WLAN Command Reference
HomeSupportWLANH3C WA2200 Series WLAN Access PointsReference GuidesCommand ReferencesH3C WA Series WLAN Access Points Command Reference-6W100WLAN Command Reference
08-WLAN Service Commands
08-WLAN Service Commands 123.63 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for commands may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
1  WLAN Service Configuration Commands
a-mpdu enable
a-mpdu enable
undo a-mpdu enable
View
WLAN radio interface view
Default Level
2: System level
None
Use the a-mpdu enable command to enable the A-MPDU function for the radio.
Use the undo a-mpdu enable command to disable the A-MPDU function for the radio.
Support for the command depends on the device model.
By default, the A-MPDU function is enabled on an 802.11n radio.
This command is only effective on 802.11n radios.
If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type will be restored.
# Disable the A-MPDU function for radio 1/0/1.
<sysname> system-view
[sysname] interface WLAN-Radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-mpdu enable
a-msdu enable
a-msdu enable
undo a-msdu enable
View
Default Level
2: System level
None
Use the a-msdu enable command to enable the A-MSDU function for the radio.
Use the undo a-msdu enable command to disable the A-MSDU function for the radio.
By default, the A-MSDU function is enabled on an 802.11n radio.
This command is only effective on 802.11n radios. If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type will be restored.
Currently, the AP can only receive A-MSDU frames.
# Disable the A-MSDU function for radio 1/0/1.
[sysname- WLAN-Radio1/0/1] undo a-msdu enable
beacon ssid-hide
beacon ssid-hide
undo beacon ssid-hide
View
WLAN service template view
Default Level
2: System level
None
Use the beacon ssid-hide command to disable the advertising of Service Set Identifier (SSID) in the beacon frames.
Use the undo beacon ssid-hide command to restore the default configuration.
By default, SSID is advertised in the beacon frames.
If the advertising of the SSID in beacon frames is disabled, the SSID must be configured for the clients to associate with the AP.
Disabling the advertising of the SSID in beacon frames does little good to wireless security. Allowing the advertising of the SSID in beacon frames enables an AP to discover a client more easily.
# Hide the SSID in the beacon frames.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval
beacon-interval interval
undo beacon-interval
View
Default Level
2: System level
interval: Specifies the interval between sending beacon frames. The value ranges from 32 to 8191 Time Units (TUs). One TU equals 1024 microseconds.
Use the beacon-interval command to set the interval of sending beacon frames.
Use the undo beacon-interval command to restore the default.
By default, the value of the beacon interval is 100 TUs.
An AP sends beacon frames at the specified interval..
# Specify the beacon interval to 1000 TUs.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] beacon-interval 1000
channel
channel { channel-number | auto }
undo channel
View
Default Level
2: System level
channel-number: Channel number. The channel numbers depend on specific country code and radio mode. The channel list depends on your device model.
auto: Specifies that the channel is automatically selected by the device according to the actual environment during system initialization.
Use the channel command to configure the operating channel for the radio.
Use the undo channel command to restore the default.
By default, auto mode is set.
Different radios support different channels. Channels may differ for each country.
# Configure interface WLAN-Radio 1/0/2 to operate on channel 6.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] radio-type dot11b
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width
channel band-width { 20 | 40 }
undo channel band-width
View
Default Level
2: System level
20: Specifies the 802.11n channel bandwidth as 20 MHz.
40: Specifies the 802.11n channel bandwidth as 40 MHz.
Use the channel band-width command to specify the channel bandwidth of the 802.11n radio.
Use the undo channel band-width command to restore the default.
By default, the channel bandwidth of the 802.11an radio is 40 MHz, and that of the 802.11gn radio is 20 MHz.
Currently, an 802.11a/n or 802.11g/n radio working in 5 GHz or 2.4 GHz bands selects an available 40 MHz channel as the operating channel. If no 40 MHz channel is available, it selects a 20 MHz channel.
# Configure the channel bandwidth of the radio as 20 MHz.
[sysname-WLAN-Radio1/0/1] radio-type dot11an
[sysname-WLAN-Radio1/0/1] channel band-width 20
client dot11n-only
client dot11n-only
undo client dot11n-only
View
Default Level
2: System level
None
Use the client dot11n-only command to allow only 802.11n clients to access.
