H3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
00-1Cover
00-1Cover 78.22 KB
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20080928-C-1.02
Copyright © 2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
customer_service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3100 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3100 Series Ethernet Switches  Installation Manual (For Soliton)
It is used for assisting the users in switch installation, booting up, hardware and software maintenance.
H3C S3100 Series Ethernet Switches  Operation Manual (For Soliton)
It is used for assisting the users in data configurations and typical applications.
H3C S3100 Series Ethernet Switches  Quick Start (For Soliton)
It provides information for the system installation.
Organization
H3C S3100 Series Ethernet Switches Command Manual (For Soliton) is organized as follows:
Part
1 CLI
Introduces the commands used for switching between the command levels and command level setting.
2 Login
Introduces the commands used for logging into the Ethernet switch.
3 Configuration File Management
Introduces the commands used for configuration file management.
4 VLAN
Introduces the commands used for configuring VLAN.
5 Management VLAN
Introduces the commands used for configuring the management VLAN.
6 IP Address-IP Performance
Introduces the commands used for IP address configuration and IP performance configuration.
7 Voice VLAN
Introduces the commands used for voice VLAN configuration.
8 GVRP
Introduces the commands used for GVRP configuration.
9 Port Basic Configuration
Introduces the commands used for basic port configuration.
10 Link Aggregation
Introduces the commands used for link aggregation.
11 Port Isolation
Introduces the commands used for port isolation.
12 Port Security-Port Binding
Introduces the commands used for port security configuration and port binding.
13 DLDP
Introduces the commands used for DLDP configuration.
14 MAC Address Table Management
Introduces the commands used for MAC address forwarding table management.
15 MSTP
Introduces the STP-related commands.
16 Multicast
Introduces the commands used for multicast configuration.
17 802.1x-System Guard
Introduces the commands used for 802.1x-System Guard configuration.
18 AAA
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration.
19 MAC Address Authentication
Introduces the commands used for MAC address authentication configuration.
20 ARP
Introduces the ARP-related commands.
21 DHCP
Introduces the commands used for DHCP, DHCP-snooping configuration.
22 ACL
Introduces the ACL-related commands.
23 QoS-QoS Profile
Introduces the commands used for QoS and QoS profile configuration.
24 Mirroring
Introduces the commands used for port mirroring.
25 Stack-Cluster
Introduces the commands used for cluster management.
26 SNMP-RMON
Introduces the commands used for SNMP and RMON configuration.
27 NTP
Introduces the NTP-related commands.
28 SSH
Introduces the commands used for SSH configuration.
29 File System Management
Introduces the commands used for file system management.
30 FTP-SFTP-TFTP
Introduces the FTP-/SFTP-/TFTP-related commands.
31 Information Center
Introduces the commands used for information center configuration.
32 System Maintenance and Debugging
Introduces the commands used for system maintenance and debugging.
33 VLAN-VPN
Introduces the commands used for VLAN VPN configuration.
34 HWPing
Introduces the commands used for HWPing configuration.
35 IPv6 Management
Introduces the commands used for IPv6 Management configuration.
36 DNS
Introduces the commands used for DNS configuration.
37 Smart Link-Monitor Link
Introduces the commands used for Smart Link, Monitor Link configuration
38 Appendix
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
