H3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
05-Management VLAN Commands
05-Management VLAN Commands 84.62 KB
Chapter 1  Management VLAN Configuration Commands
1.1  Management VLAN Configuration Commands
1.1.1  delete static-routes all
View
Parameter
None
Use the delete static-routes all command to delete all static routes.
The system will request your confirmation before it deletes all the configured static routes.
Related command: ip route-static and display ip routing-table.
Example
# Delete all the static routes in the router.
[Sysname] delete static-routes all
Are you sure to delete all the unicast static routes?[Y/N]y
1.1.2  display interface Vlan-interface
display interface Vlan-interface [ vlan-id ]
View
Parameter
vlan-id: ID of the management VLAN interface the information about which is to be displayed.
Use the display interface Vlan-interface command to display the information about the management VLAN interface.
Related command: interface Vlan-interface.
Example
# Display the information about the management VLAN interface. (Assume that VLAN 1 is the management VLAN.)
<Sysname> display interface Vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e256-ae10
Internet Address is 192.168.0.39/24 Primary
Description : Vlan-interface1 Interface
The Maximum Transmit Unit is 1500
Table 1-1 Description on the fields of the display interface Vlan-interface command
Vlan-interface current state
Current state of Vlan-interface1
Current state of the link layer protocol
Format of the sent IP packets
Hardware address
MAC address corresponding to the management VLAN interface
Internet Address Primary
Primary IP address
Description string assigned to the VLAN interface
The maximum transmit unit (MTU)
1.1.3  display ip interface
display ip interface [ Vlan-interface vlan-id ]
View
Parameter
vlan-id: ID of the management VLAN interface.
Use the display ip interface command to display the information about a specified VLAN interface.
Example
# Display the information about VLAN-interface 1.
<Sysname> display ip interface Vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
IP packets input number: 7420, bytes: 557679, multicasts: 1
IP packets output number: 7509, bytes: 385809, multicasts: 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
Table 1-2 Description on the fields of the display ip interface command
Internet Address
IP address
Broadcast address
Broadcast address
IP packets input number: 11790, bytes: 550920, multicasts: 3049
IP packets output number: 8374, bytes: 404537, multicasts: 0
Number of received/sent packets (total), bytes, and multicast packets.
Number of received packets with TTL errors
Number of received ICMP messages
Echo reply
Echo replies
Unreachable
Unreachable messages
Source quench
Source quench messages
Routing redirect
Routing redirect messages
Echo request
Echo requests
Router advert
Router advertisements
Router solicit
Router solicit messages
Time exceed
Time exceed messages
IP header bad
IP header bad messages
Timestamp request
Timestamp requests
Timestamp reply
Timestamp replies
Information request
Information requests
Information reply
Information replies
Netmask request
Netmask requests
Netmask reply
Netmask replies
Unknown type
Messages with unknown type
1.1.4  display ip interface brief
display ip interface brief [ Vlan-interface [ vlan-id ] ]
View
Parameter
Use the display ip interface brief command to display brief information about a specified VLAN interface.
Example
# Display brief information about VLAN-interface1.
<Sysname> display ip interface brief vlan-interface 1
*down: administratively down
(l): loopback
(s): spoofing
 Interface               IP Address     Physical Protocol     Description
 Vlan-interface1         192.168.0.39    up       up           Vlan-inte...
Table 1-3 Description on fields of the display ip interface brief command
*down
The interface is administratively shut down with the shutdown command.
(s)
Spoofing attribute of the interface. It indicates that the interface whose link layer protocol is displayed up may have no such a link present or the link is set up only on demand.
Interface name
IP Address
IP address of the interface (If no IP address is configured, “unassigned” is displayed.)
Physical
Physical state of the interface
Protocol
Link layer protocol state of the interface
Description information for the interface
1.1.5  display ip routing-table
display ip routing-table [ | { begin | exclude | include } regular-expression ]
View
Parameter
regular-expression: Regular expression, which specifies a match character string.
|: Uses the regular expression to match the output routing information.
begin: Displays the routing information from the route entry containing the specified character string.
include: Displays all routing information containing the specified character string.
exclude: Displays all routing information without the specified character string.