Use the undo client dot11n-only command to restore the default.
By default, an 802.11a/n radio permits both 802.11a and 802.11n clients to access, and an 802.11g/n radio permits both 802.11b/g and 802.11n clients to access.
An 802.11n radio supports both 2.4 GHz and 5 GHz bands and thus can allow 802.11a/b/g stations to access for good compatibility.
The client dot11n-only command prohibits non-802.11n clients from access. Therefore, if you want to provide access for all 802.11a/b/g clients, you need to disable this command.
# Configure the radio to allow only 802.11n clients to access.
[sysname-WLAN-Radio1/0/1] client dot11n-only
client max-count
client max-count max-number
undo client max-count
View
Default Level
2: System level
max-number: Maximum number of clients associated to a radio, which ranges from 1 to 124.
Use the client max-count command to specify the maximum number of clients associated to a radio for an SSID.
Use the undo client max-count command to restore the default.
By default, the max-number is 64.
When the number of clients associated to a radio reaches the maximum number, the SSID is automatically hidden.
# Specify the maximum number of clients associated to a radio with SSID service as 10.
[Sysname-wlan-st-1] ssid service
[Sysname-wlan-st-1] client max-count 10
display wlan client
display wlan client { interface wlan-radio [ radio-number ] | mac-address mac-address | service-template service-template-number } [ verbose ]
View
Default Level
1: Monitor level
wlan-radio radio-number: Displays the information of the clients attached to the specified WLAN-Radio interface.
mac-address mac-address: Specifies the MAC address of a client.
service-template service-template-number: Displays the client information based on the specified service template. The service template value ranges from 1 to 1024.
verbose: Displays the detail information of the client.
Use the display wlan client command to view the information of a specified client or all clients.
# Display the information about all the clients.
<Sysname> display wlan client
 Total Number of Clients           : 2
 Total Number of Clients Connected : 2
                               Client Information
MAC Address        BSSID             AID    State       PS Mode      QoS Mode
 0011-95c3-9241    000f-e200-0500    1      Running     Active      WMM
 0013-4695-16dd    000f-e200-0500    2      Running     Active      None
Table 1-1 display wlan client command output description.
MAC Address
MAC address of the client
BSSID
ID of a BSS
AID
Association ID of the client
State of the client such as Running
“B” denotes a backup client.
PS Mode
Client’s power save mode such as Active or Sleep.
QoS Mode
l      WMM indicates that the WMM function is supported;
l      None indicates that the WMM function is not supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
# Display the detail information of all the clients.
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
 Total Number of Clients Connected : 1
                              Client Information
 MAC Address                       : 0014-6c91-9a14
 AID                               : 251
 Radio Interface                   : WLAN-Radio1/0/2
 SSID                              : nsw-nsw
 BSSID                             : 000f-e2cc-2022
 Port                              : WLAN-BSS1
 VLAN                              : 1
 State                             : Running
 Power Save Mode                   : Sleep
 Wireless Mode                     : 11g
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 25
 SNR                               : -NA-
 Rx/Tx Rate                        : 48/54
 Client Type                       : RSN
 Authentication Method             : Open System
 AKM Method                        : Dot1X
 4-Way Handshake State             : PTKINITDONE
 Group Key State                   : IDLE
 Encryption Cipher                 : CCMP
 Roam Status                       : Normal
 Up Time (hh:mm:ss)                : 00:05:15
Table 1-2 display wlan client verbose command output description
MAC Address
AID
Radio Interface
SSID
The SSID with which the client is associated
BSSID
ID of a BSS
Port
WLAN-BSS interface associated with the client
VLAN
VLAN to which the client belongs
Power Save Mode
Wireless Mode
The wireless mode, which includes 802.11a, 802.11b, 802.11g, 802.11gn, 802.11an at present.
Support for wireless mode depends on your device model.
