H3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
38-Appendix
38-Appendix 81.96 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
18-AAA
1-1
accounting
18-AAA
1-2
accounting optional
18-AAA
1-3
accounting optional
18-AAA
1-31
accounting-on enable
18-AAA
1-32
acl
02-Login
2-1
acl
22-ACL
1-1
active region-configuration
15-MSTP
1-1
add-member
25-Stack-Cluster
2-15
administrator-address
25-Stack-Cluster
2-16
am user-bind
12-Port Security-Port Binding
2-1
apply qos-profile
23-QoS-QoS Profile
2-1
arp anti-attack valid-check enable
20-ARP
1-1
arp check enable
20-ARP
1-1
arp detection enable
20-ARP
1-2
arp detection trust
20-ARP
1-3
arp protective-down recover enable
20-ARP
1-3
arp protective-down recover interval
20-ARP
1-4
arp rate-limit
20-ARP
1-5
arp rate-limit enable
20-ARP
1-6
20-ARP
1-7
arp static
20-ARP
1-7
arp timer aging
20-ARP
1-8
ascii
30-FTP-SFTP-TFTP
1-6
attribute
18-AAA
1-4
authentication
18-AAA
1-5
authentication super
18-AAA
1-6
authentication-mode
02-Login
1-1
authorization
18-AAA
1-8
authorization vlan
18-AAA
1-8
auto-build
25-Stack-Cluster
2-17
auto-execute command
02-Login
1-3
B
binary
30-FTP-SFTP-TFTP
1-7
black-list
25-Stack-Cluster
2-45
boot attribute-switch
29-File System Management
1-17
boot boot-loader
1-17
boot boot-loader
32-System Maintenance and Debugging
3-1
boot boot-loader backup-attribute
1-18
boot bootrom
3-1
boot web-package
1-18
bpdu-drop any
15-MSTP
1-2
bpdu-tunnel
33-VLAN-VPN
4-1
bpdu-tunnel tunnel-dmac
33-VLAN-VPN
4-2
broadcast-suppression
09-Port Basic Configuration
1-1
build
25-Stack-Cluster
2-19
burst-mode enable
23-QoS-QoS Profile
1-1
bye
30-FTP-SFTP-TFTP
1-7
bye
30-FTP-SFTP-TFTP
1-24
C
calling-station-id mode
18-AAA
1-34
cd
1-1
cd
30-FTP-SFTP-TFTP
1-8
cd
30-FTP-SFTP-TFTP
1-25
cdup
30-FTP-SFTP-TFTP
1-8
cdup
30-FTP-SFTP-TFTP
1-25
check region-configuration
15-MSTP
1-2
clock datetime
1-1
clock summer-time
1-2
clock timezone
1-3
close
30-FTP-SFTP-TFTP
1-9
cluster
25-Stack-Cluster
2-22
cluster enable
25-Stack-Cluster
2-22
cluster switch-to
25-Stack-Cluster
2-23
cluster-mac
25-Stack-Cluster
2-24
cluster-mac syn-interval
25-Stack-Cluster
2-25
command-privilege level
01-CLI
1-1
copy
1-2
copy configuration
1-2
copyright-info enable
02-Login
1-4
count
34-HWPing
1-1
cut connection
18-AAA
1-9
D
databits
02-Login
1-5
data-flow-format
18-AAA
1-35
data-flow-format
18-AAA
1-66
datasize
34-HWPing
1-1
debugging
1-9
delete
1-3
delete
30-FTP-SFTP-TFTP
1-10
delete
30-FTP-SFTP-TFTP
1-26
delete static-routes all
05-Management VLAN
1-1
delete-member
25-Stack-Cluster
2-26
description
04-VLAN
1-1
description
1-5
description
22-ACL
1-2
destination-ip
34-HWPing
1-2
destination-port
34-HWPing
1-3
dhcp protective-down recover enable
21-DHCP
2-1
dhcp protective-down recover interval
21-DHCP
2-1
dhcp rate-limit
21-DHCP
2-2
dhcp rate-limit enable
21-DHCP
2-3
dhcp-snooping
21-DHCP
1-1
dhcp-snooping information enable
21-DHCP
1-2
dhcp-snooping information format
21-DHCP
1-2
dhcp-snooping information packet-format
21-DHCP
1-3
dhcp-snooping information remote-id
21-DHCP
1-4
dhcp-snooping information strategy
21-DHCP
1-4
dhcp-snooping information vlan circuit-id
21-DHCP
1-6
dhcp-snooping information vlan remote-id
21-DHCP
1-7
dhcp-snooping trust
21-DHCP
1-8
dir
1-5
dir
30-FTP-SFTP-TFTP
1-10
dir
30-FTP-SFTP-TFTP
1-27
disconnect
30-FTP-SFTP-TFTP
1-12
display acl
22-ACL
1-3
display acl remaining entry
22-ACL
1-4
display am user-bind
2-2
display arp
20-ARP
1-9
display arp |
20-ARP
1-10
display arp count
20-ARP
1-11
display arp detection statistics interface
20-ARP
1-12
display arp timer aging
20-ARP
1-13
display boot-loader
1-19
display boot-loader
3-2
display bootp client
21-DHCP
3-3
display bpdu-tunnel
33-VLAN-VPN
4-3
display brief interface
