H3C S3100-52P Command Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Command Manual-Release 1602(V1.01)
39-Appendix
39-Appendix 382.97 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
18-AAA Command
1-1
accounting
18-AAA Command
1-2
accounting optional
18-AAA Command
1-3
accounting optional
18-AAA Command
1-32
accounting-on enable
18-AAA Command
1-33
acl
02-Login Command
2-1
acl
23-ACL Command
1-1
active region-configuration
14-MSTP Command
1-1
add-member
26-Stack-Cluster Command
2-14
administrator-address
2-15
am user-bind
11-Port Security-Port Binding Command
2-1
apply qos-profile
24-QoS-QoS Profile Command
2-1
arp check enable
21-ARP Command
1-1
arp detection enable
21-ARP Command
1-2
arp detection trust
21-ARP Command
1-3
arp protective-down recover enable
21-ARP Command
1-3
arp protective-down recover interval
21-ARP Command
1-4
arp rate-limit
21-ARP Command
1-5
arp rate-limit enable
21-ARP Command
1-6
21-ARP Command
1-6
arp static
21-ARP Command
1-7
arp timer aging
21-ARP Command
1-8
ascii
31-FTP-SFTP-TFTP Command
1-8
attribute
18-AAA Command
1-4
authentication
18-AAA Command
1-5
authentication super
18-AAA Command
1-7
authentication-mode
02-Login Command
1-1
authorization
18-AAA Command
1-8
authorization vlan
18-AAA Command
1-9
auto-build
2-16
auto-execute command
02-Login Command
1-3
B
binary
1-9
black-list
2-44
boot attribute-switch
30-File System Management Command
1-17
boot boot-loader
1-17
boot boot-loader
33-System Maintenance and Debugging Command
3-1
boot boot-loader backup-attribute
1-18
boot bootrom
3-1
boot web-package
1-18
bpdu-drop any
14-MSTP Command
1-2
bpdu-tunnel
34-VLAN-VPN Command
3-1
bpdu-tunnel tunnel-dmac
34-VLAN-VPN Command
3-3
broadcast-suppression
08-Port Basic Configuration Command
1-1
build
2-19
burst-mode enable
1-1
bye
1-9
bye
1-30
C
calling-station-id mode
18-AAA Command
1-34
cd
1-1
cd
1-10
cd
1-30
cdup
1-11
cdup
1-31
check region-configuration
14-MSTP Command
1-3
clock datetime
1-1
clock summer-time
1-2
clock timezone
1-3
close
1-11
cluster
2-21
cluster enable
2-21
cluster switch-to
2-22
cluster-mac
2-23
cluster-mac syn-interval
2-24
command-privilege level
01-CLI Command
1-1
copy
1-2
copy configuration
1-3
copyright-info enable
02-Login Command
1-4
count
35-HWPing Command
1-1
cut connection
18-AAA Command
1-9
D
databits
02-Login Command
1-5
data-flow-format
18-AAA Command
1-35
data-flow-format
18-AAA Command
1-66
datasize
35-HWPing Command
1-2
debugging
1-9
delete
1-3
delete
1-12
delete
1-32
delete static-routes all
15-Static Route Command
2-1
delete-member
2-25
description
04-VLAN Command
1-1
description
1-5
description
23-ACL Command
1-2
destination-ip
35-HWPing Command
1-3
destination-port
35-HWPing Command
1-3
dhcp protective-down recover enable
22-DHCP Command
2-1
dhcp protective-down recover interval
22-DHCP Command
2-1
dhcp rate-limit
22-DHCP Command
2-2
dhcp rate-limit enable
22-DHCP Command
2-3
dhcp-snooping
22-DHCP Command
1-1
dhcp-snooping information enable
22-DHCP Command
1-2
dhcp-snooping information format
22-DHCP Command
1-2
dhcp-snooping information packet-format
22-DHCP Command
1-3
dhcp-snooping information remote-id
22-DHCP Command
1-4
dhcp-snooping information strategy
22-DHCP Command
1-4
dhcp-snooping information vlan circuit-id
22-DHCP Command
1-6
dhcp-snooping information vlan remote-id
22-DHCP Command
1-7
dhcp-snooping trust
22-DHCP Command
1-8
dir
1-5
dir
1-12
dir
1-32
disconnect
1-14
display acl
23-ACL Command
1-3
display am user-bind
2-2
display arp
21-ARP Command
1-9
display arp |
21-ARP Command
1-10
display arp count
21-ARP Command
1-11
display arp detection statistics interface
