selector of the MST region. The value is 0 and cannot be configured. |
Region name |
MST region name. |
Revision level |
Revision level of the MST region. |
Instance Vlans Mapped |
VLAN-to-instance mappings in the MST region. |
display stp
In standalone mode:
display stp [ instance instance-id | vlan vlan-id ] [ interface interface-list | slot slot-number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display stp [ instance instance-id | vlan vlan-id ] [ interface interface-list | chassis chassis-number slot slot-number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
instance instance-id: Displays the status and statistics of an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the common internal spanning tree (CIST).
vlan vlan-id: Displays the spanning tree status and statistics of a VLAN specified by vlan-id. The value range for the vlan-id argument is 1 to 4094.
interface interface-list: Displays the spanning tree status and statistics on the ports specified by a port list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
slot slot-number: Displays the spanning tree status and statistics on the specified card. The slot-number argument represents the number of the slot that houses the card. Use this option when your switch is operating in standalone mode. If this option is not specified, this command displays the spanning tree status and statistics on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the spanning tree status and statistics on the specified card of the specified IRF member switch. The chassis-number argument represents the ID of the IRF member switch. The slot-number argument represents the number of the slot that houses the card, which can be displayed with the display device command. Use this option when your switch is operating in IRF mode. If this option is not specified, this command displays the spanning tree status and statistics on all cards of all member switches in the IRF fabric. (In IRF mode.)
brief: Displays brief spanning tree status and statistics.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display stp to display the spanning tree status and statistics.
Based on the spanning tree status and statistics, you can analyze and maintain the network topology or check whether spanning tree is operating correctly.
In STP/RSTP mode, follow these guidelines:
· If you do not specify any port, this command displays the spanning tree information for all ports. The displayed information is sorted by port name.
· If you specify a port list, this command displays the spanning tree information for the specified ports. The displayed information is sorted by port name.
In MSTP mode, follow these guidelines:
· If you do not specify any MSTI or port, this command displays the spanning tree information of all MSTIs on all ports. The displayed information is sorted by MSTI ID and by port name in each MSTI.
· If you specify an MSTI but not a port, this command displays the spanning tree information on all ports in that MSTI. The displayed information is sorted by port name.
· If you specify some ports but not an MSTI, this command displays the spanning tree information of all MSTIs on the specified ports. The displayed information is sorted by MSTI ID and by port name in each MSTI.
· If you specify both an MSTI ID and a port list, this command displays the spanning tree information on the specified ports in the specified MSTI. The displayed information is sorted by port name.
In PVST mode, follow these guidelines:
· If you do not specify any VLAN or port, this command displays the spanning tree information of all VLANs on all ports. The displayed information is sorted by VLAN ID and by port name in each VLAN.
· If you specify a VLAN but not a port, this command displays the spanning tree information on all ports in that VLAN. The displayed information is sorted by port name.
· If you specify some ports but not any VLAN, this command displays the spanning tree information of all VLANs on the specified ports. The displayed information is sorted by VLAN ID and by port name in each VLAN.
· If you specify both a VLAN ID and a port list, this command displays the spanning tree information on the specified ports in the specified VLAN. The displayed information is sorted by port name.
Related commands: reset stp.
# In MSTP mode, display the brief spanning tree status and statistics of MSTI 0 on ports GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4.
<Sysname> display stp instance 0 interface gigabitethernet 3/0/1 to gigabitethernet 3/0/4 brief
MSTID Port Role STP State Protection
0 GigabitEthernet3/0/1 DESI DISCARDING NONE
0 GigabitEthernet3/0/2 DESI FORWARDING NONE
0 GigabitEthernet3/0/3 DESI FORWARDING NONE
0 GigabitEthernet3/0/4 DESI FORWARDING NONE
# In PVST mode, display the brief spanning tree status and statistics of VLAN 2 on ports GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4.
[Sysname] stp mode pvst
[Sysname] display stp vlan 2 interface gigabitethernet 3/0/1 to gigabitethernet 3/0/4 brief
VLAN Port Role STP State Protection
2 GigabitEthernet3/0/1 ALTE DISCARDING LOOP
2 GigabitEthernet3/0/2 DESI FORWARDING NONE
2 GigabitEthernet3/0/3 DESI FORWARDING NONE
2 GigabitEthernet3/0/4 DESI FORWARDING NONE
MSTID |
MSTI ID in the MST region. |
Port |
Port name, corresponding to each MSTI or VLAN. |
Role |
Port role: · ALTE—The port is an alternate port. · BACK—The port is a backup port. · ROOT—The port is a root port. · DESI—The port is a designated port. · MAST—The port is a master port. · DISA—The port is disabled. |
STP State |
Spanning tree status on the port: · FORWARDING—The port can receive and send BPDUs, and also forward user traffic. · DISCARDING—The port can receive and send BPDUs, but cannot forward user traffic. · LEARNING—The port is in a transitional state. It can receive and send BPDUs, but cannot forward user traffic. |
Protection |
Protection type on the port: · ROOT—Root guard. · LOOP—Loop guard. · BPDU—BPDU guard. · BPDU/ROOT—BPDU guard and root guard. · NONE—No protection. |