Use the display ip routing-table command to display the summary information about the routing table.
This command displays the summary information about a routing table, with the items of a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, preference, cost, next hop and outbound interface.
The display ip routing-table command only displays the routes currently in use, that is, the optimal routes.
Example
# Display the summary information about the routing table.
<Sysname> display ip routing-table
 Routing Table: public net
Destination/Mask   Protocol Pre  Cost        Nexthop         Interface
127.0.0.0/8        DIRECT   0    0           127.0.0.1       InLoopBack0
127.0.0.1/32       DIRECT   0    0           127.0.0.1       InLoopBack0
Table 1-4 Description on the fields of the display ip routing-table command
Destination/Mask
Destination IP address/mask length
Protocol
Routing protocol that discovers the route
Pre
Route preference
Cost
Route cost
Nexthop
Next hop IP address of the route
Outbound interface, through which packets destined for the destination network segment are to be transmitted
1.1.6  display ip routing-table acl
display ip routing-table acl acl-number [ verbose ]
View
Parameter
acl-number: Number of a basic access control list (ACL), in the range of 2000 to 2999.
verbose: Displays the detailed information about the active and inactive routes that match the specified ACL. If you do not specify this keyword, only the summary information about the active routes matching the specified ACL is displayed.
Use the display ip routing-table acl command to display the routes that match a specified basic ACL.
As this command displays the routes that match a specified basic ACL, you can use it to trace routing policies.
Example
# Display the summary information about the active routes that match ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.1.1 0.0.0.255
[Sysname-acl-basic-2000] rule deny source any
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes matched by access-list 2000:
  Summary count: 1
10.1.1.0/24         STATIC   60   0            192.168.0.31    Vlan-interface1
Refer to Table 1-4 for the description on the output fields.
# Display the detailed information about the active and inactive routes that match ACL 2000.
[Sysname] display ip routing-table acl 2000 verbose
  + = Active Route, - = Last Active, # = Both    * = Next hop in use
  Summary count: 1
**Destination: 10.1.1.0          Mask: 255.255.255.0
         Protocol: #STATIC       Preference: 60
         *NextHop: 192.168.0.31     Interface: 192.168.0.51(Vlan-interface1)
         State: <Int ActiveU Gateway Static Unicast>
         Age: 1:48:18            Cost: 0/0
Table 1-5 Description on the fields of the display ip routing-table acl command
Destination
Destination address
Mask
Mask
Protocol
Preference
Route preference
NextHop
Next hop IP address
Descriptions on the route state are as follows:
ActiveU
Valid unicast route. “U” stands for unicast.
Blackhole
Blackhole route is the same as reject route except that a router drops a packet traveling along a blackhole route without sending ICMP unreachable messages to the source of the packets.
Delete
The route is deleted.
Gateway
The route is not a direct route.
Hidden
The route is a hidden route. The system hides routes that are temporarily unavailable for some reasons (such as the policy configured or the interface is down) for later use.
Holddown
The route is held down. Holddown is a kind of route advertisement policy used in some D-V (distance vector) routing protocols (such as RIP) to avoid the propagation of some incorrect routes and improve the transmission speed of route-unreachable information. For details, refer to corresponding routing protocols.
Int
The route is discovered by the internal gateway protocol (IGP).
NoAdvise
The route is not advertised when the router advertises routes based on policies
NotInstall
The route are not loaded to the core routing table but can be advertised. Normally, the routes with the highest preference in the routing table are loaded to the core routing table and are advertised.
Reject
The packets travel along the route will be dropped. Besides, the router sends ICMP unreachable messages to the source of the dropped packets. The Reject routes are usually used for network testing.
Retain
The route is not deleted when the routes in the core routing table are deleted. You can enable static routes to remain in the core routing table by configure them to be in retain state.