QoS Mode
Specifies how often the client wakes up to listen to beacon frames and is expressed in units of beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
SNR
Signal to Noise Ratio
Rx/Tx Rate
Represents the receiving/sending rate of frames such as data, management, and control frames
Client Type
Displays the client type such as RSN, WPA, and PRE-RSN
Authentication method such as open system or shared key
AKM Method
AKM suite, such as Dot1x, PSK
Displays either of the 4 way handshake state:
l      IDLE: Displayed when initial state
l      PTKSTART: Displayed when the 4-way handshake is initialized.
l      PTKNEGOTIATING: Displayed after sending valid message 3.
l      PTKINITDONE: Displayed when the 4-way handshake is successful.
Group Key State
Displays the group key state such as:
l      IDLE: Displayed when initial state.
l      REKEYNEGOTIATE: Displayed when WCM sends the initial message to client.
l      REKEYESTABLISHED: Displayed when re-keying is successful.
Encryption Cipher
Encryption cipher such as clear or crypto.
Roam Status
Displays the roam status such as Normal or Fast Roaming. For fat AP is always shown as Normal.
Up Time (hh:mm:ss)
Time for which the client is associated with AP.
display wlan service-template
display wlan service-template [ service-template-number ]
View
Default Level
1: Monitor level
service-template-number: Specifies service template number. The value ranges from 1 to 1024.
Use the display wlan service-template command to view the specified service template information. If you do not specify the service template number, all service templates are displayed.
# Display the configuration information of service template 1.
<Sysname> display wlan service-template 1
                           Service Template Parameters
 Service Template Number      : 1
 SSID                         : nsw-nsw
 Service Template Type        : Crypto
 Security IE                  : RSN WPA
 SSID-hide                    : Disabled
 Cipher Suite                 : TKIP CCMP
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : 12345
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 180
 GTK Rekey                    : Enable
 GTK Rekey Method             : Packet-based
 GTK Rekey Packets            : 5000
 Service Template Status      : Enable
 Maximum clients per BSS      : 35
Table 1-3 display wlan service-template command output description.
Current service template number
SSID
Service set identifier for the ESS.
Service template type,Crypto or Clear .
Security IE
Security IE such as WPA or RSN.
Type of authentication used, open system or shared key
SSID-hide
l      Disabled: SSID advertisement is enabled.
l      Enabled: SSID advertisement is disabled.
Cipher Suite
The cipher suite such as CCMP, TKIP, WEP40, WEP104 or WEP128.
WEP Key Index
The index of the default WEP key for encrypting and decrypting the broadcast and multicast frames.
WEP Key Mode
WEP key mode
l       HEX: Hexadecimal format WEP key
l      ASCII: The WEP key is in the format of a character string.
WEP Key
WEP key
TKIP countermeasure time in seconds
PTK Life Time
PTK lifetime in seconds.
GTK Rekey
The GTK rekey configured.
Disable: GTK rekey is disabled.
Enable: GTK rekey is enabled.
GTK Rekey Method
The GTK rekey method configured such as packet based or time based.
GTK Rekey Packets
Number of GTK rekey packets
Status such as enabled or disabled.
display wlan statistics
display wlan statistics client { all | mac-address mac-address }
View
Default Level
1: Monitor level
client: Displays the statistics of the specified client.
all: Displays the statistics of all the clients.
mac-address mac-address: Specifies the MAC address of the client.
Use the display wlan statistics command to view the client statistics.
# Display the statistics of all the clients.
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : ap1
 Radio Id                          : 1
 SSID                              : 123
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
Table 1-4 display wlan statistics command output description
AP Name
Access Point name
Radio Id
Radio ID
SSID
BSSID
ID of a BSS
MAC Address
RSSI
Transmitted Frames
Transmitted Frames
Back Ground
Statistics of background traffic
Best Effort
Statistics of best effort traffic
Video
Statistics of video traffic
Voice
Statistics of voice traffic
Received Frames
Received Frames
Discarded Frames
Discarded Frames
Statistics for background, best effort, video and voice traffic are only for QoS-capable clients. For QoS-incapable clients, only best effort traffic statistics are available (including SVP packets) and may be inconsistent with the real physical output queues. This is because the above mentioned priority-queue statistics can only identify priorities carried in Dot11E and WMM packets; otherwise, statistics of received packets cannot be collected.
dtim
dtim counter
undo dtim
View
Default Level
2: System level
counter: Number of beacons between delivery traffic indication message (DTIM) frames, which ranges from 1 to 31. For example, if the counter is 1, each beacon frame carries DTIM information.