# In MSTP mode, display the spanning tree status and statistics of MSTI 0 on GigabitEthernet 3/0/2.
<Sysname> display stp instance 0 interface gigabitethernet 3/0/2
-------[CIST Global Info][Mode MSTP]-------
CIST Bridge :32768.000f-e200-2200
Bridge Times :Hello 2s MaxAge 20s FwDly 15s MaxHop 20
CIST Root/ERPC :0.00e0-fc0e-6554 / 200200
CIST RegRoot/IRPC :32768.000f-e200-2200 / 0
CIST RootPortId :128.48
BPDU-Protection :disabled
Bridge Config-
Digest-Snooping :disabled
TC or TCN received :2
Time since last TC :0 days 0h:5m:42s
----[Port2(GigabitEthernet3/0/2)][FORWARDING]----
Port Protocol :enabled
Port Role :CIST Designated Port
Port Priority :128
Port Cost(Legacy) :Config=auto / Active=200
Desg. Bridge/Port :32768.000f-e200-2200 / 128.2
Port Edged :Config=disabled / Active=disabled
Point-to-point :Config=auto / Active=true
Transmit Limit :10 packets/hello-time
Protection Type :None
MST BPDU Format :Config=auto / Active=legacy
Port Config-
Rapid transition :false
Num of Vlans Mapped :1
PortTimes :Hello 2s MaxAge 20s FwDly 15s MsgAge 2s RemHop 20
BPDU Sent :186
TCN: 0, Config: 0, RST: 0, MST: 186
BPDU Received :0
TCN: 0, Config: 0, RST: 0, MST: 0
# Display the spanning tree status and statistics when the spanning tree feature is disabled.
Protocol Status :disabled
Protocol Std. :IEEE 802.1s
Version :0
Bridge-Prio. :32768
MAC address :000f-e200-8048
Max age(s) :20
Forward delay(s) :15
Hello time(s) :2
Max hops :20
CIST Bridge |
CIST bridge ID, which comprises the switch's priority in the CIST and its MAC address. For example, in output "32768.000f-e200-2200", the value preceding the dot is the switch's priority in the CIST, and the value following the dot is the switch's MAC address. |
Bridge ID |
Bridge ID, which comprises the switch's priority in VLAN 1 and its MAC address. For example, in output "32768.000f-e200-2200", the value preceding the dot is the switch's priority in VLAN 1, and the value following the dot is the switch's MAC address. |
Bridge Times |
Major parameters for the bridge: · Hello—Hello timer. · MaxAge—Max age timer. · FWDly—Forward delay timer. · MaxHop—Max hops within the MST region. |
CIST Root/ERPC |
CIST root ID and external path cost (the path cost from the switch to the CIST root). |
CIST RegRoot/IRPC |
CIST regional root ID and internal path cost (the path cost from the switch to the CIST regional root). |
CIST RootPortId |
CIST root port ID. "0.0" indicates that the switch is the root and there is no root port. |
BPDU-Protection |
Global status of BPDU protection. |
Bridge Config- Digest-Snooping |
Global status of Digest Snooping. |
TC or TCN received |
Number of TC/TCN BPDUs received in the MSTI. |
Time since last TC |
Time since the latest topology change in the MSTI. |
FORWARDING |
The port is in forwarding state. |
Port Protocol |
The status of the spanning tree feature on the port. |
Port Role |
Port role: · Alternate. · Backup. · Root. · Designated. · Master. · Disabled. |
Port Cost(Legacy) |
Path cost of the port. The field in parentheses indicates the standard (legacy, dot1d-1998, or dot1t) used for port path cost calculation. · Config—Configured value. · Active—Actual value. |
Desg. Bridge/Port |
Designated bridge ID and port ID of the port. The port ID displayed is insignificant for a port which does not support port priority. |
Port Edged |
The port is an edge port or non-edge port. · Config—Configured value. · Active—Actual value. |
Point-to-point |
The port is connected to a point-to-point link or not. · Config—Configured value. · Active—Actual value. |
Transmit Limit |
The maximum number of packets sent within each hello time. |
Protection Type |
Protection type on the port: · Root—Root guard. · Loop—Loop guard. · BPDU—BPDU guard. · BPDU/ROOT—BPDU guard and root guard. · None—No protection. |
MST BPDU Format |
Format of the MST BPDUs that the port can send, which can be legacy or 802.1s. · Config—Configured value. · Active—Actual value. |
Port Config- Digest-Snooping |
Status of Digest Snooping on the port. |
Rapid transition |
The port rapidly transits to the forwarding state or not in the MSTI. |
PortTimes |
Major parameters for the port: · Hello—Hello timer. · MaxAge—Max Age timer. · FwDly—Forward delay timer. · MsgAge—Message Age timer. · RemHop—Remaining hops. |
BPDU Sent |
Statistics on sent BPDUs. |
BPDU Received |
Statistics on received BPDUs. |
Protocol Status |
Spanning tree protocol status. |
Protocol Std. |
Spanning tree protocol standard. |
Version |
Spanning tree protocol version. |
Bridge-Prio. |
In MSTP mode, this field indicates the switch's priority in the CIST. In PVST mode, this field indicates the switch's priority in VLAN 1. |
Max age(s) |
Aging timer (in seconds) for BPDUs. In PVST mode, this field is the configuration in VLAN 1. |
Forward delay(s) |
Port state transition delay (in seconds). In PVST mode, this field is the configuration in VLAN 1. |
Hello time(s) |
Interval (in seconds) for the root bridge to send BPDUs. In PVST mode, this field is the configuration in VLAN 1. |
Max hops |
Maximum hops in the MSTI. |
display stp abnormal-port
display stp abnormal-port [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display stp abnormal-port to display information about ports blocked by spanning tree protection functions.
# In MSTP mode, display information about ports blocked by spanning tree protection functions.
<Sysname> display stp abnormal-port
MSTID Blocked Port Reason
1 GigabitEthernet3/0/1 ROOT-Protected
2 GigabitEthernet3/0/2 LOOP-Protected
2 GigabitEthernet3/0/3 Formatcompatibility–Protected
Blocked Port |
Name of a blocked port, which corresponds to the related MSTI. |
Reason |
Reason that the port was blocked: · ROOT-Protected—Root guard function. · LOOP-Protected—Loop guard function. · Formatcompatibility-Protected—MSTP BPDU format incompatibility protection function. · InconsistentPortType-Protected—Port type inconsistent protection function. · InconsistentPvid-Protected—PVID inconsistent protection function. |
display stp bpdu-statistics
display stp bpdu-statistics [ interface interface-type interface-number [ instance instance-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the BPDU statistics on a port specified by port type and number.
instance instance-id: Displays the BPDU statistics of an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
Use display stp bpdu-statistics to display the BPDU statistics on ports.
· If you do not specify any MSTI or port, this command displays the BPDU statistics of all MSTIs on all ports. The displayed information is sorted by port name and by MSTI ID on each port.
· If you specify a port but not an MSTI, this command displays the BPDU statistics of all MSTIs on the port. The displayed information is sorted by MSTI ID.
· If you specify both an MSTI ID and a port, this command displays the BPDU statistics of the specified MSTI on the port.
In STP, RSTP, or PVST mode, follow these guidelines:
· If you do not specify any port, this command displays the BPDU statistics of on all ports. The displayed information is sorted by port name.
· If you specify a port, this command displays the BPDU statistics on the port.
