- 13-Network Management and Monitoring Command Reference
- 01-System Maintenance and Debugging Commands
- 02-NQA Commands
- 03-NTP Commands
- 04-Clock Monitoring Commands
- 05-IPC Commands
- 06-SNMP Commands
- 07-RMON Commands
- 08-CWMP Commands
- 09-Sampler Commands
- 10-Mirroring Commands
- 11-Protocol Packet Statistics Commands
- 12-sFlow Commands
- 13-Information Center Commands
| 13-Information Center Commands | 215.52 KB |
Information center configuration commands
display security-logfile buffer
display security-logfile summary
info-center logfile size-quota
info-center logfile switch-directory
NOTE: The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide. |
display channel
display channel [ channel-number | channel-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
channel-number: Displays information of the channel with a specified number, which ranges from 0 to 9.
channel-name: Displays information of the channel with a specified name, which could be a default name or a self-defined name. The user needs to specify a channel name first before using it as a self-defined channel name. For more information, refer to the info-center channel name command.
Table 1 Information channels for different output destinations
Output destination |
Information channel number |
Default channel name |
Console |
0 |
console |
Monitor terminal |
1 |
monitor |
Log host |
2 |
loghost |
Trap buffer |
3 |
trapbuffer |
Log buffer |
4 |
logbuffer |
SNMP module |
5 |
snmpagent |
Web interface |
6 |
Cahnnel6 |
Log file |
9 |
channel9 |
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display channel command to display channel information.
If no channel is specified, information for all channels is displayed.
# Display information for channel 0.
<Sysname> display channel 0
channel number:0, channel name:console
MODU_ID? NAME???? ENABLE LOG_LEVEL??? ????ENABLE TRAP_LEVEL??? ENABLE DEBUG_LEVEL
ffff0000 default? Y????? informational??? Y????? debugging???? Y????? debugging
The above information indicates to output log information with the severity from 0 to 4, trap information with the severity from 0 to 7 and debugging information with the severity from 0 to 7 to the console. The information source modules are all modules (default).
Table 2 Output description
channel number |
A specified channel number, in the range 0 to 9. |
channel name |
A specified channel name, which varies with user’s configuration. For more information, refer to the info-center channel name command. |
MODU_ID |
The ID of the module to which the information permitted to pass through the current channel belongs |
NAME |
The name of the module to which the information permitted to pass through the current channel belongs Default means all modules are allowed to output system information, but the module type varies with switches. |
ENABLE |
Indicates whether to enable or disable the output of log information, which could be Y or N. |
LOG_LEVEL |
The severity of log information, see Table 4 for more information. |
ENABLE |
Indicates whether to enable or disable the output of trap information, which could be Y or N. |
TRAP_LEVEL |
The severity of trap information, see Table 4 for more information. |
ENABLE |
Indicates whether to enable or disable the output of debugging information, which could be Y or N. |
DEBUG_LEVEL |
The severity of debugging information, see Table 4 for more information. |
display info-center
display info-center [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display info-center command to display the information of each output destination.
# Display configurations on each output destination.
<Sysname> display info-center
Information Center:enabled
Log host:
??? 1.1.1.1,
??? port number : 514, host facility : local7,
??? channel number : 2, channel name : loghost
Console:
??? channel number : 0, channel name : console
Monitor:
??? channel number : 1, channel name : monitor
SNMP Agent:
??? channel number : 5, channel name : snmpagent
Log buffer:
??? enabled,max buffer size 1024, current buffer size 512,
??? current messages 512, dropped messages 0, overwritten messages 740
??? channel number : 4, channel name : logbuffer
Trap buffer:
??? enabled,max buffer size 1024, current buffer size 256,
??? current messages 216, dropped messages 0, overwritten messages 0
??? channel number : 3, channel name : trapbuffer
logfile:
??? channel number:9, channel name:channel9
syslog:
??? channel number:6, channel name:channel6
Information timestamp setting:
??? log - date, trap - date, debug - date,
loghost – date
Sent messages = 8331, Received messages = 25582
IO Reg messages = 0 IO Sent messages = 17252
Table 3 Output description
Information Center |
The current state of the information center, which could be enabled or disabled. |
Log host: 1.1.1.1, port number : 514, host facility : local2, channel number : 8, channel name : channel8 |
Configurations on the log host destination (It can be displayed only when the info-center loghost command is configured), including IP address of the log host, number of the port that receives the system information on the log host, logging facility used, and the channel number and channel name used.) |
Console: ??? channel number : 0, channel name : console |
Configurations on the console destination, including the channel number and channel name used |