Use the dtim command to set the beacon frame counter for the AP before it starts sending the buffered multicast and broadcast frames.
Use the undo dtim command to restore the default.
By default, the DTIM counter is 1.
The AP sends the buffered broadcast/multicast frames when the DTIM counter reaches 0.
# Set the DTIM counter to 10.
[Sysname-WLAN-Radio1/0/1] dtim 10
fragment-threshold
fragment-threshold size
undo fragment-threshold
View
Default Level
2: System level
size: Specifies the maximum length of the frame without fragmentation. The value ranges from 256 to 2346 bytes and must be an even number.
Use the fragment-threshold command to specify the maximum length of packet that can be transmitted without fragmentation.
Use the undo fragment-threshold command to restore the default.
By default, the fragment threshold is 2346 bytes.
When the actual packet size exceeds the specified fragment threshold value, the packets are fragmented.
# Specify the maximum frame length as 2048 bytes.
[Sysname-WLAN-Radio1/0/1] fragment-threshold 2048
long-retry threshold
long-retry threshold count
undo long-retry threshold
View
Default Level
2: System level
count: Number of retry times AP can send a long unicast frame with a size larger than the Request to Send (RTS) threshold. The value ranges from 1 to 15.
Use the long-retry threshold command to set the number of re-transmission attempts for frames larger than the RTS threshold.
Use the undo long-retry threshold command to restore the default.
By default, the long retry threshold is 4.
# Set the long-retry threshold to 10.
[Sysname-WLAN-Radio1/0/1] long-retry threshold 10
max-power
max-power radio-power
undo max-power
View
Default Level
2: System level
radio-power: Maximum radio power. The value range depends on the country code and radio mode.
Use the max-power command to configure the maximum transmission power on the radio.
Use the undo max-power command to restore the default.
By default, the maximum radio power varies with country codes, channels, AP models, radio types and antenna types. If 802.11n is adopted, the maximum radio power also depends on the bandwidth mode.
Related commands: wlan country-code and radio type
# Specify the radio max power to 5.
[Sysname-WLAN-Radio1/0/1] radio-type 11b
[Sysname-WLAN-Radio1/0/1] max-power 5
max-rx-duration
max-rx-duration interval
undo max-rx-duration
View
Default Level
2: System level
interval: Specifies the interval for which a frame received by AP can remain in buffer memory. The value ranges from 500 to 250000 milliseconds.
Use the max-rx-duration command to specify the interval for the AP to hold the received packets. AP holds these packets in its buffer memory.
Use the undo max-rx-duration command to restore the default.
By default, max-rx-duration is 2000 milliseconds.
# Set the duration for holding frames received to 5000 milliseconds.
[Sysname-WLAN-Radio1/0/1] max-rx-duration 5000
preamble
preamble { long | short }
View
Default Level
2: System level
long: Specifies to transmit only frames with long preamble.
short: Specifies to transmit only frames with short or long preamble.
Use the preamble command to specify the type of preamble that AP can support.
Use the undo preamble command to restore the default.
Preamble is a pattern of bits at the beginning of the packet so that the receiver can sync up and be ready for the real data. There are two different kinds of preamble, short and long.
Only 802.11b/g supports this configuration.
# Specify the radio to support long preamble.
[Sysname-WLAN-Radio1/0/2] preamble long
radio-type
radio-type { dot11a | dot11an | dot11b | dot11g | dot11gn }
View
Default Level
2: System level
dot11a: Indicates that the wireless radio type is 802.11a (5 GHz).
dot11an: Indicates that the wireless radio type is 802.11a/n (5 GHz).
dot11b: Indicates that the wireless radio type is 802.11b (2.4 GHz).
dot11g: Indicates that the wireless radio type is 802.11g (2.4 GHz).
dot11gn: Indicates that the wireless radio type is 802.11g/n (2.4 GHz).
Use the radio-type command to specify the radio type to be used by a radio.
Support for this command depends on the device model.
The default value of the radio type depends on the device model.
You can customize the default radio type for different types of AP.