# In MSTP mode, display the BPDU statistics of all MSTIs on GigabitEthernet 3/0/1.
<Sysname> display stp bpdu-statistics interface gigabitethernet 3/0/1
Port: GigabitEthernet 3/0/1
Instance-independent:
Type Count Last Updated
Invalid BPDUs 0
Looped-back BPDUs 0
MAX-aged BPDUs 0
TCN sent 0
TCN received 0
TCA sent 0
TCA received 2 10:33:12 01/13/2010
Config sent 0
Config received 0
RST sent 0
RST received 0
MST sent 4 10:33:11 01/13/2010
MST received 151 10:37:43 01/13/2010
Instance 0:
Timeout BPDUs 0
MAX-hoped BPDUs 0
TC detected 1 10:32:40 01/13/2010
TC sent 3 10:33:11 01/13/2010
TC received 0
Instance 1:
Timeout BPDUs 0
MAX-hoped BPDUs 0
TC detected 0
TC sent 0
TC received 0
Instance 2:
Timeout BPDUs 0
MAX-hoped BPDUs 0
TC detected 0
TC sent 0
TC received 0
Table 5 Command output
Port |
Port name. |
Instance-independent |
Statistics not related to any particular MSTI. |
Type |
Statistical item. |
Looped-back BPDUs |
BPDUs sent and then received by the same port. |
Max-Aged BPDUs |
BPDUs whose max age was exceeded. |
TCN Sent |
TCN BPDUs sent. |
TCN Received |
TCN BPDUs received. |
TCA Sent |
TCA BPDUs sent. |
TCA Received |
TCA BPDUs received. |
Config Sent |
Configuration BPDUs sent. |
Config Received |
Configuration BPDUs received. |
RST Sent |
RSTP BPDUs sent. |
RST Received |
RSTP BPDUs received. |
MST Sent |
MSTP BPDUs sent. |
MST Received |
MSTP BPDUs received. |
Instance |
Statistical information for a particular MSTI. |
Timeout BPDUs |
Expired BPDUs. |
Max-Hoped BPDUs |
BPDUs whose maximum hops were exceeded. |
TC Detected |
TC BPDUs detected. |
TC Sent |
TC BPDUs sent. |
TC Received |
TC BPDUs received. |
display stp down-port
display stp down-port [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display stp down-port to display information about ports shut down by spanning tree protection functions.
# Display information about ports shut down by spanning tree protection functions.
<Sysname> display stp down-port
Down Port Reason
GigabitEthernet3/0/1 BPDU-Protected
GigabitEthernet3/0/2 Formatfrequency-Protected
Table 6 Command output
Down Port |
Name of a port shut down by the spanning tree protection functions. |
Reason |
Reason that the port was shut down: · BPDU-Protected—BPDU guard function. · Formatfrequency-Protected—MSTP BPDU format frequent change protection function. |
display stp history
In standalone mode:
display stp [ instance instance-id | vlan vlan-id ] history [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display stp [ instance instance-id | vlan vlan-id ] history [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
instance instance-id: Displays the historical port role calculation information of an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
vlan vlan-id: Displays the historical port role calculation information of a VLAN specified by vlan-id. The value range for the vlan-id argument is 1 to 4094.
slot slot-number: Displays the historical port role calculation information on the specified card. The slot-number argument represents the number of the slot that houses the card. Use this option when your switch is operating in standalone mode. If this option is not specified, this command displays the historical port role calculation information on all the cards. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the historical port role calculation information on the specified card of the specified IRF member switch. The chassis-number argument represents the ID of the IRF member switch. The slot-number argument represents the number of the slot that houses the card, which can be displayed with the display device command. Use this option when your switch is operating in IRF mode. If this option is not specified, this command displays the historical port role calculation information on all cards of all member switches in the IRF fabric. (In IRF mode.)
Use display stp history to display the historical port role calculation information of the specified MSTI or all MSTIs.
In STP/RSTP mode, the displayed information is sorted by port role calculation time.
· If you do not specify any MSTI, this command displays the historical port role calculation information of all MSTIs. The displayed information is sorted by MSTI ID and by port role calculation time in each MSTI.
· If you specify an MSTI, this command displays the historical port role calculation information of the specified MSTI by the sequence of port role calculation time.
· If you do not specify any VLAN, this command displays the historical port role calculation information of all VLANs. The displayed information is sorted by VLAN ID, and by port role calculation time in each VLAN.
· If you specify a VLAN, this command displays the historical port role calculation information of the specified VLAN by the sequence of port role calculation time.
# In MSTP mode, display the historical port role calculation information of the card on slot 1 in MSTI 2.
<Sysname> display stp instance 2 history slot 1
--------------- STP slot 1 history trace ---------------
------------------- Instance 2 ---------------------
Port GigabitEthernet3/0/1
Role change : ROOT->DESI (Aged)
Time : 2009/02/08 00:22:56
Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.1
Port GigabitEthernet3/0/2
Role change : ALTER->ROOT
Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.2
Table 7 Command output
Port |
Port name. |
Role change |
A role change of the port ("Aged" means that the change was caused by expiration of the received configuration BPDU). |
Time |
Time of port role calculation. |
Port priority |
Port priority. |
display stp ignored-vlan
display stp ignored-vlan [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display stp ignored-vlan to display VLAN Ignore-enabled VLANs.
# Display VLAN Ignore-enabled VLANs.
<Sysname> display stp ignored-vlan
STP-Ignored VLAN: 1 to 2
Table 8 Command output
STP-Ignored VLAN |
List of VLAN Ignore-enabled VLANs. A value of NONE for this field indicates that no VLAN is enabled with the VLAN Ignore feature. |
display stp region-configuration
display stp region-configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display stp region-configuration to display effective configuration information of the MST region, including the region name, revision level, and user-configured VLAN-to-instance mappings.
Related commands: instance, region-name, revision-level, and vlan-mapping modulo.
# In MSTP mode, display effective MST region configuration information.
<Sysname> display stp region-configuration
Oper Configuration
Format selector :0
Region name :hello
Revision level :0
Configuration digest :0x5f762d9a46311effb7a488a3267fca9f
0 21 to 4094
1 1 to 10
2 11 to 20
# In PVST mode, display the effective MST region configuration information.
[Sysname] display stp region-configuration
Oper Configuration
Format selector :0
Region name :hello
Revision level :0
Instance Mode Vlans Mapped
0 default 3 to 4094
1 static 1
2 dynamic 2
Table 9 Command output
Format selector |
Format selector defined by the spanning tree protocol. |
Region name |
MST region name. |
Revision level |
Revision level of the MST region, which can be configured by using the revision-level command. |
Mode |
The MSTI mode: · Default—The default instance MSTI 0. In PVST mode, the spanning tree feature is disabled. · Static—The static MSTI. · Dynamic—The dynamically assigned MSTI, which only exists in PVST mode. |
display stp root
display stp root [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display stp root to display the root bridge information of all MSTIs.
