- 04-Layer 2 - LAN Switching Command Reference
- 01-VLAN Commands
- 02-MAC Address Table Commands
- 03-Spanning Tree Commands
- 04-Ethernet Link Aggregation Commands
- 05-Port Isolation Commands
- 06-QinQ Commands
- 07-VLAN Mapping Commands
- 08-BPDU Tunneling Commands
- 09-GVRP Commands
- 10-Loopback Detection Commands
- 11-VLAN Termination Commands
- 12-MAC-in-MAC Commands
- 13-LLDP Commands
- 14-MVRP Commands
| 04-Ethernet Link Aggregation Commands | 160.79 KB |
Ethernet link aggregation configuration commands
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
link-aggregation lacp traffic-redirect-notification enable
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
When a device operating in IRF mode is enabled with enhanced IRF mode, it does not support creating Layer 3 Ethernet interfaces/subinterfaces or Layer 3 aggregate interfaces/subinterfaces.
default
default
View
Layer 2 aggregate interface view, Layer 3 aggregate interface view, Layer 3 aggregate subinterface view
Default level
2: System level
None
Use default to restore the default settings for an aggregate interface or subinterface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can identify these commands by using the display this command in interface view, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you perform it on a live network. |
# Restore the default settings for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Description of the interface, which is a string of 1 to 80 characters.
Use description to set the description of the interface.
By default, the description of an interface is interface-name Interface. For example, the default description of interface Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Set the description of Layer 2 aggregate interface Bridge-Aggregation 1 to link-aggregation interface.
[Sysname-Bridge-Aggregation1] description link-aggregation interface
display interface
display interface [ bridge-aggregation | route-aggregation ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bridge-aggregation: Displays information about Layer 2 aggregate interfaces.
route-aggregation: Displays information about Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number. The value range for the interface-number argument is the set of all existing aggregate interface numbers.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in the down state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface to display aggregate interface information.
· If bridge-aggregation | route-aggregation is not specified, this command displays information about all interfaces.
· If bridge-aggregation or route-aggregation is specified without any interface number specified, this command displays information about all aggregate interfaces.
· If bridge-aggregation interface-number or route-aggregation interface-number is specified, this command displays information about the specified aggregate interface.
# Display information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1 current state: DOWN
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
PVID: 1
Port link-type: access
Tagged VLAN ID : none
Untagged VLAN ID : 1
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
0 broadcasts, 0 multicasts, 0 pauses
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
# Display information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1 current state: DOWN
Line protocol current state: DOWN
Description: Route-Aggregation1 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e20a-0001
IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e20a-0001
Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
Interface Link Speed Duplex Type PVID Description
BAGG1 DOWN auto A A 1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
RAGG1 DOWN DOWN --
# Display information about all Layer 2 aggregate interfaces in the down state.
<Sysname> display interface bridge-aggregation brief down
Interface Link Cause
BAGG1 DOWN Not connected
# Display information about all Layer 3 aggregate interfaces in the down state.
<Sysname> display interface route-aggregation brief down
RAGG1 DOWN Not connected
Bridge-Aggregation1/Route-Aggregation1 current state |
Layer 2 or Layer 3 interface status: · DOWN (Administratively)—The interface is administratively shut down with the shutdown command. · DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link is faulty). · UP—The Ethernet interface is both administratively and physically up. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
PVID |
Default VLAN ID. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. Never indicates the reset counters interface command has never been used on the interface since the switch’s startup. |
Last 300 seconds input/output |
Average input/output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received/sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received/sent on the interface. |
Line protocol current state |
Link layer state of the interface. |
Internet protocol processing |
IP packet processing. Disabled indicates that IP packets cannot be processed. For an interface configured with an IP address, this field changes to Internet Address is. |
Output queue : (Urgent queuing : Size/Length/Discards) |
Output queue (current message number in the urgent queue/maximum number of messages allowed in the urgent queue/number of discarded messages). |
Output queue : (Protocol queuing : Size/Length/Discards) |
Output queue (current message number in the protocol queue/maximum number of messages allowed in the protocol queue/number of discarded messages). |
Output queue : (FIFO queuing : Size/Length/Discards) |
Output queue (current message number in the FIFO queue/maximum number of messages allowed in the FIFO queue/number of discarded messages). |
The brief information of interface(s) under route mode |
Brief information about Layer 3 interfaces. |
The brief information of interface(s) under bridge mode |
Brief information about Layer 2 interfaces. |
Link: ADM - administratively down; Stby - standby |
Link status: · ADM—The interface has been administratively shut down. To recover its physical layer state, execute the undo shutdown command. · Stby—The interface is operating as a backup interface. |
Speed or Duplex: (a)/A - auto; H - half; F - full |
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, letter a in parentheses. If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the auto negotiation flag, letter a in parentheses or a capital A. Letter H indicates the half duplex mode, and letter F indicates the full duplex mode. |
Type: A - access; T - trunk; H - hybrid |
Link type options for Ethernet interfaces. |
Protocol: (s) - spoofing |
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present, its protocol attribute includes the spoofing flag (an s in parentheses). |
Abbreviated interface name. |
Link |
Physical link state of the interface. |
Speed |
Interface speed, in bps. |
Cause |
Cause of a DOWN physical link. |
display lacp system-id
display lacp system-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display lacp system-id to display the system ID of the local system.