Monitor: ??? channel number : 1, channel name : monitor |
Configurations on the monitor terminal destination, including the channel number and channel name used |
SNMP Agent: ??? channel number : 5, channel name : snmpagent |
Configurations on the SNMP module destination, including the channel number and channel name used |
Log buffer: ??? enabled,max buffer size 1024, current buffer size 512, ??? current messages 512, dropped messages 0, overwritten messages 740 ??? channel number : 4, channel name : logbuffer |
Configurations on the log buffer destination, including whether information output to this destination is enabled or disabled, the maximum capacity, the current capacity, the current number of messages, the number of dropped messages, the number of messages that have been overwritten, and the channel number and channel name used. |
Trap buffer: ??? enabled,max buffer size 1024, current buffer size 256, ??? current messages 216, dropped messages 0, overwritten messages 0 ??? channel number : 3, channel name : trapbuffer |
Configurations on the trap buffer destination, including whether information output to this destination is enabled or disabled, the maximum capacity, the current capacity, the current number of messages, the number of dropped messages, the number of messages that have been overwritten, and the channel number and channel name used. |
logfile: ??? channel number:9, channel name:channel9 |
Configurations on the log file destination, including the channel number, and channel name used. |
syslog: ??? channel number:6, channel name:channel6 |
Configurations on the Web interface destination, including the channel number, and channel name used. |
Information timestamp setting |
The time stamp configurations, specifying the time stamp format for log, trap, debug, and log host information. |
display logbuffer
Standalone mode:
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number] * [ | { begin | exclude | include } regular-expression ]
IRF mode:
display logbuffer [ reverse ] [ level severity | size buffersize | chassis chassis-number slot slot-number ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
reverse: Displays log entries chronologically, with the most recent entry at the top. If this keyword is not specified, the log entries will be displayed chronologically, with the oldest entry at the top.
level severity: Displays information of the log with specified level, where severity represents information level, which ranges from 0 to 7.
Severity |
Value |
Corresponding keyword in commands |
Emergency |
0 |
The system is unusable. |
emergencies |
Alert |
1 |
Action must be taken immediately |
alerts |
Critical |
2 |
Critical conditions |
critical |
Error |
3 |
Error conditions |
errors |
Warning |
4 |
Warning conditions |
warnings |
Notice |
5 |
Normal but significant condition |
notifications |
Informational |
6 |
Informational messages |
informational |
Debug |
7 |
Debug-level messages |
debugging |
size buffersize: Displays specified number of the latest log messages in the log buffer, where buffersize represents the number of the latest log messages to be displayed in the log buffer, which ranges from 1 to 1,024.
slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode. For more information about IRF, see IRF Configuration Guide.
Use the display logbuffer command to display the state of the log buffer and the log information recorded. Absence of the size buffersize argument indicates that all log information recorded in the log buffer is displayed.
# Display the state of the log buffer and the log information recorded in the log buffer. (in standalone mode)
<Sysname> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 0
Current messages : 127
%Jun 19 18:03:24:55 2008 Sysname IC/7/SYS_RESTART:
System restarted --
The rest is not shown here.
# Display the state of the log buffer and the log information recorded in the log buffer. (in IRF mode)
<Sysname> display logbuffer chassis 1 slot 0
Current messages : 168
%Feb 16 16:58:31:528 2011 h3c IC/6/SYS_RESTART:
System restarted –
Table 5 Output description
Logging buffer configuration and contents |
Indicates the current state of the log buffer and its contents, which could be enabled or disabled. |
Allowed max buffer size |
The maximum buffer size allowed |
Actual buffer size |
The actual buffer size |
Channel number |
The channel number of the log buffer, defaults to 4. |
Channel name |
The channel name of the log buffer, defaults to logbuffer. |
Dropped messages |
The number of dropped messages |
Overwritten messages |
The number of overwritten messages (when the buffer size is not big enough to hold all messages, the latest messages overwrite the old ones). |
Current messages |
The number of the current messages |
display logbuffer summary
Standalone mode:
display logbuffer summary [ level severity | slot slot-number] * [ | { begin | exclude | include } regular-expression ]
IRF mode:
display logbuffer summary [ level severity | chassis chassis-number slot slot-number ] * [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level severity: Displays the summary of the log buffer, where severity represents information level, which ranges from 0 to 7.
Use the display logbuffer summary command to display the summary of the log buffer.