1-5
display channel
31-Information Center
1-1
display clock
1-6
display cluster
25-Stack-Cluster
2-27
display cluster base-members
25-Stack-Cluster
2-46
display cluster base-topology
25-Stack-Cluster
2-47
display cluster black-list
25-Stack-Cluster
2-48
display cluster candidates
25-Stack-Cluster
2-29
display cluster current-topology
25-Stack-Cluster
2-49
display cluster members
25-Stack-Cluster
2-31
display connection
18-AAA
1-10
display cpu
3-3
display current-configuration
03-Configuration File Management
1-1
display current-configuration vlan
1-6
display debugging
1-7
display device
3-4
display dhcp client
21-DHCP
3-1
display dhcp-snooping
21-DHCP
1-9
display dhcp-snooping trust
21-DHCP
1-9
display diagnostic-information
1-10
display dldp
13-DLDP
1-1
display dns domain
36-DNS
1-1
display dns dynamic-host
36-DNS
1-2
display dns ipv6 dynamic-host
35-IPv6 Management
1-1
display dns server
36-DNS
1-2
display domain
18-AAA
1-12
display dot1x
17-802.1x-System Guard
1-1
display fib
06-IP Address-IP Performance
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib statistics
2-5
display ftp-server
30-FTP-SFTP-TFTP
1-1
display ftp-user
30-FTP-SFTP-TFTP
1-2
display garp statistics
08-GVRP
1-1
display garp timer
08-GVRP
1-2
display gvrp statistics
08-GVRP
1-6
display gvrp status
08-GVRP
1-7
display habp
3-1
display habp table
3-2
display habp traffic
3-2
display history-command
01-CLI
1-3
display hwping
34-HWPing
1-4
display hwtacacs
18-AAA
1-67
display icmp statistics
2-5
display igmp-snooping configuration
16-Multicast
1-1
display igmp-snooping group
16-Multicast
1-2
display igmp-snooping statistics
16-Multicast
1-3
display info-center
1-1
display interface
1-7
display interface Vlan-interface
04-VLAN
1-2
05-Management VLAN
1-1
display ip host
36-DNS
1-4
display ip interface
05-Management VLAN
1-2
1-1
display ip interface brief
05-Management VLAN
1-4
1-3
display ip routing-table
05-Management VLAN
1-5
display ip routing-table acl
05-Management VLAN
1-7
display ip routing-table ip-address
05-Management VLAN
1-10
display ip routing-table ip-address1 ip-address2
05-Management VLAN
1-11
display ip routing-table protocol
05-Management VLAN
1-12
display ip routing-table radix
05-Management VLAN
1-13
display ip routing-table statistics
05-Management VLAN
1-14
display ip routing-table verbose
05-Management VLAN
1-15
display ip socket
2-7
display ip source static binding
21-DHCP
1-10
display ip statistics
2-9
display ipv6 fib
35-IPv6 Management
1-2
display ipv6 host
35-IPv6 Management
1-3
display ipv6 interface
35-IPv6 Management
1-4
display ipv6 neighbors
35-IPv6 Management
1-7
display ipv6 neighbors count
35-IPv6 Management
1-9
display ipv6 route-table
35-IPv6 Management
1-10
display ipv6 socket
35-IPv6 Management
1-12
display ipv6 statistics
35-IPv6 Management
1-13
display ipv6-acl-template
22-ACL
1-5
display isolate port
11-Port Isolation
1-1
display lacp system-id
10-Link Aggregation
1-5
display link-aggregation interface
10-Link Aggregation
1-1
display link-aggregation summary
10-Link Aggregation
1-2
display link-aggregation verbose
10-Link Aggregation
1-3
display link-delay
1-13
display local-server statistics
18-AAA
1-36
display local-user
18-AAA
1-14
display logbuffer
1-3
display logbuffer summary
1-5
display loopback-detection
1-13
display mac-address
14-MAC Address Table Management
1-2
display mac-address aging-time
1-1
display mac-address multicast static
16-Multicast
2-1
display mac-address security
1-1
display mac-authentication
19-MAC Address Authentication
1-1
display mac-vlan
04-VLAN
1-18
display mac-vlan interface
04-VLAN
1-17
display memory
3-5
display mirroring-group
24-Mirroring
1-1
display monitor-link group
37-Smart Link-Monitor Link