21-ARP Command
1-12
display arp timer aging
21-ARP Command
1-13
display boot-loader
1-19
display boot-loader
3-2
display bootp client
22-DHCP Command
3-3
display bpdu-tunnel
34-VLAN-VPN Command
3-4
display brief interface
1-6
display channel
32-Information Center Command
1-1
display clock
1-6
display cluster
2-26
display cluster base-members
2-45
display cluster base-topology
2-46
display cluster black-list
2-47
display cluster candidates
2-28
display cluster current-topology
2-48
display cluster members
2-30
display connection
18-AAA Command
1-11
display cpu
3-3
display current-configuration
03-Configuration File Management Command
1-1
display current-configuration vlan
1-7
display debugging
1-7
display device
3-4
display dhcp client
22-DHCP Command
3-1
display dhcp-snooping
22-DHCP Command
1-9
display dhcp-snooping trust
22-DHCP Command
1-9
display diagnostic-information
1-10
display dldp
12-DLDP Command
1-1
display dns domain
37-DNS Command
1-1
display dns dynamic-host
37-DNS Command
1-1
display dns ipv6 dynamic-host
36-IPv6 Management Command
1-1
display dns server
37-DNS Command
1-2
display domain
18-AAA Command
1-12
display dot1x
17-802.1x and System Guard Command
1-1
display drv qacl_resource
23-ACL Command
1-4
display fan
3-5
display fib
05-IP Address and Performance Command
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib statistics
2-5
display ftp source-ip
1-14
display ftp-server
1-1
display ftp-server source-ip
1-2
display ftp-user
1-3
display garp statistics
07-GVRP Command
1-1
display garp timer
07-GVRP Command
1-2
display gvrp statistics
07-GVRP Command
1-7
display gvrp status
07-GVRP Command
1-8
display habp
3-1
display habp table
3-2
display habp traffic
3-2
display history-command
01-CLI Command
1-3
display hwping
35-HWPing Command
1-4
display hwtacacs
18-AAA Command
1-67
display icmp statistics
2-5
display igmp-snooping configuration
16-Multicast Command
2-1
display igmp-snooping group
2-2
display igmp-snooping statistics
2-4
display info-center
1-2
display interface
1-7
display interface Vlan-interface
04-VLAN Command
1-2
display ip host
37-DNS Command
1-4
display ip interface
1-1
display ip interface brief
1-3
display ip routing-table
1-1
display ip routing-table acl
1-3
display ip routing-table ip-address
1-6
display ip routing-table ip-address1 ip-address2
1-7
display ip routing-table protocol
1-8
display ip routing-table radix
1-9
display ip routing-table statistics
1-10
display ip routing-table verbose
1-11
display ip socket
2-7
display ip source static binding
22-DHCP Command
1-10
display ip statistics
2-9
display ipv6 fib
1-2
display ipv6 host
1-3
display ipv6 interface
1-4
display ipv6 neighbors
1-7
display ipv6 neighbors count
1-9
display ipv6 route-table
1-10
display ipv6 socket
1-12
display ipv6 statistics
1-13
display isolate port
10-Port Isolation Command
1-1
display lacp system-id
09-Link Aggregation Command
1-5
display link-aggregation interface
1-1
display link-aggregation summary
1-2
display link-aggregation verbose
1-4
display link-delay
1-12
display local-server statistics
18-AAA Command
1-36
display local-user
18-AAA Command
1-14
display logbuffer
1-3
display logbuffer summary
1-5
display loopback-detection
1-13
display mac-address
13-MAC Address Table Management Command
1-2
display mac-address aging-time
1-1
display mac-address multicast static
1-1
display mac-address security
1-1
display mac-authentication
20-MAC Address Authentication Command
1-1
display memory
3-5
display mirroring-group
25-Mirroring Command
1-1
display monitor-link group
38-Smart Link-Monitor Link Command
2-1
display multicast-source-deny
1-2