# Specify the radio type as 802.11g for interface WLAN-Radio 1/0/2.
[Sysname-WLAN-Radio1/0/2] radio-type dot11g
reset wlan client
reset wlan client { all | mac-address mac-address }
View
Default Level
2: System level
all: Cuts off all client connections.
mac-address mac-address: MAC address of the client whose connection will be cut off.
Use the reset wlan client command is to cut off a specific or all clients.
When this command is used, the AP sends the de-authentication frame to the client and the client is removed from the WLAN service.
# Cut off the client with MAC address 0102-0304-0506.
<Sysname> reset wlan client mac-address 0102-0304-0506
reset wlan statistics
reset wlan statistics client { all | mac-address mac-address }
View
Default Level
2: System level
all: Resets the statistics of all clients.
mac-address: Specifies the MAC address of the clients.
Use the reset wlan statistics command to reset the statistics of specified client, or all clients.
# Reset the corresponding radio statistics of all clients.
<Sysname> reset wlan statistics client all
rts-threshold
rts-threshold size
undo rts-threshold
View
Default Level
2: System level
size: Specifies the maximum frame length required by the RTS method. The value ranges from 0 to 2346 bytes.
Use the rts-threshold command to specify the request to send (RTS) threshold length. Use the undo rts-threshold command to restore the default value.
By default, the rts-threshold is 2346 bytes.
If the frame length is beyond this value, the RTS mechanism will be used.
Request to Send (RTS) is used to avoid data sending collisions in a WLAN. You need to set a rational value:
A small value causes RTS packets to be sent more often, thus consuming more of the available bandwidth. However, the more often RTS packets are sent, the quicker the system can recover from interference or collisions.
# Specify the maximum length as 2046 bytes.
[Sysname] interface wlan-radios 1/0/1
[Sysname-WLAN-Radio1/0/1] rts-threshold 2046
service-template (WLAN radio interface view)
service-template service-template-number interface wlan-bss wlan-bss-number
undo service-template service-template-number
View
Default Level
2: System level
service-template-number: Service-template number, which ranges from 1 to 1024.
wlan-bss-number: WLAN-BSS interface number, which ranges from 0 to 255.
Use the service-template command to map the service template to the specified WLAN-BSS interface on the current WLAN-Radio interface.
Use the undo service-template command to remove the mapping.
By default, no service-template is mapped to WLAN-BSS interface on this WLAN-Radio interface.
# Map service template 1 to WLAN-BSS 1 on WLAN-Radio 1/0/1.
[Sysname-WLAN-Radio1/0/1] service-template 1 interface WLAN-BSS 1
service-template { disable | enable } (WLAN service template view)
View
Default Level
2: System level
disable: Disables the service template.
enable: Enables the service template.
Use the service-template enable command to enable the service template.
Use the service-template disable command to disable the service template.
By default, the service-template is disabled.
# Enable the service template 1.
[Syaname] wlan service-template 1 clear
[Syaname-wlan-st-1] ssid ssid-1
[Syaname-wlan-st-1] authentication-method open-system
[Syaname-wlan-st-1] service-template enable
short-gi enable
short-gi enable
undo short-gi enable
View
Default Level
2: System level
None
Use the short-gi enable command to enable the short GI function.
Use the undo short-gi enable command to disable the short GI function.
By default, the short GI function is enabled.
Delays may occur during receiving radio signals due to factors like multi-path reception. Therefore, a subsequently sent frame may interfere with a previously sent frame. The GI function is used to avoid such interference. It increases the data speed by 10 percent.
The short GI function is independent of bandwidth and thus supports both 20 MHz and 40 MHz bandwidths.
# Disable the short GI function.
[sysname] interface WLAN-Radio1/0/2
[sysname-WLAN-Radio1/0/2] undo short-gi enable
short-retry threshold
short-retry threshold count
undo short-retry threshold
View
Default Level
2: System level
count: Number of retry times AP can send a short unicast frame (frame size less than the RTS threshold) without receiving an acknowledgment. The value ranges from 1 to 15.
Use the short-retry threshold command to specify the maximum number of attempts to transmit a frame less than RTS threshold.
Use the undo short-retry threshold command to restore the default.
By default, the short retry threshold is 7.