Static
Static routes configured manually on the router are marked as static. Such routes are not lost when you perform the save operation and then restart the router.
Unicast
The route is a unicast route.
Age
Time period during which the route is allowed to be in the routing table, in the form of hh:mm:ss.
Cost
Cost of the route
1.1.7  display ip routing-table ip-address
display ip routing-table ip-address [ mask ] [ longer-match ] [ verbose ]
View
Parameter
ip-address: Destination IP address, in dotted decimal notation.
mask: Mask of the destination IP address, which can be in dotted decimal notation or be an integer ranging from 0 to 32.
longer-match: Displays all the routes leading to the destination coupled with the default mask.
verbose: Displays the detailed information about the active and inactive routes leading to the destination. If this keyword is not specified, only the summary information about the active routes is displayed.
Use the display ip routing-table ip-address command to display the information about the routes leading to a specified destination.
The output information of this command differs with the arguments/keywords specified as follows:
l           display ip routing-table ip-address
For the destination address ip-address, if there are some routes matched within the natural mask range, the active routes which best match ip-address are displayed.
l           display ip routing-table ip-address mask
Only the routes which match exactly the specified destination address and mask are displayed.
l           display ip routing-table ip-address longer-match
All routes with their destination addresses matched within the natural mask range are displayed.
l           display ip routing-table ip-address mask longer-match
All routes with their destination addresses matched within the specified mask range are displayed.
Example
# Display the summary information of the routes with their destination addresses matched within the natural mask range.
<Sysname> display ip routing-table 10.1.1.0
# Display the detailed information of the routes with their destination addresses matched within the natural mask range.
<Sysname> display ip routing-table 10.1.1.0 verbose
Routing tables:
  Summary count: 1
         *NextHop: 192.168.0.31     Interface: 192.168.0.246(Vlan-interface1)
         Age: 32:31              Cost: 0/0
Refer to Table 1-5 for the description on the output fields.
1.1.8  display ip routing-table ip-address1 ip-address2
display ip routing-table ip-address1 mask1 ip-address2 mask2 [ verbose ]
View
Parameter
ip-address1, ip-address2: Destination IP addresses in dotted decimal notation. ip-address1 and mask1, together with ip-address2 and mask2, determine an IP address range. The starting address of the IP address range is determined by the ip-address1 and mask1 arguments; and the end address of the IP address range is determined by the ip-address2 and mask2 arguments.
mask1, mask2: IP address masks. These two arguments can be in dotted decimal notation or two integers ranging from 0 to 32.
verbose: Displays the detailed information about the active and inactive routes. If you do not specify this keyword, only the summary information about the active routes is displayed.
Use the display ip routing-table ip-address1 ip-address2 command to display the information about the routes with their destinations within the specified destination IP address range.
Example
# Display the information about the routes with their destinations within the range of 1.1.1.0 to 2.2.2.0.
<Sysname> display ip routing-table 1.1.1.0 24 2.2.2.0 24
Routing tables:
  Summary count: 1
1.1.1.0/24         DIRECT      0  0          1.1.1.1      Vlan-interface1
1.1.9  display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
Parameter
protocol: This argument can be one of the following:
l           direct: Displays the information about the direct routes.
l           static: Displays the information about the static routes.
inactive: Displays the information about the inactive routes. If you do not specify this keyword, the information about both active and inactive routes is displayed.
verbose: Displays the detailed route information. If you do not specify this keyword, only the summary route information is displayed.
Use the display ip routing-table protocol command to display the information about specified type of routes.
Example
# Display the summary information about all the direct routes.
<Sysname> display ip routing-table protocol direct
DIRECT Routing tables:
  Summary count: 4
DIRECT Routing table status:<active>:
  Summary count: 4
192.168.0.0/24     DIRECT   0    0         192.168.0.246 Vlan-interface1
192.168.0.246/32   DIRECT   0    0         127.0.0.1     InLoopBack0
DIRECT Routing table status:<inactive>:
  Summary count: 0
# Display the summary information about the static routing table.
<Sysname> display ip routing-table protocol static
STATIC Routing tables:
  Summary count: 1
STATIC Routing table status:<active>:
  Summary count: 1
STATIC Routing table status:<inactive>:
  Summary count: 0
1.1.10  display ip routing-table radix
View
Parameter
None
Use the display ip routing-table radix command to display the information about the routes in a routing table in a hierarchical way.