The system ID comprises the system LACP priority and the system MAC address.
You can use the lacp system-priority command to change the LACP priority of the local system.
Although you specify the LACP priority value in decimal format in the lacp system-priority command, it is displayed as a hexadecimal value with the display lacp system-id command.
Related commands: lacp system-priority.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 00e0-fc00-0100
Actor System ID |
Local system ID, which comprises the system LACP priority (0x8000 in this sample output) and the system MAC address (00e0-fc00-0100 in this sample output). |
display link-aggregation load-sharing mode [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display link-aggregation load-sharing mode to display the load sharing criteria of load-sharing link aggregation groups.
# Display the default load sharing criteria when no load sharing criteria have been configured.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: destination-mac address, source-mac address
Layer 3 traffic: destination-mac address, source-mac address,
destination-ip address, source-ip address
Layer 4 traffic: destination-mac address, source-mac address,
destination-ip address, source-ip address,
destination-port, source-port
MPLS traffic : destination-mac address, source-mac address,
mpls-label1, mpls-label2,
mpls-label3
# After you configure load sharing criteria, display the load sharing criteria configuration.
Link-Aggregation Load-Sharing Mode |
Displays the load sharing criteria for load-sharing link aggregation groups. · By default, the link-aggregation load sharing criteria for Layer 2 traffic, Layer 3 traffic, Layer 4 traffic, and MPLS traffic are displayed. · Otherwise, the user-configured link-aggregation load sharing criteria are displayed. |
Layer 2 traffic |
Default link-aggregation load sharing criteria for Layer 2 traffic. |
Layer 3 traffic |
Default link-aggregation load sharing criteria for Layer 3 traffic. |
Layer 4 traffic |
Default link-aggregation load sharing criteria for Layer 4 traffic. |
MPLS traffic |
Default link-aggregation load sharing criteria for MPLS traffic. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing criteria. |
display link-aggregation member-port [ interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number indicates the port type and port number.
Use display link-aggregation member-port to display the detailed link aggregation information of the specified member ports or all member ports if no port is specified.
For a member port in a static aggregation group, only the port number and operational key are displayed, because the aggregation group is unaware of information about the peer groups.
# Display the detailed link aggregation information of GigabitEthernet 4/0/1, a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 4/0/1
G -- Defaulted, H -- Expired
GigabitEthernet4/0/1:
Aggregation Interface: Bridge-Aggregation1
Port Number: 1
Port Priority: 32768
Oper-Key: 1
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. The letter is present when its bit is 1 and absent when its bit is 0. · A—Indicates whether LACP is enabled. 1 indicates enabled, and 0 indicates disabled. · B—Indicates the LACP short or long timeout. 1 indicates short timeout, and 0 indicates long timeout. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes, and 0 indicates no. · D—Indicates whether the sending system considers that the link is synchronized. 1 indicates yes, and 0 indicates no. · E—Indicates whether the sending system considers that the incoming frames are collected. 1 indicates yes, and 0 indicates no. · F—Indicates whether the sending system considers that the outgoing frames are distributed. 1 indicates yes, and 0 indicates no. · G—Indicates whether the sending system receives frames in the default state. 1 indicates yes, and 0 indicates no. · H—Indicates whether the sending system receives frames in the expired state. 1 indicates yes, and 0 indicates no. |
Aggregation Interface |
Aggregate interface to which the port belongs. |
Port Priority |
Aggregation priority of the port. |
Oper-key |
Operational key. |
display link-aggregation summary [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display link-aggregation summary to display the summary information of all aggregation groups.