display ndp
2-1
display ntdp
2-6
display ntdp device-list
2-7
display ntdp single-device mac-address
2-49
display ntp-service sessions
28-NTP Command
1-1
display ntp-service status
28-NTP Command
1-3
display ntp-service trace
28-NTP Command
1-4
display packet-drop
1-13
display packet-filter
23-ACL Command
1-6
display patch-information
3-6
display port
04-VLAN Command
1-10
display port vlan-vpn
34-VLAN-VPN Command
1-1
display port-mac
1-4
display port-security
1-3
display power
3-7
display protocol-priority
1-2
display protocol-vlan interface
04-VLAN Command
1-17
display protocol-vlan vlan
04-VLAN Command
1-19
display public-key local
29-SSH Command
1-1
display public-key peer
29-SSH Command
1-3
display qos cos-local-precedence-map
1-3
display qos-interface all
1-4
display qos-interface line-rate
1-7
display qos-interface mirrored-to
1-8
display qos-interface traffic-limit
1-9
display qos-interface traffic-priority
1-9
display qos-interface traffic-redirect
1-10
display qos-interface traffic-remark-vlanid
1-11
display qos-interface traffic-statistic
1-12
display qos-profile
2-2
display queue-scheduler
1-12
display radius scheme
18-AAA Command
1-37
display radius statistics
18-AAA Command
1-39
display rmon alarm
27-SNMP-RMON Command
2-1
display rmon event
2-2
display rmon eventlog
2-3
display rmon history
2-4
display rmon prialarm
2-6
display rmon statistics
2-8
display rsa local-key-pair public
29-SSH Command
1-4
display rsa peer-public-key
29-SSH Command
1-5
display saved-configuration
1-8
display schedule reboot
3-7
display sftp source-ip
1-33
display smart-link flush
1-1
display smart-link group
1-2
display snmp-agent
1-1
display snmp-agent community
1-2
display snmp-agent group
1-3
display snmp-agent mib-view
1-5
display snmp-agent statistics
1-6
display snmp-agent sys-info
1-9
display snmp-agent trap-list
1-10
display snmp-agent usm-user
1-11
display ssh server
29-SSH Command
1-7
display ssh server-info
29-SSH Command
1-8
display ssh user-information
29-SSH Command
1-9
display ssh2 source-ip
29-SSH Command
1-10
display ssh-server source-ip
29-SSH Command
1-10
display stacking
1-1
display startup
1-12
display stop-accounting-buffer
18-AAA Command
1-41
18-AAA Command
1-68
display storm-constrain
1-14
display stp
14-MSTP Command
1-4
display stp abnormalport
14-MSTP Command
1-8
display stp portdown
14-MSTP Command
1-9
display stp region-configuration
14-MSTP Command
1-10
display stp root
14-MSTP Command
1-11
display system-guard ip state
4-1
display system-guard ip-record
4-2
display system-guard l3err state
4-3
display system-guard tcn state
4-3
display tcp ipv6 statistics
1-17
display tcp ipv6 status
1-19
display tcp statistics
2-11
display tcp status
2-14
display telnet source-ip
02-Login Command
1-7
display telnet-server source-ip
02-Login Command
1-6
display tftp source-ip
2-1
display this
1-13
display time-range
23-ACL Command
1-7
display transceiver alarm interface
3-8
display transceiver diagnosis interface
3-12
display transceiver interface
3-13
display transceiver manuinfo interface
3-14
display trapbuffer
1-6
display udp ipv6 statistics
1-20
display udp statistics
2-15
display unit
1-17
display user-interface
02-Login Command
1-7
display users
02-Login Command
1-10
display version
1-8
display vlan
04-VLAN Command
1-4
display vlan
06-Voice VLAN Command
1-3
display voice vlan error-info
1-1
display voice vlan oui
1-1
display voice vlan status
1-2
display web package
1-20
display web users
02-Login Command
1-11
display web-authentication configuration
19-Web Authentication Command
1-1
display web-authentication connection
1-2
dldp
12-DLDP Command
1-2
