H3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
03-Configuration File Management Commands
03-Configuration File Management Commands 62.25 KB
Chapter 1  Configuration File Management Commands
&  Note:
S3100 series Ethernet switches allow you to input a file path and file name in one of the following ways:
l      In universal resource locator (URL) format and starting with “unit1>flash:/”. or “flash:/” This method is used to specify a file in the current Flash memory. For example, the URL of a file named text.txt in the root directory of the switch is unit1>flash:/text.txt or flash:/text.txt.
l      Entering the path name or file name directly. This method can be used to specify a path or a file in the current work directory. For example, to access file text.txt in the current directory, you can directly input the file name text.txt as the file URL
1.1  File Attribute Configuration Commands
1.1.1  display current-configuration
display current-configuration [ configuration [ configuration-type ] | interface [ interface-type ] [ interface-number ] ] [ by-linenum ] [ | { begin | exclude | include } regular-expression ]
View
configuration configuration-type: Specifies to display non-interface configuration. If configuration-type is not specified, all the non-interface configurations are displayed; if configuration-type is specified, the specified type of configuration is displayed. The configuration type you can specify is based on your current configuration. For example:
l           acl-adv: Indicates the advanced Access Control List (ACL) configuration.
l           acl-basic: Indicates the basic ACL configuration.
l           hwping: Indicates the HWPing configuration.
l           isp: Indicates the internet service provider configuration.
l           radius-template: Indicates the radius template configuration.
l           system: Indicates the system configuration.
l           user-interface: Indicates the user interface configuration.
interface: Displays port/interface configuration.
interface-type: Port/interface type, which can be one of the following: Aux, Ethernet, GigabitEthernet, Loopback, NULL and VLAN-interface.
interface-number: Port/interface number.
by-linenum: Displays configuration information with line numbers.
|: Uses a regular expression to filter the configuration of the switch to be displayed. By specifying a regular expression, you can locate and query the needed information quickly.
regular-expression: A regular expression, case sensitive. It supports the following match rules:
l           begin: Displays the line that matches the regular expression and all the subsequent lines.
l           exclude: Displays the lines that do not match the regular expression.
l           include: Displays only the lines that match the regular expression.
A regular expression also supports some special characters. For match rules of the special characters, refer to Table 1-1 for details.
Table 1-1 Special characters in regular expression
Character
Meaning
Remarks
Starting sign, the string to the right of this character appears only at the beginning of a line.
For example, regular expression ^user matches lines beginning with user, not Auser.
Ending sign, the string to the left of this character appears only at the end of a line.
For example, regular expression user$ matches lines ending with user, not userA.
Full stop, a wildcard used in place of any character, including blank
None
Asterisk, the character to the left of the asterisk should match zero or more consecutive times.
For example, zo* can match z and zoo, and so on, but not zo.
Plus sign, the character to the left of the plus sign should match one or more consecutive times.
For example, zo+ can match zo and zoo, and so on, but not z.
Hyphen. It connects two values (the smaller one before it and the bigger one after it) to indicate a range together with [ ].
For example, 1-9 means numbers from 1 to 9 (inclusive); a-h means from a to h (inclusive).
Square brackets. Specifies a range of characters, and matches any character in the specified range.
For example, [1-36A] can match  a string containing any character among 1, 2, 3, 6, and A.
Parenthesis. Specifies a character group. It is usually used with + or *.
For example, (123A) means a character group 123A; 408(12)+ can match 40812 or 408121212. But it cannot match 408. That is, 12 can appear continuously and it must at least appear once.
Use the display current-configuration command to display the current configuration of a switch.
After you finish a set of configurations, you can execute the display current-configuration command to display the parameters that take effect currently.
Note that:
l           Parameters that are the same as the default are not displayed.
l           The configured parameter whose corresponding function does not take effect is not displayed.
Related commands: save, reset saved-configuration, display saved-configuration.