# Display the summary of the log buffer (standalone mode).
<Sysname> display logbuffer summary
? SLOT EMERG ALERT? CRIT ERROR? WARN NOTIF? INFO DEBUG
???? 0???? 0???? 0???? 0???? 0???? 0???? 0???? 0???? 0
???? 1???? 0???? 0???? 0???? 0???? 0???? 0???? 0???? 0
???? 2???? 0???? 0???? 0???? 0???? 0???? 0???? 0???? 0
???? 3???? 0???? 0???? 0???? 0??? 16???? 0???? 1???? 0
# Display the summary of the log buffer (IRF mode).
?CHASSIS? SLOT EMERG ALERT? CRIT ERROR? WARN NOTIF? INFO DEBUG
?????? 1???? 0???? 0???? 0???? 0???? 1?? 238???? 0???? 1???? 0
?????? 1???? 1???? 0???? 0???? 0???? 0???? 0???? 0???? 0???? 0
?????? 1???? 2???? 0???? 0???? 0???? 0???? 1???? 0???? 0???? 0
?????? 2???? 0???? 0???? 0???? 0???? 0???? 5???? 0???? 0???? 0
?????? 2???? 1???? 0???? 0???? 0???? 0???? 1???? 0???? 0???? 0
Table 6 Output description
CHASSIS |
ID of an IRF member switch |
SLOT |
Number of the slot where the card resides |
EMERG |
Represents emergency. See Table 4 for more information. |
ALERT |
Represents alert. See Table 4 for more information. |
CRIT |
Represents critical. See Table 4 for more information. |
ERROR |
Represents error. See Table 4 for more information. |
WARN |
Represents warning. See Table 4 for more information. |
NOTIF |
Represents notice. See Table 4 for more information. |
INFO |
Represents informational. See Table 4 for more information. |
DEBUG |
Represents debug. See Table 4 for more information. |
display logfile buffer
display logfile buffer [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display logfile buffer command to display contents of the log file buffer.
All contents in the log file buffer will be cleared after they are successfully saved into the log file automatically or manually.
# Display the contents of the log file buffer.
<Sysname> display logfile buffer
%@27091414#Aug? 7 08:04:02:470 2009 Sysname IFNET/4/INTERFACE UPDOWN:
?Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983040 is Up, ifAdminStatus is 1, ifOperStatus is 1
The rest is omitted here.
display logfile summary
display logfile summary [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display logfile summary command to display the configuration of the log file.
# Display the configuration of the log file.
<Sysname> display logfile summary
? Log file is enabled.
? Channel number : 9
? Log file size quota : 10 MB
? Log file directory : flash:/logfile
? Writing frequency : 24 hour 0 min 10 sec
Table 7 Output description
Log file is |
The current state of a log file, which could be enabled or disabled. |
Channel number |
The channel number of a log file, defaults to 9. |
Log file size quota |
The maximum storage space reserved for a log file |
Log file directory |
Writing frequency |
Log file writing frequency |
display security-logfile buffer [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display security-logfile buffer command to display the contents of the security log file buffer.
Before saving the security logs into the security log file, the system buffers the security logs into the security log file buffer temporarily. When the saving of the security log file is triggered automatically or manually, the system saves the contents of the security log file buffer into the security log file. If the contents of the buffer are saved into the security log file successfully, the security log file buffer is cleared immediately.
Related commands: info-center security-logfile frequency and security-logfile save.
NOTE: A local user can use this command only after being authorized as the security log administrator by the system administrator through the authorization-attribute user-role security-audit command. For details of the authorization-attribute command, see Security Command Reference. |
# Display the contents of the security log file buffer.
<Sysname> display security-logfile buffer
%@1 Sep 17 11:13:16:609 2009 Sysname SHELL/5/SHELL_LOGIN: Console logged in from con0.
……Omitted……
display security-logfile summary [ | { begin | exclude | include } regular-expression ]
View
Security log management view
Default level
1: Monitor level
Use the display security-logfile summary command to display the summary of the security log file.
# Display the summary of the security log file.
<Sysname> display security-logfile summary
? Security log file is enabled
? Security log file size quota: 6MB
? Security log file directory: flash:/seclog
? Alarm-threshold: 80%
? Current usage: 30%
? Writing frequency: 1 hour 0 min 0 sec
Table 8 Output description
Security log file is |
The current state of the security log file, which can be enabled or disabled. |
Security log file size quota |
The maximum storage space reserved for the security log file |
Security log file directory |
Alarm-threshold |
The alarm threshold of the security log file usage |
Current usage |
The current usage of the security log file |
Writing frequency |
Security log file writing frequency |
display trapbuffer
display trapbuffer [ reverse ] [ size buffersize ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
reverse: Displays trap entries chronologically, with the most recent entry at the top. If this keyword is not specified, trap entries will be displayed chronologically, with the oldest entry at the top.
size buffersize: Displays specified number of the latest trap messages in a trap buffer, where buffersize represents the number of the latest trap messages in a trap buffer, which ranges from 1 to 1,024.
Use the display trapbuffer command to display the state and the trap information recorded.
Absence of the size buffersize argument indicates that all trap information is displayed.