# In MSTP mode, display the root bridge information of all spanning trees.
<Sysname> display stp root
MSTID Root Bridge ID ExtPathCost IntPathCost Root Port
0 0.00e0-fc0e-6554 200200 0 GigabitEthernet3/0/6
Table 10 Command output
ExtPathCost |
External path cost. The switch automatically calculates the default path cost of a port, or alternatively, you can use the stp cost command to configure the path cost of a port. |
IntPathCost |
Internal path cost. The switch automatically calculates the default path cost of a port, or alternatively, you can use the stp cost command to configure the path cost of a port. |
Root Port |
Root port name (displayed only if a port of the switch is the root port of MSTIs). |
display stp tc
In standalone mode:
display stp [ instance instance-id | vlan vlan-id ] tc [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display stp [ instance instance-id | vlan vlan-id ] tc [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
instance instance-id: Displays the statistics of TC/TCN BPDUs received and sent by all ports in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
vlan vlan-id: Displays the statistics of TC/TCN BPDUs received and sent by all ports in a VLAN specified by vlan-id. The value range for the vlan-id argument is 1 to 4094.
slot slot-number: Displays the statistics of TC/TCN BPDUs received and sent by all ports on the specified card. The slot-number argument represents the number of the slot that houses the card. Use this option when your switch is operating in standalone mode. If this option is not specified, this command displays the statistics of TC/TCN BPDUs received and sent by all ports on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the statistics of TC/TCN BPDUs received and sent by all ports on the specified card of the specified IRF member switch. The chassis-number argument represents the ID of the IRF member switch. The slot-number argument represents the number of the slot that houses the card, which can be displayed with the display device command. Use this option when your switch is operating in IRF mode. If this option is not specified, this command displays the statistics of TC/TCN BPDUs received and sent by all ports on all cards of all member switches in the IRF fabric. (In IRF mode.)
Use display stp tc to display the statistics of TC/TCN BPDUs received and sent by all ports in an MSTI or all MSTIs.
In STP/RSTP mode, the displayed information is sorted by port name.
· If you do not specify any MSTI, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in all MSTIs. The displayed information is sorted by instance ID and by port name in each MSTI.
· If you specify an MSTI, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in the specified MSTI, in port name order.
· If you do not specify any VLAN, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in all VLANs. The displayed information is sorted by VLAN ID and by port name in each VLAN.
· If you specify a VLAN, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in the specified VLAN, in port name order.
# In MSTP mode, display the statistics of TC/TCN BPDUs received and sent by all ports in MSTI 0.
<Sysname> display stp instance 0 tc
-------------- STP slot 3 TC or TCN count -------------
MSTID Port Receive Send
0 GigabitEthernet3/0/1 6 4
0 GigabitEthernet3/0/2 0 2
Table 11 Command output
Port |
Port name. |
Receive |
Number of TC/TCN BPDUs received on each port. |
Send |
Number of TC/TCN BPDUs sent by each port. |
instance
instance instance-id vlan vlan-list
undo instance instance-id [ vlan vlan-list ]
View
MST region view
Default level
2: System level
instance-id: Specifies an MSTI ID in the range of 0 to 47, where 0 represents the CIST.
vlan vlan-list: Specifies a VLAN list in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument represents the VLAN ID in the range of 1 to 4094, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
Use instance to map a list of VLANs to the specified MSTI.
Use undo instance to remap the specified VLAN or all VLANs to the CIST (MSTI 0).
By default, all VLANs are mapped to the CIST.
If you specify no VLAN in the undo instance command, all VLANs mapped to the specified MSTI will be remapped to the CIST.
You cannot map the same VLAN to different MSTIs. If you map a VLAN that has been mapped to an MSTI to a new MSTI, the old mapping will be automatically removed.
In PVST mode, you can map multiple VLANs to the CIST, and only one VLAN to each remaining MSTI.
After configuring this command, run the active region-configuration command to activate the VLAN-to-instance mapping.
Related commands: display stp region-configuration, check region-configuration, and active region-configuration.
# Map VLAN 2 to MSTI 1.
region-name
region-name name
undo region-name
View
MST region view
Default level
2: System level
name: Specifies the MST region name, a string of 1 to 32 characters.
Use region-name to configure the MST region name.
Use undo region-name to restore the default MST region name.
By default, the MST region name of the switch is its MAC address.
The MST region name, the VLAN-to-instance mapping table, and the MSTP revision level of a switch determine the switch's MST region.
After configuring this command, run the active region-configuration command to activate the configured MST region name.
Related commands: instance, revision-level, vlan-mapping modulo, display stp region-configuration, check region-configuration, and active region-configuration.
# Set the MST region name of the switch to hello.
[Sysname-mst-region] region-name hello
reset stp
reset stp [ interface interface-list ]
View
Default level
1: Monitor level
interface interface-list: Clears the MSTP statistics of the ports specified in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges. If this option is not specified, the command clears the spanning tree-related statistics on all ports.
Use reset stp to clear the MSTP statistics.
The MSTP statistics includes the numbers of TCN BPDUs, configuration BPDUs, RST BPDUs and MST BPDUs sent/received through the specified ports.
Related commands: display stp.
# Clear the spanning tree-related statistics on ports GigabitEthernet 4/0/1 through GigabitEthernet 4/0/3.
<Sysname> reset stp interface gigabitethernet 4/0/1 to gigabitethernet 4/0/3
revision-level
revision-level level
undo revision-level
View
MST region view
Default level
2: System level
level: Specifies an MSTP revision level in the range of 0 to 65535.
Use revision-level to configure the MSTP revision level.
Use undo revision-level to restore the default MSTP revision level.
By default, the MSTP revision level is 0.
The MSTP revision level, the MST region name, and the VLAN-to-instance mapping table of a switch determine the switch's MST region. When the MST region name and VLAN-to-instance mapping table are both the same for two MST regions, they can still be differentiated by their MSTP revision levels.
After configuring this command, run the active region-configuration command to activate the configured MST region level.
Related commands: instance, region-name, vlan-mapping modulo, display stp region-configuration, check region-configuration, and active region-configuration.
# Set the MSTP revision level of the MST region to 5.
[Sysname-mst-region] revision-level 5
stp bpdu-protection
stp bpdu-protection
undo stp bpdu-protection
View
Default level
2: System level
None
Use stp bpdu-protection to enable the BPDU guard function.
Use undo stp bpdu-protection to disable the BPDU guard function.
By default, the BPDU guard function is disabled.
# Enable the BPDU guard function.
[Sysname] stp bpdu-protection
stp bridge-diameter
stp [ vlan vlan-list ] bridge-diameter diameter
undo stp [ vlan vlan-list ] bridge-diameter
View
Default level
2: System level
diameter: Specifies the switched network diameter in the range of 2 to 7.
Use stp bridge-diameter to specify the network diameter, the maximum possible number of stations between any two terminal devices on the switched network.
Use undo stp bridge-diameter to restore the default.
By default, the network diameter of the switched network is 7.