2-1
display multicast-source-deny
16-Multicast
2-2
display ndp
25-Stack-Cluster
2-1
display ntdp
25-Stack-Cluster
2-6
display ntdp device-list
25-Stack-Cluster
2-8
display ntdp single-device mac-address
25-Stack-Cluster
2-51
display ntp-service sessions
27-NTP
1-1
display ntp-service status
27-NTP
1-3
display ntp-service trace
27-NTP
1-4
display packet-filter
22-ACL
1-6
display port
04-VLAN
1-10
display port combo
1-14
display port vlan-vpn
33-VLAN-VPN
1-1
display port-mac
1-4
display port-security
1-3
display power
3-6
display priority-trust
23-QoS-QoS Profile
1-1
display protocol-vlan interface
04-VLAN
1-21
display protocol-vlan vlan
04-VLAN
1-22
display public-key local
28-SSH
1-1
display public-key peer
28-SSH
1-2
display qos cos-local-precedence-map
23-QoS-QoS Profile
1-2
display qos dscp-local-precedence-map
23-QoS-QoS Profile
1-2
display qos-global
23-QoS-QoS Profile
1-5
display qos-interface all
23-QoS-QoS Profile
1-6
display qos-interface line-rate
23-QoS-QoS Profile
1-7
display qos-interface mirrored-to
23-QoS-QoS Profile
1-8
display qos-interface traffic-limit
23-QoS-QoS Profile
1-9
display qos-interface traffic-priority
23-QoS-QoS Profile
1-9
display qos-interface traffic-redirect
23-QoS-QoS Profile
1-10
display qos-interface traffic-shape
23-QoS-QoS Profile
1-11
display qos-interface traffic-statistic
23-QoS-QoS Profile
1-12
display qos-port-group
23-QoS-QoS Profile
1-13
display qos-profile
23-QoS-QoS Profile
2-2
display qos-vlan
23-QoS-QoS Profile
1-14
display queue-scheduler
23-QoS-QoS Profile
1-15
display radius scheme
18-AAA
1-36
display radius statistics
18-AAA
1-39
display rmon alarm
26-SNMP-RMON
2-1
display rmon event
26-SNMP-RMON
2-2
display rmon eventlog
26-SNMP-RMON
2-3
display rmon history
26-SNMP-RMON
2-4
display rmon prialarm
26-SNMP-RMON
2-6
display rmon statistics
26-SNMP-RMON
2-8
display rsa local-key-pair public
28-SSH
1-4
display rsa peer-public-key
28-SSH
1-5
display saved-configuration
1-7
display schedule reboot
3-6
display smart-link flush
1-1
display smart-link group
1-2
display snmp-agent
26-SNMP-RMON
1-1
display snmp-agent community
26-SNMP-RMON
1-2
display snmp-agent group
26-SNMP-RMON
1-3
display snmp-agent mib-view
26-SNMP-RMON
1-5
display snmp-agent statistics
26-SNMP-RMON
1-6
display snmp-agent sys-info
26-SNMP-RMON
1-9
display snmp-agent trap-list
26-SNMP-RMON
1-10
display snmp-agent usm-user
26-SNMP-RMON
1-10
display ssh server
28-SSH
1-6
display ssh server-info
28-SSH
1-8
display ssh user-information
28-SSH
1-9
display stacking
25-Stack-Cluster
1-1
display startup
1-9
display stop-accounting-buffer
18-AAA
1-40
18-AAA
1-68
display storm-constrain
1-15
display stp
15-MSTP
1-4
display stp abnormalport
15-MSTP
1-8
display stp portdown
15-MSTP
1-9
display stp region-configuration
15-MSTP
1-10
display stp root
15-MSTP
1-11
display system-guard attack-record
4-1
display system-guard state
4-2
display tcp ipv6 statistics
35-IPv6 Management
1-17
display tcp ipv6 status
35-IPv6 Management
1-19
display tcp statistics
2-11
display tcp status
2-13
display this
1-10
display time-range
22-ACL
1-7
display transceiver alarm interface
3-7
display transceiver diagnosis interface
3-10
display transceiver interface
3-11
display transceiver manuinfo interface
3-13
display trapbuffer
1-6
display udp ipv6 statistics
35-IPv6 Management
1-20
display udp statistics
2-14
display unit
1-16
display user-interface
02-Login
1-6
display users
02-Login
1-8
display version
1-8
display vlan
04-VLAN
1-3
display vlan
07-Voice VLAN
1-4
display voice vlan error-info
07-Voice VLAN
1-1
display voice vlan oui
07-Voice VLAN
1-2
display voice vlan status
07-Voice VLAN
1-2
display web package
1-20
display web users
02-Login
1-9
dldp