# Display the state of the trap buffer and the trap information recorded.
<Sysname> display trapbuffer
Trapping buffer configuration and contents:enabled
Actual buffer size : 256
Channel number : 3 , channel name : trapbuffer
Current messages : 9
#Aug? 7 08:03:27:421 2009 Sysname IFNET/4/INTERFACE UPDOWN:
?Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983041 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug? 7 08:03:27:439 2009 Sysname IFNET/4/INTERFACE UPDOWN:
?Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983048 is Up, ifAdminStatus is 1, ifOperStatus is 1
?Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983056 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug? 7 08:03:27:465 2009 Sysname IFNET/4/INTERFACE UPDOWN:
?Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 3277798 is Up, ifAdminStatus is 1, ifOperStatus is 1
#Aug? 7 08:05:32:425 2009 Sysname IFNET/4/INTERFACE UPDOWN:
?Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983048 is Down, ifAdminStatus is 1, ifOperStatus is 2
#Aug? 7 08:39:53:302 2009 Sysname SHELL/4/LOGIN:
?Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from VTY
#Aug? 7 08:43:25:583 2009 Sysname CFGMAN/4/TRAP:
????????? 1.3.6.1.4.1.2011.10.2.4.2.1<h3cCfgManEventlog> configure changed:
????????? EventIndex=1,CommandSource=2,ConfigSource=4,ConfigDestination=2
Table 9 Output description
Trapping buffer configuration and contents |
Indicates the current state of the trap buffer and its contents, which could be enabled or disabled. |
Channel number |
The channel number of the trap buffer, defaults to 3. |
channel name |
The channel name of the trap buffer, defaults to trapbuffer. |
Dropped messages |
Current messages |
enable log updown
enable log updown
undo enable log updown
View
Interface view
Default level
2: System level
None
Use the enable log updown command to allow a port to generate link up/down logging information when the port state changes.
Use the undo enable log updown command to disable a port from generating link up/down logging information when the port state changes.
By default, all the ports are allowed to generate port link up/down logging information when the port state changes.
# Disable port GigabitEthernet 3/0/1 from generating link up/down logging information.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] undo enable log updown
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
Default level
2: System level
channel-number: Specifies a channel number, which ranges from 0 to 9.
channel-name: Specifies a channel name, which is a case-insensitive string of 1 to 30 characters. It must be a combination of letters and numbers, and start with a letter.
Use the info-center channel name command to name a channel with a specified channel number.
Use the undo info-center channel command to restore the default name for a channel with a specified channel number.
See Table 1 for more information about default channel names and channel numbers.
# Name channel 0 as abc.
[Sysname] info-center channel 0 name abc
info-center console channel
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
Default level
2: System level
channel-name: Specifies a channel name, which could be a default name or a self-defined name. The user needs to specify a channel name first before using it as a self-defined channel name. For more information, see the info-center channel name command.
Use the info-center console channel command to specify the channel to output system information to the console.
Use the undo info-center console channel command to restore the default output channel to the console.
By default, output of information to the console is enabled with channel 0 as the default channel (known as console).
Note that the info-center console channel command takes effect only after the information center is enabled first with the info-center enable command.
# Set channel 0 to output system information to the console.
[Sysname] info-center console channel 0
info-center enable
info-center enable
undo info-center enable
View
Default level
2: System level
None
Use the info-center enable command to enable information center.
Use the undo info-center enable command to disable the information center.
By default, the information center is enabled.
The system outputs information to the log host or the console only after the information center is enabled first.
# Enable the information center.
[Sysname] info-center enable
Info: Information center is enabled.
info-center format unicom
undo info-center format
View
Default level
2: System level
None
Use the info-center format unicom command to set the format of the system information sent to a log host to UNICOM.
Use the undo info-center format command to restore the default.
By default, the format of the system information sent to a log host is H3C.
The system information sent to a log host is in two formats: H3C and UNICOM. For more information, see Network Management and Monitoring Configuration Guide.
# Set the format of the system information sent to a log host to UNICOM.
[Sysname] info-center format unicom
info-center logbuffer
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center logbuffer [ channel | size ]
View
Default level
2: System level
channel-number: A specified channel number, which ranges from 0 to 9.
channel-name: Specifies a channel name, which could be a default name or a self-defined name. The user needs to specify a channel name first before using it as a self-defined channel name. For more information, refer to the info-center channel name command.
buffersize: Specifies the maximum number of log messages that can be stored in a log buffer. It ranges from 0 to 1,024 and defaults to 512.
Use the info-center logbuffer command to enable information output to a log buffer and set the corresponding parameters.
Use the undo info-center logbuffer command to disable information output to a log buffer.
By default, information is output to the log buffer with the default channel of channel 4 (logbuffer) and the default buffer size of 512.
Note that the info-center logbuffer command takes effect only after the information center is enabled with the info-center enable command.
# Configure the system to output information to the log buffer through channel 4, and set the log buffer size to 50.
[Sysname] info-center logbuffer size 50
info-center logfile enable
undo info-center logfile enable
View
Default level
2: System level
None
Use the info-center logfile enable command to enable the output of system information to the log file.
