H3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual (For Soliton)(V1.02)
13-DLDP Commands
13-DLDP Commands 45.42 KB
Chapter 1  DLDP Configuration Commands
1.1  DLDP Configuration Commands
1.1.1  display dldp
display dldp { unit-id | interface-type interface-number }
View
Parameter
unit-id: Unit number of a device.
interface-type: Port type.
interface-number: Port number.
Use the display dldp command to display the DLDP configuration of a unit or a port.
Example
# Display the DLDP configuration of unit 1.
<Sysname> display dldp 1
 dldp interval 10
 dldp work-mode enhance
 dldp authentication-mode md5, cipher is ;)<01%^&;YGQ=^Q`MAF4<1!!
 dldp unidirectional-shutdown manual
 dldp delaydown-timer 1
 The port number of unit 1 with DLDP is 1.
interface GigabitEthernet1/1/1
 dldp port state : advertisement
 dldp link state : up
 The neighbor number of the port is 1.
         neighbor mac address : 00e0-fc00-5690
         neighbor port index : 372
         neighbor state : two way
         neighbor aged time : 12
Table 1-1 Description on the fields of the display dldp command
dldp interval
Interval for sending DLDP advertisement packets
dldp work-mode
DLDP work mode
DLDP authentication mode
cipher
DLDP authentication password
DLDP action to be performed on detecting a unidirectional link
Setting of the DelayDown timer
Number of the DLDP-enabled ports on unit 1
Port type and port number
dldp port state
DLDP state of a port
dldp link state
DLDP link state
Number of the neighbor ports
MAC address of a neighbor port
neighbor port index
Neighbor port index
neighbor state
Neighbor state, which can be two way or unknown.
neighbor aged time
Neighbor aging time
1.1.2  dldp
dldp { enable | disable }
View
System view, Ethernet port view
Parameter
None
In system view,
Use the dldp enable command to enable DLDP for all the optical ports.
Use the dldp disable command to disable DLDP for all the optical ports.
In Ethernet port view,
Use the dldp enable command to enable DLDP for the current port.
Use the dldp disable command to disable DLDP for the current port.
This command applies to non-optical ports as well as optical ports.
By default, DLDP is disabled.
  Caution:
When you use the dldp enable/dldp disable command in system view to enable/disable DLDP on all optical ports of the switch, the configuration takes effect on the existing optical ports, instead of those added subsequently.
Example
# Enable DLDP for all the optical ports of the switch.
[Sysname] dldp enable
1.1.3  dldp authentication-mode
dldp authentication-mode { none | simple simple-password | md5 md5-password }
undo dldp authentication-mode
View
Parameter
none: Sets the authentication mode to none (Performs no authentication).
simple: Sets the authentication mode to plain text.
simple-password: Authentication password in plain text, a string of 1 to 16 characters.
md5: Sets the authentication mode to MD5.
md5-password: MD5 authentication password, a string in plain text consisting of 1 to 16 characters or a string in cipher text corresponding to the string in plain text.
Use the dldp authentication-mode command to set the DLDP authentication mode and password.
Use the undo dldp authentication-mode to remove the DLDP authentication mode and password.
By default, the authentication mode is none.
&  Note:
l      When you configure a DLDP authentication mode and authentication password on a port, make sure that the same DLDP authentication mode and password are set on both the local port and the peer port. Otherwise, DLDP authentication fails.
l      DLDP cannot work before DLDP authentication succeeds.
Related command: dldp unidirectional-shutdown.
Example
# Set the DLDP authentication mode and password to plain text and “abc” on the ports connected with a fiber cable or copper twisted pair between A and  B.
l           Configure A
<A> system-view
[A] dldp authentication-mode simple abc
l           Configure B
<B> system-view
[B] dldp authentication-mode simple abc
1.1.4  dldp interval
dldp interval timer-value
undo dldp interval
View
Parameter
timer-value: Interval for sending DLDP advertisement packets, in the range 1 to 100 (in seconds).
