- 07-Layer 3 - IP Routing Command Reference
- 01-Basic IP Routing Commands
- 02-Static Routing Commands
- 03-RIP Commands
- 04-OSPF Commands
- 05-IS-IS Commands
- 06-BGP Commands
- 07-Policy-Based Routing Commands
- 08-Guard Route Commands
- 09-IPv6 Static Routing Commands
- 10-RIPng Commands
- 11-OSPFv3 Commands
- 12-IPv6 IS-IS Commands
- 13-IPv6 BGP Commands
- 14-IPv6 Policy-Based Routing Commands
- 15-Routing Policy Commands
| 07-Policy-Based Routing Commands | 109.42 KB |
Policy-based routing configuration commands
display ip policy-based-route setup
display ip policy-based-route statistics
reset policy-based-route statistics
NOTE: The switch operates in IRF or standalone (the default) mode. For information about the IRF mode, see the IRF Configuration Guide. |
apply access-vpn vpn-instance
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
View
PBR policy node view
Default level
2: System level
vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters.
Use the apply access-vpn vpn-instance command to set a VPN instance.
Use the undo apply access-vpn vpn-instance command to remove the specified VPN instance.
NOTE: · The specified VPN instance must exist. · You can set only one VPN instance for a policy node. When a packet matches the criteria, it is forwarded according to the forwarding table of the VPN instance. · Using the undo apply access-vpn vpn-instance command with a VPN instance specified removes the VPN instance. Using this command without any VPN instance disables packet forwarding in VPN instance. |
Related commands: apply ip-precedence and apply ip-address next-hop.
# Set VPN instance vpn1 for forwarding packets.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1
apply ip-address next-hop [ vpn-instance vpn-instance-name ] ip-address1 [ direct ] [ track track-entry-number ] [ ip-address2 [ direct ] [ track track-entry-number ] ]
undo apply ip-address next-hop [ [ vpn-instance vpn-instance-name ] ip-address1 | ip-address2 ] *
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. The specified VPN must already exist.
ip-address1: IP address of the primary next hop.
ip-address2: IP address of the backup next hop.
direct: Specifies the current next hop as valid when it is a directly connected next hop.
track track-entry-number: Specifies a track entry. The track-entry-number argument is in the range of 1 to 1024.
Use the apply ip-address next-hop command to set a next hop for packets.
Use the undo apply ip-address next-hop command to remove the configuration.
You can specify up to two next hops in one policy node.
If you configure two next hops for interface PBR at the same time, only the primary next hop takes effect. The backup next hop takes effect only when the primary next hop is invalid. When neither next hop is effective, packets are forwarded according to the routing table.
If you configure two next hops for local PBR at the same time, both next hops take effect to implement load sharing.
Using the undo apply ip-address next-hop command with a next hop specified removes the next hop. Using this command without any next hop specified removes all next hops.
# Set the directly connected next hop to 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply ip-address next-hop 1.1.1.1 direct
apply ip-precedence
apply ip-precedence value
undo apply ip-precedence
View
Default level
2: System level
value: Sets the precedence for IP packets. There are eight precedence values (0 to 7). Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
Use the apply ip-precedence command to set a precedence for packets.
Use the undo apply ip-precedence command to remove the configuration.
# Set the precedence to 5 (critical) for packets.
[Sysname-pbr-aa-11] apply ip-precedence critical
display ip policy-based-route [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ip policy-based-route command to display the PBR routing information.
# Display the PBR routing information.
<Sysname> display ip policy-based-route
Policy Name interface
pr02 local
pr01 Vlan-interface 1
Policy Name |
Policy name. |
interface |
PBR type: · local—Means Local PBR. · A specific interface—Means the policy has been applied to the interface to implement interface PBR. For example, Virtual-template0. |
Standalone mode:
display ip policy-based-route setup { policy-name | interface interface-type interface-number [ slot slot-number ] | local [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip policy-based-route setup { policy-name | interface interface-type interface-number [ chassis chassis-number slot slot-number ] | local [ chassis chassis-number slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays the PBR routing information of the specified policy. A policy name is a string of 1 to 19 characters.
interface interface-type interface-number: Displays the PBR routing information on the specified interface.
local: Displays the local PBR information.
slot slot-number: Displays the PBR routing information on a card. slot-number represents the number of the slot that holds the card.
chassis chassis-number slot slot-number: Displays the PBR routing information of a card on an IRF member device. chassis-number represents the ID of the IRF member device, and slot-number argument represents the number of the slot that holds the card.
Use the display ip policy-based-route setup command to display the specified PBR routing information.