dldp authentication-mode
12-DLDP Command
1-3
dldp delaydown-timer
12-DLDP Command
1-8
dldp interval
12-DLDP Command
1-4
dldp reset
12-DLDP Command
1-5
dldp unidirectional-shutdown
12-DLDP Command
1-6
dldp work-mode
12-DLDP Command
1-7
dns domain
37-DNS Command
1-4
dns resolve
37-DNS Command
1-5
dns resolve-target
35-HWPing Command
1-13
dns server
37-DNS Command
1-6
dns server ipv6
1-21
dns-server
35-HWPing Command
1-12
domain
18-AAA Command
1-16
domain delimiter
18-AAA Command
1-17
dot1x
1-5
dot1x authentication-method
1-7
dot1x dhcp-launch
1-8
dot1x free-ip
2-1
dot1x guest-vlan
1-9
dot1x handshake
1-10
dot1x handshake secure
1-11
dot1x max-user
1-12
dot1x port-control
1-13
dot1x port-method
1-14
dot1x quiet-period
1-15
dot1x re-authenticate
1-18
dot1x retry
1-16
dot1x retry-version-max
1-17
dot1x supp-proxy-check
1-19
dot1x timer
1-21
dot1x timer acl-timeout
2-2
dot1x timer reauth-period
1-23
dot1x url
2-2
dot1x version-check
1-24
duplex
1-18
E
enable log updown
1-19
enable snmp trap updown
1-12
execute
1-6
exit
1-34
F
file prompt
1-7
filename
35-HWPing Command
1-13
fixdisk
1-8
flow interval
1-21
flow-control
1-20
flush enable control-vlan
1-3
format
1-9
free user-interface
02-Login Command
1-12
free web-users
02-Login Command
2-2
frequency
35-HWPing Command
1-14
ftp
1-15
ftp { cluster | remote-server } source-interface
1-16
ftp { cluster | remote-server } source-ip
1-16
ftp cluster
2-32
ftp disconnect
1-4
ftp server enable
1-5
ftp source-interface
1-17
ftp source-ip
1-18
ftp timeout
1-6
ftp-operation
35-HWPing Command
1-15
ftp-server
2-33
ftp-server source-interface
1-6
1-7
G
garp timer
07-GVRP Command
1-3
garp timer leaveall
07-GVRP Command
1-5
get
1-19
get
1-34
giant-frame statistics enable
1-22
gratuitous-arp-learning enable
21-ARP Command
1-13
gvrp
07-GVRP Command
1-8
gvrp registration
07-GVRP Command
1-9
H
habp enable
3-3
habp server vlan
3-4
habp timer
3-5
header
02-Login Command
1-13
help
1-35
history-command max-size
02-Login Command
1-15
history-records
35-HWPing Command
1-16
holdtime
2-34
http-operation
35-HWPing Command
1-17
http-string
35-HWPing Command
1-17
hwping
35-HWPing Command
1-18
hwping-agent enable
35-HWPing Command
1-19
hwping-server enable
35-HWPing Command
1-31
hwping-server tcpconnect
35-HWPing Command
1-32
hwping-server udpecho
35-HWPing Command
1-33
hwtacacs nas-ip
18-AAA Command
1-69
hwtacacs scheme
18-AAA Command
1-70
I
icmp redirect send
2-16
icmp unreach send
2-17
idle-cut
18-AAA Command
1-18
idle-timeout
02-Login Command
1-16
igmp host-join
2-18
igmp-snooping
2-5
igmp-snooping fast-leave
2-6
igmp-snooping general-query source-ip
2-7
igmp-snooping group-limit
2-8
igmp-snooping group-policy
2-10
igmp-snooping host-aging-time
2-12
igmp-snooping max-response-time
2-13
igmp-snooping nonflooding-enable
2-13
igmp-snooping querier
2-14
igmp-snooping query-interval
2-15
igmp-snooping router-aging-time
2-16
igmp-snooping version
2-17
igmp-snooping vlan-mapping
2-17
info-center channel name
1-7
info-center console channel
1-7
info-center enable
1-8
info-center logbuffer
1-9
info-center loghost
1-10
info-center loghost source
1-11
info-center monitor channel
1-12
info-center snmp channel
1-12
info-center source
1-13
info-center synchronous
1-16
info-center timestamp
1-17
info-center timestamp loghost
1-18
info-center timestamp utc
1-19
info-center trapbuffer
1-20
instance
14-MSTP Command
1-12
interface
1-23
04-VLAN Command
1-6
ip address
1-4
ip address bootp-alloc
22-DHCP Command
3-4
ip address dhcp-alloc
22-DHCP Command
3-2
ip check source ip-address
22-DHCP Command
1-11
ip host
37-DNS Command
1-7
ip http acl
02-Login Command
2-2
ip http shutdown