# Specify the short retry threshold as 10.
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
shutdown
shutdown
View
WLAN radio interface view/WLAN-BSS interface view
Default Level
2: System level
None
Use the shutdown command to shut down the radio that is being used.
Use the undo shutdown command to enable the radio.
By default, the radio is enabled.
# Shut down the radio.
[Sysname-WLAN-Radio1/0/1] shutdown
ssid
ssid ssid-name
undo ssid
View
Default Level
2: System level
ssid-name: Name of the service set identifier, a case sensitive string of 1 to 32 characters that can contain letters, digits, underlines, and spaces.
Use the ssid command to set the SSID for the current service template.
Use the undo ssid command to remove the SSID.
By default, the SSID of service template 1 is set to H3C.
An SSID should be as unique as possible.
# Set the SSID to firstfloor for service template 1.
[Sysname-wlan-st-1] ssid firstfloor
wlan broadcast-probe reply
undo wlan broadcast-probe reply
View
Default Level
2: System level
None
Use the wlan broadcast-probe reply command to enable the AP to respond to the probe requests with SSID null sent by the client.
Use the undo wlan broadcast-probe reply command to remove the configuration. In other words, the AP responds only to probe requests that carry the specified SSID.
By default, an AP responds to probe requests with SSID null sent by the client.
# Enable the AP to respond to probe requests with SSID null sent by the client.
[Sysname] wlan broadcast-probe reply
wlan client idle-timeout
wlan client idle-timeout interval
undo wlan client idle-timeout
View
Default Level
2: System level
interval: Specifies the time for which the link between AP and client ( power-save or awake ) can be idle. The value ranges from 60 to 86400 seconds.
Use the wlan client idle-timeout command to specify the idle time functionality.
Use the undo wlan client idle-timeout command to restore the default.
By default, client idle timeout is 3600 seconds..
If the client is idle for more than the specified interval, that is if the AP does not receive any data from the client within a specified interval, the client will be removed from the network.
# Specify the client idle time as 600 seconds.
[Sysname] wlan client idle-timeout 600
wlan client keep-alive
wlan client keep-alive interval
undo wlan client keep-alive
View
Default Level
2: System level
interval: Specifies the interval between keep alive requests. The value ranges from 3 to 1800 seconds.
Use the client keep-alive command to specify the keep alive interval.
Use the undo client keep-alive command to cancel the keep-alive functionality.
By default, client keep-alive function is disabled.
The keep-alive mechanism is used to detect clients segregated from the system due to various reasons such as power failure or crash, and disconnect them from AP.
# Specify keep-alive time as 60 seconds.
[Sysname] wlan client keep-alive 60
wlan country-code
wlan country-code code
undo wlan country-code
View
Default Level
2: System level
code: Specifies the country code. Refer the Table 1-5.
Table 1-5 Country code information
Country
Code
Country
Code
Andorra
AD
Kenya
KE
Albania
AL
Kuwait
KW
Armenia
AM
Kazakhstan
KZ
Australia
AU
Lebanon
LB
Azerbaijan
AZ
Liechtenstein
LI
Argentina
AR
Sri Lanka
LK
Austria
AT
Lithuania
LT
Bosnia and Herzegovina
BA
Luxembourg
LU
Belgium
BE
Latvija
LV
Bulgaria
BG
Libyan
LY
Bahrain
BH
Morocco
MA
Brunei Darussalam
BN
Monaco
MC
Bolivia
BO
Moldova
MD
Brazil
BR
Macedonia
MK
Bahamas
BS
Macau
MO
Belarus
BY
Martinique
MQ
Belize
BZ
Malta
MT
Canada
CA
Mauritius
MU
Switzerland
CH
Mexico
MX
Cote d'ivoire
CI
Malay Archipelago
MY
Chile
CL
Namibia
NA
China
CN
Nigeria
NG
Colombia
CO
Nicaragua
NI
Costarica
CR
Netherlands
NL
Serbia
RS
Norway
NO
Cyprus
CY
New Zealand
NZ
Czech Republic
CZ
Oman
OM
Germany
DE
Panama
PA
Denmark
DK
Peru
PE
Dominica
DO
Poland
PL
Algeria
DZ
Philippines
PH
Ecuador
EC
Pakistan
PK
Estonia
EE
Puerto Rico
PR
Egypt
EG
Portugal
PT
Spain
ES
Paraguay
PY
Faroe Islands
FO
Qatar
QA
Finland
FI
Romania
RO
France