Use the dldp interval command to set the interval for sending DLDP advertisement packets for all DLDP-enabled ports in the advertisement state.
Use the undo dldp interval command to restore the default.
By default, the interval for sending DLDP advertisement packets is 5 seconds.
Note that:
l           The interval takes effect on all the DLDP-enabled ports.
l           It is recommended that you set the interval shorter than one-third of the STP convergence time (usually 30 seconds). If too long an interval is set, an STP loop may occur before DLDP shuts down unidirectional links. On the contrary, if too short an interval is set, network traffic increases, unnecessarily consuming port bandwidth.
Example
# Set the interval for sending DLDP advertisement packets to 6 seconds.
[Sysname] dldp interval 6
1.1.5  dldp reset
dldp reset
View
Parameter
None
In system view:
Use the dldp reset command to reset the DLDP status of all the ports disabled by DLDP.
In Ethernet port view:
Use the dldp reset command to reset the DLDP status of the current port disabled by DLDP.
After the dldp reset command is executed, the DLDP status of a port changes from disable to active and DLDP restarts to detect the link status of the fiber cable or copper twisted pair.
Related command: dldp and dldp unidirectional-shutdown.
Example
# Reset the DLDP status of all the ports disabled by DLDP.
[Sysname] dldp reset
1.1.6  dldp unidirectional-shutdown
dldp unidirectional-shutdown { auto | manual }
undo dldp unidirectional-shutdown
View
Parameter
auto: Disables automatically the corresponding port when DLDP detects an unidirectional link or finds in the enhanced mode that the peer port is down.
manual: Prompts the user to disable manually the corresponding port when DLDP detects an unidirectional link or finds in the enhanced mode that the peer port is down. After the port is disabled, it can only send and receive Recover Probe packets and Recover Echo packets.
Use the dldp unidirectional-shutdown command to set the DLDP handling mode for unidirectional links.
Use the undo dldp unidirectional-shutdown command to restore the default DLDP handling mode.
By default, the DLDP handling mode after a unidirectional link is detected is auto.
Related command: dldp work-mode.
Example
# Configure DLDP to shut down the corresponding port on detecting a unidirectional link.
[Sysname] dldp unidirectional-shutdown auto
1.1.7  dldp work-mode
dldp work-mode { enhance | normal }
undo dldp work-mode
View
Parameter
enhance: Configures DLDP to work in enhanced mode. In this mode, DLDP detects whether neighbors exist when neighbor tables are aging.
normal: Configures DLDP to work in normal mode. In this mode, DLDP does not detect whether neighbors exist when neighbor tables are aging.
Use the dldp work-mode command to set the DLDP operating mode.
Use the undo dldp work-mode command to restore the default DLDP operating mode.
By default, DLDP works in normal mode.
&  Note:
l      When DLDP works in normal mode, the system can identify only the unidirectional links caused by fiber cross-connection.
l      When the DLDP protocol works in enhanced mode, the system can identify two types of unidirectional links: one is caused by fiber cross-connection and the other is caused by one fiber being not connected or being disconnected.
Example
# Configure DLDP to work in enhanced mode.
[Sysname] dldp work-mode enhance
1.1.8  dldp delaydown-timer
dldp delaydown-timer delaydown-time
undo dldp delaydown-timer
View
Parameter
delaydown-time: DelayDown timer to be set (in seconds). This argument ranges from 1 to 5.
Use the dldp delaydown-timer command to set the delaydown timer.
Use the undo dldp delaydown-timer command to restore the default delaydown timer setting.
By default, the DelayDown timer is set to 1 second. A period of 5 seconds is recommended.
&  Note
When a device in the active, advertisement, or probe DLDP state receives a port down message, it does not remove the corresponding neighbor immediately, nor does it transit to the inactive state. Instead, it transits to the delaydown state and starts the DelayDown timer. In delaydown state, the device retains the related DLDP neighbor information. When the DelayDown timer expires, the DLDP neighbor information is removed.
Example
# Set the delaydown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