02-Login Command
1-16
ip route-static
2-2
22-DHCP Command
1-12
ip-pool
2-35
ipv6 address
1-22
ipv6 address auto link-local
1-23
ipv6 address eui-64
1-24
ipv6 address link-local
1-25
ipv6 host
1-26
ipv6 icmp-error
1-27
ipv6 nd dad attempts
1-28
ipv6 nd hop-limit
1-29
ipv6 nd ns retrans-timer
1-29
ipv6 nd nud reachable-time
1-30
ipv6 neighbor
1-31
ipv6 neighbors max-learning-num
1-32
ipv6 route-static
1-32
J
jitter-interval
35-HWPing Command
1-19
jitter-packetnum
35-HWPing Command
1-20
jumboframe enable
1-23
K
key
18-AAA Command
1-42
key
18-AAA Command
1-71
L
lacp enable
1-6
lacp port-priority
1-6
lacp system-priority
1-7
lcd
1-20
level
18-AAA Command
1-19
line-rate
1-13
link-aggregation group
1-4
2-2
link-aggregation group description
1-8
link-aggregation group mode
1-9
link-delay
1-24
local-server
18-AAA Command
1-43
local-server nas-ip
18-AAA Command
1-44
local-user
18-AAA Command
1-20
local-user password-display-mode
18-AAA Command
1-21
lock
02-Login Command
1-18
logging-host
2-36
loopback
1-25
loopback-detection control enable
1-26
loopback-detection enable
1-27
loopback-detection interval-time
1-28
loopback-detection per-vlan enable
1-28
ls
1-20
ls
1-36
M
mac-address
1-4
mac-address aging destination-hit enable
1-6
mac-address max-mac-count
1-7
mac-address multicast interface
1-3
mac-address multicast vlan
1-4
1-6
mac-address timer
1-8
mac-address-mapping
34-VLAN-VPN Command
2-1
mac-authentication
1-4
mac-authentication authmode usernameasmacaddress
1-6
mac-authentication authmode usernamefixed
1-7
mac-authentication authpassword
1-8
mac-authentication authusername
1-9
mac-authentication domain
1-9
mac-authentication guest-vlan
1-11
mac-authentication interface
1-5
mac-authentication max-auth-num
1-13
mac-authentication timer
1-10
mac-authentication timer guest-vlan-reauth
1-14
management-vlan
2-37
mdi
1-29
messenger
18-AAA Command
1-22
mirrored-to
1-14
mirroring-group
1-3
mirroring-group mirroring-port
1-4
mirroring-group monitor-port
1-5
mirroring-group reflector-port
1-6
mirroring-group remote-probe vlan
1-7
mirroring-port
1-8
mkdir
1-10
mkdir
1-21
mkdir
1-36
monitor-link group
2-3
monitor-port
1-9
more
1-11
move
1-12
multicast static-group interface
2-19
multicast static-group vlan
2-20
multicast static-router-port
2-21
multicast static-router-port vlan
2-22
1-4
multicast-suppression
1-30
N
name
04-VLAN Command
1-7
name
18-AAA Command
1-23
nas-ip
18-AAA Command
1-45
nas-ip
18-AAA Command
1-72
ndp enable
2-3
ndp timer aging
2-4
ndp timer hello
2-5
nslookup type
37-DNS Command
1-7
ntdp enable
2-9
ntdp explore
2-10
ntdp hop
2-11
ntdp timer
2-12
ntdp timer hop-delay
2-13
ntdp timer port-delay
2-13
ntp-service access
28-NTP Command
1-5
ntp-service authentication enable
28-NTP Command
1-7
ntp-service authentication-keyid
28-NTP Command
1-7
ntp-service broadcast-client
28-NTP Command
1-8
ntp-service broadcast-server
28-NTP Command
1-9
ntp-service in-interface disable
28-NTP Command
1-10
ntp-service max-dynamic-sessions
28-NTP Command
1-10
ntp-service multicast-client
28-NTP Command
1-11
ntp-service multicast-server
28-NTP Command
1-12
ntp-service reliable authentication-keyid
28-NTP Command
1-13
ntp-service source-interface
28-NTP Command
1-13
ntp-service unicast-peer
28-NTP Command
1-14
ntp-service unicast-server
28-NTP Command
1-15
O
open
1-22
P
packet-filter
23-ACL Command
1-8
packet-filter
2-4
packet-filter vlan
23-ACL Command
1-10
parity
02-Login Command
1-19
passive
1-23
password
18-AAA Command
1-23
password
35-HWPing Command
1-21
patch activate
3-15
patch delete
3-16
patch load
3-17
patch run
3-17
peer-public-key end
29-SSH Command
1-11
ping
2-1
