04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18204-Layer 2 - LAN Switching Command Reference
06-QinQ Commands
06-QinQ Commands 70.19 KB
QinQ configuration commands
qinq enable
qinq enable
undo qinq enable
View
Layer 2 Ethernet interface view, port group view, Layer 2 aggregate interface view
Default level
2: System level
None
Use qinq enable to enable the basic QinQ function.
Use undo qinq enable to disable the basic QinQ function.
By default, the basic QinQ function is disabled.
With the basic QinQ function enabled on a port, the port tags each received frame with the VLAN tag of the default VLAN of the port.
Configured in Layer 2 Ethernet interface view, the command takes effect on the interface only. Configured in Layer 2 aggregate interface view, the command takes effect on the aggregate interface and the member ports in its aggregation group. Configured in port group view, the command takes effect on all ports in the port group.
# Enable basic QinQ function on GigabitEthernet 4/0/1.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] qinq enable
qinq ethernet-type
qinq ethernet-type hex-value
undo qinq ethernet-type
View
Default level
2: System level
hex-value: Sets a hexadecimal tag protocol identifier (TPID) value, excluding the common protocol type values listed in Table 1.
Table 1 Common protocol type values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1X
0x888E
Cluster
0x88A7
Reserved
0xFFFD/0xFFFE/0xFFFF
Use qinq ethernet-type to set the TPID in the outer VLAN tag of QinQ frames.
Use undo qinq ethernet-type to restore the default.
The default TPID in the outer VLAN tag of QinQ frames is 0x8100.
A board supports only one TPID in addition to its default TPID.
Configured in Layer 2 Ethernet interface view, the command takes effect on the interface only. Configured in aggregate interface view, the command takes effect on the Layer 2 aggregate interface and the member ports in its aggregation group. Configured in port group view, the command takes effect on all ports in the port group.
If you execute the command multiple times, the most recent TPID value takes effect.
# Set the TPID in the outer VLAN tag of QinQ frames to 0x9100 on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] qinq ethernet-type 9100