Use the undo info-center logfile enable command to disable the output of system information to the log file.
By default, the output of system information to the log file is enabled.
# Enable the log file feature.
[Sysname] info-center logfile enable
info-center logfile frequency
undo info-center logfile frequency
View
Default level
2: System level
freq-sec: Frequency with which the system saves the log file, which ranges from 1 to 86,400 seconds.
Use the info-center logfile frequency command to configure the frequency with which the system saves the log file.
Use the undo info-center logfile frequency command to restore the default frequency.
By default, the frequency with which the system saves the log file is 86400 seconds.
# Configure the frequency with which the system saves the log file as 60,000 seconds.
[Sysname] info-center logfile frequency 60000
undo info-center logfile size-quota
View
Default level
2: System level
size: The maximum storage space reserved for a log file, which ranges from 1 to 10 MB.
Use the info-center logfile size-quota command to set the maximum storage space reserved for a log file.
Use the undo info-center logfile size-quota command to restore the default maximum storage space reserved for a log file.
By default, the storage space reserved for a log file is 5 MB.
# Set the maximum storage space reserved for a log file to 6 MB.
[Sysname] info-center logfile size-quota 6
info-center logfile switch-directory dir-name
View
Default level
2: System level
dir-name: The name of the directory where a log file is saved, which is a string of 1 to 64 characters.
Use the info-center logfile switch-directory command to configure the directory where a log file is saved. Make sure that the directory is created first before saving a log file into it.
By default, the directory to save a log file is the log file directory under the root directory of the storage device. For a switch supporting CF partition, the directory to save a log file is usually the log file directory in the second partition of the storage media.
NOTE: This command can be used to configure the directory to which a log file can be saved. The configuration will be lost after system restart or active standby switchover of the main control boards. |
# Create a directory with the name test under flash root directory.
<Sysname> mkdir test
%Created dir flash:/test.
?# Set the directory to save the log file to flash:/test.
[Sysname] info-center logfile switch-directory flash:/test
info-center loghost
info-center loghost [ vpn-instance vpn-instance-name ] { host-ipv4-address | ipv6 host-ipv6-address } [ port port-number ] [ channel { channel-number | channel-name } | facility local-number ] *
undo info-center loghost [ vpn-instance vpn-instance-name ] { host-ipv4-address | ipv6 host-ipv6-address }
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the log host belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
ipv6 host-ipv6-address: The IPv6 address of the log host.
host-ipv4-address: The IPv4 address of the log host.
port port-number: Specifies the number of the port that receives the system information on the log host. The value ranges from 1 to 65535 and defaults to 514. In addition, the value of the port-number argument should be the same as the value configured on the log host, otherwise, the log host cannot receive system information.
channel: Specifies the channel through which system information can be output to the log host.
facility local-number: The logging facility of the log host. The value can be local0 to local7 and defaults to local7. Logging facility is mainly used to mark different logging sources, query and filer the logs of the corresponding log source.
Use the info-center loghost command to specify a log host and to configure the related parameters.
Use the undo info-center loghost command to restore the default configurations on a log host.
By default, output of system information to the log host is disabled.
NOTE: · If you specify to output system information to a log host without providing the channel, the system uses channel 2 (loghost) by default. · The info-center loghost command takes effect only after the information center is enabled with the info-center enable command. · Ensure to input a correct IP address while using the info-center loghost command to configure the IP address for a log host. System will prompt an invalid address if the loopback address (127.0.0.1) is input. · A maximum number of 4 hosts (different) can be designated as the log host. |
# Output log information to a log host with the IP address being 1.1.1.1.
[Sysname] info-center loghost 1.1.1.1
# Output log information to a log host with the IP address being 1.1.1.2, and the VPN instance name is vpn1.
[Sysname] info-center loghost vpn-instance vpn1 1.1.1.2
# Output log information to a log host with the IPv6 address being 1::1.
[Sysname] info-center loghost ipv6 1::1
info-center loghost source
undo info-center loghost source
View
Default level
2: System level
interface-type interface-number: Specifies the egress interface for log information by the interface type and interface number.
Use the info-center loghost source command to specify the source IP address for log information.
Use the undo info-center loghost source command to restore the default.
By default, the interface for sending log information is determined by the matched route, and the primary IP address of this interface is the source IP address of the log information.
After the source IP address of log information is specified, no matter which physical interface is used to output the log information, the source IP address of the log information is the primary IP address of the specified interface. If you want to display the source IP address in the log information, you can configure it by using this command.
The info-center loghost source command takes effect only after the information center is enabled with the info-center enable command.
The IP address of the specified source interface must be configured; otherwise, although the info-center loghost source command can be configured successfully, the log host will not receive any log information.