Example
# Display the information about the routes in a routing table in a hierarchical way.
<Sysname> display ip routing-table radix
Radix tree for INET (2) inodes 2 routes 2:
                   +--8+--{127.0.0.0
                      +-32+--{127.0.0.1
Table 1-6 Description on the fields of the display ip routing-table radix command
INET
Address family
inodes
Number of nodes
routes
Number of routes
1.1.11  display ip routing-table statistics
View
Parameter
None
Use the display ip routing-table statistics command to display the statistics of a routing table.
The statistics information displayed by this command includes:
l           The total number of the routes
l           The number of the active routes
l           The number of the added routes
l           The number of the routes with deleted flags
Example
# Display the statistics information about the routing table.
<Sysname> display ip routing-table statistics
Routing tables:
Proto      route       active      added       deleted
DIRECT     2            2          2           0
STATIC     0            0          0           0
Total      2            2          2           0
Table 1-7 Description on the fields of the display ip routing-table statistics command
Proto
Routing protocol
route
Total number of routes
active
Number of the active routes that are currently in use
added
Number of the routes that are added to the routing table after the switch starts or the routing table is cleared last time
deleted
Number of the routes with deleted flags (this type of routes will be removed after a period of time)
Total
Total numbers of various routes
1.1.12  display ip routing-table verbose
View
Parameter
None
Use the display ip routing-table verbose command to display the detailed information about a routing table.
You can use this command to display all the routes, including the inactive and invalid routes.
Example
# Display the detailed information about the routing table.
<Sysname> display ip routing-table verbose
Routing Tables:
  Destinations: 2       Routes: 2
  Holddown: 0   Delete: 0       Hidden: 0
**Destination: 127.0.0.0        Mask: 255.0.0.0
        Protocol: #DIRECT       Preference: 0
        *NextHop: 127.0.0.1        Interface: 127.0.0.1(InLoopBack0)
        State: <NoAdvise Int ActiveU Retain Unicast>
        Age: 57:12      Cost: 0/0
**Destination: 127.0.0.1        Mask: 255.255.255.255
        State: <NotInstall NoAdvise Int ActiveU Retain Gateway Unicast>
The statistics of the routing table are displayed first, and then the detailed descriptions of each route. Table 1-5 describes the route states and Table 1-8 describes the statistics information about the routing table.
Table 1-8 Description on the fields of the display ip routing-table verbose command
Holddown
Number of the routes that are held down
Delete
Number of the deleted routes
Hidden
Number of the hidden routes
1.1.13  interface Vlan-interface
interface Vlan-interface vlan-id
undo interface Vlan-interface vlan-id
View
Parameter
vlan-id: ID of the management VLAN, in the range of 1 to 4094.
Use the interface Vlan-interface command to create a management VLAN interface and enter management VLAN interface view.
Use the undo interface Vlan-interface command to remove the management VLAN interface.
Before creating a management VLAN interface, make sure the VLAN identified by the vlan-id argument is created and is configured as the management VLAN.
Note that:
To create the VLAN interface for the management VLAN on a switch operating as the management device in a cluster, make sure the ID of the management VLAN is consistent with that of the cluster management VLAN, that is, the vlan-id argument in the management-vlan vlan-id command when you configure the cluster management VLAN. Otherwise, the configuration fails.
Example
# Create VLAN 10 and configure it as the management VLAN. Create VLAN 10 interface and enter VLAN 10 interface view.
[Sysname] vlan 10
[Sysname-vlan10] quit
[Sysname] management-vlan 10
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10]
1.1.14  ip address
ip address ip-address mask
undo ip address [ ip-address mask ]
View
VLAN interface view
Parameter
ip-address: IP address to be assigned to the management VLAN interface.
mask: Mask of the IP address to be assigned to the management VLAN interface. The mask can be in dotted decimal notation or an integer in the range of 0 to 32.