ping ipv6
2-1
port
04-VLAN Command
1-11
port
1-5
port
2-4
port access vlan
04-VLAN Command
1-11
port hybrid protocol-vlan vlan
04-VLAN Command
1-20
port hybrid pvid vlan
04-VLAN Command
1-12
port hybrid vlan
04-VLAN Command
1-13
port isolate
1-1
port link-aggregation group
1-9
port link-type
04-VLAN Command
1-14
port monitor-link group
2-5
port smart-link group
1-6
port trunk permit vlan
04-VLAN Command
1-15
port trunk pvid vlan
04-VLAN Command
1-16
port-mac
1-9
port-security authorization ignore
1-11
port-security enable
1-7
port-security intrusion-mode
1-8
port-security max-mac-count
1-12
port-security ntk-mode
1-13
port-security oui
1-14
port-security port-mode
1-15
port-security timer disableport
1-20
port-security trap
1-21
primary accounting
18-AAA Command
1-46
primary accounting
18-AAA Command
1-72
primary authentication
18-AAA Command
1-47
18-AAA Command
1-73
primary authorization
18-AAA Command
1-74
priority
1-17
priority trust
1-17
probe-failtimes
35-HWPing Command
1-22
protocol inbound
02-Login Command
1-19
protocol inbound
29-SSH Command
1-12
protocol-priority protocol-type
1-18
protocol-vlan
04-VLAN Command
1-21
public-key local create
29-SSH Command
1-13
public-key local destroy
29-SSH Command
1-15
public-key local export dsa
29-SSH Command
1-18
public-key local export rsa
29-SSH Command
1-16
public-key peer
29-SSH Command
1-19
public-key peer import sshkey
29-SSH Command
1-20
public-key-code begin
29-SSH Command
1-21
public-key-code end
29-SSH Command
1-22
put
1-23
put
1-37
pwd
1-12
pwd
1-24
pwd
1-38
Q
1-21
qos-profile
2-5
qos-profile port-based
2-5
queue-scheduler
1-22
1-25
1-38
1-4
R
radius client
18-AAA Command
1-48
radius nas-ip
18-AAA Command
1-49
radius scheme
18-AAA Command
1-50
radius trap
18-AAA Command
1-51
radius-scheme
18-AAA Command
1-24
raw-vlan-id inbound
34-VLAN-VPN Command
2-2
reboot
3-18
reboot member
2-37
region-name
14-MSTP Command
1-13
remotehelp
1-25
remote-probe vlan enable
1-10
remove
1-39
rename
1-13
rename
1-26
rename
1-39
reset arp
21-ARP Command
1-14
reset counters interface
1-31
reset dns dynamic-host
37-DNS Command
1-8
reset dns ipv6 dynamic-host
1-33
reset dot1x statistics
1-25
reset garp statistics
07-GVRP Command
1-6
reset hwtacacs statistics
18-AAA Command
1-75
reset igmp-snooping statistics
2-23
reset ip routing-table statistics protocol
1-12
reset ip statistics
2-18
reset ipv6 neighbors
1-34
reset ipv6 statistics
1-35
reset lacp statistics
1-10
reset logbuffer
1-21
reset mac-authentication
1-11
reset ndp statistics
2-5
reset packet-drop interface
1-32
reset radius statistics
18-AAA Command
1-52
reset recycle-bin
1-14
reset saved-configuration
1-14
reset smart-link packets counter
1-7
reset stop-accounting-buffer
18-AAA Command
1-52
18-AAA Command
1-76
reset stp
14-MSTP Command
1-13
reset tcp ipv6 statistics
1-35
reset tcp statistics
2-18
reset traffic-statistic
1-25
reset trapbuffer
1-22
reset udp ipv6 statistics
1-36
reset udp statistics
2-19
retry
18-AAA Command
1-53
retry realtime-accounting
18-AAA Command
1-54
retry stop-accounting
18-AAA Command
1-56
18-AAA Command
1-76
return
1-4
revision-level
14-MSTP Command
1-14
rmdir
1-16
rmdir
1-26
rmdir
1-40
rmon alarm
2-10
rmon event
2-12
rmon history
2-13
rmon prialarm
2-14
rmon statistics
2-16
rsa local-key-pair create
29-SSH Command
1-23
rsa local-key-pair destroy
29-SSH Command
1-25
rsa peer-public-key
29-SSH Command
1-25
rsa peer-public-key import sshkey
29-SSH Command
1-26
rule (for Advanced ACLs)
23-ACL Command
1-13
rule (for Basic ACLs)
23-ACL Command
1-11
rule (for Layer 2 ACLs)
23-ACL Command
1-22
rule (for user-defined ACLs)
23-ACL Command
1-25
rule comment