An appropriate setting of hello time, forward delay, and max age can speed up network convergence. The values of these timers are related to the network size and you can set the timers by setting the network diameter. With the network diameter set to 7 (the default), the three timers will be set to their defaults.
To set the network diameter of an STP/RSTP/MSTP switched network, use this command without specifying any VLAN. To set the network diameter of a specified VLAN or multiple VLANs in a PVST switched network, use this command with a VLAN list specified.
In STP, RSTP, or MSTP mode, each MST region is considered as a network device, and the configured network diameter of the switched network takes effect only on the CIST (or MSTI 0), but the diameter does not take effect on other MSTIs.
In PVST mode, the network diameter configuration takes effect only on the root bridge.
Related commands: stp timer forward-delay, stp timer hello, and stp timer max-age.
# Set the network diameter of the switched network to 5.
[Sysname] stp bridge-diameter 5
stp compliance
stp compliance { auto | dot1s | legacy }
undo stp compliance
View
Ethernet interface view, port group view, Layer 2 aggregate interface view
Default level
2: System level
auto: Configures the ports to recognize the MSTP BPDU format automatically and determine the format of MSTP BPDUs to send.
dot1s: Configures the ports to receive and send only standard-format (802.1s-compliant) MSTP BPDUs.
legacy: Configures the ports to receive and send only compatible-format MSTP BPDUs.
Use stp compliance to configure the mode the specified ports will use to recognize and send MSTP BPDUs.
Use undo stp compliance to restore the default.
By default, a port automatically recognizes the formats of received MSTP packets and determines the formats of MSTP packets to be sent based on the recognized formats.
Configured in Ethernet interface view, the setting takes effect on the interface only. Configured in port group view, the setting takes effect on all ports in the port group. Configured in Layer 2 aggregate interface view, the setting takes effect only on the aggregate interface. Configured on a member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group. For more information about Ethernet link aggregation, see Layer 2—LAN Switching Configuration Guide.
# Configure GigabitEthernet 4/0/1 to receive and send only standard-format (802.1s) MSTP packets.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] stp compliance dot1s
stp config-digest-snooping
undo stp config-digest-snooping
View
System view, Ethernet interface view, port group view, Layer 2 aggregate interface view
Default level
2: System level
None
Use stp config-digest-snooping to enable Digest Snooping.
Use undo stp config-digest-snooping to disable Digest Snooping.
The feature is disabled by default.
Enable this feature both globally and on ports connected to other vendors' devices to make it effective. To minimize impact, enable the feature on all associated ports before you enable it globally, and disable the feature globally before you disable it on each associated port.
With global Digest Snooping enabled, modification of VLAN-to-instance mappings and removing of the current region configuration using the undo stp region-configuration command can cause loops or traffic interruption if the VLAN-to-instance mappings on the device differ from those on the neighboring devices. Perform these operations with caution.
Configured in system view, the setting takes effect globally. Configured in Ethernet interface view, the setting takes effect on the interface only. Configured in port group view, the setting takes effect on all ports in the port group. Configured in Layer 2 aggregate interface view, the setting takes effect only on the aggregate interface. Configured on a member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group. For more information about Ethernet link aggregation, see Layer 2—LAN Switching Configuration Guide.
# Enable Digest Snooping on GigabitEthernet 3/0/1 and then globally.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] stp config-digest-snooping
[Sysname-GigabitEthernet3/0/1] quit
[Sysname] stp config-digest-snooping
stp cost
stp [ instance instance-id | vlan vlan-list ] cost cost
undo stp [ instance instance-id | vlan vlan-list ] cost
View
Default level
2: System level
instance instance-id: Sets the path cost of the ports in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
cost: Specifies the path cost of the port, with an effective range that depends on the path cost calculation standard adopted.
· With the IEEE 802.1d-1998 standard selected for path cost calculation, the value range for the cost argument is 1 to 65,535.
· With the IEEE 802.1t standard selected for path cost calculation, the value range for the cost argument is 1 to 200,000,000.
· With the private standard selected for path cost calculation, the value range for the cost argument is 1 to 200,000.
Use stp cost to set the path cost of the port or ports.
Use undo stp cost to restore the default.
By default, the switch automatically calculates the path costs of ports in each spanning tree based on the corresponding standard.
To set the path cost of an MSTP port in a specific MSTI, use this command with the MSTI specified. To set the path cost of a PVST port in a specific VLAN, use this command with the VLAN specified. To set the path cost of an MSTP port in the CIST or an STP/RSTP port, use this command without specifying any MSTI or VLAN.
Path cost is an important factor in spanning tree calculation. Setting different path costs for a port in MSTIs allows VLAN traffic flows to be forwarded along different physical links, achieving VLAN-based load balancing.
The path cost setting of a port can affect the role selection of the port. When the path cost of a port is changed, the system will re-calculate the role of the port and initiate a state transition.
# In MSTP mode, set the path cost of port GigabitEthernet 4/0/1 in MSTI 2 to 200.
[Sysname-GigabitEthernet4/0/1] stp instance 2 cost 200
stp edged-port
stp edged-port { enable | disable }
undo stp edged-port
View
Default level
2: System level
enable: Configures the ports as edge ports.
disable: Configures the ports as non-edge ports.
Use the stp edged-port enable command to configure Ethernet ports as edge ports.
Use the stp edged-port disable command to configure the ports as non-edge ports.
Use undo stp edged-port to restore the default.
By default, all ports are non-edge ports.
If a port directly connects to a user terminal rather than another device or a shared LAN segment, this port is regarded as an edge port. When the network topology changes, an edge port will not cause a temporary loop. You can enable the port to transit to the forwarding state rapidly by configuring it as an edge port. H3C recommends you to configure ports directly connecting to user terminals as edge ports.
Configuration BPDUs from other devices usually cannot reach an edge port, because the edge port does not connect to any other device. If a port receives a configuration BPDU when the BPDU guard function is disabled, the port functions as a non-edge port, even if you configure it as an edge port.
On a port, the loop guard function and the edge port settings are mutually exclusive.
Related commands: stp loop-protection.
# Configure GigabitEthernet 4/0/1 as an edge port.
[Sysname-GigabitEthernet4/0/1] stp edged-port enable
stp enable
In system view:
stp [ vlan vlan-list ] enable
undo stp [ vlan vlan-list ] enable
In Ethernet interface, Layer 2 aggregate interface, or port group view:
stp enable
undo stp enable
View
Default level
2: System level
vlan vlan-list: Enables or disables the spanning tree feature for a VLAN list specified in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument represents the VLAN ID in the range of 1 to 4094, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. If this option is not specified, this command enables or disables the spanning tree feature globally rather than for VLANs.