13-DLDP
1-2
dldp authentication-mode
13-DLDP
1-3
dldp delaydown-timer
13-DLDP
1-8
dldp interval
13-DLDP
1-4
dldp reset
13-DLDP
1-5
dldp unidirectional-shutdown
13-DLDP
1-6
dldp work-mode
13-DLDP
1-7
dns domain
36-DNS
1-4
dns resolve
36-DNS
1-5
dns resolve-target
34-HWPing
1-13
dns server
36-DNS
1-6
dns server ipv6
35-IPv6 Management
1-21
dns-server
34-HWPing
1-12
domain
18-AAA
1-15
domain delimiter
18-AAA
1-17
dot1x
1-5
dot1x authentication-method
1-6
dot1x dhcp-launch
1-7
dot1x free-ip
2-1
dot1x guest-vlan
1-8
dot1x handshake
1-9
dot1x handshake secure
1-10
dot1x max-user
1-11
dot1x port-control
1-12
dot1x port-method
1-14
dot1x quiet-period
1-15
dot1x re-authenticate
1-17
dot1x retry
1-16
dot1x retry-version-max
1-16
dot1x supp-proxy-check
1-18
dot1x timer
1-20
dot1x timer acl-timeout
2-2
dot1x timer reauth-period
1-22
dot1x url
2-2
dot1x version-check
1-23
duplex
1-18
E
enable log updown
1-19
enable snmp trap updown
26-SNMP-RMON
1-12
execute
1-6
exit
30-FTP-SFTP-TFTP
1-27
F
file prompt
1-7
filename
34-HWPing
1-13
fixdisk
1-8
flow interval
1-20
flow-control
1-20
flush enable control-vlan
1-3
format
1-9
free user-interface
02-Login
1-10
free web-users
02-Login
2-2
frequency
34-HWPing
1-14
ftp
30-FTP-SFTP-TFTP
1-12
ftp cluster
25-Stack-Cluster
2-33
ftp disconnect
30-FTP-SFTP-TFTP
1-3
ftp server enable
30-FTP-SFTP-TFTP
1-4
ftp timeout
30-FTP-SFTP-TFTP
1-5
ftp-operation
34-HWPing
1-15
ftp-server
25-Stack-Cluster
2-34
G
garp timer
08-GVRP
1-3
garp timer leaveall
08-GVRP
1-5
get
30-FTP-SFTP-TFTP
1-13
get
30-FTP-SFTP-TFTP
1-28
gratuitous-arp-learning enable
20-ARP
1-14
gvrp
08-GVRP
1-8
gvrp registration
08-GVRP
1-9
H
habp enable
3-3
habp server vlan
3-4
habp timer
3-5
header
02-Login
1-11
help
30-FTP-SFTP-TFTP
1-29
history-command max-size
02-Login
1-13
history-records
34-HWPing
1-16
holdtime
25-Stack-Cluster
2-35
http-operation
34-HWPing
1-17
http-string
34-HWPing
1-17
hwping
34-HWPing
1-18
hwping-agent enable
34-HWPing
1-19
hwping-server enable
34-HWPing
1-31
hwping-server tcpconnect
34-HWPing
1-32
hwping-server udpecho
34-HWPing
1-33
hwtacacs nas-ip
18-AAA
1-68
hwtacacs scheme
18-AAA
1-69
I
icmp redirect send
2-16
icmp unreach send
2-16
idle-cut
18-AAA
1-18
idle-timeout
02-Login
1-14
igmp host-join
16-Multicast
1-17
igmp-snooping
16-Multicast
1-5
igmp-snooping fast-leave
16-Multicast
1-5
igmp-snooping general-query source-ip
16-Multicast
1-7
igmp-snooping group-limit
16-Multicast
1-8
igmp-snooping group-policy
16-Multicast
1-9
igmp-snooping host-aging-time
16-Multicast
1-11
igmp-snooping nonflooding-enable
16-Multicast
1-12
igmp-snooping querier
16-Multicast
1-13
igmp-snooping query-interval
16-Multicast
1-14
igmp-snooping router-aging-time
16-Multicast
1-15
igmp-snooping version
16-Multicast
1-15
igmp-snooping vlan-mapping
16-Multicast
1-16
info-center channel name
1-7
info-center console channel
1-7
info-center enable
1-8
info-center logbuffer
1-9
info-center loghost
1-10
info-center loghost source
1-11
info-center monitor channel
1-12
info-center snmp channel
1-12
info-center source
1-13
info-center synchronous
1-16
info-center timestamp
1-17
info-center timestamp loghost
1-18
info-center timestamp utc
1-19
info-center trapbuffer
1-20
instance
15-MSTP
1-11
interface
1-21
04-VLAN
1-5
05-Management VLAN
1-16
ip address
05-Management VLAN
1-17
ip address
1-4
ip address bootp-alloc
21-DHCP
3-4
ip address dhcp-alloc
21-DHCP
3-2
ip check source ip-address
21-DHCP
1-11
ip host
36-DNS
1-7
ip http acl
02-Login
2-2
ip http shutdown
02-Login
1-15
ip route-static
05-Management VLAN
1-18
21-DHCP
1-12
ip-pool
25-Stack-Cluster
2-36
ipv6 address
35-IPv6 Management
1-22
ipv6 address auto link-local
35-IPv6 Management
1-23
ipv6 address eui-64
35-IPv6 Management
