- 13-Network Management and Monitoring Command Reference
- 01-System Maintenance and Debugging Commands
- 02-NQA Commands
- 03-NTP Commands
- 04-Clock Monitoring Commands
- 05-IPC Commands
- 06-SNMP Commands
- 07-RMON Commands
- 08-CWMP Commands
- 09-Sampler Commands
- 10-Mirroring Commands
- 11-Protocol Packet Statistics Commands
- 12-sFlow Commands
- 13-Information Center Commands
| 11-Protocol Packet Statistics Commands | 68.58 KB |
Protocol packet statistics configuration commands
display to-cpu-packet statistics
reset to-cpu-packet statistics
NOTE: The switch operates in IRF or standalone (the default) mode. For more information about IRF mode, see IRF Configuration Guide. |
In standalone mode:
display to-cpu-packet statistics { interface interface-type interface-number | [ protocol protocol-type ] slot slot-number } [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display to-cpu-packet statistics { interface interface-type interface-number | [ protocol protocol-type ] chassis chassis-number slot slot-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays statistics on protocol packets passed to the CPU from the specified interface.
protocol protocol-type: Displays statistics on packets of the specified protocol that have been passed to the CPU. The following protocol types are supported: ARP-unicast, ARP-multicast, DHCP, 802.1X, 802.3ah, DLDP, GVRP, ICMP-echo, ICMPv6-echo, IP-lasthop, IP-subnet, IGMP, ISIS, LACP, Loop-detection, LLDP, MLD, NTP, ND-unicast, ND-multicast, OSPF, PIM, RIP, RRPP, RSVP, SNMP, STP, and VRRP.
slot slot-number: Displays statistics on protocol packets passed to the CPU from the specified card. slot-number represents the number of the slot that holds the card. Use this option when your switch is operating in standalone mode.
chassis chassis-number slot slot-number: Displays statistics on protocol packets passed to the CPU from a card on an IRF member switch. The chassis-number represents the ID of the IRF member switch. The slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display to-cpu-packet statistics command to view protocol packet statistics.
When your switch is operating in standalone mode, if you do not specify the protocol protocol-type combination for this command, protocol packet statistics of all protocol types on the specified card will be displayed.
When your switch is operating in IRF mode, if you do not specify the protocol protocol-type combination for this command, protocol packet statistics of all protocol types on the specified card of the specified IRF member device will be displayed.
# Display statistics on ARP-multicast protocol packets passed from the card in slot 6 to the CPU.
<Sysname> display to-cpu-packet statistics protocol arp-multicast slot 6
Slot: 6
The total received packets of ARP-multicast: 0
Interface Protocol type Received packets
GE6/0/1 ARP-multicast 0
GE6/0/2 ARP-multicast 0
GE6/0/3 ARP-multicast 0
GE6/0/4 ARP-multicast 0
GE6/0/5 ARP-multicast 0
GE6/0/6 ARP-multicast 0
GE6/0/7 ARP-multicast 0
GE6/0/8 ARP-multicast 0
GE6/0/9 ARP-multicast 0
GE6/0/10 ARP-multicast 0
GE6/0/11 ARP-multicast 0
GE6/0/12 ARP-multicast 0
GE6/0/13 ARP-multicast 0
GE6/0/14 ARP-multicast 0
GE6/0/15 ARP-multicast 0
GE6/0/16 ARP-multicast 0
GE6/0/17 ARP-multicast 0
GE6/0/18 ARP-multicast 0
GE6/0/19 ARP-multicast 0
GE6/0/20 ARP-multicast 0
GE6/0/21 ARP-multicast 0
GE6/0/22 ARP-multicast 0
GE6/0/23 ARP-multicast 0
GE6/0/24 ARP-multicast 0
# Display statistics on protocol packets passed from GigabitEthernet 6/0/1 to the CPU.
<Sysname> display to-cpu-packet statistics interface GigabitEthernet 6/0/1
Slot: 6
The total received packets of port GE6/0/1: 0
GE6/0/1 ARP-unicast 0
GE6/0/1 DHCP 0
GE6/0/1 802.1X 0
GE6/0/1 802.3ah 0
GE6/0/1 DLDP 0
GE6/0/1 GVRP 0
GE6/0/1 ICMP-echo 0
GE6/0/1 ICMPv6-echo 0
GE6/0/1 IP-lasthop 0
GE6/0/1 IP-subnet 0
GE6/0/1 IGMP 0
GE6/0/1 ISIS 0
GE6/0/1 LACP 0
GE6/0/1 Loop-detection 0
GE6/0/1 LLDP 0
GE6/0/1 MLD 0
GE6/0/1 NTP 0
GE6/0/1 ND-unicast 0
GE6/0/1 ND-multicast 0
GE6/0/1 OSPF 0
GE6/0/1 PIM 0
GE6/0/1 RIP 0
GE6/0/1 RRPP 0
GE6/0/1 RSVP 0
GE6/0/1 SNMP 0
GE6/0/1 STP 0
GE6/0/1 VRRP 0
GE6/0/1 Other-protocol 0
In standalone mode:
reset to-cpu-packet statistics slot slot-number
In IRF mode:
reset to-cpu-packet statistics chassis chassis-number slot slot-number
View
Default level
1: Monitor level
slot slot-number: Clears statistics for protocol packets that the specified card passed to the CPU. slot-number represents the number of the slot that holds the card. Use this option when your switch is operating in standalone mode.
chassis chassis-number slot slot-number: Clears statistics on protocol packets passed to the CPU from a card on an IRF member switch. The chassis-number represents the ID of the IRF member switch. The slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode.
Use the reset to-cpu-packet statistics command to clear statistics on protocol packets passed to the CPU.
# Clear statistics on protocol packets passed from the card in slot 2 to the CPU.
<Sysname> reset to-cpu-packet statistics slot 2
# Clear statistics on protocol packets passed from the card in slot 2 of IRF member switch 1 to the CPU.
<Sysname> reset to-cpu-packet statistics chassis 1 slot 2