23-ACL Command
1-29
S
save
1-15
schedule reboot at
3-19
schedule reboot delay
3-20
schedule reboot regularity
3-21
scheme
18-AAA Command
1-25
screen-length
02-Login Command
1-21
secondary accounting
18-AAA Command
1-57
18-AAA Command
1-77
secondary authentication
18-AAA Command
1-57
18-AAA Command
1-78
secondary authorization
18-AAA Command
1-79
security-policy-server
18-AAA Command
2-1
self-service-url
18-AAA Command
1-26
send
02-Login Command
1-21
send-trap
35-HWPing Command
1-23
server-type
18-AAA Command
1-58
service-type
02-Login Command
1-22
service-type
18-AAA Command
1-28
service-type multicast
2-23
set authentication password
02-Login Command
1-24
sftp
1-40
sftp server enable
1-29
sftp source-interface
1-42
sftp source-ip
1-43
sftp timeout
1-29
shell
02-Login Command
1-25
shutdown
04-VLAN Command
1-7
shutdown
1-32
smart-link flush enable
1-7
smart-link group
1-8
smart-link group
2-6
snmp-agent
1-13
snmp-agent calculate-password
1-14
02-Login Command
2-3
1-15
snmp-agent group
02-Login Command
2-4
snmp-agent group
1-16
snmp-agent local-engineid
1-18
snmp-agent log
1-19
snmp-agent mib-view
1-20
snmp-agent packet max-size
1-22
snmp-agent sys-info
1-23
snmp-agent target-host
1-24
snmp-agent trap enable
1-26
snmp-agent trap ifmib
1-27
snmp-agent trap life
1-28
snmp-agent trap queue-size
1-28
snmp-agent trap source
1-29
snmp-agent usm-user
02-Login Command
2-5
snmp-agent usm-user { v1 | v2c }
1-30
snmp-agent usm-user v3
1-32
snmp-host
2-38
source-interface
35-HWPing Command
1-23
source-ip
35-HWPing Command
1-25
source-port
35-HWPing Command
1-25
speed
02-Login Command
1-26
speed
1-33
speed auto
1-34
ssh authentication-type default
29-SSH Command
1-27
ssh client assign
29-SSH Command
1-29
ssh client first-time enable
29-SSH Command
1-30
ssh server authentication-retries
29-SSH Command
1-31
ssh server compatible-ssh1x enable
29-SSH Command
1-32
ssh server rekey-interval
29-SSH Command
1-33
ssh server timeout
29-SSH Command
1-33
ssh user
29-SSH Command
1-34
ssh user assign
29-SSH Command
1-35
ssh user authentication-type
29-SSH Command
1-37
ssh user service-type
29-SSH Command
1-38
ssh2
29-SSH Command
1-39
ssh2 source-interface
29-SSH Command
1-41
ssh2 source-ip
29-SSH Command
1-42
ssh-server source-interface
29-SSH Command
1-42
29-SSH Command
1-43
stacking
1-3
stacking enable
1-4
stacking ip-pool
1-5
stack-port enable
1-3
startup bootrom-access enable
1-20
startup saved-configuration
1-17
state
18-AAA Command
1-29
state
18-AAA Command
1-59
stop-accounting-buffer enable
18-AAA Command
1-60
stopbits
02-Login Command
1-26
storm-constrain
1-34
storm-constrain control
1-35
storm-constrain enable
1-36
storm-constrain interval
1-37
stp
14-MSTP Command
1-15
stp bpdu-protection
14-MSTP Command
1-16
stp bridge-diameter
14-MSTP Command
1-17
stp compliance
14-MSTP Command
1-18
stp config-digest-snooping
14-MSTP Command
1-19
stp cost
14-MSTP Command
1-21
stp dot1d-trap
14-MSTP Command
1-22
stp edged-port
14-MSTP Command
1-23
stp interface
14-MSTP Command
1-24
stp interface config-digest-snooping
14-MSTP Command
1-25
stp interface cost
14-MSTP Command
1-27
stp interface edged-port
14-MSTP Command
1-28
stp interface loop-protection
14-MSTP Command
1-29
stp interface mcheck
14-MSTP Command
1-30
stp interface no-agreement-check
14-MSTP Command
1-31
stp interface point-to-point
14-MSTP Command
1-32
stp interface port priority
14-MSTP Command
1-33
stp interface root-protection
14-MSTP Command
1-34
stp interface transmit-limit
14-MSTP Command
1-35
stp loop-protection
14-MSTP Command
1-36
stp max-hops
14-MSTP Command
1-37
stp mcheck
14-MSTP Command
1-38
stp mode
14-MSTP Command