Use the ip address command to assign an IP address with the mask to a management VLAN interface.
Use the undo ip address command to remove the IP address assigned to a management VLAN interface.
Related command: display interface Vlan-interface.
Example
# Assign the IP address 192.168.0.51 (with the mask 255.255.255.0) to the management VLAN interface. (Assume that VLAN 1 is the management VLAN.)
[Sysname-Vlan-interface1] ip address 192.168.0.51 255.255.255.0
1.1.15  ip route-static
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] [ description text ]
undo ip route-static ip-address { mask | mask-length } [ interface-type interface-number | next-hop ] [ preference preference-value ]
View
Parameter
mask: IP address mask, in dotted decimal notation.
mask-length: Mask length, in the range of 0 to 32.
interface-type interface-number: Next hop outgoing interface. Currently, you can specify a NULL interface only. A null interface is a virtual interface. Packets destined for a null interface are discarded, helping to reduce system load.
next-hop: IP address of the next hop of this route, in dotted decimal notation.
preference-value: Preference of this route, in the range of 1 to 255.
reject: Specifies the route as an unreachable route. When a static route destined for a destination address is of the reject attribute, all the IP packets destined for the destination address are discarded, and the source host is informed that the destination address is unreachable.
blackhole: Specifies the route as a black hole route. When a static route destined for a destination address is of the blackhole attribute, the outgoing interface of the route is Null 0 regardless of the next hop address. All the IP packets destined for the destination address are discarded, and the source host is not informed that the destination address is unreachable.
description text: Specifies a descriptive string for the static route. The text argument is a case-sensitive string of 1 to 60 characters (including the space).
Use the ip route-static command to configure a static route.
Use the undo ip route-static command to remove a static route.
By default, the system can obtain the subnet route directly connected to the router. When you configure a static route, if no preference is specified for the route, the preference defaults to 60. Note that routes with the same destinations, the same next hops, but different preferences are different routes. Among these routes, the one with least preference (which means the highest preference) is chosen to be the current route. A route configured using the ip route-static command is a reachable route if neither of the reject and blackhole keywords is specified.
Note the following when configuring a static route:
l           The next hop address of a static route cannot be the VLAN interface address of the local switch.
l           A static route with both its destination IP address and mask both being 0.0.0.0 is the default route. When no matched entry is found in the routing table, a received packet is forwarded according to the default route.
Related command: display ip routing-table.
Example
# Configure the next hop of the default route as 129.102.0.2.
[Sysname] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
1.1.16  management-vlan
undo management-vlan
View
Parameter
Use the management-vlan command to configure a VLAN as the management VLAN.
Use the undo management vlan command to restore the default.
VLAN 1 is the default management VLAN.
Example
# Configure VLAN 2 as the management VLAN.
[Sysname] management-vlan 2
1.1.17  reset ip routing-table statistics protocol
reset ip routing-table statistics protocol { all | protocol }
View
Parameter
all: Specifies all protocols.
protocol: Specifies a protocol, which can be static, or direct.
Use the reset ip routing-table statistics protocol command to clear the statistics of routes in a routing table.
Example
# Before executing the reset ip routing-table statistics protocol command, use the display ip routing-table statistics command to display the routing statistics:
Routing tables:
DIRECT     4           4           24          20
STATIC     0           0           1           1
Total      4           4           25          21
# Clear the routing statistics of all protocols from the IP routing table.
<Sysname> reset ip routing-table statistics protocol all
This will erase the specific routing counters information.
Are you sure?[Y/N]y
# Display the routing statistics in the IP routing table.
Routing tables:
DIRECT     4           4           0           0
STATIC     0           0           0           0
Total      4           4           0           0
The above information shows that the routing statistics in the IP routing table is cleared.