1-24
ipv6 address link-local
35-IPv6 Management
1-25
ipv6 host
35-IPv6 Management
1-26
ipv6 icmp-error
35-IPv6 Management
1-27
ipv6 nd dad attempts
35-IPv6 Management
1-28
ipv6 nd hop-limit
35-IPv6 Management
1-29
ipv6 nd ns retrans-timer
35-IPv6 Management
1-29
ipv6 nd nud reachable-time
35-IPv6 Management
1-30
ipv6 neighbor
35-IPv6 Management
1-31
ipv6 neighbors max-learning-num
35-IPv6 Management
1-32
ipv6 route-static
35-IPv6 Management
1-32
ipv6-acl-template
22-ACL
1-8
J
jitter-interval
34-HWPing
1-19
jitter-packetnum
34-HWPing
1-20
jumboframe enable
1-22
K
key
18-AAA
1-41
key
18-AAA
1-70
L
lacp enable
10-Link Aggregation
1-5
lacp port-priority
10-Link Aggregation
1-6
lacp system-priority
10-Link Aggregation
1-7
lcd
30-FTP-SFTP-TFTP
1-14
level
18-AAA
1-18
line-rate
23-QoS-QoS Profile
1-16
link-aggregation group
1-4
2-2
link-aggregation group description
10-Link Aggregation
1-7
link-aggregation group mode
10-Link Aggregation
1-8
link-delay
1-23
local-server
18-AAA
1-43
local-server nas-ip
18-AAA
1-43
local-user
18-AAA
1-19
local-user password-display-mode
18-AAA
1-21
lock
02-Login
1-16
logging-host
25-Stack-Cluster
2-37
loopback
1-24
loopback-detection control enable
1-24
loopback-detection enable
1-25
loopback-detection interface-list enable
1-27
loopback-detection interval-time
1-28
loopback-detection per-vlan enable
1-28
loopback-detection shutdown enable
1-29
ls
30-FTP-SFTP-TFTP
1-14
ls
30-FTP-SFTP-TFTP
1-29
M
mac-address
1-4
mac-address max-mac-count
1-6
mac-address max-mac-count 0
1-7
mac-address multicast interface
16-Multicast
2-3
mac-address multicast vlan
16-Multicast
2-4
1-6
mac-address timer
1-8
mac-authentication
1-4
mac-authentication authmode usernameasmacaddress
1-6
mac-authentication authmode usernamefixed
1-7
mac-authentication authpassword
1-7
mac-authentication authusername
1-8
mac-authentication domain
1-9
mac-authentication guest-vlan
1-11
mac-authentication interface
1-5
mac-authentication max-auth-num
1-13
mac-authentication timer
1-9
mac-authentication timer guest-vlan-reauth
1-14
mac-authenticiaon intrusion-mode block-mac
1-12
mac-vlan enable
04-VLAN
1-20
mac-vlan mac-address
04-VLAN
1-19
management-vlan
05-Management VLAN
1-19
management-vlan
25-Stack-Cluster
2-38
mdi
1-30
messenger
18-AAA
1-21
mirrored-to
23-QoS-QoS Profile
1-17
mirrored-to vlan
23-QoS-QoS Profile
1-19
mirroring-group
24-Mirroring
1-3
mirroring-group mirroring-port
24-Mirroring
1-4
mirroring-group monitor-port
24-Mirroring
1-5
mirroring-group reflector-port
24-Mirroring
1-6
mirroring-group remote-probe vlan
24-Mirroring
1-6
mirroring-port
24-Mirroring
1-7
mkdir
1-10
mkdir
30-FTP-SFTP-TFTP
1-15
mkdir
30-FTP-SFTP-TFTP
1-30
monitor-link group
2-3
monitor-port
24-Mirroring
1-8
more
1-11
move
1-12
multicast static-group interface
16-Multicast
1-18
multicast static-group vlan
16-Multicast
1-19
multicast static-router-port
16-Multicast
1-20
multicast static-router-port vlan
16-Multicast
1-20
16-Multicast
2-4
multicast-suppression
1-31
N
name
04-VLAN
1-6
name
18-AAA
1-22
nas-ip
18-AAA
1-44
nas-ip
18-AAA
1-71
ndp enable
25-Stack-Cluster
2-3
ndp timer aging
25-Stack-Cluster
2-4
ndp timer hello
25-Stack-Cluster
2-5
nslookup type
36-DNS
1-7
ntdp enable
25-Stack-Cluster
2-10
ntdp explore
25-Stack-Cluster
2-11
ntdp hop
25-Stack-Cluster
2-11
ntdp timer
25-Stack-Cluster
2-12
ntdp timer hop-delay
25-Stack-Cluster
2-13
ntdp timer port-delay
25-Stack-Cluster
2-14
ntp-service access
27-NTP
1-5
ntp-service authentication enable
27-NTP
1-7
ntp-service authentication-keyid
27-NTP
1-7
ntp-service broadcast-client
27-NTP
1-8
ntp-service broadcast-server
27-NTP
1-9
ntp-service in-interface disable
27-NTP
1-10
ntp-service max-dynamic-sessions
27-NTP
1-10
