| 04-WLAN RRM Commands | 49.76 KB |
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Support of the H3C WA series WLAN access points (APs) for commands may vary by AP model. For more information, see Feature Matrix.
l The interface types and the number of interfaces vary by AP model.
autochannel-set avoid-dot11h
undo autochannel-set
View
WLAN RRM view
Default Level
2: System level
None
Use the autochannel-set avoid-dot11h command to set the channel set to non-802.11h channels, which means only the non-802.11h channels belonging to the country code are scanned during initial channel selection, and one of them is selected if auto channel section is also configured.
Use the undo autochannel-set command to restore the default.
By default, the channel set involves all channels.
Example
# Set the channel set to non-802.11h channels.
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
display wlan rrm
display wlan rrm
View
Default Level
1: Monitor level
None
Use the display wlan rrm command to display basic RRM configuration information.
# Display RRM configuration information.
RRM Configuration
11a Configured Rates (Mbps)
Mandatory : 6, 12, 24
Supported : 9, 18, 36, 48, 54
Disabled : -NA-
11b Configured Rates (Mbps)
Mandatory : 1, 2
Supported : 5.5, 11
Disabled : -NA-
11g Configured Rates (Mbps)
Mandatory : 1, 2, 5.5, 11
Supported : 6, 9, 12, 18, 24, 36, 48, 54
Disabled : -NA-
11g Protection : Enabled
11h Configuration
Spectrum Management : Disabled
Power Constraint (dBm) : 0
Channel Set : Non-dot11h
Table 1-1 display wlan rrm command output description
Mandatory |
Rates that an APs is required to support |
Supported |
Additional rates supported by the client or AP |
Disabled |
Rates at which an AP does not transmit data |
11g Protection |
Enables 802.11g protection. |
11h Configuration |
802.11h configuration |
Spectrum Management |
Spectrum management for all 802.11a radios, which is set with command spectrum-management enable. |
Power Constraint (dBm) |
Power constraint for all 802.11a radios, which is set with command power-constraint. |
Channel Set |
l Non-dot11h: Sets the channel set to non dot11h channels. After this function is enabled, the device selects the non 802.11h channels of the country code only. l all: Channel selection is not limited. |
dot11a
dot11a { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | supported-rate }
View
WLAN RRM view
Default Level
2: System level
disabled-rate: Specifies a disabled rate.
mandatory-rate: Specifies a mandatory rate.
supported-rate: Specifies a supported rate.
rate-value: Specifies a radio rate from the following rates:
l 6 Mbps
l 9 Mbps
l 12 Mbps
l 18 Mbps
l 24 Mbps
l 36 Mbps
l 48 Mbps
l 54 Mbps
Use the dot11a command to configure the rates for the radio mode “802.11a”.
Use the undo dot11a command to restore the default.
By default:
l Mandatory rates: 6, 12, 24;
l Supported rates: 9, 18, 36, 48, 54;
l Disabled rates: none.
Support for this command depends on your device model.
# Configure rates (disabled: 12, 24: supported: 6) for 802.11a.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a disabled-rate 12 24
[Sysname-wlan-rrm] dot11a supported-rate 6
dot11b
dot11b { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | supported-rate }
View
WLAN RRM view
Default Level
2: System level
rate-value: Specifies the radio rates as follows:
l 1 Mbps
l 2 Mbps
l 5.5 Mbps
l 11 Mbps
Use the dot11b command to configure the rates for radio mode “802.11b”.
Use the undo dot11b command to restore the default.
By default:
l Mandatory rates: 1, 2;
l Supported rates: 5.5, 11;
# Configure rates (disabled: 1, 2: supported: 11) for 802.11b.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1 2
[Sysname-wlan-rrm] dot11b supported-rate 11
dot11g
dot11g { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | supported-rate }
View
WLAN RRM view
Default Level
2: System level
l 1 Mbps
l 2 Mbps
l 5.5 Mbps
l 6 Mbps
l 9 Mbps
l 11 Mbps
l 12 Mbps
l 18 Mbps
l 24 Mbps
l 36 Mbps
l 48 Mbps
l 54 Mbps
Use the dot11g command to configure the rates for radio mode “802.11g”.
Use the undo dot11g command to restore the default.
By default:
l Mandatory rates: 1, 2, 5.5, 11;
l Supported rates: 6, 9, 12, 18, 24, 36, 48, 54;
# Configure rates (disabled: 2, 36: supported: 54) for 802.11g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g supported-rate 54
dot11g protection enable
undo dot11g protection enable
View
WLAN RRM view
Default Level
2: System level
None
Use the dot11g protection enable command to enable 802.11g protection.
Use the undo dot11g protection enable command to disable 802.11g protection.
By default, 802.11g protection is disabled.
# Enable 802.11g protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11n mandatory maximum-mcs
dot11n mandatory maximum-mcs index
undo dot11n mandatory maximum-mcs
View
WLAN RRM view
Default Level
2: System level
index: Specifies the maximum MCS index for 802.11n mandatory rates, which ranges from 0 to 76. Support for the command depends on the device model.
Use the dot11n mandatory maximum-mcs command to specify the maximum MCS index for 802.11n mandatory rates.
Use the undo dot11n mandatory maximum-mcs command to remove the configuration.
No maximum MCS index is specified for 802.11n mandatory rates by default.
If you configure the maximum MCS and enable the client dot11n-only command, non 802.11n clients cannot associate with the AP.
If you configure the client dot11n-only command for a radio, you must configure the maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n mandatory rates as 15.
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 15
dot11n support maximum-mcs
dot11n support maximum-mcs index
undo dot11n support maximum-mcs
View
WLAN RRM view
Default Level
2: System level
index: Specifies the maximum MCS index for 802.11n supported rates, which ranges from 0 to 76.
Use the dot11n support maximum-mcs command to specify the maximum MCS index for 802.11n supported rates.
Use the undo dot11n support maximum-mcs command to restore the default.
By default, the maximum MCS index for 802.11n supported rates is 76.
# Specify the maximum MCS index for 802.11n supported rates as 25.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
power-constraint
power-constraint power-constraint
undo power-constraint
View
WLAN RRM view
Default Level
2: System level
power-constraint: Power constraint value in dBm, which ranges from 0 to MAX-POWER–1 (where the MAX-POWER is the default maximum power of 802.11a radios, and is defined by the country code).
Use the power-constraint command to configure power constraint for all 11a radios. Configured power constraint is advertised in the beacon if spectrum is enabled.
By default, the power constraint is 0 dBm.
Related commands: spectrum-management enable.
# Configure power-constraint.
[Sysname] wlan rrm
[Sysname-wlan-rrm] power-constraint 5
undo spectrum-management enable
View
WLAN RRM view
Default Level
2: System level
None
Use the spectrum-management enable command to enable spectrum management for 11a radio. When spectrum management is enabled, WLAN sub-system advertises power capabilities of our AP and power constraints applicable to all devices in the BSS based on regulatory domain specification.
Use the undo spectrum-management enable command to disable spectrum management for 11a radio.
By default, spectrum management for 802.11a radios is disabled.
# Enable spectrum management.
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
wlan rrm
wlan rrm
View
Default Level
2: System level
None
Use the wlan rrm command to enter RRM view.
This view is useful for managing resources of Radio.
# Enter RRM view.
[Sysname] wlan rrm
[Sysname-wlan-rrm]