Use stp enable to enable the spanning tree feature globally.
Use undo stp enable to disable the spanning tree feature.
By default, the spanning tree feature is enabled globally, in all VLANs, and on all ports.
When you enable the spanning tree feature, the switch operates in STP, RSTP, MSTP, or PVST mode, depending on the spanning tree mode setting.
When the spanning tree feature is enabled, the switch dynamically maintains the spanning tree status of VLANs based on received configuration BPDUs. When the spanning tree feature is disabled, the switch stops maintaining the spanning tree status.
Related commands: stp mode.
# Globally enable the spanning tree feature.
[Sysname] stp enable
# In PVST mode, enable the spanning tree feature globally and in VLAN 2.
[Sysname] stp vlan 2 enable
# In MSTP mode, disable the spanning tree feature on port GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] undo stp enable
stp ignored vlan
stp ignored vlan vlan-list
undo stp ignored vlan vlan-list
View
Default level
2: System level
Use stp ignored vlan to enable VLAN Ignore for the specified VLANs.
Use undo stp ignored vlan to disable VLAN Ignore for the specified VLANs.
By default, VLAN Ignore is disabled for a VLAN.
Related commands: display stp ignored-vlan.
# Enable VLAN Ignore for VLAN 2.
[Sysname] stp ignored vlan 2
# Enable VLAN Ignore for VLAN 1 through VLAN 10.
[Sysname] stp ignored vlan 1 to 10
stp loop-protection
stp loop-protection
undo stp loop-protection
View
Default level
2: System level
None
Use stp loop-protection to enable the loop guard function on the ports.
Use undo stp loop-protection to disable the loop guard function on the ports.
By default, the loop guard function is disabled.
On a port, the loop guard function is mutually exclusive with the edge port settings or the root guard function.
Related commands: stp edged-port and stp root-protection.
# Enable the loop guard function on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] stp loop-protection
stp max-hops
stp max-hops hops
undo stp max-hops
View
Default level
2: System level
hops: Sets the maximum hops in the range of 1 to 40.
Use stp max-hops to set the maximum hops of the MST region.
Use undo stp max-hops to restore the default.
By default, the maximum number of hops of an MST region is 20.
The maximum hops limit the size of the MST region.
# Set the maximum hops of the MST region to 35.
[Sysname] stp max-hops 35
stp mcheck
stp mcheck
View
System view, Ethernet interface view, Layer 2 aggregate interface view
Default level
2: System level
None
Use stp mcheck to perform the mCheck operation globally or on a port.
If a port on a device that runs MSTP, RSTP, or PVST mode connects to an STP device, the port will automatically transit to the STP mode. It cannot automatically transit back to the original mode when:
· The STP device is shut down or removed.
· The STP device transits to the MSTP, RSTP, or PVST mode.
Then, you can perform an mCheck operation to forcibly transit the port to operation in the original mode.
The device operates in STP, RSTP, MSTP, or PVST mode depending on the spanning tree mode setting.
The stp mcheck command is effective only when the device operates in MSTP, RSTP, or PVST mode.
Configured in system view, the setting takes effect globally. Configured in Ethernet interface view, the setting takes effect only on the interface. Configured in Layer 2 aggregate interface view, the setting takes effect only on the aggregate interface. Configured on a member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group.
# Perform mCheck on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] stp mcheck
stp mode
stp mode { mstp | pvst | rstp | stp }
undo stp mode
View
Default level
2: System level
mstp: Configures the spanning tree switch to operate in MSTP mode.
pvst: Configures the spanning tree switch to operate in PVST mode.
rstp: Configures the spanning tree switch to operate in RSTP mode.
stp: Configures the spanning tree switch to operate in STP mode.
Use stp mode to configure the spanning tree operating mode.
Use undo stp mode to restore the default.
By default, a spanning tree switch operates in MSTP mode.
MSTP mode is compatible with RSTP mode, RSTP mode is compatible with STP mode, and PVST mode is incompatible with any other mode.
Related commands: stp mcheck and stp enable.
# Configure the spanning tree switch to operate in STP mode.
[Sysname] stp mode stp
stp no-agreement-check
undo stp no-agreement-check
View
Default level
2: System level
None
Use stp no-agreement-check to enable No Agreement Check on the ports.
Use undo stp no-agreement-check to disable No Agreement Check on the ports.
By default, No Agreement Check is disabled.
This feature takes effect only after you enable it on the root port.
# Enable No Agreement Check on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] stp no-agreement-check
stp pathcost-standard
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
undo stp pathcost-standard
View
Default level
2: System level
dot1d-1998: Configures the switch to calculate the default path cost for ports based on IEEE 802.1d-1998.
dot1t: Configures the switch to calculate the default path cost for ports based on IEEE 802.1t.
legacy: Configures the switch to calculate the default path cost for ports based on a private standard.
Use stp pathcost-standard to specify a standard for the switch to use when calculating the default path costs for ports.
Use undo stp pathcost-standard to restore the default.
By default, the switch calculates the default path cost for ports based on a private standard.
If you change the standard that the switch uses in calculating the default path costs, you restore the path costs to the default.
Related commands: stp cost and display stp.
# Configure the switch to calculate the default path cost for ports based on IEEE 802.1d-1998.
[Sysname] stp pathcost-standard dot1d-1998
stp point-to-point
stp point-to-point { auto | force-false | force-true }
undo stp point-to-point
View
Default level
2: System level
auto: Specifies automatic detection of the link type.
force-false: Specifies the non-point-to-point link type.
force-true: Specifies the point-to-point link type.
Use stp point-to-point to configure the link type of the ports.
Use undo stp point-to-point to restore the default.
By default, the setting is auto and the switch automatically detects whether a port connects to a point-to-point link.
When connecting to a non-point-to-point link, a port is incapable of rapid state transition.
You can configure the link type as point-to-point for a Layer 2 aggregate interface or a port that operates in full duplex mode. H3C recommends that you use the default setting to let the switch automatically detect the port link type.
The stp point-to-point force-false or stp point-to-point force-true command configured on a port in MSTP or PVST mode takes effect on all MSTIs or VLANs.
If the physical link to which the port connects is not a point-to-point link but you set it to be one, your configuration might bring a temporary loop.
# Configure the link connecting GigabitEthernet 4/0/1 as a point-to-point link.
[Sysname-GigabitEthernet4/0/1] stp point-to-point force-true
stp port priority
stp [ instance instance-id | vlan vlan-list ] port priority priority
undo stp [ instance instance-id | vlan vlan-list ] port priority
View
Default level
2: System level
instance instance-id: Sets the priority of the ports in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
priority: Specifies a port priority. The value range is 0 to 240 in steps of 16 (as in 0, 16, 32).