ntp-service multicast-client
27-NTP
1-11
ntp-service multicast-server
27-NTP
1-12
ntp-service reliable authentication-keyid
27-NTP
1-13
ntp-service source-interface
27-NTP
1-13
ntp-service unicast-peer
27-NTP
1-14
ntp-service unicast-server
27-NTP
1-15
O
open
30-FTP-SFTP-TFTP
1-16
P
packet-filter
22-ACL
1-9
packet-filter
23-QoS-QoS Profile
2-4
packet-filter vlan
22-ACL
1-10
parity
02-Login
1-17
passive
30-FTP-SFTP-TFTP
1-17
password
18-AAA
1-23
password
34-HWPing
1-21
peer-public-key end
28-SSH
1-9
ping
2-1
ping ipv6
35-IPv6 Management
2-1
port
04-VLAN
1-10
port
1-32
port
1-5
port
2-4
port access vlan
04-VLAN
1-11
port hybrid protocol-vlan vlan
04-VLAN
1-23
port hybrid pvid vlan
04-VLAN
1-12
port hybrid vlan
04-VLAN
1-13
port isolate
11-Port Isolation
1-1
port link-aggregation group
10-Link Aggregation
1-9
port link-type
04-VLAN
1-14
port monitor-link group
2-5
port smart-link group
1-6
port trunk permit vlan
04-VLAN
1-15
port trunk pvid vlan
04-VLAN
1-16
port-group
1-33
port-mac
1-9
port-security authorization ignore
1-11
port-security enable
1-7
port-security intrusion-mode
1-8
port-security max-mac-count
1-12
port-security ntk-mode
1-13
port-security oui
1-14
port-security port-mode
1-15
port-security timer disableport
1-18
port-security trap
1-19
primary accounting
18-AAA
1-45
primary accounting
18-AAA
1-72
primary authentication
18-AAA
1-46
18-AAA
1-73
primary authorization
18-AAA
1-73
priority
23-QoS-QoS Profile
1-20
priority trust
23-QoS-QoS Profile
1-21
priority-trust
23-QoS-QoS Profile
1-22
probe-failtimes
34-HWPing
1-22
protocol inbound
02-Login
1-17
protocol inbound
28-SSH
1-10
protocol-vlan
04-VLAN
1-25
public-key local create
28-SSH
1-11
public-key local destroy
28-SSH
1-14
public-key local export dsa
28-SSH
1-16
public-key local export rsa
28-SSH
1-14
public-key peer
28-SSH
1-18
public-key peer import sshkey
28-SSH
1-19
public-key-code begin
28-SSH
1-20
public-key-code end
28-SSH
1-20
put
30-FTP-SFTP-TFTP
1-18
put
30-FTP-SFTP-TFTP
1-31
pwd
1-12
pwd
30-FTP-SFTP-TFTP
1-18
pwd
30-FTP-SFTP-TFTP
1-31
Q
23-QoS-QoS Profile
1-23
23-QoS-QoS Profile
1-24
qos-profile
23-QoS-QoS Profile
2-5
qos-profile port-based
23-QoS-QoS Profile
2-5
queue-scheduler
23-QoS-QoS Profile
1-27
30-FTP-SFTP-TFTP
1-19
30-FTP-SFTP-TFTP
1-32
1-4
R
radius client
18-AAA
1-48
radius nas-ip
18-AAA
1-48
radius scheme
18-AAA
1-49
radius trap
18-AAA
1-50
radius-scheme
18-AAA
1-24
raw-vlan-id inbound
33-VLAN-VPN
2-1
reboot
3-13
reboot member
25-Stack-Cluster
2-38
region-name
15-MSTP
1-12
remotehelp
30-FTP-SFTP-TFTP
1-19
remote-probe vlan enable
24-Mirroring
1-9
remove
30-FTP-SFTP-TFTP
1-32
rename
1-13
rename
30-FTP-SFTP-TFTP
1-20
rename
30-FTP-SFTP-TFTP
1-33
reset arp
20-ARP
1-14
reset counters interface
1-34
reset dns dynamic-host
36-DNS
1-8
reset dns ipv6 dynamic-host
35-IPv6 Management
1-33
reset dot1x statistics
1-24
reset garp statistics
08-GVRP
1-6
reset hwtacacs statistics
18-AAA
1-74
reset igmp-snooping statistics
16-Multicast
1-21
reset ip routing-table statistics protocol
05-Management VLAN
1-20
reset ip statistics
2-17
reset ipv6 neighbors
35-IPv6 Management
1-34
reset ipv6 statistics
35-IPv6 Management
1-35
reset lacp statistics
10-Link Aggregation
1-10
reset logbuffer
1-21
reset mac-authentication
1-10
reset ndp statistics
25-Stack-Cluster
2-6
reset radius statistics
18-AAA
1-51
reset recycle-bin
1-14
reset saved-configuration
1-11
reset smart-link packets counter
1-7
reset stop-accounting-buffer
18-AAA
1-52
18-AAA
1-75
reset stp
15-MSTP
1-13
reset tcp ipv6 statistics
35-IPv6 Management
1-35
reset tcp statistics
2-17
reset traffic-limit
23-QoS-QoS Profile
1-29
reset traffic-limit vlan
23-QoS-QoS Profile
1-29
reset traffic-statistic
23-QoS-QoS Profile
1-30
reset traffic-statistic vlan