1-39
stp no-agreement-check
14-MSTP Command
1-40
stp pathcost-standard
14-MSTP Command
1-41
stp point-to-point
14-MSTP Command
1-43
stp port priority
14-MSTP Command
1-44
stp portlog
14-MSTP Command
1-45
stp portlog all
14-MSTP Command
1-46
stp priority
14-MSTP Command
1-46
14-MSTP Command
1-47
stp root primary
14-MSTP Command
1-48
stp root secondary
14-MSTP Command
1-49
stp root-protection
14-MSTP Command
1-51
stp tc-protection
14-MSTP Command
1-52
stp tc-protection threshold
14-MSTP Command
1-53
stp timer forward-delay
14-MSTP Command
1-54
stp timer hello
14-MSTP Command
1-55
stp timer max-age
14-MSTP Command
1-56
stp timer-factor
14-MSTP Command
1-57
stp transmit-limit
14-MSTP Command
1-58
super
01-CLI Command
1-4
super authentication-mode
01-CLI Command
1-5
super password
01-CLI Command
1-6
sysname
1-5
system-guard ip detect-maxnum
4-4
system-guard ip detect-threshold
4-4
system-guard ip enable
4-6
system-guard l3err enable
4-7
system-guard tcn enable
4-8
system-guard tcn rate-threshold
4-8
system-monitor enable
3-22
1-6
T
tcp ipv6 timer fin-timeout
1-36
tcp ipv6 timer syn-timeout
1-37
tcp ipv6 window
1-37
tcp timer fin-timeout
2-19
tcp timer syn-timeout
2-20
tcp window
2-20
telnet
02-Login Command
1-27
telnet ipv6
02-Login Command
1-28
telnet ipv6
2-3
telnet source-interface
02-Login Command
1-29
telnet source-ip
02-Login Command
1-30
telnet-server source-interface
02-Login Command
1-30
02-Login Command
1-31
terminal debugging
1-22
terminal debugging
1-10
terminal logging
1-23
terminal monitor
1-23
terminal trapping
1-24
test-enable
35-HWPing Command
1-27
test-failtimes
35-HWPing Command
1-28
test-type
35-HWPing Command
1-26
tftp { ascii | binary }
2-2
tftp get
2-39
tftp get
2-2
tftp ipv6
2-4
tftp put
2-40
tftp put
2-4
tftp source-interface
2-6
tftp source-ip
2-7
tftp tftp-server source-interface
2-5
tftp tftp-server source-ip
2-5
tftp-server
2-41
tftp-server acl
2-8
timeout
35-HWPing Command
1-29
timer
18-AAA Command
1-61
timer
2-42
timer quiet
18-AAA Command
1-62
timer quiet
18-AAA Command
1-80
timer realtime-accounting
18-AAA Command
1-63
18-AAA Command
1-80
timer response-timeout
18-AAA Command
1-64
18-AAA Command
1-81
time-range
23-ACL Command
1-30
topology accept
2-51
topology restore-from
2-52
topology save-to
2-53
tos
35-HWPing Command
1-29
tracemac
2-43
tracert
2-3
tracert ipv6
2-5
traffic-limit
1-27
traffic-limit
2-6
traffic-priority
1-29
traffic-priority
2-8
traffic-priority vlan
1-32
traffic-redirect
1-33
1-35
traffic-statistic
1-36
U
undelete
1-16
unicast-suppression
1-38
unknown-multicast drop enable
1-6
user
1-27
user privilege level
02-Login Command
1-33
user-interface
02-Login Command
1-32
username
35-HWPing Command
1-30
user-name-format
18-AAA Command
1-65
user-name-format
18-AAA Command
1-82
V
verbose
1-28
virtual-cable-test
1-39
vlan
04-VLAN Command
1-8
vlan-assignment-mode
18-AAA Command
1-30
vlan-mapping modulo
14-MSTP Command
1-58
vlan-vpn enable
34-VLAN-VPN Command
1-2
vlan-vpn inner-cos-trust
34-VLAN-VPN Command
1-3
vlan-vpn priority
34-VLAN-VPN Command
1-3
vlan-vpn tpid
34-VLAN-VPN Command
1-5
vlan-vpn tunnel
14-MSTP Command
1-60
vlan-vpn vid
34-VLAN-VPN Command
2-3
voice vlan
1-4
voice vlan aging
1-5
voice vlan enable
1-7
voice vlan legacy
1-7
voice vlan mac-address
1-8
voice vlan mode
1-9
voice vlan security enable
1-10
W
web-authentication cut connection
1-3
web-authentication enable
1-4
web-authentication free-ip
1-4
web-authentication free-user
1-5
web-authentication max-connection
1-6
web-authentication select method
1-7
web-authentication timer idle-cut
1-8
web-authentication web-server
1-9
wred
1-37
X
xmodem get
3-23
Y
Z