FR
Russian Federation
RU
Britain
GB
Saudi Arabia
SA
Georgia
GE
Sweden
SE
Gibraltar
GI
Singapore
SG
Greenland
GL
Slovenia
SI
Guadeloupe
GP
Slovak
SK
Greece
GR
San Marino
SM
Guatemala
GT
Salvador
SV
Guyana
GY
Syrian
SY
Honduras
HN
Thailand
TH
Hong Kong
HK
Tunisia
TN
Croatia
HR
Turkey
TR
Hungary
HU
Trinidad and Tobago
TT
Iceland
IS
, Province of China
TW
India
IN
Ukraine
UA
Indonesia
ID
The United Arab Emirates
UE
Ireland
IE
United States of America
US
Israel
IL
Uruguay
UY
Iraq
IQ
Uzbekistan
UZ
Italy
IT
The Vatican City State
VA
Iran
IR
Venezuela
VE
Jamaica
JM
Virgin Islands
VI
Jordan
JO
Vietnam
VN
Japan
JP
Yemen
YE
Democratic People's Republic of Korea
KP
South Africa
ZA
Korea, Republic of Korea
KR
Zimbabwe
ZW
Use the wlan country-code command to specify the country code.
Use the undo wlan country-code command to restore the default.
By default, the country code value is CN.
l          The country code determines the characteristics such as power level, and total number of channels. You must set the valid country code or area code before configuring an AP.
l          If you change the country code for an AP that has a radio card not supported by the new country code, the corresponding WLAN-radio interface will have its configurations of the service template, maximum power and channels removed automatically.
# Specify the country code as US.
[Sysname] wlan country-code us
wlan service-template service-template-number { clear | crypto }
undo wlan service-template service-template-number
View
Default Level
2: System level
service-template-number: Specifies the service-template number. The value ranges from 1 to 1024.
clear: Sets the current service template type to clear, that is, data will be sent in clear text after the template is mapped to an AP.
crypto: Sets the current service template type to crypto, that is, data will be sent in cipher text after the template is mapped to an AP.
Use the wlan service-template command to create a new service template and to enter the configuration view. If the input service template exists, then you can directly enter the configuration view.
Use the undo wlan service-template command to delete the service template, and clear related configurations. If the specified service template is mapped to radio, it can not be directly deleted before mapping is removed.
By default, a clear-type service-template has been configured.
You cannot change the type of an existing service template. To do so, you must delete the existing service template, and configure a new service template with the new type.
# Create a new service template 1.
[Sysname] wlan service-template 1 crypto
[Sysname-wlan-st-1]
wlan uplink-interface
wlan uplink-interface interface-type interface-number
undo wlan uplink-interface interface-type interface-number
View
Default Level
2: System level
interface-type interface-number: Interface type and interface number.
Use the wlan uplink-interface command to specify an uplink interface.
Use the undo wlan uplink-interface command to remove the uplink interface.
By default, no uplink interface is configured.
If the status of all configured uplink interfaces is down, WLAN service will not be provided. If at least one of them is up, WLAN service will be provided.
Any physical interface can be configured as an uplink interface.
You can use this command to configure multiple uplink interfaces.
# Configure GigabitEthernet 1/0/1 as an uplink interface.
<Sysname> system
[Sysname] wlan uplink-interface GigabitEthernet 1/0/1
l2fw wlan-client-isolation enable
undo l2fw wlan-client-isolation enable
View
Default Level
2: System level
None
Use the l2fw wlan-client-isolation enable command to enable wireless user Layer 2 isolation.
Use the undo l2fw wlan-client-isolation enable command to disable wireless user Layer 2 isolation.
By default, wireless user Layer 2 isolation is enabled.
# Disable wireless user Layer 2 isolation.
[Sysname] undo l2fw wlan-client-isolation enable
% Info: wlan client isolation disabled.
  • Become a Partner
  • Partner Resources