When the source IP address for log information is not specified, log in to the FTP server using the username ftp. The log information in the following format is displayed on the log host:
<189>May 31 05:37:52 2003 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully.
# Specify the IP address of interface loopback 0 as the source IP address of log information. (Layer 3 mode)
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
# Specify the IP address of the VLAN interface as the source IP address of log information. (Layer 2 mode)
[Sysname] vlan 100
[Sysname-vlan100] interface vlan-interface 100
[Sysname-Vlan-interface100] ip address 2.2.2.2 24
[Sysname-Vlan-interface100] quit
[Sysname] info-center loghost source Vlan-interface 100
After the above configuration, log in to the FTP server by using the username ftp. The log information in the following format is displayed on the log host (compared with the format displayed when the source IP address for log information is not specified, the following format has the -DevIP=2.2.2.2 field added to show the source IP address):
<189>May 31 05:38:14 2003 Sysname %%10FTPD/5/FTPD_LOGIN(l): -DevIP=2.2.2.2; User ftp (192.168.1.23) has logged in successfully.
info-center monitor channel
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
Default level
2: System level
Use the info-center monitor channel command to configure the channel to output system information to the monitor.
Use the undo info-center monitor channel command to restore the default channel to output system information to the monitor.
By default, output of system information to the monitor is enabled with a default channel name of monitor and a default channel number of 1.
NOTE: The info-center monitor channel command takes effect only after the information center is enabled with the info-center enable command. |
# Output system information to the monitor through channel 0.
[Sysname] info-center monitor channel 0
info-center snmp channel
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
Default level
2: System level
Use the info-center snmp channel command to configure the channel to output system information to the SNMP module.
Use the undo info-center snmp channel command to restore the default channel to output system information to the SNMP module.
By default, output of system information to the SNMP module is enabled with a default channel name of snmpagent and a default channel number of 5.
For more information, see the display snmp-agent command in the chapter “SNMP configuration commands.”
# Output system information to the SNMP module through channel 6.
[Sysname] info-center snmp channel 6
info-center source
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] *
undo info-center source { module-name | default } channel { channel-number | channel-name }
View
Default level
2: System level
module-name: Specifies the output rules of the system information of the specified modules. For instance, if information on ARP module is to be output, you can configure this argument as ARP. You can use the info-center source ? command to view the modules supported by the switch.
default: Specifies the output rules of the system information of all the modules allowed to output the system information, including all the modules displayed by using the info-center source ? command.
debug: Debugging information.
log: Log information.
trap: Trap information.
level severity: Specifies the severity of system information, see Table 4 for more information. With this keyword, you can specify the severity level of the information allowed/denied to output.
state state: Configures whether to output the system information, which could be on (enabled) or off (disabled). With this keyword, you can specify whether to output the specified system information.
Use the info-center source command to specify the output rules of the system information.
Use the undo info-center source command to remove the specified output rules.
By default, the output rules for the system information are listed in Table 10.
This command can be used to set the filter and redirection rules of log, trap and debugging information.
For example, the user can set to output log information with severity higher than warning to the log host, and information with severity higher than informational to the log buffer. The user can also set to output trap information of the IP module to a specified output destination.
· If you do not use the module-name argument to set output rules for a module, the module uses the default output rules or the output rules set by the default keyword; otherwise the module uses the output rules separately set for it.
· If you use the default keyword to set the output rules for all the modules without specifying the debug, log, and trap keywords, the default output rules for the modules are used. See Table 10 for more information.
· If you use the module-name argument to set the output rules for a module without specifying the optional keywords, the default output rules for the module are as follows: the output of log and trap information is enabled, with severity being informational; the output of debugging information is disabled, with severity being debug. For example, if you execute the command info-center source snmp channel 5, the command is actually equal to the command info-center source snmp channel 5 debug level debugging state off log level informational state on trap level informational state on.
· If you repeatedly use the command to set the output rules for a module or for all the modules with the default keyword, the last configured output rules take effect.
· After you separately set the output rules for a module, you must use the module-name argument to modify or remove the rules. The new configuration by using the default keyword is invalid on the module.
· You can configure outputting the log, trap and debugging information to the trap buffer, but the trap buffer only receives the trap information and discards the log and debugging information.
· You can configure outputting the log, trap and debugging information to the log buffer, but the log buffer only receives the log and debugging information and discards the trap information.
· You can configure outputting the log, trap and debugging information to the SNMP module, but the SNMP module only receives the trap information and discards the log and debugging information.