Use stp port priority to set the priority of ports.
Use undo stp port priority to restore the default.
By default, the port priority is 128.
To set the priority of an MSTP port in a specific MSTI, use this command with the MSTI specified. To set the priority of a PVST port in a specific VLAN or multiple VLANs, use this command with a VLAN list specified. To set the priority of an MSTP port in the CIST or an STP/RSTP port, use this command without specifying any MSTI or VLAN.
Port priority affects the role of a port in a spanning tree.
The smaller the value, the higher the port priority. If all ports on your switch use the same priority value, the port priority depends on the port index. The smaller the index, the higher the priority.
# In MSTP mode, set the priority of port GigabitEthernet 4/0/1 to 16 in MSTI 2.
[Sysname-GigabitEthernet4/0/1] stp instance 2 port priority 16
stp priority
stp [ instance instance-id | vlan vlan-list ] priority priority
undo stp [ instance instance-id | vlan vlan-list ] priority
View
Default level
2: System level
instance instance-id: Sets the priority of the switch in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
priority: Specifies a switch priority. The value range is 0 to 61440 in steps of 4096 (as in 0, 4096, 8192). You can set up to 16 priority values on the switch. The smaller the value, the higher the switch priority.
Use stp priority to set the switch priority.
Use undo stp priority to restore the default priority.
By default, the switch priority is 32768.
To set the priority of an MSTP switch in a specific MSTI, use this command with the MSTI specified. To set the priority of a PVST switch in a specific VLAN or multiple VLANs, use this command with a VLAN list specified. To set the priority of an MSTP switch in the CIST or an STP/RSTP switch, use this command without specifying any MSTI or VLAN.
# Set the switch priority to 4096 in MSTI 1.
[Sysname] stp instance 1 priority 4096
View
Default level
2: System level
None
Use stp region-configuration to enter MST region view.
Use undo stp region-configuration to restore the default MST region configurations.
These are the default settings for the MST region:
· The MST region name of the switch is the MAC address of the switch.
· All VLANs are mapped to the CIST.
· The MSTP revision level is 0.
After you enter MST region view, you can configure the MST region-related parameters, including the region name, VLAN-to-instance mappings, and revision level.
# Enter MST region view.
stp root primary
stp [ instance instance-id | vlan vlan-list ] root primary
undo stp [ instance instance-id | vlan vlan-list ] root
View
Default level
2: System level
instance instance-id: Configures the switch as the root bridge in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
Use stp root primary to configure the switch as the root bridge.
Use the undo stp root command to restore the default.
By default, the switch is not a root bridge.
To set an MSTP switch as the root bridge in a specific MSTI, use this command with the MSTI specified. To set a PVST switch as the root bridge in a specific VLAN or multiple VLANs, use this command with a VLAN list specified. To set an MSTP switch in the CIST or an STP/RSTP switch as the root bridge, use this command without specifying any MSTI or VLAN.
Once you specify the switch as the root bridge, you cannot change the switch priority.
Related commands: stp priority and stp root secondary.
# In MSTP mode, specify the switch as the root bridge of MSTI 1.
[Sysname] stp instance 1 root primary
stp root secondary
stp [ instance instance-id | vlan vlan-list ] root secondary
View
Default level
2: System level
instance instance-id: Configures the switch as a secondary root bridge in an MSTI specified by instance-id. The value range for the instance-id argument is 0 to 47, where 0 represents the CIST.
Use stp root secondary to configure the switch as a secondary root bridge.
By default, the switch is not a secondary root bridge.
To set an MSTP switch as a secondary root bridge in a specific MSTI, use this command with the MSTI specified. To set a PVST switch as a secondary bridge in a specific VLAN or multiple VLANs, use this command with a VLAN list specified. To set an MSTP switch in the CIST or an STP/RSTP switch as a secondary root bridge, use this command without specifying any MSTI or VLAN.
Once you specify the switch as a secondary root bridge, you cannot change the switch priority.
Related commands: stp priority and stp root primary.
# In MSTP mode, specify the switch as a secondary root bridge in MSTI 0.
[Sysname] stp instance 0 root secondary
stp root-protection
stp root-protection
undo stp root-protection
View
Default level
2: System level
None
Use stp root-protection to enable the root guard function on the ports.
Use undo stp root-protection to disable the root guard function on the ports.
By default, the root guard function is disabled.
On a port, the loop guard function and the root guard function are mutually exclusive.
# Enable the root guard function for GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] stp root-protection
stp tc-protection
stp tc-protection enable
stp tc-protection disable
View
Default level
2: System level
None
Use the stp tc-protection enable command to enable the TC-BPDU attack guard function for the switch.
Use the stp tc-protection disable command to disable the TC-BPDU attack guard function for the switch.
By default, the TC-BPDU attack guard function is enabled.
With the TC-BPDU guard function, you can set the maximum number of immediate forwarding address entry flushes that the device can perform every a certain period of time (10 seconds). For TC-BPDUs received in excess of the limit, the device performs a forwarding address entry flush when the time period expires. This prevents frequent flushing of forwarding address entries.
Related commands: stp tc-protection threshold.
# Enable the TC-BPDU attack guard function for the switch.
[Sysname] stp tc-protection enable
stp tc-protection threshold number
undo stp tc-protection threshold
View
Default level
2: System level
number: Sets the maximum number of immediate forwarding address entry flushes that the switch can perform every a certain period of time (10 seconds). The value range for this argument is 1 to 255.
Use stp tc-protection threshold to configure the maximum number of forwarding address entry flushes that the switch can perform every a certain period of time (10 seconds).
Use undo stp tc-protection threshold to restore the default.
By default, the switch can perform a maximum of six forwarding address entry flushes every 10 seconds.
Related commands: stp tc-protection.
# Configure the switch to perform up to 10 forwarding address entry flushes every 10 seconds.
[Sysname] stp tc-protection threshold 10
stp tc-snooping
stp tc-snooping
undo stp tc-snooping
View
Default level
2: System level
None
Use stp tc-snooping to enable topology change (TC) snooping.
Use undo stp tc-snooping to disable TC snooping.
By default, TC snooping disabled.
TC snooping is supported on Ethernet interface cards only.
TC snooping and the spanning tree feature are mutually exclusive. Globally disable the spanning tree feature before you enable TC snooping.
TC snooping is ineffective on the ports on which BPDU tunneling is enabled for STP. For more information about BPDU tunneling, see Layer 2—LAN Switching Configuration Guide.
Related commands: stp enable.