23-QoS-QoS Profile
1-30
reset trapbuffer
1-21
reset udp ipv6 statistics
35-IPv6 Management
1-36
reset udp statistics
2-18
retry
18-AAA
1-53
retry realtime-accounting
18-AAA
1-54
retry stop-accounting
18-AAA
1-55
18-AAA
1-75
return
1-4
revision-level
15-MSTP
1-14
rmdir
1-16
rmdir
30-FTP-SFTP-TFTP
1-21
rmdir
30-FTP-SFTP-TFTP
1-33
rmon alarm
26-SNMP-RMON
2-9
rmon event
26-SNMP-RMON
2-12
rmon history
26-SNMP-RMON
2-13
rmon prialarm
26-SNMP-RMON
2-14
rmon statistics
26-SNMP-RMON
2-16
rsa local-key-pair create
28-SSH
1-21
rsa local-key-pair destroy
28-SSH
1-23
rsa peer-public-key
28-SSH
1-24
rsa peer-public-key import sshkey
28-SSH
1-25
rule (for Advanced ACLs)
22-ACL
1-14
rule (for Basic ACLs)
22-ACL
1-11
rule (for IPv6 ACLs)
22-ACL
1-25
rule (for Layer 2 ACLs)
22-ACL
1-22
rule comment
22-ACL
1-27
S
save
1-13
schedule reboot at
3-14
schedule reboot delay
3-16
schedule reboot regularity
3-17
scheme
18-AAA
1-25
screen-length
02-Login
1-19
secondary accounting
18-AAA
1-56
18-AAA
1-76
secondary authentication
18-AAA
1-57
18-AAA
1-77
secondary authorization
18-AAA
1-78
security-policy-server
18-AAA
2-1
self-service-url
18-AAA
1-26
send
02-Login
1-19
send-trap
34-HWPing
1-23
server-type
18-AAA
1-58
service-type
02-Login
1-20
service-type
18-AAA
1-27
service-type multicast
16-Multicast
1-22
set authentication password
02-Login
1-22
sftp
30-FTP-SFTP-TFTP
1-34
sftp server enable
30-FTP-SFTP-TFTP
1-23
sftp timeout
30-FTP-SFTP-TFTP
1-23
shell
02-Login
1-23
shutdown
04-VLAN
1-7
shutdown
1-34
smart-link flush enable
1-7
smart-link group
1-8
smart-link group
2-6
snmp-agent
26-SNMP-RMON
1-13
snmp-agent calculate-password
26-SNMP-RMON
1-14
02-Login
2-3
26-SNMP-RMON
1-15
snmp-agent group
02-Login
2-4
snmp-agent group
26-SNMP-RMON
1-16
snmp-agent local-engineid
26-SNMP-RMON
1-18
snmp-agent log
26-SNMP-RMON
1-19
snmp-agent mib-view
26-SNMP-RMON
1-20
snmp-agent packet max-size
26-SNMP-RMON
1-22
snmp-agent sys-info
26-SNMP-RMON
1-23
snmp-agent target-host
26-SNMP-RMON
1-24
snmp-agent trap enable
26-SNMP-RMON
1-25
snmp-agent trap ifmib
26-SNMP-RMON
1-26
snmp-agent trap life
26-SNMP-RMON
1-28
snmp-agent trap queue-size
26-SNMP-RMON
1-28
snmp-agent trap source
26-SNMP-RMON
1-29
snmp-agent usm-user
02-Login
2-5
snmp-agent usm-user { v1 | v2c }
26-SNMP-RMON
1-30
snmp-agent usm-user v3
26-SNMP-RMON
1-32
snmp-host
25-Stack-Cluster
2-39
source-interface
34-HWPing
1-23
source-ip
34-HWPing
1-25
source-port
34-HWPing
1-25
speed
02-Login
1-24
speed
1-35
ssh authentication-type default
28-SSH
1-26
ssh client assign
28-SSH
1-27
ssh client first-time enable
28-SSH
1-29
ssh server authentication-retries
28-SSH
1-30
ssh server compatible-ssh1x enable
28-SSH
1-30
ssh server rekey-interval
28-SSH
1-31
ssh server timeout
28-SSH
1-32
ssh user
28-SSH
1-33
ssh user assign
28-SSH
1-34
ssh user authentication-type
28-SSH
1-35
ssh user service-type
28-SSH
1-37
ssh2
28-SSH
1-38
stacking
25-Stack-Cluster
1-3
stacking enable
25-Stack-Cluster
1-4
stacking ip-pool
25-Stack-Cluster
1-5
stack-port enable
25-Stack-Cluster
1-3
startup bootrom-access enable
1-20
startup saved-configuration
1-14
state
18-AAA
1-28
state
18-AAA
1-59
stop-accounting-buffer enable
18-AAA
1-60
stopbits
02-Login
1-24
storm-constrain
1-36
storm-constrain control
1-37
storm-constrain enable
1-38
storm-constrain interval
1-39
stp
15-MSTP
1-15
stp bpdu-protection
15-MSTP
1-16
stp bridge-diameter
15-MSTP
1-16
stp compliance
15-MSTP
1-17
stp config-digest-snooping
15-MSTP
1-19
stp cost
15-MSTP
1-20
stp dot1d-trap
15-MSTP
1-21
stp edged-port
15-MSTP
1-23
stp interface
15-MSTP
1-24
stp interface compliance
15-MSTP
1-25
stp interface config-digest-snooping
15-MSTP
1-26
stp interface cost
15-MSTP
1-28
stp interface edged-port