# Display the PBR routing information on VLAN-interface 1.
<Sysname> display ip policy-based-route setup interface Vlan-interface 1
Interface Vlan-interface 1 policy based routing configuration information:
policy-based-route pr01 permit node 1
if-match acl 3101
Interface Vlan-interface 1 policy based routing configuration information |
PBR routing information on VLAN-interface 1. |
policy-based-route pr01 permit node 1 |
The referenced policy name is pr01, the match mode is permit, and the policy has a node 1. |
if-match acl 3101 |
Packets satisfying ACL 3101 are matched. |
apply ip-address next-hop 1.1.1.1 |
The matched packets are sent to next hop 1.1.1.1. |
Standalone mode:
display ip policy-based-route statistics { interface interface-type interface-number | local } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display ip policy-based-route statistics { interface interface-type interface-number | local } [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the PBR statistics on the specified interface.
local: Displays the statistics of local PBR.
slot slot-number: Displays the PBR statistics on a card. slot-number represents the number of the slot that holds the card. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Displays the PBR statistics of a card on an IRF member switch. The chassis-number represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode.
Use the display ip policy-based-route statistics command to display PBR statistics.
# Display the statistics of PBR on GigabitEthernet 3/0/1.
<Sysname> display ip policy-based-route statistic interface GigabitEthernet 3/0/1
policy-based-route: 111
permit node 1:
if-match acl 3004
apply ip-address next-hop 3.3.3.3
matched: 0
Total matched: 0
Table 4 Output description
policy-based-route: 111 |
The policy name is 111. |
permit node 1 |
The match mode of node 1 is permit. |
if-match acl 3004 |
Match packets against ACL 3104 |
matched: 0 |
Matching packets on node 1 |
Total matched: 0 |
Total matching packets on all nodes of policy 111 |
display policy-based-route
display policy-based-route [ policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Displays information about the specified policy. A policy name is a string of 1 to 19 characters.
Use the display policy-based-route command to display PBR policy information.
If no policy name is specified, all PBR policy information is displayed. If a policy name is specified, information about the specified policy is displayed.
# Display the PBR policy information.
<Sysname> display policy-based-route
Policy based routing configuration information:
policy-based-route : p1
Node 10 permit :
apply ip-address next-hop 10.1.1.1
apply ip-address next-hop vpn-instance vpn1 1.1.1.1
Node 11 permit :
apply ip-address next-hop vpn-instance vpn2 2.1.1.1
apply ip-address next-hop vpn-instance vpn3 3.1.1.1
Table 5 Output description
policy-based-route : aaa |
The policy name is aaa. |
Node 1 permit : |
The matching mode of node 1 is permit. |
apply ip-address next-hop |
Specify a next hop for matched packets. The output shows the backup next hop and then the primary next hop. |
if-match acl
if-match acl acl-number
undo if-match acl
View
Default level
2: System level
acl-number: ACL number, in the range of 2000 to 3999. The number of a basic ACL ranges from 2000 to 2999 and that of an advanced ACL ranges from 3000 to 3999.
Use the if-match acl command to define an ACL match criterion.
Use the undo if-match acl command to remove the ACL match criterion.
# Permit the packets matching ACL 2010.
[Sysname-pbr-aa-11] if-match acl 2010
ip local policy-based-route
ip local policy-based-route policy-name
undo ip local policy-based-route policy-name
View
Default level
2: System level
policy-name: Policy name, a string of 1 to 19 characters.
Use the ip local policy-based-route command to configure local PBR based on a specified policy.
Use the undo ip local policy-based-route command to remove the configuration.
No policy is referenced for local PBR by default.
Only one policy can be referenced for local PBR.
Local PBR is used to route packets generated locally. Unless otherwise required, H3C does not recommend configuring local PBR.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
ip policy-based-route policy-name
undo ip policy-based-route policy-name
View
Interface view
Default level
2: System level
Use the ip policy-based-route command to configure PBR based on a specified policy on the interface.
Use the undo ip policy-based-route command to remove the configuration.
No policy is referenced for interface PBR by default.
Only one policy can be referenced by an interface for PBR.
The referenced policy applies to all packets arriving on the interface.
Related commands: ip local policy-based-route.
# Configure PBR based on policy aaa on VLAN-interface 2000.
[Sysname] interface Vlan-interface 2000
[Sysname-Vlan-interface2000] ip policy-based-route aaa
policy-based-route
undo policy-based-route policy-name [ deny | node node-number | permit ]
View
Default level
2: System level
deny: Specifies the match mode of the policy node as deny.
permit: Specifies the match mode of the policy node as permit.
node node-number: Number of a policy node, in the range of 0 to 65535. A node with a smaller node-number has a higher match priority than a node with a greater one.
Use the policy-based-route command to create a policy or/and policy node and enter PBR policy node view.
Use the undo policy-based-route command to remove a created policy or policy node.
No policy or policy node is created by default.
The default match mode of a policy node is permit.
# Configure the match mode of node 10 of policy 1 as permit, and enter PBR policy node view.
reset policy-based-route statistics [ policy-name ]
View
Default level
1: Monitor level
Use the reset policy-based-route statistics command to clear PBR statistics.
If no policy name is specified, this command clears all the PBR statistics.
# Clear all PBR statistics.
<Sysname> reset policy-based-route statistics