# Globally disable the spanning tree feature and enable TC snooping.
[Sysname] undo stp enable
[Sysname] stp tc-snooping
stp [ vlan vlan-list ] timer forward-delay time
undo stp [ vlan vlan-list ] timer forward-delay
View
Default level
2: System level
time: Sets the forward delay in centiseconds. The value range is 400 to 3000 in steps of 100 (as in 400, 500, 600).
Use stp timer forward-delay to set the forward delay timer of the switch.
Use undo stp timer forward-delay to restore the default.
By default, the forward delay timer is 1500 centiseconds.
The forward delay timer determines the time interval of state transition. To prevent temporary loops, a spanning tree port goes through the learning (intermediate) state before it transits from the discarding to the forwarding state. To stay synchronized with the remote device, the port has a wait period between transition states that is determined by the forward delay timer.
To set the forward delay in STP/RSTP/MSTP mode, use this command without any VLAN specified. To set the forward delay for a specific VLAN or multiple VLANs in PVST mode, use this command with a VLAN list specified.
H3C recommends not setting the forward delay with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the forward delay timer. If the network diameter uses the default value, the forward delay timer also uses the default value.
Related commands: stp timer hello, stp timer max-age, and stp bridge-diameter.
# Set the forward delay timer to 2000 centiseconds.
[Sysname] stp timer forward-delay 2000
stp timer hello
stp [ vlan vlan-list ] timer hello time
undo stp [ vlan vlan-list ] timer hello
View
Default level
2: System level
time: Sets the hello time in centiseconds. The value range is 100 to 1000 in steps of 100 (as in 100, 200, 300).
Use stp timer hello to set the hello time of the switch.
Use undo stp timer hello to restore the default.
By default, the hello time is 200 centiseconds.
Hello time is the time interval at which spanning tree switches send configuration BPDUs to maintain spanning tree. If a switch fails to receive configuration BPDUs within the set period of time, a new spanning tree calculation process will be triggered due to timeout.
To set the hello time in STP/RSTP/MSTP mode, use this command without any VLAN specified. To set the hello time for a specific VLAN or multiple VLANs in PVST mode, use this command with a VLAN list specified.
H3C recommends not setting the hello time with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the hello timer. If the network diameter uses the default value, the hello timer also uses the default value.
Related commands: stp timer forward-delay, stp timer max-age, and stp bridge-diameter.
# In MSTP mode, set the hello time to 400 centiseconds.
[Sysname] stp timer hello 400
# In PVST mode, set the hello time to 400 centiseconds for VLAN 400.
[Sysname] stp vlan 2 timer hello 400
stp timer max-age
stp [ vlan vlan-list ] timer max-age time
undo stp [ vlan vlan-list ] timer max-age
View
Default level
2: System level
time: Sets the max age in centiseconds. The value range is 600 to 4000 in steps of 100 (as in 600, 700, 800).
Use stp timer max-age to set the max age timer of the switch.
Use undo stp timer max-age to restore the default.
By default, the max age is 2000 centiseconds.
In the CIST of an MSTP network or each VLAN of a PVST network, the switch determines whether a configuration BPDU received on a port has expired, based on the max age timer. If yes, a new spanning tree calculation process starts. The max age timer does not take effect on other MSTIs except the CIST (or MSTI 0).
To set the max age timer in STP/RSTP/MSTP mode, use this command without any VLAN specified. To set the max age timer for a specific VLAN or multiple VLANs in PVST mode, use this command with a VLAN list specified.
H3C recommends not setting the max age timer with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the max age timer. If the network diameter uses the default value, the max age timer also uses the default value.
Related commands: stp timer forward-delay, stp timer hello, and stp bridge-diameter.
# Set the max age timer to 1000 centiseconds.
[Sysname] stp timer max-age 1000
stp timer-factor
stp timer-factor factor
undo stp timer-factor
View
Default level
2: System level
factor: Sets the timeout factor in the range of 1 to 20.
Use stp timer-factor to set the timeout factor, which decides the timeout time.
Timeout time = timeout factor × 3 × hello time.
Use undo stp timer-factor to restore the default.
By default, the timeout factor is 3.
After the network topology is stabilized, each non-root-bridge switch forwards configuration BPDUs to the surrounding devices at the interval of hello time to check whether any link is faulty. If a switch does not receive a BPDU from the upstream device within nine times the hello time, it will assume that the upstream device has failed and start a new spanning tree calculation process.
In a stable network, this kind of spanning tree calculation might occur because the upstream device is busy. You can avoid such unwanted spanning tree calculations by lengthening the timeout time, saving the network resources. H3C recommends you to set the timeout factor to 5, 6, or 7 for a stable network.
Related commands: stp timer hello.
# Set the timeout factor of the switch to 7.
[Sysname] stp timer-factor 7
stp transmit-limit
stp transmit-limit limit
undo stp transmit-limit
View
Default level
2: System level
limit: Sets the maximum number of BPDUs the ports can send within each hello time. The value range is 1 to 255.
Use stp transmit-limit to set the maximum transmission rate of the ports, which specifies the maximum number of BPDUs the ports can send within each hello time.
Use undo stp transmit-limit to restore the default.
By default, the maximum transmission rate of all ports is 10. Each port can send up to 10 BPDUs within each hello time.
A larger maximum transmission rate value requires more system resources. An appropriate maximum transmission rate setting can limit the speed at which a port sends BPDUs and prevent spanning tree protocols from using excessive bandwidth resources during network topology changes. H3C recommends you to use the default value.
# Set the maximum transmission rate of port GigabitEthernet 4/0/1 to 5.
[Sysname-GigabitEthernet4/0/1] stp transmit-limit 5
vlan-mapping modulo
vlan-mapping modulo modulo
View
MST region view
Default level
2: System level
modulo: Sets the modulo value in the range of 1 to 47.
Use vlan-mapping modulo to map VLANs in the MST region to MSTIs according to the specified modulo value, quickly creating a VLAN-to-instance mapping table.
By default, all VLANs are mapped to the CIST (MSTI 0).
This command maps each VLAN to the MSTI whose ID is (VLAN ID - 1) %modulo + 1, where (VLAN ID - 1) %modulo is the modulo operation for (VLAN ID - 1). If the modulo value is 15, for example, then VLAN 1 will be mapped to MSTI 1, VLAN 2 to MSTI 2, VLAN 15 to MSTI 15, VLAN 16 to MSTI 1, and so on.
Related commands: region-name, revision-level, display stp region-configuration, check region-configuration, and active region-configuration.
# Map VLANs to MSTIs as per modulo 8.
[Sysname-mst-region] vlan-mapping modulo 8