Information about the remote system for a static link aggregation group might be either shown as none or not displayed, because the aggregation group is unaware of information about the peer groups.
# Display the summary information of all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 00e0-fc00-9512
AGG AGG Partner ID Select Unselect Share
Interface Mode Ports Ports Type
BAGG2 S none 1 1 Shar
Table 5 Command output
Aggregation Interface Type |
Aggregate interface type: · BAGG—Layer 2 aggregate interface. · RAGG—Layer 3 aggregate interface. |
Aggregation Mode |
Aggregation group type: · S—Static link aggregation. · D—Dynamic aggregation. |
Loadsharing Type |
Load-sharing type: · Shar—Load sharing. · NonS—Non-load sharing. |
Actor System ID |
Local system ID, which comprises the system LACP priority and the system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the partner, which comprises the system LACP priority and the system MAC address. |
Select Ports |
Number of Selected ports. |
Unselect Ports |
Number of Unselected ports. |
Share Type |
Load sharing type. |
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bridge-aggregation: Displays detailed information about the Layer 2 aggregation groups corresponding to Layer 2 aggregate interfaces.
route-aggregation: Displays detailed information about the Layer 3 aggregation groups corresponding to Layer 3 aggregate interfaces.
interface-number: Specifies an aggregate interface number in the range of 1 to 1024. You can configure up to 240 aggregation groups on the switch.
Use display link-aggregation verbose to display detailed information about the aggregation groups corresponding to the aggregate interfaces in the system.
If you do not specify an aggregate interface, this command displays detailed information about the aggregation groups corresponding to all aggregate interfaces.
If you specify only the aggregate interface type, this command displays detailed information about the aggregation groups corresponding to all aggregate interfaces of that type.
# Display the detailed information about the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port Status: S -- Selected, U -- Unselected
Aggregation Interface: Bridge-Aggregation10
Aggregation Mode: Static
Port Status Priority Oper-Key
GE3/0/1 S 32768 1
GE3/0/2 U 32768 2
Table 6 Command output
Loadsharing Type |
Port Status |
Port state: Selected or Unselected. |
Flags |
Name of the aggregate interface. |
Aggregation Mode |
Type of the aggregation group: · Static for static aggregation. · Dynamic for dynamic aggregation. |
Port |
Port type and number. |
Status |
State of the port. |
Oper-Key |
Operational key value. |
enable snmp trap updown
undo enable snmp trap updown
View
Default level
2: System level
None
Use enable snmp trap updown to enable link state trapping for the aggregate interface.
Use undo enable snmp trap updown to disable link state trapping for the aggregate interface.
By default, linkUp/linkDown trap generation is enabled for an aggregate interface.
For an aggregate interface to generate linkUp/linkDown traps when its link state changes, you must enable link state trapping globally with the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command.
For more information about the snmp-agent trap enable command, see Network Management and Monitoring Command Reference.
# Enable linkUp/linkDown trap generation on interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] enable snmp trap updown
undo interface bridge-aggregation interface-number
View
Default level
2: System level
interface-number: Specifies a Layer 2 aggregate interface number in the range of 1 to 1024. You can configure up to 240 aggregation groups on the switch.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
Use undo interface bridge-aggregation to remove a Layer 2 aggregate interface.
When a Layer 2 aggregate interface is created, a Layer 2 aggregation group with the same number is automatically created. If you remove the Layer 2 aggregate interface, you also remove the Layer 2 aggregation group, and any member ports will leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1 and enter its view.
undo interface route-aggregation { interface-number | interface-number.subnumber }
View
Default level
2: System level
interface-number: Specifies a Layer 3 aggregate interface number.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number in the range of 1 to 4093 and is separated from the main interface number by a dot (.).
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter Layer 3 aggregate interface or subinterface view.
Use undo interface route-aggregation to remove a Layer 3 aggregate interface or subinterface.
Upon creation of a Layer 3 aggregate interface, a Layer 3 aggregation group numbered the same is created automatically. Removing the Layer 3 aggregate interface also removes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Removing a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
The switch operating in a non-standard operating mode does not support Layer 3 aggregation interfaces. For more information about system operating modes, see Fundamentals Configuration Guide.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
lacp period short
lacp period short
undo lacp period
View
Ethernet interface view
Default level
2: System level
None
Use lacp period short to set the LACP timeout interval on a port to the short timeout interval (1 second).
Use undo lacp period to restore the default setting.