15-MSTP
1-29
stp interface loop-protection
15-MSTP
1-31
stp interface mcheck
15-MSTP
1-32
stp interface no-agreement-check
15-MSTP
1-32
stp interface point-to-point
15-MSTP
1-34
stp interface port priority
15-MSTP
1-35
stp interface root-protection
15-MSTP
1-36
stp interface transmit-limit
15-MSTP
1-37
stp loop-protection
15-MSTP
1-38
stp max-hops
15-MSTP
1-39
stp mcheck
15-MSTP
1-40
stp mode
15-MSTP
1-41
stp no-agreement-check
15-MSTP
1-42
stp pathcost-standard
15-MSTP
1-43
stp point-to-point
15-MSTP
1-45
stp port priority
15-MSTP
1-46
stp portlog
15-MSTP
1-47
stp portlog all
15-MSTP
1-47
stp priority
15-MSTP
1-48
15-MSTP
1-49
stp root primary
15-MSTP
1-50
stp root secondary
15-MSTP
1-51
stp root-protection
15-MSTP
1-52
stp tc-protection
15-MSTP
1-53
stp tc-protection threshold
15-MSTP
1-54
stp timer forward-delay
15-MSTP
1-55
stp timer hello
15-MSTP
1-56
stp timer max-age
15-MSTP
1-57
stp timer-factor
15-MSTP
1-58
stp transmit-limit
15-MSTP
1-59
super
01-CLI
1-4
super authentication-mode
01-CLI
1-5
super password
01-CLI
1-6
sysname
1-5
system-guard detect-threshold
4-3
system-guard enable
4-3
system-guard permit
4-4
system-guard timer-interval
4-5
system-monitor enable
3-18
1-6
T
tcp ipv6 timer fin-timeout
35-IPv6 Management
1-36
tcp ipv6 timer syn-timeout
35-IPv6 Management
1-37
tcp ipv6 window
35-IPv6 Management
1-37
tcp timer fin-timeout
2-18
tcp timer syn-timeout
2-19
tcp window
2-20
telnet
02-Login
1-25
telnet ipv6
02-Login
1-26
telnet ipv6
35-IPv6 Management
2-3
terminal debugging
1-22
terminal debugging
1-11
terminal logging
1-22
terminal monitor
1-23
terminal trapping
1-24
test-enable
34-HWPing
1-27
test-failtimes
34-HWPing
1-28
test-type
34-HWPing
1-26
tftp { ascii | binary }
30-FTP-SFTP-TFTP
2-1
tftp get
25-Stack-Cluster
2-40
tftp get
30-FTP-SFTP-TFTP
2-1
tftp ipv6
35-IPv6 Management
2-4
tftp put
25-Stack-Cluster
2-41
tftp put
30-FTP-SFTP-TFTP
2-3
tftp-server
25-Stack-Cluster
2-42
tftp-server acl
30-FTP-SFTP-TFTP
2-4
timeout
34-HWPing
1-29
timer
18-AAA
1-61
timer
25-Stack-Cluster
2-43
timer quiet
18-AAA
1-62
timer quiet
18-AAA
1-79
timer realtime-accounting
18-AAA
1-63
18-AAA
1-80
timer response-timeout
18-AAA
1-64
18-AAA
1-81
time-range
22-ACL
1-28
topology accept
25-Stack-Cluster
2-52
topology restore-from
25-Stack-Cluster
2-53
topology save-to
25-Stack-Cluster
2-54
tos
34-HWPing
1-29
tracemac
25-Stack-Cluster
2-44
tracert
2-3
tracert ipv6
35-IPv6 Management
2-5
traffic-limit
23-QoS-QoS Profile
1-31
traffic-limit
23-QoS-QoS Profile
2-6
traffic-limit vlan
23-QoS-QoS Profile
1-34
traffic-priority
23-QoS-QoS Profile
1-36
traffic-priority
23-QoS-QoS Profile
2-8
traffic-priority vlan
23-QoS-QoS Profile
1-37
traffic-redirect
23-QoS-QoS Profile
1-38
traffic-redirect vlan
23-QoS-QoS Profile
1-40
traffic-shape
23-QoS-QoS Profile
1-41
traffic-statistic
23-QoS-QoS Profile
1-42
23-QoS-QoS Profile
1-43
U
undelete
1-16
unknown-multicast drop enable
16-Multicast
2-6
user
30-FTP-SFTP-TFTP
1-21
user privilege level
02-Login
1-28
user-interface
02-Login
1-27
username
34-HWPing
1-30
user-name-format
18-AAA
1-65
user-name-format
18-AAA
1-81
V
verbose
30-FTP-SFTP-TFTP
1-22
virtual-cable-test
1-40
vlan
04-VLAN
1-8
vlan-assignment-mode
18-AAA
1-29
vlan-mapping
33-VLAN-VPN
3-1
vlan-mapping enable
33-VLAN-VPN
3-2
vlan-mapping modulo
15-MSTP
1-60
vlan-vpn enable
33-VLAN-VPN
1-2
vlan-vpn selective enable
33-VLAN-VPN
2-3
vlan-vpn tpid
33-VLAN-VPN
1-3
vlan-vpn vid
33-VLAN-VPN
2-2
voice vlan
07-Voice VLAN
1-4
voice vlan aging
07-Voice VLAN
1-6
voice vlan enable
07-Voice VLAN
1-7
voice vlan legacy
07-Voice VLAN
1-8
voice vlan mac-address
07-Voice VLAN
1-8
voice vlan mode
07-Voice VLAN
1-9
voice vlan security enable
07-Voice VLAN
1-10
W
X
xmodem get
3-19
Y
Z