Table 10 Default output rules for different output destinations
System information source |
Log |
Trap |
Debug |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Console |
All supported modules |
Enabled |
Informational |
Enabled |
Debug |
Enabled |
Debug |
Monitor terminal |
Enabled |
Informational |
Enabled |
Debug |
Enabled |
Debug |
Log host |
Enabled |
Informational |
Enabled |
Debug |
Disabled |
Debug |
Trap buffer |
Disabled |
Informational |
Enabled |
Informational |
Disabled |
Debug |
Log buffer |
Enabled |
Informational |
Disabled |
Debug |
Disabled |
Debug |
SNMP module |
Disabled |
Debug |
Enabled |
Informational |
Disabled |
Debug |
Log file |
Enabled |
Debug |
Enabled |
Debug |
Disabled |
Debug |
# Set the output channel for the log information of VLAN module to snmpagent and to output information with severity being emergency. Log information of other modules cannot be output to this channel; other types of information of this module may or may not be output to this channel.
[Sysname] info-center source default channel snmpagent log state off
[Sysname] info-center source vlan channel snmpagent log level emergencies state on
# Set the output channel for the log information of VLAN module to snmpagent and to output information with severity being emergency. Log information of other modules and all the other system information cannot be output to this channel.
[Sysname] info-center source default channel snmpagent debug state off log state off trap state off
info-center synchronous
View
Default level
2: System level
None
Use the info-center synchronous command to enable synchronous information output.
Use the undo info-center synchronous command to disable the synchronous information output.
By default, the synchronous information output is disabled.
NOTE: · If system information, such as log information, is output before you input any information under a current command line prompt, the system will not display the command line prompt after the system information output. · If system information is output when you are inputting some interactive information (non Y/N confirmation information), then after the system information output, the system will not display the command line prompt but your previous input in a new line. |
# Enable the synchronous information output function, and then input the display interface GigabitEthernet command to view the current configuration of the switch.
[Sysname] info-center synchronous
% Info-center synchronous output is on
[Sysname] display current-
At this time, the system receives log messages, and it then displays the log messages first. After the system displays all the log messages, it displays the user’s previous input, which is display current- in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/4/LOGIN: VTY login from 192.168.1.44
After the above information is displayed, you can input configuration to complete your input of the display current-configuration command, and then press the Enter key to execute the command.
# Enable the synchronous information output function, and then save the current configuration (input interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information, and it then displays the log information first. After the system displays all the log information, it displays the user’s previous input, which is [Y/N] in this example.
[Y/N]:
After the above information is displayed, you can input Y or N to complete your input before the output of the log information.
info-center syslog channel
info-center syslog channel { channel-number | channel-name }
undo info-center syslog channel
View
Default level
2: System level
channel-name: Specifies a channel name, which could be a default name or a self-defined name. You need to specify a channel name first before using it as a self-defined channel name. For more information, see the info-center channel name command.
Use the info-center syslog channel command to enable the output of system information to the web interface.
Use the undo info-center syslog channel command to restore the default.
By default, system information is output to the web interface with the default channel of channel 6.
# Configure the system to output information to the web interface through channel 7.
[Sysname] info-center syslog channel 7
info-center timestamp
info-center timestamp { debugging | log | trap } { boot | date | none }
undo info-center timestamp { debugging | log | trap }
View
Default level
2: System level
debugging: Sets the time stamp format of the debugging information.
log: Sets the time stamp output format of the log information.
trap: Sets the time stamp output format of the trap information.
boot: The time taken to boot up the system, in the format of xxxxxx.yyyyyy, in which xxxxxx represents the most significant 32 bits of the time taken to boot up the system (in milliseconds) whereas yyyyyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007.
date: The current system date and time, in the format of “Mmm dd hh:mm:ss:sss yyyy”. For example, Dec 8 10:12:21:708 2007.
· Mmm: The abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
· dd: The date, starting with a space if less than 10, for example “ 7”.
· hh:mm:ss:sss: The local time, with hh ranging from 00 to 23, mm and ss ranging from 00 to 59, and sss ranging from 0 to 999.
· yyyy: Represents the year.
none: Indicates no time information is provided.
Use the info-center timestamp command to configure the time stamp format of the system information sent to all destinations except log host.
Use the undo info-center timestamp command to restore the default.
By default, the time stamp format of the system information sent to a log host is set by the info-center timestamp loghost command, and the format of log, trap and debugging information sent to other destinations is date.
Related commands: info-center timestamp loghost.
# Configure the time stamp format for log information as boot.
[Sysname] info-center timestamp log boot
At this time, if you log in to the FTP server using the username ftp, the log information generated is as follows:
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
# Configure the time stamp format for log information as date.
[Sysname] info-center timestamp log date
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
# Configure the time stamp format for log information as none.
[Sysname] info-center timestamp log none
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
info-center timestamp loghost { date | iso | no-year-date | none }
undo info-center timestamp loghost
View
Default level
2: System level
date: The current system date and time, in the format of “Mmm dd hh:mm:ss:sss yyyy”. For example, Dec 8 10:12:21:708 2007. The display format depends on the log host.
iso: Sets the time stamp to ISO 8601 format, for example, 2009-09-21T15:32:55.
no-year-date: Indicates the current system date and time (year exclusive).
none: Indicates that no time stamp information is provided.