The default LACP timeout interval is the long timeout interval (30 seconds).
# Set the LACP timeout interval on GigabitEthernet 4/0/1 to the short timeout interval (1 second).
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] lacp period short
lacp system-priority system-priority
undo lacp system-priority
View
Default level
2: System level
system-priority: LACP priority of the local system, in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
Use lacp system-priority to set the LACP priority of the local system.
Use undo lacp system-priority to restore the default.
By default, the system LACP priority is 32768.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation irf-enhanced
undo link-aggregation irf-enhanced
View
Default level
2: System level
Use link-aggregation irf-enhanced to enable link aggregation enhancement in IRF mode.
Use undo link-aggregation irf-enhanced to restore the default.
By default, link aggregation enhancement is disabled in IRF mode.
If one end is configured with this command, make sure the other end is also configured with this command. Otherwise, link aggregation might not work.
When this command is configured, the maximum number of aggregated links (Selected ports) supported in hardware for an aggregation is identical to the maximum number of aggregated links supported per chassis multiplied by the number of member chassis.
# Enable link aggregation enhancement in IRF mode.
[Sysname] link-aggregation irf-enhanced
undo link-aggregation lacp traffic-redirect-notification enable
View
Default level
2: System level
None
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
By default, link-aggregation traffic redirection is disabled.
Link-aggregation traffic redirection applies only to dynamic link aggregation groups.
To prevent traffic interruption, you must enable link-aggregation traffic redirection on switches at both ends of the aggregate link.
Do not enable both MSTP and link-aggregation traffic redirection at the same time, because light packet loss might occur when a card or the switch reboots.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode { { destination-ip | destination-mac | destination-port | ingress-port | mpls-label1 | mpls-label2 | mpls-label3 | source-ip | source-mac | source-port } * | per-packet }
undo link-aggregation load-sharing mode
View
Default level
2: System level
destination-ip: Performs load sharing in link aggregation groups based on destination IP address.
destination-mac: Performs load sharing in link aggregation groups based on destination MAC address.
destination-port: Performs load sharing in link aggregation groups based on destination port.
ingress-port: Performs load sharing in link aggregation groups based on ingress port.
mpls-label1: Performs load sharing for MPLS traffic based on Layer 1 label.
mpls-label2: Performs load sharing for MPLS traffic based on Layer 2 label.
mpls-label3: Performs load sharing for MPLS traffic based on Layer 3 label.
source-ip: Performs load sharing in link aggregation groups based on source IP address.
source-mac: Performs load sharing in link aggregation groups based on source MAC address.
source-port: Performs load sharing in link aggregation groups based on source port.
per-packet: Performs per-packet load sharing in link aggregation groups.
Use link-aggregation load-sharing mode to configure link-aggregation load sharing criteria.
Use undo link-aggregation load-sharing mode to restore the default.
By default, the switch performs load sharing based on all the criteria except ingress port and per-packet.
The load sharing criteria that you configure will overwrite the previous criteria. For example, to change the load sharing criteria from source port based to source and destination ports based, you must configure the link-aggregation load-sharing mode destination-port source-port command (not the link-aggregation load-sharing mode source-port command) to overwrite the link-aggregation load-sharing mode destination-port command.
Per-packet load sharing is not configurable when the system is operating in IRF mode or in hybrid mode. Because per-packet load sharing might disorder the packets, H3C recommends not specifying the per-packet keyword when the internal interface on the OAP card belongs to an aggregation group. For more information about the system operating mode, see Fundamentals Configuration Guide. For more information about the OAP card, see OAA Configuration Guide.
All the criteria except mpls-label1, mpls-label2, mpls-label3 and per-packet, if configured, apply to equal-cost multi-path (ECMP) load sharing for unicast traffic. If the per-packet keyword is specified, ECMP load sharing is performed according to the default load sharing criteria supported by the switch. For more information about ECMP routing, see Layer 3—IP Routing Configuration Guide.
The ingress-port keyword is mutually exclusive with any other keyword of this command.
# Configure destination MAC-based load sharing for link aggregation groups.
[Sysname] link-aggregation load-sharing mode destination-mac
link-aggregation mode
link-aggregation mode dynamic
undo link-aggregation mode
View
Default level
2: System level
None
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode.
Use undo link-aggregation mode to restore the default.
By default, an aggregation group operates in static aggregation mode.
You cannot change the aggregation mode of an aggregation group that contains member ports.
