- 04-Layer 2 - LAN Switching Command Reference
- 01-VLAN Commands
- 02-MAC Address Table Commands
- 03-Spanning Tree Commands
- 04-Ethernet Link Aggregation Commands
- 05-Port Isolation Commands
- 06-QinQ Commands
- 07-VLAN Mapping Commands
- 08-BPDU Tunneling Commands
- 09-GVRP Commands
- 10-Loopback Detection Commands
- 11-VLAN Termination Commands
- 12-MAC-in-MAC Commands
- 13-LLDP Commands
- 14-MVRP Commands
| 05-Port Isolation Commands | 67.97 KB |
community-vlan vlan
community-vlan vlan { vlan-id-list | all }
undo community-vlan
View
Isolation group view
Default level
2: System level
vlan-id-list: Specifies a list of VLANs in the format of { vlan-id1 [ to vlan-id2 ] }&<1-10>, where vlan-id is in the range of 1 to 4094 with vlan-id1 no smaller than vlan-id2, and &<1-10> indicates that you can specify up to ten vlan-id1 [ to vlan-id2 ] options.
all: Configures all VLANs in the isolation group as community VLANs.
Use community-vlan vlan to configure community VLANs in an isolation group.
Use undo community-vlan to remove all community VLANs from an isolation group.
By default, an isolation group does not contain any community VLANs.
The command is available only when the switch operates in non-hybrid mode. For more information about the system working modes, see Fundamentals Configuration Guide.
You cannot repeatedly configure the community-vlan vlan command. To update the community VLANs in an isolation group, you must use the undo community-vlan vlan command first.
# Configure VLAN 3 as a community VLAN in isolation group 1.
[Sysname] port-isolate group 1
[Sysname-port-isolate-group1] community-vlan vlan 3
# Remove all community VLANs from isolation group 2.
[Sysname] port-isolate group 2
[Sysname-port-isolate-group2] undo community-vlan
display port-isolate group
display port-isolate group [ group-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-number: Specifies an isolation group number. The value range is 1 to 16 in standalone mode and 1 to 4 in IRF mode.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display port-isolate group to display port isolation group information.
If no isolation group is specified, this command displays information about all isolation groups.
# Display information about all isolation groups.
<Sysname> display port-isolate group
Port-isolate group information:
Uplink port support: NO
Group ID: 2
Group members:
GigabitEthernet4/0/1
Port-isolate group information |
Port isolation group information. |
Uplink port support |
Indicates whether the uplink port is supported. |
Group ID |
Isolation group number. |
Group members |
Isolated ports in the isolation group. |
port-isolate enable
port-isolate enable group group-number
undo port-isolate enable
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
Default level
2: System level
group group-number: Specifies an isolation group by its number. The value range is 1 to 16 in standalone mode and 1 to 4 in IRF mode.
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from the isolation group.
Before assigning a port to an isolation group, create the isolation group with the port-isolate group command first.
The number of ports that can be assigned to an isolation group is not limited.
To assign Ethernet ports to the isolation group one by one, perform the command in Layer 2 Ethernet interface view.
To bulk assign Ethernet ports to the isolation group, perform the command in port group view.
To assign a Layer 2 aggregate interface to the isolation group, perform the command in Layer 2 aggregate interface view. The configuration applies to the Layer 2 aggregate interface and all its member ports. If the device fails to apply the port-isolate enable command to a Layer 2 aggregate interface, it does not assign any member port of the aggregate interface to the isolation group. If the failure occurs on a member port, the device can still assign other member ports to the isolation group. For more information about Layer 2 aggregate interfaces, see Layer 2—LAN Switching Configuration Guide.
# Assign ports GigabitEthernet 4/0/1 to isolation group 2.
[Sysname] interface GigabitEthernet 4/0/1
[Sysname-GigabitEthernet4/0/1] port-isolate enable group 2
port-isolate group
port-isolate group group-number
undo port-isolate group { group-number | all }
View
Default level
2: System level
group-number: Specifies the isolation group number. The value range is 1 to 16 in standalone mode and 1 to 4 in IRF mode.
all: Deletes all isolation groups.
Use port-isolate group to create an isolation group and enter isolation group view if the switch operates in non-hybrid mode.
Use undo port isolate group to delete one or all isolation groups.
# Create isolation group 2.
port-isolate uplink-port
port-isolate uplink-port group group-number
undo port-isolate uplink-port
View
Ethernet interface view, Layer-2 aggregate interface view
Default level
2: System level
group-number: Specifies an isolation group by its number. The value range is 1 to 16.
Use port-isolate uplink-port to configure the specified port as the uplink port in the isolation group.
Use undo port-isolate uplink-port to remove the uplink port in the isolation group.
This command is available only when the switch operates in hybrid mode.
Before configuring a port as the uplink port of an isolation group, create the isolation group first.
The port-isolate enable and port-isolate uplink-port commands are mutually exclusive. After you configure a port as an isolated port of an isolation group, you cannot configure the port as the uplink port of any isolation group, and vice versa.
The member port of an aggregation group cannot be configured as the uplink port of an isolation group and vice versa. If you assign a port to an aggregation group and to an isolation group as the uplink port at the same time, the aggregation group configuration will take effect and the isolation group configuration will be removed for backward configuration file compatibility.
# Configure port GigabitEthernet 3/0/1 as the uplink port of the isolation group.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] port-isolate uplink-port group 2
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as the uplink port of the isolation group.
[Sysname] interface Bridge-Aggregation 1
[Sysname-Bridge-Aggregation1] port-isolate uplink-port group 2