Use the info-center timestamp loghost command to configure the time stamp format of the system information sent to the log host.
Use the undo info-center timestamp loghost command to restore the default.
By default, the time stamp format for system information sent to the log host is date.
Related commands: info-center timestamp.
# Configure that the system information output to the log host includes the current data and time, and does not include the year information.
[Sysname] info-center timestamp loghost no-year-date
info-center trapbuffer
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center trapbuffer [ channel | size ]
View
Default level
2: System level
size buffersize: Specifies the maximum number of trap messages in a trap buffer. It ranges from 0 to 1,024 and defaults to 256.
Use the info-center trapbuffer command to enable information output to the trap buffer and set the corresponding parameters.
Use the undo info-center trapbuffer command to disable information output to the trap buffer.
By default, information output to the trap buffer is enabled with channel 3 (trapbuffer) as the default channel and a maximum buffer size of 256.
NOTE: The info-center trapbuffer command takes effect only after the information center is enabled with the info-center enable command. |
# Configure the system to output information to the trap buffer through the default channel, and set the trap buffer size to 30.
[Sysname] info-center trapbuffer size 30
logfile save
logfile save
View
Default level
2: System level
None
Use the logfile save command to save all the contents in the log file buffer into the log file.
By default, the system automatically saves the log file based on a frequency configured by the info-center logfile frequency command into a directory configured by the info-center logfile switch-directory command.
# Save the contents in the log file buffer into the log file.
<Sysname> logfile save
reset logbuffer
reset logbuffer
View
Default level
3: Manage level
None
Use the reset logbuffer command to reset the log buffer contents.
# Reset the log buffer contents.
<Sysname> reset logbuffer
reset trapbuffer
reset trapbuffer
View
Default level
3: Manage level
None
Use the reset trapbuffer command to reset the trap buffer contents.
# Reset the trap buffer contents.
<Sysname> reset trapbuffer
terminal debugging
terminal debugging
undo terminal debugging
View
Default level
1: Monitor level
None
Use the terminal debugging command to enable the display of debugging information on the current terminal.
Use the undo terminal debugging command to disable the display of debugging information on the current terminal.
By default, the display of debugging information on the current terminal is disabled.
To display the debugging information, execute the terminal monitor and terminal debugging commands, then enable information center (enabled by default), and finally use a debugging command to enable the related debugging.
The configuration of this command is valid for only the current connection between the terminal and the switch. If a new connection is established, the display of debugging information on the terminal restores the default.
# Enable the display of debugging information on the current terminal.
<Sysname> terminal debugging
Info: Current terminal debugging is on.
terminal logging
terminal logging
undo terminal logging
View
Default level
1: Monitor level
None
Use the terminal logging command to enable the display of log information on the current terminal.
Use the undo terminal logging command to disable the display of log information on the current terminal.
By default, the display of log information on the current terminal is disabled.
To display the log information, execute the terminal monitor and terminal logging commands, and then enable information center (enabled by default).
The configuration of this command is valid for only the current connection between the terminal and the switch. If a new connection is established, the display of log information on the terminal restores the default.
# Disable the display of log information on the current terminal.
<Sysname> undo terminal logging
Info: Current terminal logging is off.
terminal monitor
terminal monitor
undo terminal monitor
View
Default level
1: Monitor level
None
Use the terminal monitor command to enable the monitoring of system information on the current terminal.
Use the undo terminal monitor command to disable the monitoring of system information on the current terminal.
By default, monitoring of the system information on the console is enabled and that on the monitor terminal is disabled.
NOTE: · You need to configure the terminal monitor command before you can display the log, trap, and debugging information. · Configuration of the undo terminal monitor command automatically disables the monitoring of log, trap, and debugging information. · The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the monitoring of system information on the terminal restores the default. |
# Enable the monitoring of system information on the current terminal.
<Sysname> terminal monitor
Info: Current terminal monitor is on.
terminal trapping
terminal trapping
undo terminal trapping
View
Default level
1: Monitor level
None
Use the terminal trapping command to enable the display of trap information on the current terminal.
Use the undo terminal trapping command to disable the display of trap information on the current terminal.
By default, the display of trap information on the current terminal is enabled.
To display the trap information, execute the terminal monitor and terminal trapping commands, and then enable information center (enabled by default).
The configuration of this command is valid for only the current connection between the terminal and the switch. If a new connection is established, the display of trap information on the terminal restores the default.
# Enable the display of trap information on the current terminal.
<Sysname> terminal trapping