# Configure the aggregation group corresponding to Bridge-Aggregation 1 to operate in dynamic aggregation mode.
link-aggregation port-priority port-priority
undo link-aggregation port-priority
View
Default level
2: System level
port-priority: Specifies a port aggregation priority in the range of 0 to 65535. The smaller the value, the higher the port aggregation priority.
Use link-aggregation port-priority to set the aggregation priority of a port.
Use undo link-aggregation port-priority to restore the default.
The default aggregation priority of a port is 32768.
# Set the aggregation priority of GigabitEthernet 4/0/1 to 64.
[Sysname-GigabitEthernet4/0/1] link-aggregation port-priority 64
link-aggregation selected-port maximum number
undo link-aggregation selected-port maximum
View
Default level
2: System level
number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value is in the range of 1 to 48.
Use link-aggregation selected-port maximum to configure the maximum number of Selected ports allowed in the aggregation group.
Use undo link-aggregation selected-port maximum to restore the default setting.
By default, the maximum number of Selected ports allowed in an aggregation group is limited only by the hardware capabilities of the member ports.
Executing this command might cause some of the selected member ports in the aggregation group to become unselected.
If you configure both the maximum number of Selected ports allowed in the aggregation group and the minimum number of Selected ports in the aggregation group, make sure that the former is no smaller than the latter. For more information about the minimum number of Selected ports in the aggregation group, see link-aggregation selected-port minimum.
# Configure the maximum number of Selected ports allowed as 3 in the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 3
link-aggregation selected-port minimum number
undo link-aggregation selected-port minimum
View
Default level
2: System level
number: Specifies the minimum number of Selected ports in the aggregation group required to bring up the aggregate interface. The value is in the range of 1 to 48.
Use link-aggregation selected-port minimum to configure the minimum number of Selected ports in the aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
By default, the minimum number of Selected ports in an aggregation group is not specified.
Executing this command might cause all the member ports in the aggregation group to become unselected.
Make sure that the minimum number of Selected ports in the aggregation group is the same both ends.
# Configure the minimum number of Selected ports in the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 1 as 3.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
mtu
mtu size
undo mtu
View
Default level
2: System level
size: Sets the maximum transmission unit (MTU) in bytes.
Use mtu to set the MTU of the Layer 3 aggregate interface or subinterface.
By default, the MTU for Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
# Set the MTU of Layer 3 aggregate interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
port link-aggregation group
port link-aggregation group number
undo port link-aggregation group
View
Default level
2: System level
number: Sets an aggregation group number in the range of 1 to 1024. You can configure up to 240 aggregation groups on the switch.
Use port link-aggregation group to assign the Ethernet interface to the specified aggregation group.
Use undo port link-aggregation group to remove the Ethernet interface from the specified aggregation group.
An Ethernet interface can belong to only one aggregation group.
# Assign GigabitEthernet 4/0/1 to aggregation group 22.
[Sysname-GigabitEthernet4/0/1] port link-aggregation group 22
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
View
Default level
2: System level
bridge-aggregation: Clears statistics for Layer 2 aggregate interfaces.
route-aggregation: Clears statistics for Layer 3 aggregate interfaces.
Use reset counters interface to clear the statistics of the specified aggregate interface or interfaces.
Before collecting statistics for an aggregate interface within a specific period, you must clear the existing statistics on the interface.
· If no keywords or argument is specified, the command clears the statistics of all interfaces in the system.
· If only the bridge-aggregation or route-aggregation keyword is specified, the command clears the statistics of all Layer 2 or Layer 3 aggregate interfaces.
· If the bridge-aggregation interface-number or route-aggregation interface-number option is specified, the command clears the statistics of the specified Layer 2 or Layer 3 aggregate interface.
· The bridge-aggregation or route-aggregation keyword becomes available only after you create Layer 2 or Layer 3 aggregate interfaces on the switch.
# Clear the statistics of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
View
Default level
1: Monitor level
Use reset lacp statistics to clear the LACP statistics for the specified member ports or all member ports, if no member ports are specified.
Related commands: display link-aggregation member-port.
# Clear the LACP statistics for all member ports.
<Sysname> reset lacp statistics
shutdown
shutdown
View
Default level
2: System level
None
Use shutdown to shut down the aggregate interface or subinterface.
Use undo shutdown to bring up the aggregate interface or subinterface.
By default, aggregate interfaces subinterfaces are up.
Shutting down or bringing up a Layer 3 aggregate interface also shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