# Display configuration information about all the interfaces on the current switch.
<Sysname> display current-configuration interface
interface Vlan-interface1
 ip address 192.168.0.241 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1
 port link-aggregation group 1
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
interface Ethernet1/0/9
interface Ethernet1/0/10
interface Ethernet1/0/11
interface Ethernet1/0/12
interface Ethernet1/0/13
interface Ethernet1/0/14
interface Ethernet1/0/15
interface Ethernet1/0/16
interface Ethernet1/0/17
interface Ethernet1/0/18
interface Ethernet1/0/19
interface Ethernet1/0/20
interface Ethernet1/0/21
interface Ethernet1/0/22
interface Ethernet1/0/23
interface Ethernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
 shutdown
interface GigabitEthernet1/2/1
interface GigabitEthernet1/2/2
 shutdown
interface NULL0
interface LoopBack0
return
# Display the lines that include the strings matching 10* in the configuration information. (The character * means that the character 0 in the string before it can appear multiple times or does not appear.)
<Sysname> display current-configuration | include 10*
vlan 1
interface Aux1/0/0
# Display the configuration information starting with the string user.
<Sysname> display current-configuration | include ^user
user-interface aux 0
user-interface vty 0 4
1.1.2  display current-configuration vlan
display current-configuration vlan [ vlan-id ] [ by-linenum ]
View
vlan vlan-id: VLAN ID, in the range 1 to 4094.
Use the display current-configuration vlan command to display the current VLAN configuration of the switch.
Without the vlan-id argument specified, this command displays configuration information about all the VLANs that exist on the switch.
If there are contiguous VLANs without any configuration, the system combines these VLANs together in the format of vlan-id to vlan-id when displaying the VLAN configuration information.
# Display the VLAN configuration information of the current switch.
<Sysname> display current-configuration vlan
vlan 1
vlan 5 to 69
vlan 70
 description Vlan 70
vlan 71 to 100
return
1.1.3  display saved-configuration
display saved-configuration [ unit unit-id ] [ by-linenum ]
View
unit unit-id: Specifies the unit ID of a switch. It only can be 1.
Use the display saved-configuration command to display the initial configuration file of a switch.
Note that:
l           If the switch starts up without a configuration file, the system will display that no configuration file exists upon execution of the command.
l           If you have saved configuration after the switch starts up, the command displays the last saved configuration.
Related commands: save, reset saved-configuration, display current-configuration.
# Display the initial configuration file of the current switch.
<Sysname> display saved-configuration
 sysname Sysname
radius scheme system
domain system
vlan 1
#LOCCFG. MUST NOT DELETE
interface Aux1/0/0
 shutdown
 shutdown
#TOPOLOGYCFG. MUST NOT DELETE
#GLBCFG. MUST NOT DELETE
interface NULL0
 authentication-mode none
 user privilege level 3
return
The configuration information output above in turn is the system configuration, logical interface configuration, physical port configuration, and user interface configuration.
1.1.4  display startup
display startup [ unit unit-id ]
View
Use the display startup command to display the startup configuration of a switch.
Related commands: startup saved-configuration.
# Display the startup configuration file information of the current switch.
<Sysname> display startup
UNIT1:
  Current Startup saved-configuration file:          flash:/config.cfg
  Next main startup saved-configuration file:        flash:/config.cfg
  Next backup startup saved-configuration file:      flash:/backup.cfg
  Bootrom-access enable state:                       enabled
Table 1-2 Description on the fields of the display startup command
The configuration file used for the current startup
The main configuration file used for the next startup
The backup configuration file used for the next startup
Whether you can use the user-defined password to access the Boot ROM:
l      enabled indicates you can access the Boot ROM with the user-defined password.
l      disabled indicates you cannot access the Boot ROM with the user-defined password.
For related information, refer to the startup bootrom-access enable command in the File System Management part of the manual.
1.1.5  display this
display this [ by-linenum ]
View
Use the display this command to display the current configuration performed in the current view. To verify the configuration performed in a view, you can use this command to display the parameters that are valid in the current view.
Note that:
l           Effective parameters that are the same as the default are not displayed.
l           Execution of this command in any user interface view or VLAN view displays the valid configuration parameters in all user interfaces or VLANs.
Related commands: save, reset saved-configuration, display saved-configuration, display current-configuration.
# Display the configuration parameters that take effect in all user interface views.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] display this
return
1.1.6  reset saved-configuration
View
backup: Erases the backup configuration file.
main: Erases the main configuration file.
Use the reset saved-configuration command to erase the configuration file saved in the Flash of a switch.
The following two situations exist:
l           While the reset saved-configuration [ main ] command erases the configuration file with main attribute, it only erases the main attribute of a configuration file having both main and backup attribute.
l           While the reset saved-configuration backup command erases the configuration file with backup attribute, it only erases the backup attribute of a configuration file having both main and backup attribute.
You may need to erase the configuration file for one of these reasons:
l           After you upgrade software, the old configuration file does not match the new software.
l           The startup configuration file is corrupted or not the one you need.
  Caution:
l      This command will permanently delete the configuration file from the switch.
l      An error occurs when you execute this command if the configuration file to be deleted does not exist.
Related commands: save.
# Erase the main configuration file to be used in the next startup.
<Sysname> reset saved-configuration main
The saved configuration will be erased.
Are you sure?[Y/N]y
Configuration in flash memory is being cleared.
Please wait ...
 Unit1 reset saved-configuration successfully.
1.1.7  save
save [ cfgfile | [ safely ] [ backup | main ] ]
View
cfgfile: Path name or file name of a configuration file in the Flash, a string of 5 to 56 characters.
safely: Saves the current configuration in the safe mode.
backup: Saves the configuration to the backup configuration file.
main: Saves the configuration to the main configuration file.
Use the save command to save the current configuration to a configuration file in the Flash.
When you use this command to save the configuration file,
l           If the main and backup keywords are not specified, the current configuration will be saved to the main configuration file.
l           If the cfgfile argument is specified, but the file specified by it does not exist, the system will create the file and then save the current configuration to it. The file attribute is neither main nor backup.
l           If the cfgfile argument is specified and the file specified by it exists, the system will save the current configuration to the specified file. The file attribute is the original attribute of the file.
l           If the cfgfile argument is not specified, the system will save the current configuration to the configuration file used for this startup. If the switch starts up without loading the configuration file, the system will save the current configuration with the default name (config.cfg) in the root directory.
The system supports two modes for saving the current configuration file.
l           Fast saving mode. This is the mode when you use the save command without the safely keyword. The mode saves the file quicker but is likely to lose the original configuration file if the switch reboots or the power fails during the process.
l           Safe mode. This is the mode when you use the save command with the safely keyword. The mode saves the file slower but can retain the original configuration file in the Flash even if the switch reboots or the power fails during the process.
  Caution:
S3100 series Ethernet switches do not support the safe mode. When you are saving a configuration file using the save safely command, if the device reboots or the power fails during the saving process, the configuration file will be lost.
&  Note:
The extension name of the configuration file must be .cfg.
# Save the current configuration to 123.cfg as the main configuration file for the next startup.
<Sysname> save main
The configuration will be written to the device.
Are you sure?[Y/N]y
Please input the file name(*.cfg)(To leave the existing filename
 unchanged press the enter key):123.cfg
Now saving current configuration to the device.
Saving configuration. Please wait...
 Unit1 save configuration flash:/123.cfg successfully
1.1.8  startup saved-configuration
undo startup saved-configuration [ unit unit-id ]
View
backup: Specifies the configuration file to be the backup configuration file.
main: Specifies the configuration file to be the main configuration file.
unit unit-id: Specifies a switch by its unit ID. It only can be 1.
Use the startup saved-configuration command to specify a configuration file to be the main configuration file or the backup configuration file to be used for the next startup of the switch.
Use the undo startup saved-configuration command to specify a switch to use null configuration when it restarts.
Note that: If you execute the startup saved-configuration command with neither the backup nor the main keyword specified, the configuration file identified by the cfgfile argument is specified as the main configuration file to be used for the next startup of the switch.
  Caution:
The configuration file must use .cfg as its extension name and the startup configuration file must be saved at the root directory in the Flash of the switch.
Related commands: display startup.
# Configure the configuration file named config.cfg as the main configuration file to be used for the next startup of the current switch.
<Sysname> startup saved-configuration config.cfg main
 Please wait......Done!
